1.14.012.916/0000
1.14.012.916/0000
    RAFI
    轻触开关 立贴
1.14.012.916/0000 数据手册
technical data sheet 1.14.012.916/0000 RACON 12 S, SMT, 6,8±1,6 N, 1 NO fields of application  Measurement-control-regulation  Mechanical and system engineering  Automotive  Electro-medical special features Gold contacts, reliable switching with low currents Special tactile feedback Different operating forces Variable overall heights due to plunger Terminal technology: SMT or THT Traceability through product identification sealable (tested media see Downloads) description Our top-quality RACON 12 tactile switches – in the dimensions 12 x 12 mm – feature an unmistakeable click, high switching reliability, a sealed contact system and castability. That has made RACON the standard in many industries. Whether for automotive applications, systems with keycaps, or membrane keyboards, RACON impresses in the THT or SMT versions – for your application too. RACON 12 tactile switches can be arranged individually, in rows or as key blocks. When used beneath membrane overlays, the RACON key switches should be combined with plungers. Suitable for the most important soldering techniques   Soldering bath for THT versions   Reflow soldering for SMT versions   Vapor phase soldering for SMT versions   Manual soldering Processing of the SMT designs with SMT automatic assembly machines IMDS entry technical data general Color blue direct links Operating temperature, min. -40 °C  RAFI eCatalog Storage temperature, min. -50 °C Operating temperature, max. 90 °C Storage temperature, max. 90 °C illuminated No Soldering Reflow Solder heat resistance according to standard DIN EN 60068-2-58 The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and other information about our products are the mere results of individual technical testing. These descriptions and other product features are only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own purposes may infringe the rights of the respective entity holding those rights. date: May 19, 2021  page: 1/3 RAFI GmbH & Co. KG Ravensburger Str. 128-134 88276 Berg / Ravensburg Germany www.rafi-group.com, info.headquarters@rafi-group.com technical data sheet 1.14.012.916/0000 Packaging Blister Packaging unit 750 pcs. Operating life 1,000,000 cycles B10 1,300,000 cycles Degree of protection, front side, according to DIN EN 60529 IP54 IPx7 Degree of protection, rear side, according to DIN EN 60529 IP54 IPx7 Corrosive gas testing according to standard Yes MOQ order 750 pcs. RoHS compliant Yes REACH compliant Yes Component material Elastomer Installation height 4.95±0.1 mm Grid, min. 12,5 x 15,24 mm Outside dimension, length 12 mm Outside dimension, width 12 mm Outside dimension, height 4.95±0.1 mm Actuation function momentary contact function Operating force, max. 10 N Operating force, min. 6,8±1,6 N Switching travel 0,7±0,1 mm Contact function 1 NO Contact system Snap-action contact Contact material Gold Terminal on the rear SMT Solderability Yes Rated voltage, min. 0.02 V Rated voltage, max. 35 V Rated current, min. 0.00001 A Rated current, max. 0.1 A Rated power, max. 1W mounting diameters mechanical data electrical data The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and other information about our products are the mere results of individual technical testing. These descriptions and other product features are only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own purposes may infringe the rights of the respective entity holding those rights. date: May 19, 2021  page: 2/3 RAFI GmbH & Co. KG Ravensburger Str. 128-134 88276 Berg / Ravensburg Germany www.rafi-group.com, info.headquarters@rafi-group.com technical data sheet 1.14.012.916/0000 drawings Dimensioned drawing System drawing System drawing System drawing PCB drawing PCB drawing Product labeling drawing Packaging drawing The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and other information about our products are the mere results of individual technical testing. These descriptions and other product features are only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own purposes may infringe the rights of the respective entity holding those rights. date: May 19, 2021  page: 3/3 RAFI GmbH & Co. KG Ravensburger Str. 128-134 88276 Berg / Ravensburg Germany www.rafi-group.com, info.headquarters@rafi-group.com
1.14.012.916/0000 价格&库存
很抱歉,暂时无法提供与“1.14.012.916/0000”相匹配的价格&库存,您可以联系我们找货
1.14.012.916/0000
    1.14.012.916/0000
    • 750+37.71493750+4.87757
