3.13.002.102/0000
3.13.002.102/0000
    RAFI
    RAFI SWITCH
3.13.002.102/0000 数据手册
05.12.2018 RS 76 C - Full-travel key switch, not illuminable 3.13.001.210/0000 Recommended for use of multi-module keycaps. For accessories and keycaps, refer to RS 76. General information Recommended key grid 19.05 mm Mechanical design Contact function Mounting Terminals Contact system Illumination momentary soldering solder terminals, tin-plated contactless with Hall-IC no Mechanical characteristics Switching travel off Operating force max. Operating travel Switching travel on Robustness max. 0.8 ... 2.4 mm 1N 4 mm 1.5 - 2.8 mm 100 N Electrical characteristics Operating voltage DC Supply current max. at UIL = 0 V 4.75 ... 5.25 V 0.5 mA Supply current max. at UIH = 5 V 5 mA Input voltage (F) at UIL = 0 V 0.4 V Input voltage (F) at UIH = 2.4V Output load current (Q) max. Output residual current (Q) max. Output saturation voltage (Q) max. bei 16 mA ESD strength max. Output switching times (Q) at 25 °C, tPHL 5.25 V 16 mA 10 µA 0.4 V 8 kV 3 µs Output switching times (Q) at 25 °C, tPLH 4 µs Output switching times (Q) at 25 °C, tTHL 1 µs Output switching times (Q) at 25 °C, tTLH 2 µs Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection. 05.12.2018 Other specifications Reliability of Hall-IC at 25 °C λ = 2.5 x 10-7 h-1 Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. (product) Storage temperature max. (rail) Environmental restistance Operating life min. (operations) Degree of protection Flammability of materials ROHS compliant REACH compliant 0 °C +70 °C -40 °C +80 °C +50 °C acc. to IEC 60068-2-14, -30, -33 and -78 108 cycle IP40 (DIN EN 60529) UL 94 HB yes yes Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection.
3.13.002.102/0000 价格&库存
很抱歉,暂时无法提供与“3.13.002.102/0000”相匹配的价格&库存,您可以联系我们找货
3.13.002.102/0000
  • 14+64.55387
  • 46+61.47066
  • 183+58.71391
  • 458+56.13853
  • 1372+53.82915
库存:2850
