ATH Series
Automotive Electrical
Overvoltage Transient Suppressors Leaded - > ATH series
Description
Overvoltage transient suppressors are designed for applications requiring a low voltage rectifier with reverse avalanche
characteristics for use as reverse power transient suppressors.
Developed to suppress transients in the automotive system,
these devices operate in reverse mode as power avalanche
rectifier and will protect electronic equipment from overvoltage
conditions
Features
• Halogen-Free
• RoHS complaint
• Glass passivated junction
for reliability
• Patented construction
• Suitable for standard ISO
7637-2 or ISO16750-2;
• Fast response time
• Excellent clamping
capability
• Low incremental surge
resistance
• Plastic package has
Underwriters Laboratory
Flammability classification
94V-O
• Matte Tin Lead-free plated
Maximum Ratings and Thermal Characteristics
(TA=25℃ unless otherwise noted)
Parameter
Symbol
10ms×400ms 12V system 87V 0.5Ω
4277
E typ.
10ms×350ms 24V system 174V 1Ω
10ms×350ms 24V system 174V 2Ω
7493
waveform
Designed to protect sensitive electronics from:
- Inductive Load Switching
- Alternator Load Dump
-GPS navigation systems
ATH series10x1000μs
150
This test is a simulation of load dump transient, occurring in the
KW
waveform
15
Operating Junction and Storage
Temperature Range
TJ, TSTG
-50 to
150
Typical Thermal Resistance Junction
to lead
RuJL
8.0
/W
to Ambient
RuJA
40
/W
Note: 10*1000μs peak pulse current
Test background
J
14987
PPPM
Applications
Unit
8553
10ms×400ms 12V system 87V 1Ω
ATH series 8×20μs
Value
Characteristics
refer to electrical
table.
Test parameters
event of a discharged battery being disconnected while the
alternator is generating charging current and with other loads
Parameter
12V system
24V system
remaining on the alternator circuit at this moment; the load
Us
65V to 87V
123V to 174V
Ri
0.5Ω to 4Ω
1Ω to 8Ω
is disconnected. In most new alternators, the load dump
td
40ms to 400ms
100ms to 350ms
amplitude is suppressed (clamped) by the addition of the
tr
(10 0−5 ) ms
Note
Pulse waveform see figure 1, figure 2.
dump amplitude depends on the alternator speed and on the
level of the alternator field excitation at the moment the battery
limiting diodes.
Revision:20-Mar-14
www.brightking.com
ATH Series
ISO 7637-2 2004 5a Waveform Simulation Test
Overvoltage transient suppressors (ATH20C/ATH24C)
Clamped pulse waveform
12V system 87V 0.5Ω 400mS
original pulse waveform
24V system 174V 2Ω 350mS
ATH20C
ATH24C
A
A
Overvoltage transient suppressors (ATH30C/ATH36C)
ATH30C
ATH36C
A
A
Electrical Characteristics (TA=25℃ unless otherwise noted)
VBR MIN.(V)
VBR MAX.(V)
IT (mA)
Reverse
Stand-Off
Voltage
VRWM(V)
ATH16C
17.0
20.0
5.0
16.0
10.0
28.0
540
ATH20C
21.0
25.0
5.0
20.0
10.0
34.0
450
ATH24C
25.0
30.0
5.0
24.0
10.0
40.0
400
ATH30C
33.0
38.0
5.0
30.0
10.0
51.0
350
ATH36C
38.0
45.0
5.0
36.0
10.0
59.0
300
Part
Number
(Bi)
Part
Number
(Bi)
ATH16C
ATH20C
ATH24C
ATH30C
ATH36C
Note:
Breakdown Voltage
@IT
Test
Current
Reverse
Leakage@
VRWM
IR (μA)
Maximum
Clamping
Voltage @IPP
Vc(V)
Peak
Pulse
Curren
Ipp(A)
Suitable ISO 7637-2 2004 5a test waveform
Maximum
Clamping Voltage
Vc(V)
87V 400mS
174V 350mS
0.5Ω
1Ω
2Ω
4Ω
8Ω
28.0
33.0
39.0
50.0
57.0
Voltage level
Resistance Level
‘x’ representatives meets this test condition;
Revision:20-Mar-14
www.brightking.com
ATH Series
Ratings and Characteristic Curves (TA=25℃ unless
otherwise noted)
Figure 1. (Pulse 5a)without centralized load
dump suppression
Figure 2. (Pulse 5b)with centralized load
dump suppression
U
td
tr
td
tr
A unsuppressed
0.9Us
B suppressed
UA
0.1Us
0.1Us
UA
U s﹡
Us
0.9Us
Us
U
t
Figure 4. Peak Pulse Power Rating Curve
100
10000
PPPM - Peak Pulse Power (kW)
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 3. Pulse Derating Curve
t
80
60
40
150KW, 8/20µs Waveform
100
10
50
75 100 125 150 175
TA-Ambient Temperature (℃)
200
Figure 5. I-V Curve Characteristics
0.1
1
10
100
1000
10000
td-Pulse Width (µs)
Figure 6. Pulse Waveform
IPP
VC VBR VR
IT
IR
IR
IT
V
VR VBR VC
% of Peak Power Current
120
Revision:20-Mar-14
Waveform
Parameters:
tr=8µs
td=20µs
Peak value Ipp
80
60
40
td=t|PP/2
IPP
tr
100
10
15
t-Time (μs)
25
30
www.brightking.com
ATH Series
Soldering Parameters
Reflow Condition
Pre
Heat
Lead-free assembly
- Temperature Min(Ts(min))
150℃
- Temperature Max(Ts(max))
200℃
tP
TP
TL
tL
60~180 seconds
Ts(max)
Average ramp up rate (Liquidus Temp
(TL) to peak
3℃/second max
Ts(min)
Ts(max) to TL - Ramp-up Rate
3℃/second max
- Time (min to max) (ts)
Ramp-down
tS
Preheat
25℃
Reflow
- Temperature (TL) (Liquidus)
217℃
60~150 seconds
+0/-5
Critical Zone
TL to TP
Ramp-up
t 25℃ to Peak
Time (t)
Peak Temperature (TP)
260
Time within 5℃ of actual peak
Temperature (tP)
20~40 seconds
Flow/Wave Soldering (Solder Dipping)
Ramp-down Rate
6℃/second max
Peak Temperature:
265℃
Time 25℃ to peak Temperature (TP)
8 minutes Max.
Dipping Time:
10 seconds
Do not exceed
280℃
Soldering:
1 time
Dimensions
ATH Series
T
D
Items
H
L
Max.
Min.
Max.
D
13.00
0.512
H
15.5.00
0.610
L
K
F
Revision:20-Mar-14
Inches
Min.
T
K≤3.5
d
Millimeters
6.00
10.0
0.23
0.393
3.00
0.118
F
7.5±0.8
0.3±0.33
d
0.8±0.1
0.0314±0.004
www.brightking.com
ATH Series
Part Numbering Systern
ATH XX C
TYPE CODE:
A Uni-Directional
C Bi-Directional
VOLTAGE CODE
(Refer to the Electrical Characteristics table)
SERIES CODE
Part Marking Systern
YXXX
ATH24C
Logo
Date Code
Marking Code
Packaging
ATH series
200pcs/box
5M
ax
Bulk
18
65 Max.
245 Max.
Note: We will always keep the technical specification updates, to customers provide with better products
Revision:20-Mar-14
www.brightking.com
很抱歉,暂时无法提供与“ATH36C”相匹配的价格&库存,您可以联系我们找货
