Other pushbuttons
Illuminable pushbutton, mounting hole diameter 9.1 mm, 24 V/0.5 A
1
Pict.: red
Technical data
Other
Pushb.
General information
Form of lens
Colour of lens
Form of collar
protruding lens
see order block
round
Dimensions
Diameter of collar
Overall height
Mounting depth
Mounting hole
11 mm
7 mm
25 mm
9.1 mm
Mechanical design
Mounting
Terminals
Contact system
Contact function
Contact arrangement
Contact materials
Illuminability
Lamp socket
Mechanical characteristics
Operating force max.
Operating travel
Switching travel NC
Switching travel NO
Robustness min.
Electrical characteristics
Rated voltage AC/DC max.
Rated voltage DC max.
Rated current max.
Contact resistance when
new max.
Contact resistance acc.
to life max.
Bouncing time max.
Lamp voltage
ring nut
solder terminals
bridge contact
momentary
1 NC + 1 NO
Au
see order block
no
5N
1.5 mm
0.5 mm
1 mm
100 N
Other specifications
Operating life key switch
Operating life filament
lamp
Degree of protection
from front side
Ambient temp. operating
min.
max.
Storage temperature min.
Storage temperature max.
Resistance to constant
environment
Soldering temperature
max.
Resistance at variable
environment
Weight
Soldering time max.
50 mΩ
300 mΩ
10 ms
see order block
200000
see order block
IP40
-25 °C
+70 °C
-40 °C
+80 °C
according to
IEC 600 68-2-3 and 2-30
350 °C
according to
IEC 600 68-2-14 and 2-33
3g
3 sec.
24 V
24 V
0.5 A
Accessories Illuminable pushbutton, mounting hole diameter 9.1 mm, 24 V/0.5 A
Description
Fixing spanner M 9, M 10
1 - 76
Order no.
Page
5.58.002.025/0105 5 - 23
Stock items are marked
by bold printed order numbers.
Pushbuttons
Other pushbuttons
1
Pict.: red
Contact arrangement Contact function
Illuminability
Lamp voltage
Colour of lens
1 NC + 1 NO
momentary
filament lamp
24 V / 0.7 W
1 NC + 1 NO
momentary
filament lamp
24 V / 0.7 W
transparent colour- 1.15.106.021/1002
less
transparent red
1.15.106.021/1307
1 NC + 1 NO
momentary
filament lamp
24 V / 0.7 W
transparent yellow 1.15.106.021/1403
1 NC + 1 NO
momentary
filament lamp
24 V / 0.7 W
transparent green
1.15.106.021/1510
1 NC + 1 NO
momentary
no
opaque black
1.15.106.301/0104
1 NC + 1 NO
momentary
no
opaque white
1.15.106.301/0214
1 NC + 1 NO
momentary
no
opaque red
1.15.106.301/0313
1 NC + 1 NO
momentary
no
opaque yellow
1.15.106.301/0410
1 NC + 1 NO
momentary
no
opaque green
1.15.106.301/0518
1 NC + 1 NO
momentary
transparent white
1.15.106.505/1000
1 NC + 1 NO
momentary
transparent red
1.15.106.501/1300
1 NC + 1 NO
momentary
1 NC + 1 NO
momentary
1 NC + 1 NO
momentary
LED super bright
white
LED super bright
red
LED super bright
yellow
LED super bright
green
LED super bright
blue
2 V/10 mA external
series resistor
2 V/10 mA external
series resistor
2 V/10 mA external
series resistor
2 V/10 mA external
series resistor
2 V/10 mA external
series resistor
Order no.
transparent yellow 1.15.106.503/1400
transparent green
1.15.106.502/1500
transparent blue
1.15.106.504/1600
Technical data see page 1 - 76
Recommended values for external series resistor for LED:
• 5 - 7 V = 270 Ω, 0.25 W
• 12 - 14 V = 680 Ω, 0.5 W
• 24 - 28 V = 1500 Ω, 1 W
Operating life filamant Lamp: approx. 2000 h.
Pushbuttons
1 - 77
Other
Pushb.
很抱歉,暂时无法提供与“1.15.106.021/1510”相匹配的价格&库存,您可以联系我们找货
