AG-BK
Thyristor Surge Suppressors (TSS) Data Sheet
Description
DO-214AA Thyristor solid state protection thyristor protect
telecommunications equipment such as modems, line cards,
fax machines, and other CPE.
AG-BK is used to enable equipment to meet various regulatory
requirements including GR 1089, ITU K.20, K.21 and K.45, IEC
60950, UL 60950, and TIA-968(formerly known as FCC Part 68).
Features
Compared to surge suppression using other technologies, AG-BK devices offer absolute surge protection
regardless of the surge current available and the rate of applied voltage (dv/dt). AG-BK devices:
■ Cannot be damaged by voltage
■ Eliminate hysteresis and heat dissipation typically found with clamping devices
■ Eliminate voltage overshoot caused by fast-rising transients
■ Are non-degenerative
■ Will not fatigue
■ Have low capacitance, making them ideal for high-speed transmission equipment
■ Meets MSL level 1, per J-STD-020
Electrical Parameters
Parameter
Definition
VDRM
Peak Off-state Voltage – maximum voltage that can be applied while maintaining off state
VS
Switching Voltage – maximum voltage prior to switching to on state
VT
On-state Voltage – maximum voltage measured at rated on-state current
IDRM
Leakage Current – maximum peak off-state current measured at VDRM
IS
Switching Current – maximum current required to switch to on state
IT
On-state Current – maximum rated continuous on-state current
IH
Holding Current –typical current required to maintain on state
CO
Off-state Capacitance – typical capacitance measured in off state
VPP
Peak Pulse Voltage – maximum rated peak impulse voltage
IPP
Peak Pulse Current – maximum rated peak impulse current
VC
Clamping Voltage – maximum voltage measured at VPP
Revision:TSS-AG-BK-001(A2)
1/4
http://brightking.yageo.com
AG-BK
Electrical Characteristics
Part
Number
VDRM
(V)
VS
(V)
VT
(V)
IDRM
(μA)
IS
(mA)
IT
(A)
IH
(mA)
CO
(pF)
AG-BK
6
25
4
5
800
2.2
50
125
VPP
10/700μs
(V)
6000
IPP
10/1000μs
(A)
90
VC
@ VPP
(V)
25
Marking
AG
Notes:
·All measurements are made at an ambient temperature of 25℃. IPP applies to -40℃ through +85℃ temperature range.
·Off-state capacitance(CO) is measured at 1 MHz with a 2V bias and is typical value.
Thermal Considerations
Package DO-214AA/SMB
Symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature
-40 to +125
TS
Storage Temperature Range
-40 to +150
RθJA
Junction to Ambient on printed circuit
90
℃/W
Characteristics Curves
Figure 1. V-I Characteristics
Figure 2. tr × td Pulse Wave-form
+I
IPP - Peak Pulse Current, %IPP
tr = rise time to peak value
td = decay time to half value
IT
IS
IH
IDRM
-V
+V
VT
VDRM
VS
Waveform = tr × td
50
-I
Half Value
td
tr
t-Time (µ s)
Figure 3. Normalized Vs Change versus Junction
Temperature
Figure 4. Normalized DC Holding Current versus
Case Temperature
16
14
12
10
2.0
8
1.4
1.8
1.6
Ratio of
IH/IH(TC=25℃)
Percent of VS, Change - %
Peak Value
100
6
25℃
4
2
1.2
25℃
1.0
0.8
0.6
-6
-8
-40 -20
60
80 100 120 140 160
TJ-Junction Temperature (℃)
0.4
-40 -20
60
80 100 120 140 160
TC-Case Temperature (℃)
2/4
AG-BK
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
20-40 seconds
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Marking Code
Logo
XXXX
AG
3/4
Internal control code
Device Marking Code
AG-BK
Dimensions (SMB/DO-214AA)
Millimeters
Inches
Symbol
Min.
Max.
Min.
Max.
L
4.06
4.57
0.160
0.180
D
3.30
3.94
0.130
0.155
D1
1.95
2.20
0.077
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.16
0.006
H
2.13
2.47
0.084
0.097
t
0.152
0.305
0.006
0.012
D1 D
L
t
H
d
T1
T
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
K0
B
SECTION B-B
A0
SECTION A-A
Reel
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
Φ330.0±2.0
D3
Φ13.5±0.5
H
2.5±0.5
W1
16.0±1.0
Quantity: 3000PCS
4/4
很抱歉,暂时无法提供与“AG-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.49713
- 100+0.39669
- 300+0.34658
- 3000+0.30888
- 6000+0.27886
- 9000+0.26374
