2RK3600L-5
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
Stable breakdown voltage.
High insulation resistance.
Low capacitance (≤1.0pF)
High holdover voltage
Large absorbing transient current capability.
Micro-Gap Design
Storage and operational temperature: -40℃ ~ +125℃
Meets MSL level 1, per J-STD-020
Safety certification: E327997
Applications
Standard power supplies requisite by US UL1449.
Highly reliable power supplies.
Three or two phases industrial or civic machinery equipment power.
Power supplies for IC or electronic circuits.
Part Number Code
2
K
R
3
6
Electrical
Characteristics
K: 3KA
L
5
Lead Type
L: Lead
SHRB: Internal Control Code
Electrode Numbers
2R: 2 Electrodes
DC
Spark-over
Voltage
Dimensions
5: 5.5mm×6.0mm
Marking
: BrightKing Logo
2RK3600-5 : Device Marking Code
XXXX
Revision: GDT-2RK3600L-5-SHRB-001(A1)
2/5
http://brightking.pulseelectronics.com
2RK3600L-5
Dimensions
T
Spec.
Tolerance
D
5.5
+0.3, -0.5
T
6.0
+0.3, -0.5
T1
10.2
±0.5
S
7.5
±0.5
R
63°
±5°
d
0.6
±0.05
L
3.5
±0.5
L1
2.5
±0.3
L
R
d
Dimension (mm)
D
Symbol
L1
T1
S
Electrical Characteristics
Part
Number
2RK3600L-5
AC
Withstanding
Voltage
Type
①
SHRB
DC
Spark-over
Voltage
100V/μs
1000V/μs
8/20μs
300 times
8/20μs
3 times
8/20μs
1 time
(V)
(V)
(V)
(A)
(KA)
(KA)
3600±20%
4350
4500
100
3
5
100
Maximum
Capacitance
Arc
Voltage
@1A
Glow to
Arc
Transition
Current
Glow
Voltage
(pF)
(V)
(A)
(V)
1.0
~45
~0.3
~240
1MHz
(GΩ)
DC(V)
1800VAC, 3s
Impulse
Life
100V/s
Minimum
Insulation
Resistance
Test
Voltage
Maximum Impulse
Spark-over Voltage
1.0
Device
Marking
Code
2RK3600-5
Notes: ①Specific code by request.
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with
voltage ramp dv/dt=1000V/μs.
3/5
To meet
the specified
value
2RK3600L-5
Maximum 8/20μs surge current that can be applied between
two electrodes, 5 positive and 5 negative surges, with 3 minutes
interval time, without causing the DC spark-over voltage to
change more than 25% from its initial value.
Crest value
100
90
Current (%)
Impulse
Discharge Current
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with
interval time 3 min. DC spark-over voltage shall not change
more than ±25% from its initial value.
The resistance of gas tube shall be measured between two
electrodes.
The capacitance of gas tube shall be measured between two
electrodes. Test frequency: 1MHz
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
Time (minutes)
3
3.5
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
4/5
4
2RK3600L-5
Packaging
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
217.0
±2.0
B
207.0
±2.0
H
10.3
±0.5
Quantity: 100pcs
Inner box
A0
225.0
±2.0
B0
210.0
±2.0
H0
60.0
±2.0
Quantity: 500pcs
5/5
很抱歉,暂时无法提供与“2RK3600L-5-SHRB”相匹配的价格&库存,您可以联系我们找货
