B600-100KA(004)
DATA SHEET
GAS DISCHARGE TUBE
B600-100KA (004)
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
■ Stable breakdown voltage
■ High insulation resistance
■ Large absorbing transient current capability
■ Micro-Gap Design
■ ROHS compliant
■ Storage and operating temperature: -40℃ ~ +85℃
Dimension (Unit: mm)
Unit: mm
Electrical Characteristics
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Maximum
Impulse
Discharge
Current
100V/s
1000V/μs
8/20μs
10/350μs
Part Number
B600-100KA(004)
Minimum
Insulation
Resistance
Test
Voltage
(V)
(V)
(KA)
(KA)
DC(V)
600±20%
1400
100
Revision: GDT-B600-100KA(004)-001(A3)
2/3
Maximum
Capacitance
1MHz
Device
Marking
Code
(GΩ)
(pF)
1.0
8
B600-100KA
http://brightking.pulseelectronics.com
B600-100KA(004)
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes.
Crest value
Current (%)
100
90
Impulse
Discharge
Current
To meet
the specified
50
value
20µs
10
8µs
Time
Impulse Width
Insulation
Resistance
Capacitance
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
Packaging
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
190.0
±2.0
B
230.0
±2.0
H
18.0
±2.0
Quantity: 25pcs
Inner box
B0
A0
200.0
±2.0
B0
240.0
±2.0
H0
100.0
±2.0
H0
Quantity: 125pcs
A0
3/3
很抱歉,暂时无法提供与“B600-100KA(004)”相匹配的价格&库存,您可以联系我们找货
