471KD20J-ALEP11Z2(AML) 数据手册
规格承认书
SPECIFCATION FOR APPROVAL
Rev1.0
SPECIFCATION
MODEL NO.
471KD20J
PART NO.
471KD20J- ALEP11Z2(AML)
UL
E327997
NO.
PAGE:1 OF 4
CSA
DATE:2018 年 1 月 12 日
246579
VDE
40027827
1. Outline
1.1
Appearance
Without any crack, marking should be clear
Dimensions (mm)
1.2
D(max.)
23.0
H(max.)
26.5
T(max.)
5.99
d(±0.05)
1.0
F(±0.5)
11.0
L(min.)
20.0
Epoxy color: Blue
2. Electrical Parameters
2.1
Maximum Allowable Voltage
2.2
Varistor Voltage(Test time for 30ms)
2.3
Rated Power
2.4
Maximum Clamping Voltage
AC: 300(V)
@1mA DC
DC: 385(V)
423-450(V)
V1mA
1.00(W)
IP: 100(A)
VC: 775(V)
Test Current Waveform
8/20μs
±10 times:12KV/6KA
1.2/50μs&8/20μs
(60s intervals)
350(J)
10/1000μs
Typical Capacitance
850(pF)
@1KHz
2.8
Leakage Current
≤24μA)
At 80% of Varistor Voltage
2.9
Nonlinear Exponent (α)
2.5
Withstanding Surge Current
2.6
Maximum Energy
2.7
≥30
α
log
I1
V1
log
I2
V2
规格承认书
Rev1.0
SPECIFCATION
MODEL NO.
471KD20J
PART NO.
2.10
Temperature Coefficient of
Varistor Voltage
2.11
Impulse Life
NO.
PAGE:2 OF 4
Vc85℃-Vc25℃
≤0.05%/℃
VCat 25℃
≤±10%(V1mA)
1
×100(%℃)
60
8/20μs
3. Packing
3.1
Quantity
3.2
Packing
Dimension
400 PCS (200pcs/bag, 2 bags/box)
LP
245max
HP
65max
WP
185max
Unit: mm
4. Material List
4.1
Drawing
4.2
Material
RoHs
Chart
Items
Coating
Lead
Electrode
Disk
Solder
Composition
Manufacturer
Epoxy Resin
Made in China, and in line with the UL94-V0
testing, meet the environmental requirements
Cp wire
Made in China, meet the environmental
requirements
Silver
requirements
Zinc Oxide
requirements
Sn:96.5%Cu
0.5%Ag3.0%
requirements
规格承认书
Rev1.0
SPECIFCATION
MODEL NO.
471KD20J
PART NO.
NO.
PAGE:3 OF 4
5. Mechanical Requirements
5.1
Tensile of Terminations
No Outstanding Damage
2.0Kgf; 10Sec.
5.2
Bending of Terminations
1.0Kgf; 90°, 3 Times
5.3
Vibration
Freq: 10-55Hz;
Amp: 0.75mm, 1Min.
5.4
Solderability
Min. 95% of the terminal
should be covered with solder
uniformly
Solder Temp: 265℃±5℃
Dipping Time: 2.5±0.5Sec.
5.5
Resistance of soldering heat
△V1mA/V1mA ≤±5%
Dipping Time: 10±1Sec.
6. Environmental Requirements
6.1
High Temperature Storage
△V1mA/V1mA ≤±5%
Ambient Temp: 125±2℃
Duration: 1000h
6.2
Low Temperature Storage
△V1mA/V1mA ≤±5%
Ambient Temp: -40±2℃
Duration: 1000h
6.3
High Humidity Storage/Damp
Heat
△V1mA/V1mA ≤±5%
Ambient Temp: 40±2℃
90~95% R.H. Duration: 1000h
6.4
6.5
Temperature 5 Cycle
High Temperature Load
△V1mA/V1mA ≤±5%
Step
Temperature
Period
(min)
1
-40±3
30±3
2
Room Temp
15±3
3
125±3
30±3
4
Room Temp
15±3
△V1mA/V1mA ≤±10%
Ambient Temp: 85±2℃
Duration: 1000h
Load: Max. Allowable Voltage
△V1mA/V1mA ≤±10%
Ambient Temp: 40±2℃
6.6
High Humidity Load
6.7
Operating Temperature Range
-40℃ ~ +85℃
6.8
Storage Temperature Range
-40℃ ~ +125℃
规格承认书
Rev1.0
SPECIFCATION
MODEL NO.
471KD20J
PART NO.
7. Marking Code
VDE
8. Part Number Code
NO.
PAGE:4 OF 4
471KD20J-ALEP11Z2(AML) 价格&库存
很抱歉,暂时无法提供与“471KD20J-ALEP11Z2(AML)”相匹配的价格&库存,您可以联系我们找货
