2RK3600L(M)-5
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤1.5pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 5.5mm*6.0mm
■ Storage and operational temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL: E327997
Applications
Standard power supplies requisite by US UL1449.
Highly reliable power supplies.
Three or two phases industrial or civic machinery equipment power.
Power supplies for IC or electronic circuits.
Part Number Code
Marking
: BrightKing Logo
2RK3600-5 : Device Marking Code
YXXX
: Date Code
Revision:0 7 - S e p - 1 7
www.brightking.com
2RK3600L(M)-5
Dimensions
L Type
Dimension (mm)
Symbol
M Type
Spec.
Tolerance
D
5.5
+0.3, -0.5
T
6.0
+0.3, -0.5
d
0.8
±0.1
L
30.0
Max.
D
5.5
+0.3, -0.5
T
6.0
+0.3, -0.5
B
0.5
±0.1
6.0
5.5
B
D
T
1.5
Recommended Pad Size
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
1time
8/20μs
100A
Test
Voltage
Minimum
Insulation
Resistance
Maximum
Capacitance
1MHz
AC
Withstanding
Voltage
Device
Marking
Code
(GΩ)
(V)
(V)
(KA)
(times)
DC(V)
(pF)
2RK3600L-5
3600±20%
5000
3.0
300
1000
1.0
1.5
AC1800, 1s
2RK3600-5
2RK3600M-5
3600±20%
5000
3.0
300
1000
1.0
1.5
AC1800, 1s
2RK3600-5
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time, without causing the DC spark-over voltage to change more than
25% from its initial value.
Impulse
Discharge
Current
To meet
the specified
value
www.brightking.com
2RK3600L(M)-5
Insulation
Resistance
Capacitance
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
Recommended Soldering Conditions
Wave Soldering
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Reflow Soldering
Profile Feature
Average ramp-up rate (TL to TP)
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Pb-Free Assembly
3℃/second max.
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
260℃
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
2RK3600L(M)-5
Packaging
Axial Packing (Bulk)
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
264.0
±1.0
B
145.0
±1.0
H
6.5
±0.5
Quantity: 100pcs
Inner box
A0
270.0
±2.0
B0
150.0
±1.0
H0
50.0
±1.0
Quantity: 500pcs
Packaging
SMD Packing (Tape & Reel)
Tape
Symbol
Dimension (mm)
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
5.85
±0.10
K0
6.20
±0.10
B0
7.00
±0.10
t0
0.50
±0.10
www.brightking.com
2RK3600L(M)-5
Reel
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
Quantity: 800pcs
www.brightking.com
很抱歉,暂时无法提供与“2RK3600L-5/B”相匹配的价格&库存,您可以联系我们找货
