4532 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
High insulation resistance
Low capacitance (≤0.5pF)
2000A 8/20μs maximum surge current capacity in accordance with IEC61000-4-5
4KV 10/700μs maximum surge rating in accordance with ITU-TK.21
Surface mounted gas arrester
Micro-Gap Design
Size 4532(1812)
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: E244458
Applications
■ Repeaters, Modems
■ Telephone Interface, Line cards
■ Data communication equipment
■ Line test equipment
Part Number Code and Marking
4532
XXX
LF
Lead Free
090: Device Marking Code
DC Spark-over Voltage
Size
Dimensions
1.5mm
4.5±0.3mm
2.7±0.3mm
4.2mm
3.2±0.3mm
3.2±0.3mm
0.5±0.1mm
3.0mm
Recommended Pad Size
Revision: GDT-4532 SERIES-001(A2)
2/5
http://brightking.pulseelectronics.com
4532 SERIES
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Impulse
Life
Test
Maximum
Capacitance
Nominal
Impulse
Discharge
Current
100V/s
1KV/μs
8/20μs
100A
Test
Voltage
(1MHz 1V)
8/20μs
(V)
(V)
(Times)
DC(V)
(pF)
(A)
4532-075-LF
55~95
600
300
25
1
0.5
2000
075
4532-091-LF
63~117
700
300
50
1
0.5
2000
090
4532-121-LF
84~156
700
300
50
1
0.5
2000
120
4532-151-LF
105~195
700
300
50
1
0.5
2000
150
4532-201-LF
140~260
750
300
100
1
0.5
2000
200
4532-231-LF
161~299
750
300
100
1
0.5
2000
10/700μs
230
4532-301-LF
210~390
900
300
100
1
0.5
2000
4kV
300
4532-351-LF
245~455
900
300
100
1
0.5
2000
±5 Times
350
4532-401-LF
280~520
1000
300
100
1
0.5
2000
400
4532-421-LF
294~546
1000
300
100
1
0.5
2000
420
4532-471-LF
329~611
1000
300
100
1
0.5
2000
470
4532-501-LF
350~650
1100
300
100
1
0.5
2000
500
4532-601-LF
420~780
1200
300
100
1
0.5
2000
600
Part
Number
Minimum
Insulation
Resistance
(GΩ)
Impulse
Withstanding
Voltage
Capacity
Device
Marking
Code
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Insulation
Resistance
Capacitance
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs.
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
Impulse
Discharge Current
Maximum 8/20μs surge current that can be applied between two electrodes,
5 positive and 5 negative surges, with 3 minutes interval time, without
causing the DC spark-over voltage to change more than 25% from its initial
value.
Impulse
Withstanding
Voltage
The maximum 10/700μs surge that can be applied to the Gas Tube, 5
positive and 5 negative surges, with 1 minute interval time, without causing
the DC spark-over voltage to change more than 25% from its initial value.
3/5
To meet
the specified
value
4532 SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
150℃
-Temperature Max (TS max)
200℃
-Time (min to max) (ts)
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
217℃
-Time (tL)
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
4/5
4532 SERIES
Packaging
Tape
Dimension (mm)
Items
P2
P1
B
t0
E
F
D1
A
A
B0
P0
W
D0
K0
B
SECTION B-B
A0
SECTION A-A
Reel
t
D
Tolerance
W
12.00
±0.20
P0
4.00
±0.10
P1
8.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.10
D1
1.00
±0.10
E
1.75
±0.10
F
5.50
±0.10
A0
3.80
±0.10
K0
3.20
±0.10
B0
4.90
±0.10
t0
0.40
±0.10
D
330.00
±2.00
d
13.00
±0.50
L
16.00
±2.00
t
2.00
±0.20
d
L
Spec.
Quantity: 2500pcs
5/5
很抱歉,暂时无法提供与“4532-401-LF-(SZZY)”相匹配的价格&库存,您可以联系我们找货
