A712-7.K20.500.000
A712-7.K20.500.000
    OTHER
A712-7.K20.500.000 数据手册
M 12 Power The compact and powerful power connector Table of contents M 12 Power Connectors M 12 6 Moulded Cordsets M 12 7 Panel Connectors M 12 8 Accessories 11 Technical Data 5 Inserts 9 Contacts 10 Assembly instructions 12 Benefits of HUMMEL 14 Limited Liability Products, design, colors and dimensions are subject to change without prior notice. We reserve the right to make technical improvements on all our products, currently ordered or for future orders. It is the user’s responsibility to verify all dimensions and technical data. HUMMEL AG will assume no liability regarding information provided to the user by published literature or inside technical staff, its distributors and outside sales personnel. Errors in the catalog can occur and shall not create any liability whatsoever for HUMMEL. All information provided by HUMMEL is without guarantee and must be verified by the user. 2 www.hummel.com compact and powerful M 12 goes Power It is a major milestone in an age of miniaturization: the presentation of the M 12 Power Connector. This circular connector opens the door to entirely new applications and capabilities. Its high power transmission, the compact design and the large temperature range are the extraordinary features. The mechanical and electrical data of this compact power connector are convincing. Power transmission to 630 V and 16 A Temperature range to 125 degree Celsius K, L, S, T Coding EMC shielding in standard version Robust metal housing, optional stainless steel Protection IP 67 and IP 69K Compact designs Cable diameter range to 11 mm 3 Product Overview 4 Housings page 6 Inserts (for contacts) page 9 Accessories page 11 Dimensions and specifications may be changed without prior notice Technical Data Connectors M 12 Mechanical Data Materials and Technical Data Housing Copper-Zinc alloy / Die Cast INOX AISI 316 L TPU (moulded versions) Housing surface Nickel plated Black chrome-plated Inserts (for contacts) PBT Contacts Copper alloy Contact surface at point of contact Gold plated Minimum mating cycles > 100 Seals / O-Rings FKM / NBR Temperature range -40° C – 125° C (-40 °F – 257 °F) Type of contacts Crimp, screw Fire protection class V-0 Protection IP 67/ IP 69K Cable diameter range 3 – 11 mm (.08 – .43“) Electrical Data Coding Colors Number of positions AWG [mm2] Nominal current [A] S T K L black dark grey blue grey 4 (3 + PE) 4 5 (4 + PE) 5 (4 + PE) 0,5 – 1,5 0,5 – 1,5 0,75 – 2,5 0,75 – 2,5 AWG 20 – 16 AWG 20 – 16 AWG 18 – 14 AWG 18 – 14 12 12 16 16 630 63 630 63 Test voltage (Breakdown voltage) [V~] 6000 1500 6000 1500 Insulation resistance [MΩ] > 106 > 106 > 106 > 106
A712-7.K20.500.000 价格&库存
很抱歉,暂时无法提供与“A712-7.K20.500.000”相匹配的价格&库存,您可以联系我们找货
