2R-6 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
Stable breakdown voltage
High insulation resistance
Low capacitance (≤1pF)
High holdover voltage
Large absorbing transient current capability
Micro-Gap Design
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E244458 & E327997
Applications
Repeaters, Modems
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Part Number Code
2
M
R
Electrical
Characteristics
K: 3KA
L: 5KA
Electrode Numbers
2R: 2 Electrodes
6
Lead Type
M: SMD
DC
Spark-over
Voltage
Dimensions
6: 6.2mm×4.2mm
Marking
: BrightKing Logo
2RL090-6 : Device Marking Code
YXXX
: Date Code
Revision: GDT-2R-6 SERIES-001(A2)
2/5
http://brightking.pulseelectronics.com
2R-6 SERIES
Dimensions
3.5
D
D
d
1.3
T
Dimension (mm)
Symbol
7.0
B
Recommended Pad Size
Spec.
Tolerance
D
6.2
±0.2
T
4.2
±0.2
B
0.6
±0.1
d
6.0
±0.2
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
2RL075M-6
75±20%
700
5
5
500
25
1
1.0
2RL075-6
2RL090M-6
90±20%
700
5
5
500
50
1
1.0
2RL090-6
2RL145M-6
145±20%
700
5
5
500
100
1
1.0
2RL145-6
2RL150M-6
150±20%
700
5
5
500
100
1
1.0
2RL150-6
2RL230M-6
230±20%
650
5
5
500
100
1
1.0
2RL230-6
2RL250M-6
250±20%
650
5
5
500
100
1
1.0
2RL250-6
2RL300M-6
300±20%
700
5
5
500
100
1
1.0
2RL300-6
2RL350M-6
350±20%
750
5
5
500
100
1
1.0
2RL350-6
2RL400M-6
400±20%
800
5
5
500
100
1
1.0
2RL400-6
2RL470M-6
470±20%
900
5
5
500
250
1
1.0
2RL470-6
2RL600M-6
600±20%
1000
5
5
500
250
1
1.0
2RL600-6
2RL800M-6
800±20%
1200
5
5
500
250
1
1.0
2RL800-6
2RK1000M-6
1000±20%
1600
3
3
300
500
1
1.0
2RK1000-6
2RK1200M-6
1200±20%
1800
3
3
300
500
1
1.0
2RK1200-6
2RK1800M-6
1800±20%
2600
3
3
300
500
1
1.0
2RK1800-6
Part
Number
Minimum
Insulation
Resistance
Maximum
Capacitance
(GΩ)
1MHz
Device
Marking
Code
(pF)
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
3/5
To meet
the specified
value
2R-6 SERIES
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time, without causing the DC spark-over voltage to change more than
25% from its initial value.
Crest value
100
90
Current (%)
Impulse
Discharge Current
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with
interval time 3 min. DC spark-over voltage shall not change more than
±25% from its initial value.IR>108 ohms (-20%, +30% for 70~90V).
Insulation
Resistance
The resistance of gas tube shall be measured between two electrodes.
Capacitance
The capacitance of gas tube shall be measured between two
electrodes. Test frequency: 1MHz
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
4/5
2R-6 SERIES
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
20-40 seconds
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Packaging
Tape
Symbol
Reel
t
D
d
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
4.44
±0.10
K0
6.37
±0.10
B0
6.48
±0.10
t0
0.50
±0.10
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
Quantity: 800pcs
L
Dimension (mm)
5/5
很抱歉,暂时无法提供与“2RL400M-6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.41380
- 200+0.93420
- 500+0.90137
- 800+0.88506
