3R-8 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
■ Stable breakdown voltage
■ High insulation resistance
■ Low capacitance (≤2pF)
■ High holdover voltage
■ Large absorbing transient current capability
■ Micro-Gap Design
■ Size: 8.0mm*10.0mm
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: E244458
Applications
Repeaters, Modems
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Part Number Code
3
8
R
Electrical
Characteristics
M: 10KA
P: 20KA
Lead Type
L: Lead
M: SMD
DC
Spark-over
Voltage
Electrode Numbers
3R: 3 Electrodes
Packing Code
No suffix: Bulk
TR: Tape & Reel packing
Failsafe Option
Blank: Standard product
F: With failsafe mechanism
Dimensions
8: 8.0mm×10.0mm
Marking
: BrightKing Logo
3RM090-8 : Device Marking Code
YXXX
: Date Code
Revision: GDT-3R-8 SERIES-001(A2)
2/7
http://brightking.pulseelectronics.com
3R-8 SERIES
Dimensions
L Type
Dimension (mm)
Symbol
T1
T
Spec.
Tolerance
D
8.0
+0.2, -0.8
T
10.0
±0.5
T1
12.0
±0.5
L
15.0
±0.5
S
4.4
±0.4
d
1.0
±0.1
R1
9.8
±0.4
R2
8.1
±0.3
D
8.0
+0.2, -0.8
T
10.0
±0.5
B
0.5
±0.1
B1
1.5
±0.2
L
D
1.2
4.4
S
4.4
Recommended Pad Size
d
L-F Type
T1
T
R1
R2
1.2
4.4
S
4.4
d
M Type
T
D
B1
B
Notes: This type is not suitable for PCB soldering.
3/7
3R-8 SERIES
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
Part
Number
Minimum
Insulation
Resistance
(V)
(V)
(KA)
(A)
(times)
DC(V)
Maximum
Capacitance
1MHz
Device
Marking
Code
(GΩ)
(pF)
3RM075L-8
3RM075M-8
75±20%
700
10
10
300
25
1.0
2.0
3RM075-8
3RM090L-8
3RM090M-8
90±20%
700
10
10
300
50
1.0
2.0
3RM090-8
3RM150L-8
3RM150M-8
150±20%
700
10
10
300
100
1.0
2.0
3RM150-8
3RM200L-8
3RM200M-8
200±20%
700
10
10
300
100
1.0
2.0
3RM200-8
3RM230L-8
3RM230M-8
230±20%
700
10
10
300
100
1.0
2.0
3RM230-8
3RM350L-8
3RM350M-8
350±20%
850
10
10
300
100
1.0
2.0
3RM350-8
3RM400L-8
3RM400M-8
400±20%
850
10
10
300
100
1.0
2.0
3RM400-8
3RM470L-8
3RM470M-8
470±20%
950
10
10
300
250
1.0
2.0
3RM470-8
3RM600L-8
3RM600M-8
600±20%
1300
10
10
300
250
1.0
2.0
3RM600-8
3RM800L-8
3RM800M-8
800±20%
1500
10
10
300
250
1.0
2.0
3RM800-8
3RP075L-8
3RP075M-8
75±20%
700
25
1.0
2.0
3RP075-8
3RP090L-8
3RP090M-8
90±20%
700
50
1.0
2.0
3RP090-8
3RP150L-8
3RP150M-8
150±20%
700
100
1.0
2.0
3RP150-8
3RP200L-8
3RP200M-8
200±20%
700
100
1.0
2.0
3RP200-8
3RP230L-8
3RP230M-8
230±20%
700
100
1.0
2.0
3RP230-8
3RP350L-8
3RP350M-8
350±20%
850
100
1.0
2.0
3RP350-8
3RP400L-8
3RP400M-8
400±20%
850
100
1.0
2.0
3RP400-8
3RP470L-8
3RP470M-8
470±20%
950
250
1.0
2.0
3RP470-8
3RP600L-8
3RP600M-8
600±20%
1300
250
1.0
2.0
3RP600-8
3RP800L-8
3RP800M-8
800±20%
1500
250
1.0
2.0
3RP800-8
Electrical Ratings
Items
Test Condition/Description
Requirement
DC Spark-over
Voltage
The voltage is measured with voltage ramp dv/dt=100V/s. Test is between
each side electrode and center electrode.
To meet
the specified
Maximum Impulse
Spark-over Voltage
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs. Test is between each side electrode and center electrode.
4/7
value
3R-8 SERIES
Maximum surge current that can be applied through center electrode with
8/20μs waveform, for 10 times with 3min interval time, which will be equally
divided between each side electrode to center electrode, without causing
the DC breakdown voltage to change more than 25% from its initial
measured value.
Crest value
100
90
Current (%)
Impulse
Discharge Current
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. DC spark-over voltage shall not change more than ±25% from
its initial value. Test is between each side electrode and center electrode.
8
IR>10 ohms (-20%, +30% for 70~90V).
The resistance of gas tube shall be measured between each side
electrodes and center electrode.
The capacitance of gas tube shall be measured between each side
Test frequency: 1MHz
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
0.5
1
1.5
2
2.5
Time (minutes)
3
3.5
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
5/7
4
3R-8 SERIES
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
3℃/second max.
Average ramp-up rate (TL to TP)
Preheat
-Temperature Min (TS min)
150℃
-Temperature Max (TS max)
200℃
-Time (min to max) (ts)
60-180 seconds
TS max to TL
3℃/second max.
-Ramp-up Rate
Time maintained above:
217℃
-Temperature (TL)
-Time (tL)
60-150 seconds
260℃
Peak Temperature (TP)
Time within 5℃ of actual Peak Temperature (tP)
6℃/second max.
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
6/7
3R-8 SERIES
Packaging
Axial Packing (Bulk)
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
217.0
±2.0
B
207.0
±2.0
H
10.3
±0.5
Quantity: 100pcs
Inner box
A0
225.0
±2.0
B0
210.0
±2.0
H0
60.0
±2.0
Quantity: 500pcs
SMD Packing (Tape & Reel)
Tape
P2
P1
t0
E
P0
B0
B1
W
F
D0
W
P0
P1
P2
D0
E
F
A0
K0
B0
B1
t0
Dimension (mm)
Spec.
Tolerance
16.00
±0.20
4.00
±0.10
16.00
±0.10
2.00
±0.10
1.55
±0.05
1.75
±0.10
7.50
±0.10
11.60
±0.10
8.90
±0.10
8.60
±0.10
10.00
±0.10
0.50
±0.05
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
Symbol
K0
A0
Reel
t
D
d
L
Quantity: 300pcs
7/7
很抱歉,暂时无法提供与“3RP200M-8”相匹配的价格&库存,您可以联系我们找货
