DATA SHEET
GAS DISCHARGE TUBES
TELEPHONE INTERFACE
3R-5-S series
Product specification– November 05, 2018 V.0
RoHS compliant & Halogen free
Circuit Protection
Product Specification
GAS DISCHARGE TUBS
2
6
3R-5-S
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤2pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 5.0mm*7.2mm
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: E244458
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
3
L
R
M
Electrical
Characteristics
L: 5KA
Electrode Numbers
3R: 3 Electrodes
DC
Spark-over
Voltage
Lead Type
M: SMD
Dimensions
5-S: 5.0mm×7.2mm
Marking
: BrightKing Logo
3SL090M : Device Marking Code
YXXX
: Date Code
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
3
6
3R-5-S
Dimensions
Dimension (mm)
6.6
D
D
B1
d
B
Spec.
Tolerance
D
5.0
±0.1
T
7.2
±0.3
B
0.4
±0.1
B1
1.5
±0.2
d
4.8
±0.1
Minimum
Insulation
Resistance
Maximum
Capacitance
3.3
5.6
T
Symbol
2.0
1.5
Recommended Pad Size
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
1MHz
Device
Marking
Code
(GΩ)
(V)
(V)
(KA)
(A)
(times)
DC(V)
(pF)
3RL075M-5-S
75±20%
700
5
5
300
25
1.0
2.0
3SL075M
3RL090M-5-S
90±20%
600
5
5
300
50
1.0
2.0
3SL090M
3RL120M-5-S
120±20%
600
5
5
300
50
1.0
2.0
3SL120M
3RL150M-5-S
150±20%
600
5
5
300
100
1.0
2.0
3SL150M
3RL200M-5-S
200±20%
600
5
5
300
100
1.0
2.0
3SL200M
3RL230M-5-S
230±20%
650
5
5
300
100
1.0
2.0
3SL230M
3RL250M-5-S
250±20%
650
5
5
300
100
1.0
2.0
3SL250M
3RL300M-5-S
300±20%
800
5
5
300
100
1.0
2.0
3SL300M
3RL350M-5-S
350±20%
800
5
5
300
100
1.0
2.0
3SL350M
3RL400M-5-S
400±20%
900
5
5
300
100
1.0
2.0
3SL400M
3RL420M-5-S
420±20%
900
5
5
300
250
1.0
2.0
3SL420M
3RL470M-5-S
470±20%
900
5
5
300
250
1.0
2.0
3SL470M
3RL600M-5-S
600±20%
1000
5
5
300
250
1.0
2.0
3SL600M
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
4
6
3R-5-S
Electrical Ratings
Items
Test Condition/Description
DC Spark-over
Voltage
The voltage is measured with voltage ramp dv/dt=100V/s. Test is
between each side electrode and center electrode.
Maximum Impulse
Spark-over Voltage
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs. Test is between each side electrode and
center electrode.
Requirement
Maximum surge current that can be applied through center electrode
with 8/20μs waveform, for 10 times with 3min interval time, which will
be equally divided between each side electrode to center electrode.
Crest value
Impulse
Discharge Current
Current (%)
100
90
50
20µs
10
To meet
the specified
value
8µs
Time
Impulse Width
Alternating
Discharge Current
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with
interval time 3 min. Test is between each side electrode and center
electrode.
Insulation
Resistance
The resistance of gas tube shall be measured between each side
electrodes and center electrode.
Capacitance
The capacitance of gas tube shall be measured between each side
Test frequency: 1MHz
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
5
6
3R-5-S
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
www.yageo.com
Nov. 05, 2018 V.0
Circuit Protection
GAS DISCHARGE TUBS
6
6
3R-5-S
Packaging
Tape
Dimension (mm)
Symbol
Reel
t
D
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
7.40
±0.10
K0
5.50
±0.10
B0
5.40
±0.10
t0
0.50
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
d
L
Quantity: 900pcs
www.yageo.com
Nov. 05, 2018 V.0
很抱歉,暂时无法提供与“3RL600M-5-S”相匹配的价格&库存,您可以联系我们找货
