B32 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
High insulation resistance
Low capacitance (≤0.5pF)
500A 8/20μs maximum surge current capacity in accordance with IEC61000-4-5
4KV 10/700μs maximum surge rating in accordance with ITU-TK.21
Surface mounted gas arrester
Micro-Gap Design
Size 3216(1206)
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E244458
Applications
■ Repeaters, Modems
■ Telephone Interface, Line cards
■ Data communication equipment
■ Line test equipment
Part Number Code
B32
XXX
LF
Lead Free
DC Spark-over Voltage
Size
3.2±0.3mm
1.8mm
1.6±0.3mm
1.6±0.3mm
Dimensions
2.0mm
1.6±0.3mm
4.4mm
Recommended Pad Size
Revision: GDT-B32 SERIES-001(A2)
2/5
http://brightking.pulseelectronics.com
B32 SERIES
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Maximum
Capacitance
Nominal
Impulse
Discharge
Current
100V/s
1000V/μs
Test
Voltage
(1MHz)
8/20μs
(V)
(V)
DC(V)
(pF)
(A)
B32-150-LF
150±30%
750
50
1000
0.5
500
B32-230-LF
230±30%
950
100
1000
0.5
500
B32-300-LF
300±30%
950
100
1000
0.5
500
10/700μs
B32-350-LF
350±30%
950
100
1000
0.5
500
4kV
B32-400-LF
400±30%
1050
100
1000
0.5
500
±5 Times
B32-420-LF
420±30%
1050
100
1000
0.5
500
B32-470-LF
470±30%
1050
100
1000
0.5
500
Part
Number
Minimum
Insulation
Resistance
(MΩ)
Impulse
Withstanding
Voltage
Capacity
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Insulation
Resistance
Capacitance
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two
electrodes. Test frequency: 1MHz
To meet
the specified
value
Impulse
Discharge
Current
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time, without causing the DC spark-over voltage to change more than
30% from its initial value.
Impulse
Withstanding
Voltage
The maximum 10/700μs surge that can be applied to the Gas Tube, 5
positive and 5 negative surges, with 1 minute interval time, without
causing the DC spark-over voltage to change more than 25% from its
initial value.
3/5
B32 SERIES
Reliability
Items
Test conditions / Methods
Cold Resistance
Measurement after -40℃/1000 HRS & normal
temperature/2 HRS.
Heat Resistance
Measurement after 125℃/1000 HRS & normal
temperature/2 HRS.
Humidity
Measurement after humidity 90~95℃(45℃)
/1000 HRS & normal temperature/2 HRS.
Resistance
Standard
Features are conformed to rated
spec.
Temperature Cycle
10 times repetition of cycle -40℃/30min
→normal, temp/2 min →125℃/30min,
measurement after normal temp/2 HRS.
Solder Ability
Check for solder adhesion after 260±5℃ for
3sec , The body immersion depth 1.5mm in
molten solder
Evenly covered by solder.
Solder Heat
Measurement after 260±5℃ solder for 10sec,
The body immersion depth 1.5mm in molten
solder
Conformed to rated spec.
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
4/5
B32 SERIES
Recommended Conditions
Profile Feature
Pb-Free Assembly
3℃/second max.
Average ramp-up rate (TL to TP)
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
260℃
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
6℃/second max.
Ramp-down Rate
Time 25℃ to Peak Temperature
8 minutes max.
Packaging
Tape
W
P0
P1
P2
D0
D1
E
F
A0
K0
B0
t0
Dimension (mm)
Spec. Tolerance
8.00
±0.20
4.00
±0.10
4.00
±0.10
2.00
±0.10
1.55
±0.05
1.00
±0.05
1.75
±0.10
3.50
±0.10
2.00
±0.10
2.00
±0.10
3.80
±0.10
0.30
±0.10
D
170.00
±2.00
d
13.00
±0.50
L
12.00
±2.00
t
1.20
±0.20
Items
Reel
t
D
d
L
Quantity: 2500pcs
5/5
很抱歉,暂时无法提供与“B32-350-LF”相匹配的价格&库存,您可以联系我们找货
