Other pushbuttons
Pushbutton, opaque, mounting hole diameter 15.2 mm, 250 V/0.7 A
1
Pict.: Screw terminals, red
Technical data
Other
Pushb.
General information
Form of lens
Colour of lens
Form of collar
protruding lens
see order block
round
Dimensions
Diameter of collar
Overall height
Mounting depth
Mounting hole
19 mm
8.2 mm
21.5 mm
15.2 mm
Mechanical design
Mounting
Terminals
Contact system
Contact function
Contact arrangement
Contact materials
Illuminability
Lamp socket
ring nut
see order block
bridge contact
momentary
see order block
Ag
no
no
Mechanical characteristics
Operating force max.
Operating travel
Switching travel NC
Switching travel NO
Robustness min.
7.5 N
3 mm
1.2 mm
2.0 mm
100 N
Electrical characteristics
Rated voltage AC max.
Rated current max.
Contact resistance when
new max.
Contact resistance acc.
to life max.
Other specifications
Operating life
Degree of protection
from front side
Ambient temp. operating
min.
max.
Storage temperature min.
Storage temperature max.
Resistance to constant
environment
Resistance at variable
environment
Weight
Approvals
Flame class acc. to UL 94
Hot wire ignition acc.
to IEC 60695-2-1
25000
IP40
(IP65 with sealing cap)
-25 °C
+85 °C
-40 °C
+90 °C
according to
IEC 600 68-2-3 and 2-30
according to
IEC 600 68-2-14 and 2-33
7g
ENEC T 85/55
V0
yes
250 V
0.7 A
50 mΩ
300 mΩ
Accessories Pushbutton, opaque, mounting hole diameter 15.2 mm, 250 V/0.7 A
Description
Order no.
Page
Sealing cap, transparent (IP65)
5.52.008.115/0000
Fixing spanner M 15, M 16
5.58.002.019/0105 5 - 23
1 - 78
Stock items are marked
by bold printed order numbers.
Pushbuttons
Other pushbuttons
1
Contact arrange- Contact function Illuminability
ment
Terminals
Colour of lens
Order no.
1 NO
momentary
no
screw terminals
opaque black
1.10.001.001/0104
1 NO
momentary
no
screw terminals
opaque white
1.10.001.001/0205
1 NO
momentary
no
screw terminals
opaque red
1.10.001.001/0301
1 NO
momentary
no
screw terminals
opaque green
1.10.001.001/0507
1 NO
momentary
no
opaque black
1.10.001.011/0104
1 NO
momentary
no
opaque white
1.10.001.011/0205
1 NO
momentary
no
opaque red
1.10.001.011/0301
1 NO
momentary
no
opaque green
1.10.001.011/0507
1 NC
momentary
no
solder/quick connector
6.3x0.8 / 2x 2.8x0.8mm
screw terminals
opaque black
1.10.001.151/0104
1 NC
momentary
no
screw terminals
opaque red
1.10.001.151/0301
1 NC
momentary
no
opaque black
1.10.001.161/0104
1 NC
momentary
no
opaque red
1.10.001.161/0301
Technical data see page 1 - 78
Quick-connector 6.3 x 0.8 mm. The connector is splitted and also usable for two connectors 2.8 x 0.8 mm.
Pushbuttons
1 - 79
Other
Pushb.
很抱歉,暂时无法提供与“1.10.001.011/0301”相匹配的价格&库存,您可以联系我们找货
