ATS33C-2CF/B
ATS33C-2CF/B
    BRIGHTKING(君耀)
    P600(R6)
    单向TVS 33V截止 190A峰值脉冲
ATS33C-2CF/B 数据手册
ATS-2CF SERIES Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ Glass passivated junction Low inductance Excellent clamping capability 10000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.05% Fast response time High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) tension Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020 IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ ■ ■ ■ Case: Moulded plastic over glass passivated junction Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026 Mounting Position: Any Weight: 2.75g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) ■ Meets ISO7637-2 surge spec. Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.2) PPPM Minimum 10000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 8.0 Watts IFSM 300 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 8 ℃/W Typical thermal resistance junction to ambient RθJA 40 ℃/W Steady state power dissipation at TL=75℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:TVS-ATS-2CF SERIES-001(A2) 1/5 http://brightking.yageo.com ATS-2CF SERIES Dimensions (P600) Millimeters d DIA. T Min. Max. Min. Max. L 25.40 - 1.000 - T 8.60 9.10 0.340 0.360 d 8.60 9.10 0.340 0.360 s 1.19 1.32 0.047 0.052 s DIA. L Inches Symbol L Electrical Characteristics (TA=25℃) Part Number Breakdown Voltage @IT Type Test Current Reverse Stand-Off Voltage Reverse Leakage @ VRWM Maximum Clamping Voltage @IPP Peak Pulse Current ① VBR MIN.(V) VBR MAX.(V) IT (mA) VRWM (V) IR (μA) VC(V) IPP(A) 2CF 24.2 26.9 5 22 1.8 35.5 287 ATS24C 2CF 26.7 29.6 5 24 1.8 39 257 ATS26A ATS26C 2CF 28.9 32 5 26 1.8 42.1 237 ATS28A ATS28C 2CF 31.1 34.5 5 28 1.8 45.4 220 ATS30A ATS30C 2CF 33 38 5 30 1.8 50 250 ATS33A ATS33C 2CF 36.7 40.6 5 33 1.8 53 190 ATS36A ATS36C 2CF 40 44.2 5 36 1.8 58.1 174 ATS40A ATS40C 2CF 44.4 49.1 5 40 1.8 64.5 155 Unidirectional Bidirectional ATS22A ATS22C ATS24A Suitable ISO 7637-2 2004 5a test waveform Part Number Type ① Maximum Clamping Voltage Voltage level 87V 174V 400mS 350mS 35.5 × 2CF 39 ATS26C 2CF ATS28A ATS28C ATS30A Resistance Level DC(V) 0.5Ω 1Ω 2Ω 3Ω 4Ω 8Ω -- 13.5 -- × × × × × × -- 13.5 -- × × × × × 42.1 × -- 27 -- -- -- -- × × 2CF 45.4 × -- 27 -- -- -- -- × × ATS30C 2CF 50 -- × 28 -- -- -- -- × × ATS33A ATS33C 2CF 53 -- × 28 -- -- -- -- × × ATS36A ATS36C 2CF 58.1 -- × 28 -- -- -- -- × × ATS40A ATS40C 2CF 64.5 -- × 28 -- -- -- -- × × Unidirectional Bidirectional ATS22A ATS22C 2CF ATS24A ATS24C ATS26A Note: Vc(V) ‘x’ representatives meets this test condition; Revision:TVS-ATS-2CF SERIES-001(A2) 2/5 http://brightking.yageo.com ATS-2CF SERIES Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. ISO 7637-2 5a Test pulse Figure 2. Peak Pulse Power Rating Curve 1000 PPPM - Peak Pulse Power (kW) U td tr Us 0.9Us UA 0.1Us 100 10 0 1 t 0.1 1 10 100 1000 10000 td-Pulse Width (µs) IPPM - Peak Pulse Current, %IRSM 150 Figure 4. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % Figure 3. Pulse Waveform TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Peak Value IPPM 100 Half Value IPPM (IPPM/2) 50 10/1000µs Waveform as defined by R.E.A td 0 0 1.0 2.0 3.0 100 75 50 25 0 0 4.0 Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 8 7 6 5 4 L= 0.375″(9.5mm) Lead Lengths 1 0 25 100 125 150 175 200 Surge Current Uni-Directional Only 9 0 75 Figure 6. Maximum Non-Repetitive Forward Curve 2 50 TA-Ambient Temperature (℃) t-Time (ms) 3 25 50 75 100 125 150 TL-Lead Temperature (℃) Revision:TVS-ATS-2CF SERIES-001(A2) 175 200 3/5 350 300 250 200 150 100 50 0 1 10 Number of Cycles at 60Hz 100 http://brightking.yageo.com ATS-2CF SERIES Recommended Soldering Conditions Wave Soldering 300 Preheating Maximum Wave 265℃ Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Recommended Conditions Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds Soldering 1 time Marking Code YXXX Logo ATS36C Intermal Control Code Marking Code Part Number Code ATS XXX C 2CF / XXXX Package code B: Box package TR13: Reel package Internal Control Code Bidirectional VRWM Voltage Series Code Revision:TVS-ATS-2CF SERIES-001(A2) 4/5 http://brightking.yageo.com ATS-2CF SERIES Ordering Code for Different Package Box package: Add suffix “/B” at the end of the part number, such as ATSXXXC-2CF/B Reel package: Add suffix “/TR13” at the end of the part number, such as ATSXXXC-2CF/TR13 Packaging Tape Z ±5° A E Symbol Dimension (mm) A 10.0±0.5 B 53.0±1.0 Z 1.2Max. T 6.0±0.4 E 0.8Max. L1-L2 1.0Max. L 250.0±5.0 W 75.0±5.0 H 114.0±5.0 L1 B L2 T E Box H L W Quantity: 300PCS Reel D 330.0±3.0 D0 16.4±2.0 D1 86.0±2.0 W1 76.0±3.0 D0 D1 D W1 Quantity: 800PCS Revision:TVS-ATS-2CF SERIES-001(A2) 5/5 http://brightking.yageo.com
ATS33C-2CF/B 价格&库存
很抱歉,暂时无法提供与“ATS33C-2CF/B”相匹配的价格&库存,您可以联系我们找货
