2R-5-ST5 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
■ Stable breakdown voltage
■ High insulation resistance
■ Low capacitance (≤1.0pF)
High holdover voltage
Large absorbing transient current capability
Micro-Gap Design
Storage and operational temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E244458
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
2
L
R
M
Electrical
Characteristics
L: 5KA
Electrode Numbers
2R: 2 Electrodes
5
Lead Type
M: SMD
ST5: Internal Control Code
DC
Spark-over
Voltage
Dimensions
5: 5.0mm×5.0mm
Marking
: BritghtKing Logo
2RL090-5 : Device Marking Code
XXXX
Revision: GDT-2R-5-ST5 SERIES-001(A0)
2 / 5
http://brightking.pulseelectronics.com
2R-5-ST5 SERIES
Dimensions
1.1
D
5.6
T
Dimension (mm)
Symbol
5.0
D
D
B
Recommended Pad Size
Spec.
Tolerance
D
5.0
±0.2
T
5.0
±0.3
B
0.5
±0.1
Electrical Characteristics
Part
Number
Type
①
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
Minimum
Insulation
Resistance
Maximum
Capacitance
(GΩ)
1MHz
Device
Marking
Code
(pF)
2RL090M-5
ST5
90±20%
650
5.0
5.0
300
50
1.0
1.0
2RL090-5
2RL150M-5
ST5
150±20%
700
5.0
5.0
300
100
1.0
1.0
2RL150-5
2RL230M-5
ST5
230±20%
700
5.0
5.0
300
100
1.0
1.0
2RL230-5
2RL250M-5
ST5
250±20%
700
5.0
5.0
300
100
1.0
1.0
2RL250-5
2RL300M-5
ST5
300±20%
900
5.0
5.0
300
100
1.0
1.0
2RL300-5
2RL350M-5
ST5
350±20%
900
5.0
5.0
300
100
1.0
1.0
2RL350-5
2RL400M-5
ST5
400±20%
1000
5.0
5.0
300
100
1.0
1.0
2RL400-5
2RL470M-5
ST5
470±20%
1100
5.0
5.0
300
250
1.0
1.0
2RL470-5
Notes:①Specific code by request.
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time.
Crest value
Impulse
Discharge Current
Current (%)
100
90
To meet
the specified
value
50
20µs
10
8µs
Time
Impulse Width
3 / 5
2R-5-ST5 SERIES
Alternating
Discharge Current
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with
interval time 3 min. IR>108 ohms
Insulation
Resistance
The resistance of gas tube shall be measured between two electrodes.
Capacitance
The capacitance of gas tube shall be measured between two
electrodes. Test frequency: 1MHz
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
3℃/second max.
Average ramp-up rate (TL to TP)
Preheat
-Temperature Min (TS min)
150℃
-Temperature Max (TS max)
200℃
-Time (min to max) (ts)
60-180 seconds
TS max to TL
3℃/second max.
-Ramp-up Rate
Time maintained above:
217℃
-Temperature (TL)
-Time (tL)
60-150 seconds
260℃
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
6℃/second max.
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
4 / 5
2R-5-ST5 SERIES
Packaging
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
W
12.00
±0.20
P0
4.00
±0.10
P
8.00
±0.10
P1
2.00
±0.10
D
1.55
±0.10
E
1.75
±0.10
F
5.50
±0.10
A0
5.40
±0.10
K0
5.40
±0.10
B0
5.40
±0.10
t
0.40
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
t
D
d
L
Quantity: 800pcs
5 / 5
很抱歉,暂时无法提供与“2RL230M-5-SS”相匹配的价格&库存,您可以联系我们找货
