5.00.100.165/0000
5.00.100.165/0000
    RAFI
    CONTACT BLOCK SPST-NO 0.1A 35V
5.00.100.165/0000 数据手册
RAFIX 22 QR 2 General data RAFIX 22QR control component range • For a mounting hole diameter of 22.3 mm to IEC 60947 • 250V/10A max. • Water-jet proof IP65 • 2 collar shapes • The lamps of the pushbuttons can also be replaced from the front • The contact blocks (silver or gold contacts) snap onto the actuators with a coupling • Screw, cage clamp, quick connect terminals or RJ12 connector • 3 NC + 3 NO max. RAFIX 22 QR The specified data apply only if actuators/signal indicators are combined with contact blocks and lamp sockets within the same product range. Content RAFIX 22 QR pushbutton RAFIX 22 QR pushbutton, flush lens, round collar RAFIX 22 QR pushbutton, protruding lens, round collar RAFIX 22 QR pushbutton, protruding front ring, round collar RAFIX 22 QR pushbutton, flush lens, square collar RAFIX 22 QR pushbutton, protruding lens, square collar RAFIX 22 QR pushbutton, protruding front ring, square collar 2222222- RAFIX 22 QR selector switch RAFIX 22 QR selector switch, round collar, short handle RAFIX 22 QR selector switch, round collar, long handle RAFIX 22 QR selector switch, square collar, short handle RAFIX 22 QR selector switch, square collar, long handle 2 - 96 2 - 97 2 - 98 2 - 99 2 - 100 RAFIX 22 QR keylock switch RAFIX 22 QR keylock switch, round collar RAFIX 22 QR keylock switch, square collar 2 - 102 2 - 103 2 - 104 RAFIX 22 QR mushroom-headed pushbutton RAFIX 22 QR mushroom-headed pushbutton 40 mm, round collar RAFIX 22 QR mushroom-headed pushbutton 40 mm, illuminated, round collar RAFIX 22 QR mushroom-headed pushbutton 60 mm, round collar RAFIX 22 QR mushroom-headed pushbutton 40 mm, square collar RAFIX 22 QR mushroom-headed pushbutton 40 mm, illuminated, square collar RAFIX 22 QR mushroom-headed pushbutton 60 mm, square collar 2 - 106 2 - 107 2 - 107 2 - 108 2 - 108 2 - 109 2 - 109 Control components 88 89 90 91 92 93 94 2 - 83 RAFIX 22 QR 2 RAFIX 22 QR RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, with indication to EN 60947-1 RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, with keylock RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, illuminated RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, illuminated 2 - 110 2 - 111 2 - 112 2 - 112 2 - 113 2 - 113 RAFIX 22 QR toggle switch RAFIX 22 QR, toggle switch, round collar RAFIX 22 QR, toggle switch, square collar 2 - 114 2 - 115 2 - 115 RAFIX 22 QR twin pushbutton RAFIX 22 QR twin pushbutton, oval collar RAFIX 22 QR twin pushbutton, rectangular collar 2 - 116 2 - 117 2 - 117 RAFIX 22 QR potentiometer drive RAFIX 22 QR potentiometer drive, round collar RAFIX 22 QR potentiometer drive, square collar 2 - 118 2 - 119 2 - 119 RAFIX 22 QR buzzer RAFIX 22 QR buzzer, round collar RAFIX 22 QR buzzer, square collar 2 - 120 2 - 121 2 - 121 RAFIX 22 QR signal indicator RAFIX 22 QR signal indicator, round collar RAFIX 22 QR signal indicator, square collar 2 - 122 2 - 123 2 - 123 RAFIX 22 QR contact blocks with silver contacts RAFIX 22 QR contact block with silver contacts RAFIX 22 QR contact block assembly, with coupling, without lamp socket, silver contacts RAFIX 22 QR contact block assembly, with coupling and lamp socket, silver contacts RAFIX 22 QR contact blocks with gold contacts RAFIX 22 QR contact block with gold contacts RAFIX 22 QR contact block assembly, with coupling, without lamp socket, gold contacts RAFIX 22 QR contact block assembly, with coupling and lamp socket, gold contacts 2 - 124 2 - 125 2 - 126 2 - 127 2 - 128 2 - 129 2 - 130 2 - 131 Contact blocks with coupling, gold contacts, RJ 12 connector, integrated LED Contact block with coupling, gold contacts, RJ 12 connector, integrated LED 2 - 132 2 - 133 RAFIX 22 QR lamp sockets BA 9s (MBC/MCC), screw terminals and cage clamp terminals RAFIX 22 QR lamp socket, without coupling RAFIX 22 QR lamp socket assembly, with coupling 2 - 134 2 - 135 2 - 136 RAFIX 22 QR lamp sockets with integrated LED, screw terminals RAFIX 22 QR lamp socket with integrated LED, without coupling 2 - 138 2 - 139 RAFIX 22 QR special accessories Housings for flush pushbuttons Lenses for flush pushbuttons Front ring RAFIX 22 QR plastic front ring with thermoflex protective cap Label holder Legend label to clip into label holder 5.07.620.xxx Coupling Blanking cap Ring nut Lamp tester Protective cover, suitable for pushbuttons with flush lens Marking tag Insulating housing IP65 for RAFIX 22 QR Emergency stop label plate 2 - 140 2 - 140 2 - 141 2 - 142 2 - 142 2 - 143 2 - 143 2 - 143 2 - 144 2 - 144 2 - 144 2 - 145 2 - 145 2 - 146 2 - 146 2 - 84 Control components RAFIX 22 QR Contact blocks marked with different colours for ease of identification in stock and when connecting. • NC contacts: red • NO contacts: green • NC/NO contacts: red/green • Lamp socket: black • Silver contacts: basic housing colour is black • Gold contacts: basic housing colour is grey • The terminals associated with a contact pair are colour coded on the connection side and marked with the respective contact numbers. 2 ➭ The lamps of pushbuttons and signal lamps can be replaced from the front. This method saves time and increases safety since it eliminates the need for accessing the machine/ control station interior and handling live cables for lamp replacement. After unscrewing the front ring, the lens can be removed and the lamp replaced. cast-on collar seal RAFIX 22 QR The components feature a removable locating lug. If installed without locating lug, the ring nut with claw can be used. Accurate alignment of the actuator can be achieved behind the front panel. The cast-on collar seal can not get lost nor be twisted during installation and allows single-person assembly: the actuator is held in the mounting hole by the cast-on seal and can then be fixed by screwing from the rear. First, snap the lamp socket and contact blocks into the coupling. Then snap the assembly on to the actuator. To release it, the bayonet must be pressed (prevents inadvertent releasing at the same time). Control Components 2 - 85 RAFIX 22 QR 2 Terminals Assembly The RAFIX 22 QR contact blocks are available in different connection styles as required for your application: • Screw terminals The terminals are open and the captive screws are mounted in the terminal recess. • Quick connect/solder terminals 6.3 x 0.8 mm • Cage clamp terminals Simply insert a screwdriver to open the terminal, insert the cable and remove the screwdriver to close the terminal. • RJ 12-terminal Just plug in the cable with a RJ 12 connector. Screw terminals Your Cage clamp terminals Insert the wire. Open the terminal. Tighten the screw. Insert the wire. Done. Remove the screwdriver. advantage: This offers your savings in three ways: • Drastically reduced assembly time thanks to wire insertion from the rear, i. e. no more bending and lateral insertion of the wires required. • You save material: No wire end sleeves are required. • You save the time previously required for mounting the wire end sleeves. Sealed for life against humidity and dirt RAFIX 22 QR The special seal reliably prevents moisture, oil and dust from penetrating to the contact block. In contrast to other sealing types which move up and down the shaft, this special seal is firmly seated on the housing (degree of protection IP 65 to DIN). Versatility of design for customized panels The RAFIX 22 QR system does not only have a particularly low profile and is also available in many different versions. Your design options for your customized panels are nearly unlimited thanks to the interchangeable front rings and lenses. In this way you can achieve an attractive design while ensuring safe operation of your equipment at the same time. RAFIX 22 QR components are available either with a round or with a square collar. 2 - 86 Control Components RAFIX 22 QR The RAFIX 22 QR control component range meets all the technical requirements and current standards for control units. The system is of modular design. Actuators, contact blocks and lamp sockets can be combined freely. This means that you may implement modifications of design or configuration even at the last minute. An additional positive effect is the reduction of stockholding costs. Sequence of assembly/disassembly at screw, cage clamp and quick connect terminals • Fix the actuator in the front panel with the ring nut. • Snap the individual elements (a maximum three contact blocks or two contact blocks together with a lamp socket) in the coupling. You can install them on any assembling axis. • Insert the lamp or LED into the lamp socket. • Snap the coupling with the contact blocks on to the actuator. • Connect the cables. • Disassembly is performed in reverse order. To remove the coupling from the actuator, the latch lever must be pressed (by hand or with a screwdriver). 2 Assembly Disassembly ● = approved, ● = pending Approvals Part no. BG zert. VDE 0660 ULc GL 10/15 1.20 124.– – – ● ● ● ● ● 1.20 125.– – – ● ● ● ● ● 1.30 243.– – – ● ● 1.71 213.– – – ● ● ● ● 1.71 214.– – – ● ● ● ● 30.00 RAFIX 22 QR 50.00 Panel cut-out according to IEC 60947-5-1 All actuators are provided with a locating lug which may be removed using a screwdriver for installation into mounting holes if required. With a grid spacing of 30 mm horizontally and 50 mm vertically, the collars of the square actuators touch each other. We revommend to use the same grid spacing also for the round collar shapes (IEC 947). Dimensioned drawing Control Components 2 - 87 RAFIX 22 QR RAFIX 22 QR pushbutton Pict.: transparent green 2 Panel cut-out to IEC 60947-5-1 Technical data General information Form of lens Colour of lens Colout of front ring Form of collar RAFIX 22 QR with contact block Operating force max. see order block see order block see order block see order block Dimensions Length of collar Width of collar Overall height Mounting depth with contact block without cable Mounting hole Key grid Diameter of collar 56.4 mm 22.3 mm 50 x 30 mm see order block Mechanical design Mounting Contact function Illuminability ring nut see order block see order block Mechanical characteristics Operating travel Robustness min. Other specifications Operating life (operations) see order block see order block see order block Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment approx. 5 N for 1 switching element 100 N 1 million momentary/ 0.5 million latching IP65 -25 °C +70 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 4 mm Accessories RAFIX 22 QR pushbutton Description Photo Order no. Page RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, screw terminals, 1 NO 1.20.124.002/0000 2 - 126 RAFIX 22 QR contact block with silver contacts, with coupling and lamp socket, screw terminals, 1 NC + 1 NO 1.20.124.027/0000 2 - 127 RAFIX 22 QR contact block with gold contacts, with coupling and lamp socket, screw terminals, 1 NO 1.20.124.122/0000 2 - 131 RAFIX 22 QR contact block with silver contacts, with coupling and lamp socket, cage clamp terminals, 1 NO, 1 NC 1.20.125.025/0000 2 - 127 Contact block with RJ 12 connector, 2 NO, white LED 1.20.128.015/0000 2 - 133 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V 1.90.060.133/0000 5 - 8 LED BA 9s (MBC/MCC) superbright, white, 24 V 1.90.690.345/0000 5 - 19 2 - 88 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR Accessories RAFIX 22 QR pushbutton Description Photo Order no. Page Fixing spanner for ring nut and front ring 5.05.800.062/0000 5 - 23 Label holder, round collar, with adhesive tape and release liner on back 5.07.620.010/0000 2 - 143 For other contact blocks, refer to the chapter „Contact blocks“; for additional accessories, refer to „RAFIX 22 QR special accessories“. RAFIX 22 QR pushbutton, flush lens, round collar 2 29.80 21.80 M22x1.5 1...6mm 22.90 9.40 Pict.: transparent green Illuminability Colour of lens Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring yes transparent white 1.30.240.001/10xx 1.30.240.021/1000 1.30.240.011/10xx 1.30.240.031/1000 yes transparent red 1.30.240.001/13xx 1.30.240.021/1300 1.30.240.011/13xx 1.30.240.031/1300 yes transparent yellow 1.30.240.001/14xx 1.30.240.021/1400 1.30.240.011/14xx 1.30.240.031/1400 yes transparent green 1.30.240.001/15xx 1.30.240.021/1500 1.30.240.011/15xx 1.30.240.031/1500 yes transparent blue 1.30.240.001/16xx 1.30.240.021/1600 1.30.240.011/16xx 1.30.240.031/1600 no opaque black 1.30.240.101/01xx 1.30.240.121/0100 1.30.240.111/01xx 1.30.240.131/0100 no opaque white 1.30.240.101/02xx 1.30.240.121/0200 1.30.240.111/02xx 1.30.240.131/0200 no opaque red 1.30.240.101/03xx 1.30.240.121/0300 1.30.240.111/03xx 1.30.240.131/0300 no opaque yellow 1.30.240.101/04xx 1.30.240.121/0400 1.30.240.111/04xx 1.30.240.131/0400 no opaque green 1.30.240.101/05xx 1.30.240.121/0500 1.30.240.111/05xx 1.30.240.131/0500 no opaque blue 1.30.240.101/06xx 1.30.240.121/0600 1.30.240.111/06xx 1.30.240.131/0600 no opaque slate-grey 1.30.240.101/07xx 1.30.240.121/0700 1.30.240.111/07xx 1.30.240.131/0700 Technical data see page 2 - 88 Accessories: Front ring, plastic with thermoflex protective cap, black: 5.05.004.914/0100 Front ring, plastic with protective cap, slate grey: 5.05.004.914/0700 Front ring, plastic with thermoflex protective cap, silver grey: 5.05.004.914/0800 Schutzklappe, selbstschließend: 5.05.511.194/0000 Protective cover, latching: 5.05.511.195/0000 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Pushbuttons with plastic front ring and white lens are also available with the following front ring colours: red = 03, yellow = 04, green = 05, blue = 06. Other colour combinations on request. Order numbers 1.30.240.001/--08, 1.30.240.011/--08 and 1.30.240.101/--08 (with silver grey plastic front ring) are stock items. Control components Stock items are marked by bold printed order numbers. 2 - 89 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR pushbutton, protruding lens, round collar 29.80 22.00 M22x1.5 1...6mm 22.90 12.45 Pict.: transparent red Panel cut-out to IEC 60947-5-1 Illuminability Colour of lens 2 RAFIX 22 QR Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring yes transparent white 1.30.240.201/10xx 1.30.240.221/1000 1.30.240.211/10xx 1.30.240.231/1000 yes transparent red 1.30.240.201/13xx 1.30.240.221/1300 1.30.240.211/13xx 1.30.240.231/1300 yes transparent yellow 1.30.240.201/14xx 1.30.240.221/1400 1.30.240.211/14xx 1.30.240.231/1400 yes transparent green 1.30.240.201/15xx 1.30.240.221/1500 1.30.240.211/15xx 1.30.240.231/1500 yes transparent blue 1.30.240.201/16xx 1.30.240.221/1600 1.30.240.211/16xx 1.30.240.231/1600 no opaque black 1.30.240.301/01xx 1.30.240.321/0100 1.30.240.311/01xx 1.30.240.331/0100 no opaque white 1.30.240.301/02xx 1.30.240.321/0200 1.30.240.311/02xx 1.30.240.331/0200 no opaque red 1.30.240.301/03xx 1.30.240.321/0300 1.30.240.311/03xx 1.30.240.331/0300 no opaque yellow 1.30.240.301/04xx 1.30.240.321/0400 1.30.240.311/04xx 1.30.240.331/0400 no opaque green 1.30.240.301/05xx 1.30.240.321/0500 1.30.240.311/05xx 1.30.240.331/0500 no opaque blue 1.30.240.301/06xx 1.30.240.321/0600 1.30.240.311/06xx 1.30.240.331/0600 no opaque slate-grey 1.30.240.301/07xx 1.30.240.321/0700 1.30.240.311/07xx 1.30.240.331/0700 Technical data see page 2 - 88 Accessories: Legend insert without legend: 5.70.802.000/2000 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Pushbuttons with plastic front ring and white lens are also available with the following front ring colours: red = 03, yellow = 04, green = 05, blue = 06. Other colour combinations on request. Order numbers 1.30.240.201/--08 and 1.30.240.211/--08 (with silver grey plastic front ring) are stock items. 2 - 90 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR pushbutton, protruding front ring, round collar 24.30 29.80 M22x1.5 1...6mm 22.90 12.60 Pict.: transparent red Illuminability Colour of lens Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring yes transparent white 1.30.240.401/10xx 1.30.240.421/1000 - - yes transparent red 1.30.240.401/13xx 1.30.240.421/1300 - - yes transparent yellow 1.30.240.401/14xx 1.30.240.421/1400 - - yes transparent green 1.30.240.401/15xx 1.30.240.421/1500 - - yes transparent blue 1.30.240.401/16xx 1.30.240.421/1600 - - no opaque black 1.30.240.501/01xx 1.30.240.521/0100 - - no opaque white 1.30.240.501/02xx 1.30.240.521/0200 - - no opaque red 1.30.240.501/03xx 1.30.240.521/0300 - - no opaque yellow 1.30.240.501/04xx 1.30.240.521/0400 - - no opaque green 1.30.240.501/05xx 1.30.240.521/0500 - - no opaque blue 1.30.240.501/06xx 1.30.240.521/0600 - - no opaque slate-grey 1.30.240.501/07xx 1.30.240.521/0700 - - 2 RAFIX 22 QR Technical data see page 2 - 88 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 The protruding collar offers protection against inadvertent operation and thereby fulfils the safety requirements of various machinery manufacturers, particularly from the printing industry. Control components Stock items are marked by bold printed order numbers. 2 - 91 RAFIX 22 QR RAFIX 22 QR pushbutton, flush lens, square collar 29.80 21.80 M22x1.5 1...6mm 22.90 9.40 Pict.: transparent red Illuminability Colour of lens 2 RAFIX 22 QR Order no. momentary Panel cut-out to IEC 60947-5-1 Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring yes transparent white 1.30.240.051/10xx 1.30.240.071/1000 1.30.240.061/10xx 1.30.240.081/1000 yes transparent red 1.30.240.051/13xx 1.30.240.071/1300 1.30.240.061/13xx 1.30.240.081/1300 yes transparent yellow 1.30.240.051/14xx 1.30.240.071/1400 1.30.240.061/14xx 1.30.240.081/1400 yes transparent green 1.30.240.051/15xx 1.30.240.071/1500 1.30.240.061/15xx 1.30.240.081/1500 yes transparent blue 1.30.240.051/16xx 1.30.240.071/1600 1.30.240.061/16xx 1.30.240.081/1600 no opaque black 1.30.240.151/01xx 1.30.240.171/0100 1.30.240.161/01xx 1.30.240.181/0100 no opaque white 1.30.240.151/02xx 1.30.240.171/0200 1.30.240.161/02xx 1.30.240.181/0200 no opaque red 1.30.240.151/03xx 1.30.240.171/0300 1.30.240.161/03xx 1.30.240.181/0300 no opaque yellow 1.30.240.151/04xx 1.30.240.171/0400 1.30.240.161/04xx 1.30.240.181/0400 no opaque green 1.30.240.151/05xx 1.30.240.171/0500 1.30.240.161/05xx 1.30.240.181/0500 no opaque blue 1.30.240.151/06xx 1.30.240.171/0600 1.30.240.161/06xx 1.30.240.181/0600 no opaque slate-grey 1.30.240.151/07xx 1.30.240.171/0700 1.30.240.161/07xx 1.30.240.181/0700 Technical data see page 2 - 88 Accessories: Front ring, plastic with thermoflex protective cap, black: 5.05.004.914/0100 Front ring, plastic with protective cap, slate grey: 5.05.004.914/0700 Front ring, plastic with thermoflex protective cap, silver grey: 5.05.004.914/0800 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Pushbuttons with plastic front ring and white lens are also available with the following front ring colours: red = 03, yellow = 04, green = 05, blue = 06. Other colour combinations on request. Order numbers 1.30.240.051/--08, 1.30.240.061/--08 and 1.30.240.151/--08 (with silver grey plastic front ring) are stock items. 2 - 92 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR pushbutton, protruding lens, square collar 29.80 22.00 M22x1.5 1...6mm 22.90 12.45 Pict.: transparent red Illuminability Colour of lens Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring yes transparent white 1.30.240.251/10xx 1.30.240.271/1000 1.30.240.261/10xx 1.30.240.281/1000 yes transparent red 1.30.240.251/13xx 1.30.240.271/1300 1.30.240.261/13xx 1.30.240.281/1300 yes transparent yellow 1.30.240.251/14xx 1.30.240.271/1400 1.30.240.261/14xx 1.30.240.281/1400 yes transparent green 1.30.240.251/15xx 1.30.240.271/1500 1.30.240.261/15xx 1.30.240.281/1500 yes transparent blue 1.30.240.251/16xx 1.30.240.271/1600 1.30.240.261/16xx 1.30.240.281/1600 no opaque black 1.30.240.351/01xx 1.30.240.371/0100 1.30.240.361/01xx 1.30.240.381/0100 no opaque white 1.30.240.351/02xx 1.30.240.371/0200 1.30.240.361/02xx 1.30.240.381/0200 no opaque red 1.30.240.351/03xx 1.30.240.371/0300 1.30.240.361/03xx 1.30.240.381/0300 no opaque yellow 1.30.240.351/04xx 1.30.240.371/0400 1.30.240.361/04xx 1.30.240.381/0400 no opaque green 1.30.240.351/05xx 1.30.240.371/0500 1.30.240.361/05xx 1.30.240.381/0500 no opaque blue 1.30.240.351/06xx 1.30.240.371/0600 1.30.240.361/06xx 1.30.240.381/0600 no opaque slate-grey 1.30.240.351/07xx 1.30.240.371/0700 1.30.240.361/07xx 1.30.240.381/0700 Technical data see page 2 - 88 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Pushbuttons with plastic front ring and white lens are also available with the following front ring colours: red = 03, yellow = 04, green = 05, blue = 06. Other colour combinations on request. Order numbers 1.30.240.251/--08 and 1.30.240.261/--08 (with silver grey plastic front ring) are stock items. Control components Stock items are marked by bold printed order numbers. 2 - 93 2 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR pushbutton, protruding front ring, square collar 24.30 29.80 M22x1.5 1...6mm 22.90 12.60 Pict.: transparent green Illuminability Colour of lens 2 RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring yes transparent white 1.30.240.451/10xx 1.30.240.471/1000 - - yes transparent red 1.30.240.451/13xx 1.30.240.471/1300 - - yes transparent yellow 1.30.240.451/14xx 1.30.240.471/1400 - - yes transparent green 1.30.240.451/15xx 1.30.240.471/1500 - - yes transparent blue 1.30.240.451/16xx 1.30.240.471/1600 - - no opaque black 1.30.240.551/01xx 1.30.240.571/0100 - - no opaque white 1.30.240.551/02xx 1.30.240.571/0200 - - no opaque red 1.30.240.551/03xx 1.30.240.571/0300 - - no opaque yellow 1.30.240.551/04xx 1.30.240.571/0400 - - no opaque green 1.30.240.551/05xx 1.30.240.571/0500 - - no opaque blue 1.30.240.551/06xx 1.30.240.571/0600 - - no opaque slate-grey 1.30.240.551/07xx 1.30.240.571/0700 - - Technical data see page 2 - 88 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 The protruding collar offers protection against inadvertent operation and thereby fulfils the safety requirements of various machinery manufacturers, particularly in the industry. 2 - 94 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR selector switch Pict.: Front ring, black, non-illuminated 2 Front ring, metallized, illuminated Panel cut-out to IEC 60947-5-1 General data The illuminated selector switches are provided with translucent handle markings. These are opaque on the non-illuminated versions. Technical data RAFIX 22 QR General information Actuator Marking of handle Colout of front ring Form of collar Dimensions Length of collar Width of collar Overall height Mounting depth with contact block without cable Mounting hole Key grid Diameter of collar Mechanical design Mounting Contact function Illuminability Rotating angle Mechanical characteristics Operating force max. Torque max. Electrical characteristics Protection class handle white see order block see order block Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment see order block see order block 22.2 mm 56.4 mm 22.3 mm 50 x 30 mm see order block Resistance at variable environment ring nut see order block see order block see order block II 0.5 million IP65 -27 °C +70 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 approx. 5 N for 1 switching element 2 Nm Accessories RAFIX 22 QR selector switch Description Photo Order no. Page RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, screw terminals, 1 NC + 1 NO 1.20.124.017/0000 2 - 126 RAFIX 22 QR contact block with silver contacts, with coupling and lamp socket, screw terminals, 1 NC + 1 NO 1.20.124.027/0000 2 - 127 RAFIX 22 QR contact block with gold contacts, with coupling and lamp socket, screw terminals, 1 NC + 1 NO, 1 NC + 1 NO 1.20.124.128/0000 2 - 131 Contact block with coupling, gold contacts, RJ 12 connector, 1 NC + 1 NO, white LED 1.20.128.013/0000 2 - 133 2 - 96 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR Accessories RAFIX 22 QR selector switch Description Photo Order no. Label holder, round collar, with adhesive tape and release liner on back Page 5.07.620.010/0000 2 - 143 For other contact blocks, refer to the chapter „Contact blocks“; for additional accessories, refer to „RAFIX 22 QR special accessories“. RAFIX 22 QR selector switch, round collar, short handle 2 Pict.: Front ring, silver grey, non-illuminated Illuminability Contact function Panel cut-out to IEC 60947-5-1 Rotating angle Rotating angle Order no. Plastic front ring Metal front ring no momentary 1 x 40° 1Ö + 1S 1.30.242.501/02xx 1.30.242.502/0200 no momentary 2 x 40° 1Ö + 1S 1.30.242.526/02xx 1.30.242.527/0200 no latching 1 x 90°, form L 1Ö + 1S 1.30.242.601/02xx 1.30.242.602/0200 no latching 1 x 90°, form V 1Ö + 1S 1.30.242.701/02xx 1.30.242.702/0200 no latching 2 x 60° 1Ö + 1S 1.30.242.801/02xx 1.30.242.802/0200 no latching 2 x 90° 1Ö + 1S 1.30.242.626/02xx 1.30.242.627/0200 yes momentary 1 x 40° 1Ö + 1S 1.30.242.001/22xx 1.30.242.002/2200 yes momentary 2 x 40° 1Ö + 1S 1.30.242.026/22xx 1.30.242.027/2200 yes latching 1 x 90°, form L 1Ö + 1S 1.30.242.101/22xx 1.30.242.102/2200 yes latching 1 x 90°, form V 1Ö + 1S 1.30.242.201/22xx 1.30.242.202/2200 yes latching 2 x 60° 1Ö + 1S 1.30.242.301/22xx 1.30.242.302/2200 yes latching 2 x 90° 1Ö + 1S 1.30.242.126/22xx 1.30.242.127/2200 Technical data see page 2 - 96 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08; other colours on request. Included: Ring nut with claw. Other contact versions on request On keylock switches with 3 switching positions (e.g. 2 x 90 degrees), either the left-hand or right-hand contact block is activated, depending on the sense of rotation. A third contact block arranged in the centre would be actuated with either sense of rotation. The following selector switches with silver grey plastic front ring are stock items: Illuminated: 1.30.252.001/2208, 1.30.252.026/2208, 1.30.252.101/2208, 1.30.252.201/2208, 1.30.252.301/2208 Non-illuminated: 1.30.252.501/0208, 1.30.252.526/0208, 1.30.252.601/0208, 1.30.252.701/0208, 1.30.252.801/0208 Control components Stock items are marked by bold printed order numbers. 2 - 97 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR selector switch, round collar, long handle 29.80 M 22x1.5 1...6 9.10 22.90 22.20 Pict.: Front ring, metallized, illuminated Illuminability Contact function 2 RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Rotating angle Rotating angle Order no. Plastic front ring Metal front ring no momentary 1 x 40° 1Ö + 1S 1.30.242.511/02xx 1.30.242.512/0200 no momentary 2 x 40° 1Ö + 1S 1.30.242.536/02xx 1.30.242.537/0200 no latching 1 x 90°, form L 1Ö + 1S 1.30.242.611/02xx 1.30.242.612/0200 no latching 1 x 90°, form V 1Ö + 1S 1.30.242.711/02xx 1.30.242.712/0200 no latching 2 x 60° 1Ö + 1S 1.30.242.811/02xx 1.30.242.812/0200 no latching 2 x 90° 1Ö + 1S 1.30.242.636/02xx 1.30.242.637/0200 yes momentary 1 x 40° 1Ö + 1S 1.30.242.011/22xx 1.30.242.012/2200 yes momentary 2 x 40° 1Ö + 1S 1.30.242.036/22xx 1.30.242.037/2200 yes latching 1 x 90°, form L 1Ö + 1S 1.30.242.111/22xx 1.30.242.112/2200 yes latching 1 x 90°, form V 1Ö + 1S 1.30.242.211/22xx 1.30.242.212/2200 yes latching 2 x 60° 1Ö + 1S 1.30.242.311/22xx 1.30.242.312/2200 yes latching 2 x 90° 1Ö + 1S 1.30.242.136/22xx 1.30.242.137/2200 Technical data see page 2 - 96 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08; other colours on request. Included: Ring nut with claw. At selector switches with 3 switching positions (e.g. 2 x 90 degrees), either the left-hand or right-hand contact block is activated, depending on the sense of rotation. A third contact block arranged in the centre would be actuated with either sense of rotation. Other contact versions on request. 2 - 98 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR selector switch, square collar, short handle Pict.: Front ring, red, non-illuminated Illuminability Contact function Panel cut-out to IEC 60947-5-1 Rotating angle Rotating angle Order no. Plastic front ring Metal front ring no momentary 1 x 40° 1Ö + 1S 1.30.242.551/02xx 1.30.242.552/0200 no momentary 2 x 40° 1Ö + 1S 1.30.242.576/02xx 1.30.242.577/0200 no latching 1 x 90°, form L 1Ö + 1S 1.30.242.651/02xx 1.30.242.652/0200 no latching 1 x 90°, form V 1Ö + 1S 1.30.242.751/02xx 1.30.242.752/0200 no latching 2 x 60° 1Ö + 1S 1.30.242.851/02xx 1.30.242.852/0200 no latching 2 x 90° 1Ö + 1S 1.30.242.676/02xx 1.30.242.677/0200 yes momentary 1 x 40° 1Ö + 1S 1.30.242.051/22xx 1.30.242.052/2200 yes momentary 2 x 40° 1Ö + 1S 1.30.242.076/22xx 1.30.242.077/2200 yes latching 1 x 90°, form L 1Ö + 1S 1.30.242.151/22xx 1.30.242.152/2200 yes latching 1 x 90°, form V 1Ö + 1S 1.30.242.251/22xx 1.30.242.252/2200 yes latching 2 x 60° 1Ö + 1S 1.30.242.351/22xx 1.30.242.352/2200 yes latching 2 x 90° 1Ö + 1S 1.30.242.176/22xx 1.30.242.177/2200 Technical data see page 2 - 96 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08; other colours on request. Included: Ring nut with claw. At selector switches with 3 switching positions (e.g. 2 x 90 degrees), either the left-hand or right-hand contact block is activated, depending on the sense of rotation. A third contact block arranged in the centre would be actuated with either sense of rotation. Other contact versions on request. The following selector switches with silver grey plastic front ring are stock items: Illuminated: 1.30.242.051/2208, 1.30.242.076/2208, 1.30.242.151/2208, 1.30.242.251/2208, 1.30.242.351/2208 Non-illuminated: 1.30.242.551/0208, 1.30.242.576/0208, 1.30.242.651/0208, 1.30.242.751/0208, 1.30.242.851/0208 Control components Stock items are marked by bold printed order numbers. 2 - 99 2 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR selector switch, square collar, long handle Pict.: Front ring, black, non-illuminated Illuminability Contact function 2 RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Rotating angle Rotating angle Order no. Plastic front ring Metal front ring no momentary 1 x 40° 1Ö + 1S 1.30.242.561/02xx 1.30.242.562/0200 no momentary 2 x 40° 1Ö + 1S 1.30.242.586/02xx 1.30.242.587/0200 no latching 1 x 90°, form L 1Ö + 1S 1.30.242.661/02xx 1.30.242.662/0200 no latching 1 x 90°, form V 1Ö + 1S 1.30.242.761/02xx 1.30.242.762/0200 no latching 2 x 60° 1Ö + 1S 1.30.242.861/02xx 1.30.242.862/0200 no latching 2 x 90° 1Ö + 1S 1.30.242.686/02xx 1.30.242.687/0200 yes momentary 1 x 40° 1Ö + 1S 1.30.242.061/22xx 1.30.242.062/2200 yes momentary 2 x 40° 1Ö + 1S 1.30.242.086/22xx 1.30.242.087/2200 yes latching 1 x 90°, form L 1Ö + 1S 1.30.242.161/22xx 1.30.242.162/2200 yes latching 1 x 90°, form V 1Ö + 1S 1.30.242.261/22xx 1.30.242.262/2200 yes latching 2 x 60° 1Ö + 1S 1.30.242.361/22xx 1.30.242.362/2200 yes latching 2 x 90° 1Ö + 1S 1.30.242.186/22xx 1.30.242.187/2200 Technical data see page 2 - 96 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08; other colours on request. Included: Ring nut with claw. At selector switches with 3 switching positions (e.g. 2 x 90 degrees), either the left-hand or right-hand contact block is activated, depending on the sense of rotation. A third contact block arranged in the centre would be actuated with either sense of rotation. Other contact versions on request. 2 - 100 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR keylock switch Pict.: Front ring, metallized 2 Panel cut-out to IEC 60947-5-1 Technical data General information Form of lens Colout of front ring Form of collar RAFIX 22 QR operating element and contact block Dimensions Length of collar Width of collar Overall height Mounting depth with contact block without cable Mounting hole Key grid Diameter of collar Mechanical design Mounting Contact function Illuminability Lock Wafers Lock type Main key Symmetric key Rotating angle Key removal position Mechanical characteristics Operating force max. see order block see order block see order block see order block see order block 30.6 mm Torque max. approx. 5 N for 1 switching element 2 Nm Electrical characteristics Protection class II Other specifications Operating life 56.4 mm 22.3 mm 50 x 30 mm see order block Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment ring nut see order block no Ronis 4 455 no no see order block see order block Resistance at variable environment 0.3 million momentary / 50000 latching IP65 -25 ° +70 ° -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR keylock switch Description Photo Order no. Page RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, screw terminals, 1 NC + 1 NO 1.20.124.017/0000 2 - 126 RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, cage clamp terminals, 1 NO 1.20.125.002/0000 2 - 126 Contact block with coupling, gold contacts, RJ 12 connector, 1 NC + 1 NO, without LED 1.20.128.003/0000 2 - 133 Label holder, round collar, with adhesive tape and release liner on back 5.07.620.010/0000 2 - 143 Spare key for RAFIX 22 QR 5.58.017.001/0000 For other contact blocks, refer to the chapter „Contact blocks“; for additional accessories, refer to „RAFIX 22 QR special accessories“. 2 - 102 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR keylock switch, round collar Pict.: Front ring, metallized Contact function Rotating angle Panel cut-out to IEC 60947-5-1 Key removal position Rotating angle Order no. Plastic front ring Metal front ring momentary 1 x 40° 0 1Ö + 1S 1.30.245.001/xxxx 1.30.245.002/0000 momentary 2 x 40° 0 1Ö + 1S 1.30.245.101/xxxx 1.30.245.102/0000 latching 1 x 90°, form L 0 1Ö + 1S 1.30.245.201/xxxx 1.30.245.202/0000 latching 1 x 90°, form L 0+1 1Ö + 1S 1.30.245.221/xxxx 1.30.245.222/0000 latching 1 x 90°, form V 0 1Ö + 1S 1.30.245.301/xxxx 1.30.245.302/0000 latching 1 x 90°, form V 0+1 1Ö + 1S 1.30.245.321/xxxx 1.30.245.322/0000 latching 2 x 60° 0+1+2 1Ö + 1S 1.30.245.731/xxxx 1.30.245.732/0000 latching 2 x 90° 0 1Ö + 1S 1.30.245.401/xxxx 1.30.245.402/0000 latching 2 x 90° 0+1+2 1Ö + 1S 1.30.245.431/xxxx 1.30.245.432/0000 Technical data see page 2 - 102 xxxx = Front ring colour: black = 0100, slate grey = 0700, silver grey = 0800. Other versions on request. Other versions on request. Included: Ring nut with claw. On selector switches with 3 switching positions (e.g. 2 x 90 degrees), either the left-hand or right-hand contact block is activated, depending on the sense of rotation. A third contact block arranged in the centre would be actuated with either sense of rotation. The following keylock switches with silver grey plastic front ring are stock items: 1.30.245.001/0800, 1.30.245.201/0800, 1.30.245.221/0800, 1.30.245.301/0800, 1.30.245.321/0800, 1.30.245.731/0800 Control components Stock items are marked by bold printed order numbers. 2 - 103 2 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR keylock switch, square collar Pict.: Front ring, metallized Contact function 2 RAFIX 22 QR Rotating angle Panel cut-out to IEC 60947-5-1 Key removal position Rotating angle Order no. Plastic front ring Metal front ring momentary 1 x 40° 0 1Ö + 1S 1.30.245.051/xxxx 1.30.245.052/0000 momentary 2 x 40° 0 1Ö + 1S 1.30.245.151/xxxx 1.30.245.152/0000 latching 1 x 90°, form L 0 1Ö + 1S 1.30.245.251/xxxx 1.30.245.252/0000 latching 1 x 90°, form L 0+1 1Ö + 1S 1.30.245.271/xxxx 1.30.245.272/0000 latching 1 x 90°, form V 0 1Ö + 1S 1.30.245.351/xxxx 1.30.245.352/0000 latching 1 x 90°, form V 0+1 1Ö + 1S 1.30.245.371/xxxx 1.30.245.372/0000 latching 2 x 60° 0+1+2 1Ö + 1S 1.30.245.781/xxxx 1.30.245.782/0000 latching 2 x 90° 0 1Ö + 1S 1.30.245.451/xxxx 1.30.245.452/0000 latching 2 x 90° 0+1+2 1Ö + 1S 1.30.245.481/xxxx 1.30.245.482/0000 Technical data see page 2 - 102 xxxx = Front ring colour: black = 0100, slate grey = 0700, silver grey = 0800. Other versions on request. Included: Ring nut with claw. On keylock switches with 3 switching positions (e.g. 2 x 90 degrees), either the left-hand or right-hand contact block is activated, depending on the sense of rotation. A third contact block arranged in the centre would be actuated with either sense of rotation. The following keylock switches with silver grey plastic front ring are stock items: 1.30.245.051/0800, 1.30.245.251/0800, 1.30.245.271/0800, 1.30.245.351/0800, 1.30.245.371/0800, 1.30.245.781/0800 2 - 104 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR mushroom-headed pushbutton Pict.: Front ring, metallized 2 Panel cut-out to IEC 60947-5-1 Technical data General information Actuator Colour of mushroom Colout of front ring Form of collar RAFIX 22 QR Front ring, slate grey Mechanical characteristics Operating force max. mushroom see order block see order block see order block Dimensions Length of collar Width of collar Overall height Mounting depth Mounting hole Key grid Diameter of collar see order block see order block 20.10 mm 56.4 mm 22.3 mm 50 x 30 mm see order block Mechanical design Mounting Contact function Illuminability ring nut see order block see order block Robustness min. approx. 5 N for 1 switching element 100 N Electrical characteristics Protection class II Other specifications Operating life Degree of protection from front side Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 1,000,000 IP65 -40 °C 80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR mushroom-headed pushbutton Description Photo Order no. Page RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, screw terminals, 1 NC + 1 NO 1.20.124.017/0000 2 - 126 RAFIX 22 QR contact block with gold contacts, with coupling, without lamp socket, cage clamp terminals, 1 NO 1.20.125.102/0000 2 - 130 Contact block with coupling, gold contacts, RJ 12 connector, 1 NO, without LED 1.20.128.002/0000 2 - 133 Fixing spanner for ring nut and front ring 5.05.800.062/0000 5 - 23 For other contact blocks, refer to the chapter „Contact blocks“; for additional accessories, refer to „RAFIX 22 QR special accessories“. 2 - 106 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR mushroom-headed pushbutton 40 mm, round collar Pict.: Front ring, metallized Illuminability Colour of mushroom Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring no opaque black 1.30.246.501/01xx 1.30.246.502/0100 1.30.246.511/01xx 1.30.246.512/0100 no opaque red 1.30.246.501/03xx 1.30.246.502/0300 1.30.246.511/03xx 1.30.246.512/0300 2 Technical data see page 2 - 106 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Order number 1.30.246.501/0308 (with silver grey plastic front ring) is a stock item. RAFIX 22 QR mushroom-headed pushbutton 40 mm, illuminated, round collar RAFIX 22 QR Pict.: Front ring, slate grey Illuminability Colour of mushroom yes opaque red/ transparent red Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring 1.30.246.001/03xx 1.30.246.002/0300 1.30.246.011/03xx 1.30.246.012/0300 Technical data see page 2 - 106 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Order number 1.30.246.001/0308 (with silver grey plastic front ring) is a stock item. Control components Stock items are marked by bold printed order numbers. 2 - 107 RAFIX 22 QR RAFIX 22 QR mushroom-headed pushbutton 60 mm, round collar Pict.: Front ring, metallized Illuminability Colour of mushroom no 2 opaque red Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring 1.30.246.601/03xx 1.30.246.602/0300 - - Technical data see page 2 - 106 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 RAFIX 22 QR mushroom-headed pushbutton 40 mm, square collar RAFIX 22 QR Pict.: Front ring, slate grey Illuminability Colour of mushroom Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring no opaque black 1.30.246.551/01xx 1.30.246.552/0100 1.30.246.561/01xx 1.30.246.562/0100 no opaque red 1.30.246.551/03xx 1.30.246.552/0300 1.30.246.561/03xx 1.30.246.562/0300 Technical data see page 2 - 106 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Order number 1.30.246.551/0308 (with silver grey plastic front ring) is a stock item. 2 - 108 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR mushroom-headed pushbutton 40 mm, illuminated, square collar Pict.: Front ring, slate grey Illuminability Colour of mushroom yes opaque red/ transparent red Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring 1.30.246.051/03xx 1.30.246.052/0300 1.30.246.061/03xx 1.30.246.062/0300 2 Technical data see page 2 - 106 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Order number 1.30.246.051/0308 (with silver grey plastic front ring) is a stock item. RAFIX 22 QR mushroom-headed pushbutton 60 mm, square collar RAFIX 22 QR Pict.: Front ring, slate grey Illuminability Colour of mushroom no opaque red Panel cut-out to IEC 60947-5-1 Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring 1.30.246.651/03xx 1.30.246.652/0300 - - Technical data see page 2 - 106 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Control components Stock items are marked by bold printed order numbers. 2 - 109 RAFIX 22 QR RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 Panel cut-out to IEC 60947-5-1 2 General data The emergency stop pushbuttons comply with IEC 60 204, IEC 60 073, IEC 60 947 and VDE 0113 Part 1. They are designed dupe-proof according to EN 418 with a positive mechanical movement sequence. A certain operating force must be exerted at the action point in order to prevent inadvertent operation.The pushbutton latches when pressed. The special shape of the actuator prevents the emergency stop pushbutton from being blocked. This means that the emergency stop process - once initiated - cannot be impeded by any jamming objects. Technical data RAFIX 22 QR General information Actuator Colour of mushroom Form of collar Mechanical characteristics Operating force max. mushroom see order block round Dimensions Overall height Mounting depth with contact block without cable Mounting hole Key grid Diameter of collar see order block see order block 50 x 30 mm see order block Mechanical design Mounting Contact function Illuminability Reset ring nut latching see order block see order block Robustness min. Robustness Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment see order block Resistance at variable environment approx. 5 N for 1 switching element 100 N acc. IEC 60947-5-5 see order block see order block -25 °C +70 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 Description Photo Order no. Page RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, screw terminals, 1 NC 1.20.124.001/0000 2 - 126 RAFIX 22 QR contact block with silver contacts, with coupling, without lamp socket, screw terminals, 2 NC 1.20.124.019/0000 2 - 126 Fixing spanner for ring nut and front ring 5.05.800.062/0000 5 - 23 2 - 110 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR Accessories RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 Description Photo Order no. Page Emergency stop label, yellow, round 60 mm, PVC adhesive, without legend 5.76.204.100/0400 2 - 146 Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend „NOT-AUS“ 5.76.204.101/0400 2 - 146 Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend „ARRET D’URGENCE“ 5.76.204.102/0400 2 - 146 Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend „EMERGENCY-STOP“ 5.76.204.103/0400 2 - 146 Emergency stop label, yellow 36 x 64 mm, PVC adhesive, without legend 5.76.205.011/0400 2 - 146 Emergency stop label, yellow, round 60 mm, rigid PVC, with legend „EMERGENCY-STOP/ARRET D’URGENCE“ 5.76.207.002/0400 2 - 146 2 For other contact blocks, refer to the chapter „Contact blocks“; for additional accessories, refer to „RAFIX 22 QR special accessories“. RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Degree of protection Reset from front side Colour of mushroom Illuminability Operating life Order no. IP65 opaque red 100000 1.30.243.501/0300 by clockwise rotation no Technical data see page 2 - 110 Included: Ring nut with claw. Switching position indication: In the non-operated condition, a green ring is visible on the side. Control components Stock items are marked by bold printed order numbers. 2 - 111 RAFIX 22 QR RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, with indication to EN 60947-1 Panel cut-out to IEC 60947-5-1 2 Degree of protection Reset from front side Colour of mushroom Illuminability Operating life Order no. IP65 opaque red 100000 1.30.243.601/0300 by clockwise rotation no Technical data see page 2 - 110 Included: Ring nut with claw. Switching position indication: In the non-operated condition, a green ring is visible on the side. This switching position is visible in addition from the front; a mechanical indicator integrated into the mushroom head changes from green to red when actuated. RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, with keylock RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Degree of protection Reset from front side Colour of mushroom Illuminability Operating life Order no. IP40 opaque red 50000 1.30.243.701/0300 by clockwise rotation no Technical data see page 2 - 110 Accessories: Spare key for RAFIX 22 QR: 5.58.017.001/0000 Included: Ring nut with claw, 2 keys. Switching position indication: In the non-operated condition, a green ring is visible on the side. Once actuated, the emergency stop pushbutton can only be reset with the key. 2 - 112 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418, illuminated Panel cut-out to IEC 60947-5-1 Degree of protection Reset from front side Colour of mushroom Illuminability Operating life Order no. IP65 opaque red/ translucent red 100000 1.30.243.001/0300 by clockwise rotation yes 2 Technical data see page 2 - 110 Included: Ring nut with claw. Switching position indication: In the non-operated condition, a green ring is visible on the side. NEW RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418 RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Degree of protection Reset from front side Colour of mushroom Illuminability Operating life Order no. IP65 opaque red 100000 1.30.243.901/0300 by pulling no Technical data see page 2 - 110 Included: Ring nut with claw. Switching position indication: In the non-operated condition, a green ring is visible on the side. Control components Stock items are marked by bold printed order numbers. 2 - 113 RAFIX 22 QR RAFIX 22 QR toggle switch Ø/ M 22 x1 29.80 1 ... 6mm 22.70 9.40 ca. 22.20 Pict.: Front ring, metallized 2 RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Technical data General information Form of lens Colour of toggle Front ring Form of collar toggle opaque white see order block see order block Dimensions Length of collar Witdth of collar Overall height Mounting depth Mounting hole see order block see order block 22 mm 56.4 mm 22.3 mm Mechanical design Mounting 50 x 30 mm see order block Mechanical design Contact function Illmuniabilitiy latching no 100 N Electrical characteristics Protection class II Other specifications Operating life Degree of protection Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment ring nut Dimensions Key grid Diameter of collar Mechanical characteristics Robustness min. 100000 IP54 -40 °C 80 °C according to IEC 60068-2-3 and 2-30 according to IEC 60068-2-14 and 2-33 Accessories RAFIX 22 QR toggle switch Description Photo Order no. Page RAFIX 22 QR contact block with gold contacts, with coupling, without lamp socket, screw terminals, 1 NC + 1 NO 1.20.124.117/0000 2 - 130 RAFIX 22 QR contact block with gold contacts, with coupling, without lamp socket, cage clamp terminals, 1 NO 1.20.125.102/0000 2 - 130 Contact block with coupling, gold contacts, RJ 12 connector, 1 NO, without LED 1.20.128.002/0000 2 - 133 Fixing spanner for ring nut and front ring 5.05.800.062/0000 5 - 23 2 - 114 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR NEW RAFIX 22 QR, toggle switch, round collar Ø/ M 22 x1 29.80 1 ... 6mm 22.70 9.40 ca. 22.20 Pict.: Front ring, slate grey Panel cut-out to IEC 60947-5-1 Illuminability Colour of toggle no opaque white Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring - - 1.30.247.501/02xx 1.30.247.502/0200 2 Technical data see page 2 - 114 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 RAFIX 22 QR, toggle switch, square collar 29.80 1 ... 6mm 22.70 9.40 ca. 22.20 Pict.: Front ring, metallized Panel cut-out to IEC 60947-5-1 Illuminability Colour of toggle no opaque white RAFIX 22 QR Ø/ M 22 x1 NEW Order no. momentary Order no. latching Plastic front ring Metallized front ring Plastic front ring Metallized front ring - - 1.30.247.551/02xx 1.30.247.552/0200 Technical data see page 2 - 114 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Control components Stock items are marked by bold printed order numbers. 2 - 115 RAFIX 22 QR RAFIX 22 QR twin pushbutton Ø22.30 +0.40 Pict.: illuminated 2 General data Lens legends are oriented for vertical installation of the twin pushbutton. Only the signal indicator is illuminated on twin pushbuttons prepared for illumination. This area is opaque slate grey on versions which cannot be illuminated. Technical data RAFIX 22 QR General information Legending Colour of lens Colout of front ring Form of collar Dimensions Length of collar Width of collar Overall height Mounting depth with contact block without cable Mounting hole Key grid Mechanical design Mounting Contact function Illuminability see order block opaque green/opaque red see order block see order block Mechanical characteristics Operating force max. Robustness min. Other specifications Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature max. Resistance to constant environment 59.6 mm 29.8 mm 9.1 mm 56.4 mm 22.3 mm 50 x 30 mm Resistance at variable environment ring nut momentary see order block approx. 5 N for 1 switching element 100 N IP65 -25 °C +70 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR twin pushbutton Description Photo Order no. Page RAFIX 22 QR contact block with silver contacts, with coupling and lamp socket, screw terminals, 1 NO, 1 NC 1.20.124.025/0000 2 - 127 RAFIX 22 QR contact block with gold contacts, with coupling and lamp socket, cage clamp terminals, 1 NO, 1 NC 1.20.125.125/0000 2 - 131 Fixing spanner for ring nut and front ring 5.05.800.062/0000 5 - 23 For other contact blocks, refer to the chapter "Contact blocks"; for additional accessories, refer to "RAFIX 22 QR special accessories". 2 - 116 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR twin pushbutton, oval collar Ø22.30 +0.40 Pict.: illuminated Illuminability Colour of lens Legending Order no. Plastic front ring Metal front ring yes opaque green/opaque red none 1.30.241.001/22xx 1.30.241.021/2200 yes opaque green/opaque red red 0, green I 1.30.241.002/22xx 1.30.241.022/2200 no opaque green/opaque red none 1.30.241.101/07xx 1.30.241.121/0700 no opaque green/opaque red red 0, green I 1.30.241.102/07xx 1.30.241.122/0700 2 Technical data see page 2 - 116 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Either the left-hand or right-hand contact block is actuated, depending on the button pressed. For illuminated versions the centre position of the coupling is reserved for the lamp socket. A third contact block arranged in the centre would be actuated by either button. RAFIX 22 QR RAFIX 22 QR twin pushbutton, rectangular collar Ø22.30 +0.40 Pict.: non-illuminated Illuminability Colour of lens Legending Order no. Plastic front ring Metal front ring yes opaque green/opaque red none 1.30.241.051/22xx 1.30.241.071/2200 yes opaque green/opaque red red 0, green I 1.30.241.052/22xx 1.30.241.072/2200 no opaque green/opaque red none 1.30.241.151/07xx 1.30.241.171/0700 no opaque green/opaque red red 0, green I 1.30.241.152/07xx 1.30.241.172/0700 Technical data see page 2 - 116 xx = Front ring colour: black = 01, slate grey = 07, silver grey = 08 Either the left-hand or right-hand contact block is actuated, depending on the button pressed. For illuminated versions the centre position of the coupling is reserved for the lamp socket. A third contact block arranged in the centre would be actuated by either button. Control components Stock items are marked by bold printed order numbers. 2 - 117 RAFIX 22 QR RAFIX 22 QR potentiometer drive 34.30 26.20 Ø M 22 x1 29.80 17.00 1 ... 6 Pict.: slate grey with potentiometer 2 Technical data General information Actuator Colour of handle Front ring Form of collar RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Dimensions Length of collar Width of collar Overall height Mounting depth Mechanical characteristics Robustness min. knob size see order block see order block see order block Mounting hole Key grid Diameter of collar see order block see order block 26 mm according to potentiometer 22.3 mm 50 x 30 mm see order block Mechanical design Mounting ring nut Other specifications Degree of protection from front side Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 100 N IP65 -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR potentiometer drive Description Photo Fixing spanner for ring nut and front ring 2 - 118 Order no. Page 5.05.800.062/0000 5 - 23 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR potentiometer drive, round collar 34.30 26.20 Ø M 22 x1 29.80 17.00 1 ... 6 Pict.: slate grey with potentiometer Panel cut-out to IEC 60947-5-1 Front ring Colour of handle Order no. metal opaque slate-grey 1.30.248.051/0000 plastic slate-grey opaque slate-grey 1.30.248.001/0700 plastic silber opaque slate-grey 1.30.248.001/0800 metal opaque black 1.30.248.061/0000 plastic slate-grey opaque black 1.30.248.011/0700 plastic silber opaque black 1.30.248.011/0800 Technical data see page 2 - 118 RAFIX 22 QR For potentiometers with 6 mm shaft diameter and 50 mm shaft length. Potentiometer not included. RAFIX 22 QR potentiometer drive, square collar 34.30 26.20 Ø 22.00 29.80 17.00 1 ... 6 Pict.: state grey, delivery content Panel cut-out to IEC 60947-5-1 Front ring Colour of handle Order no. metal opaque slate-grey 1.30.248.071/0000 plastic slate-grey opaque slate-grey 1.30.248.021/0700 plastic silber opaque slate-grey 1.30.248.021/0800 metal opaque black 1.30.248.081/0000 plastic slate-grey opaque black 1.30.248.031/0700 plastic silber opaque black 1.30.248.031/0800 Technical data see page 2 - 118 For potentiometers with 6 mm shaft diameter and 50 mm shaft length. Potentiometer not included. Control components Stock items are marked by bold printed order numbers. 2 2 - 119 RAFIX 22 QR RAFIX 22 QR buzzer Panel cut-out to IEC 60947-5-1 2 Technical data General information Form of lens Colour of lens Form of collar Sound RAFIX 22 QR Dimensions Length of collar Width of collar Overall height Mounting depth Mounting hole Key grid Diameter of collar Mechanical design Mounting Acoustic characteristics Sonic pressure, 1 m distance min. flat lens opaque slate-grey see order block see order block see order block see order block 9.8 mm 56.4 mm 22.3 mm 50 x 30 mm see order block ring nut Electrical characteristics Operating voltage DC Input current Sound frequency see order block see order block see order block Mechanical characteristics Robustness min. 100 N Other specifications Degree of protection from front side Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment IP65 -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 see order block Accessories RAFIX 22 QR buzzer Description Photo Fixing spanner for ring nut and front ring 2 - 120 Order no. Page 5.05.800.062/0000 5 - 23 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR buzzer, round collar Panel cut-out to IEC 60947-5-1 Operating voltage DC Input current Sound Sonic pressure, 1 m distance min. Sound frequency 12 V 25 mA continuos beep 70 dB 1.30.249.002/0000 24 V 25 mA continuos beep 70 dB 1.30.249.001/0000 Order no. 2 Technical data see page 2 - 120 RAFIX 22 QR buzzer, square collar RAFIX 22 QR Panel cut-out to IEC 60947-5-1 Operating voltage DC Input current Sound Sonic pressure, 1 m distance min. Sound frequency 12 V 25 mA continuos beep 70 dB 1.30.249.022/0000 24 V 25 mA continuos beep 70 dB 1.30.249.021/0000 Order no. Technical data see page 2 - 120 Control components Stock items are marked by bold printed order numbers. 2 - 121 RAFIX 22 QR RAFIX 22 QR signal indicator Pict.: yellow 2 RAFIX 22 QR red Panel cut-out to IEC 60947-5-1 Technical data General information Form of lens Colour of lens Form of collar flat lens see order block see order block Dimensions Length of collar Width of collar Overall height Mounting depth Mounting hole Key grid Diameter of collar see order block see order block 9.4 mm 56.4 mm 22.3 mm 50 x 30 mm see order block Mechanical design Mounting Illuminability Electrical characteristics Protection class Other specifications Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment ring nut yes II IP65 -25 °C +70 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR signal indicator Description Photo Order no. Page RAFIX 22 QR lamp socket assembly, screw terminals, with coupling 1.71.213.001/0000 2 - 136 RAFIX 22 QR lamp socket assembly, screw terminals, with coupling, diode and series resistor 130 V 1.71.213.004/0000 2 - 136 RAFIX 22 QR lamp socket assembly, cage clamp terminals, with coupling 1.71.214.001/0000 2 - 136 Fixing spanner for ring nut and front ring 5.05.800.062/0000 5 - 23 Legend insert without legend 5.70.803.000/2000 2 - 122 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR signal indicator, round collar 29.80 21.80 M22x1.5 1...6mm 22.90 9.40 Pict.: yellow Panel cut-out to IEC 60947-5-1 Colour of lens Form of collar Order no. transparent colourless round 1.74.505.501/1000 transparent red round 1.74.505.501/1300 transparent yellow round 1.74.505.501/1400 transparent green round 1.74.505.501/1500 transparent blue round 1.74.505.501/1600 2 Technical data see page 2 - 122 RAFIX 22 QR RAFIX 22 QR signal indicator, square collar 29.80 22.00 M22x1.5 1...6mm 22.90 12.45 Pict.: red Panel cut-out to IEC 60947-5-1 Colour of lens Form of collar Order no. transparent colourless square 1.74.505.551/1000 transparent red square 1.74.505.551/1300 transparent yellow square 1.74.505.551/1400 transparent green square 1.74.505.551/1500 transparent blue square 1.74.505.551/1600 Technical data see page 2 - 122 Control components Stock items are marked by bold printed order numbers. 2 - 123 RAFIX 22 QR RAFIX 22 QR contact blocks with silver contacts Pict.: Silver contacts, 1 NC, cage clamp terminals 2 Silver contacts, 2 NC, screw terminals Silver contacts, 1NC+1NO, lamp socket, 1NC+1NO General data Most of the values specified apply to all terminal versions. Any deviating values specific to the cage clamp or quickconnect version are given in parentheses ( ). Technical data RAFIX 22 QR Dimensions Length Width Height Mounting depth without cable Mechanical design Mounting Contact system 39.5 mm 10 mm 46 mm 56.4 mm snap on coupling and actuator bridgecontact self cleaning Ag see order block Contact materials Contact arrangement NC contact forcibly actuated acc. to IEC 60947-5-1 yes Terminals see order block Terminal marking colour encoded Robustness 100 N Operating force approx. 5 N for 1 contact element Wire range solid wires without wire end sleeves 2 x 0.75 ... 2.5 mm2 Wire range stranded wires without end sleeves 2 x 1.0 ... 1.5 (2 x 0.08 ... 2.5) mm2 Stripping length, solid or stranded 8 mm Wire range with wire end sleeves 2 x 0.75 ... 1.5 mm2 Electrical characteristics acc. to IEC 60947 Rated insulation voltage AC/DC 400 V Rated peak voltage 6000 V Rated operating current Ie AC 12 10 A Rated operating current Ie AC-15 125 V/10 A, 250 V/6 A, 400 V/3.5 A Rated operating current Ie DC-13 Q300 24V/2.75A, 60V/1.1A, 125V/0.55A, 250V/0.275A Degree of pollution 3 2 - 124 Positive opening travel Operating speed 3 mm 5 ... 1000 mm/s Electrical characteristics acc. to IEC 61058 Resistive load AC 10 A/250 V; 7,5 A/400 V Motor load AC 6 A/250 V; 4 A/400 V (5 A/250 V) Peak input current filament lamp AC 36 A Peak capacity input current AC 100 A Protection class II Lamp characteristics Lamp characteristics Other specifications Operating life at 10 A/250 V AC Switching reliability at 24V/5mA DC Approvals Robustness Corresponding to CE Shock resistance acc. to IEC 600 68-2-27 Resistance to vibrations acc. to IEC 600 68-2-6 Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 Resistance to constant environment Resistance at variable environment BA 9 s 500000 (70000) 10 x 10-6 ENEC, cURus (UL + CSA) acc. IEC 60947-5-5 acc. EU-guideline N 72/73 50 g at 11 ms, amplitude half sinusoidal 10 g at 40 ... 500 Hz -25 °C +70°C (+50°C) -40 °C +80 °C V0 yes IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 Control components RAFIX 22 QR Accessories RAFIX 22 QR contact blocks with silver contacts, screw terminals and cage clamp terminals Description Photo Order no. Page Coupling with reference numbers 1-3-2, for contact blocks with single contacts 5.05.510.935/0000 2 - 143 Coupling with reference numbers 1/2-5/6-3/4, for contact blocks with double contacts 5.05.510.936/0000 2 - 143 Marking tag for contact blocks/lamp sockets with screw terminals 5.40.010.131/0000 2 - 145 2 RAFIX 22 QR contact block with silver contacts Pict.: Silver contacts, 2 NC, screw terminals Silver contacts, 1 NC, screw terminals Au contacts, quick connector, 1S Terminals Contact arrangement Contact materials screw terminals 1 NC Ag 5.00.100.139/0000 screw terminals 1 NO Ag 5.00.100.140/0000 screw terminals 2 NC Ag 5.00.100.141/0000 screw terminals 2 NO Ag 5.00.100.142/0000 screw terminals 1 NC + 1 NO Ag 5.00.100.143/0000 clamp cage 1 NC Ag 5.00.100.144/0000 clamp cage 1 NO Ag 5.00.100.145/0000 solder/quick connector 1 NC Ag 5.00.100.194/0000 1 NO Ag 5.00.100.196/0000 6.3 x 0.8 mm NEW solder/quick connector 6.3 x 0.8 mm Lamp characteristics Order no. RAFIX 22 QR Technical data see page 2 - 124 Control components Stock items are marked by bold printed order numbers. 2 - 125 RAFIX 22 QR RAFIX 22 QR contact block assembly, with coupling, without lamp socket, silver contacts Pict.: Silver contacts, 1 NO 2 RAFIX 22 QR Terminals Contact arrangement Contact materials Lamp characteristics screw terminals 1 NC Ag 1.20.124.001/0000 screw terminals 1 NO Ag 1.20.124.002/0000 screw terminals 1 NC, 1 NC Ag 1.20.124.003/0000 screw terminals 1 NO , 1 NO Ag 1.20.124.004/0000 screw terminals 1 NO , 1 NC Ag 1.20.124.005/0000 screw terminals 1 NC + 1 NO Ag 1.20.124.017/0000 screw terminals Ag 1.20.124.018/0000 screw terminals 1 NC + 1 NO , 1 NC + 1 NO 2 NC Ag 1.20.124.019/0000 screw terminals 2 NO Ag 1.20.124.020/0000 clamp cage 1 NC Ag 1.20.125.001/0000 clamp cage 1 NO Ag 1.20.125.002/0000 clamp cage 1 NC, 1 NC Ag 1.20.125.003/0000 clamp cage 1 NO , 1 NO Ag 1.20.125.004/0000 clamp cage 1 NO , 1 NC Ag 1.20.125.005/0000 Order no. Technical data see page 2 - 124 Contact arrangement example (1 NO = 1 normally open contact, 1 NC = 1 normally closed contact) 1 NO, 1 NC = Two separate contact blocks are mounted on the coupling: One with a normally open contact and one with a normally closed contact 1 NC + 1 NO = One contact block with double contacts (1 normally closed and 1 normally open) is mounted on the coupling. 2 - 126 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR contact block assembly, with coupling and lamp socket, silver contacts Pict.: lamp socket Terminals Contact arrangement Contact materials Lamp characteristics Order no. screw terminals 1 NC Ag BA 9 s 1.20.124.021/0000 screw terminals 1 NO Ag BA 9 s 1.20.124.022/0000 screw terminals 1 NC, 1 NC Ag BA 9 s 1.20.124.023/0000 screw terminals 1 NO , 1 NO Ag BA 9 s 1.20.124.024/0000 screw terminals 1 NO , 1 NC Ag BA 9 s 1.20.124.025/0000 screw terminals 1 NC + 1 NO Ag BA 9 s 1.20.124.027/0000 screw terminals Ag BA 9 s 1.20.124.028/0000 screw terminals 1 NC + 1 NO , 1 NC + 1 NO 2 NC Ag BA 9 s 1.20.124.029/0000 screw terminals 2 NO Ag BA 9 s 1.20.124.030/0000 clamp cage 1 NC Ag BA 9 s 1.20.125.021/0000 clamp cage 1 NO Ag BA 9 s 1.20.125.022/0000 clamp cage 1 NC, 1 NC Ag BA 9 s 1.20.125.023/0000 clamp cage 1 NO , 1 NO Ag BA 9 s 1.20.125.024/0000 clamp cage 1 NO , 1 NC Ag BA 9 s 1.20.125.025/0000 Technical data see page 2 - 124 Accessories: Filament lamp, BA 9s base (MBC/MCC), 12 - 15 V: 1.90.060.132/0000 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V: 1.90.060.133/0000 Filament lamp, BA 9s base (MBC/MCC), 110 - 130 V: 1.90.060.137/0000 LED BA 9s (MBC/MCC) superbright, red, 24 V: 1.90.690.341/0000 LED BA 9s (MBC/MCC) superbright, green, 24 V: 1.90.690.342/0000 LED BA 9s (MBC/MCC) superbright, yellow, 24 V: 1.90.690.343/0000 LED BA 9s (MBC/MCC) superbright, blue, 24 V: 1.90.690.344/0000 LED BA 9s (MBC/MCC) superbright, white, 24 V: 1.90.690.345/0000 Contact arrangement example (1 NO = 1 normally open contact, 1 NC = 1 normally closed contact) 1 NO, 1 NC = Two separate contact blocks are mounted on the coupling: One with a normally open contact and one with a normally closed contact 1 NC + 1 NO = One contact block with double contacts (1 normally closed and 1 normally open) is mounted on the coupling. BA 9s (MBC/MCC) = Lamp socket snaps onto coupling centre. More technical data see "Lamp sockets". Control components Stock items are marked by bold printed order numbers. 2 - 127 2 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR contact blocks with gold contacts Pict.: Gold contacts, 1 NC, screw terminals 2 Gold contacts, 1 NO, cage clamp terminals Assembly: Gold contacts, 1NC + 1NO General data Most of the values specified apply to all terminal and cage clamp terminal versions. Any deviating values specific to the cage clamp or quick connect version are given in parentheses ( ). Technical data RAFIX 22 QR Dimensions Length Width Height Mounting depth without cable Mechanical design Mounting Contact system 39.5 mm 10 mm 46 mm 56.4 mm snap on coupling and actuator bridgecontact self cleaning Au see order block Contact materials Contact arrangement NC contact forcibly actuated acc. to IEC 60947-5-1 yes Terminals see order block Terminal marking colour encoded Robustness 100 N Operating force approx. 5 N for 1 contact element Wire range solid wires without wire end sleeves 2 x 0,75 ... 2,5 mm2 Wire range stranded wires without wire end sleeves 2 x 1,0 ... 1,5 mm2 Stripping length, solid or stranded 8 mm Wire range with wire end sleeves 2 x 0,75 ... 1,5 mm2 Electrical characteristics Operating voltage AC/DC Operating current AC/DC Rated power max. 1 ... 42 V 0,01 ... 100 mA 1W (ohmic load) Lamp characteristics Lamp socket BA 9 s Other specifications Operating life Switching reliability at 24V/5mA DC Robustness Corresponding to CE Shock resistance acc. to IEC 600 68-2-27 Resistance to vibrations acc. to IEC 600 68-2-6 Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 1 million at 10 mA/ 24 V DC 10 x 10-6 acc. IEC 60947-5-5 acc. EU-guideline N 72/73 50 g at 11 ms, amplitude half sinusoidal 10 g at 40 ... 500 Hz -25 °C +70 °C -40 °C +80 °C IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 Accessories RAFIX 22 QR contact blocks with gold contacts, screw terminals and cage clamp terminals Description Photo Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V 2 - 128 Stock items are marked by bold printed order numbers. Order no. Page 1.90.060.133/0000 5 - 8 Control components RAFIX 22 QR Accessories RAFIX 22 QR contact blocks with gold contacts, screw terminals and cage clamp terminals Description Photo Order no. Page Neon lamp BA 9s (MBC/MCC), 220 V AC (red) 1.90.560.102/0000 5 - 9 LED BA 9s (MBC/MCC) superbright, white, 24 V 1.90.690.345/0000 5 - 19 Coupling with reference numbers 1-3-2, for contact blocks with single contacts 5.05.510.935/0000 2 - 143 Coupling with reference numbers 1/2-5/6-3/4, for contact blocks with double contacts 5.05.510.936/0000 2 - 143 Marking tag for contact blocks/lamp sockets with screw terminals 5.40.010.131/0000 2 - 145 2 RAFIX 22 QR contact block with gold contacts RAFIX 22 QR Pict.: Gold contacts, 1 NC, screw terminals Gold contacts, 1 NO, cage clamp terminals Gold contacts, quick connector, 1NO Terminals Contact arrangement Contact materials screw terminals 2 NC Au 5.00.100.161/0000 screw terminals 2 NO Au 5.00.100.162/0000 screw terminals 1 NC + 1 NO Au 5.00.100.163/0000 screw terminals 1 NC Au 5.00.100.164/0000 screw terminals 1 NO Au 5.00.100.165/0000 clamp cage 1 NC Au 5.00.100.159/0000 clamp cage 1 NO Au 5.00.100.160/0000 solder/quick connector 1 NC Au 5.00.100.193/0000 1 NO Au 5.00.100.195/0000 6.3 x 0.8 mm NEW solder/quick connector 6.3 x 0.8 mm Lamp socket Order no. Technical data see page 2 - 128 Control components Stock items are marked by bold printed order numbers. 2 - 129 RAFIX 22 QR RAFIX 22 QR contact block assembly, with coupling, without lamp socket, gold contacts Pict.: Gold contacts, 1NC + 1NO 2 RAFIX 22 QR Terminals Contact arrangement Contact materials Lamp socket screw terminals 1 NC Au 1.20.124.101/0000 screw terminals 1 NO Au 1.20.124.102/0000 screw terminals 1 NC, 1 NC Au 1.20.124.103/0000 screw terminals 1 NO , 1 NO Au 1.20.124.104/0000 screw terminals 1 NO , 1 NC Au 1.20.124.105/0000 screw terminals 1 NC + 1 NO Au 1.20.124.117/0000 screw terminals Au 1.20.124.118/0000 screw terminals 1 NC + 1 NO , 1 NC + 1 NO 2 NC Au 1.20.124.119/0000 screw terminals 2 NO Au 1.20.124.120/0000 clamp cage 1 NC Au 1.20.125.101/0000 clamp cage 1 NO Au 1.20.125.102/0000 clamp cage 1 NC, 1 NC Au 1.20.125.103/0000 clamp cage 1 NO , 1 NO Au 1.20.125.104/0000 clamp cage 1 NO , 1 NC Au 1.20.125.105/0000 Order no. Technical data see page 2 - 128 Contact arrangement example (1 NO = 1 normally open contact, 1 NC = 1 normally closed contact) 1 NO, 1 NC = Two separate contact blocks are mounted on the coupling: One with a normally open contact and one with a normally closed contact 1 NC + 1 NO = One contact block with double contacts (1 normally closed and 1 normally open) are mounted on the coupling. 2 - 130 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR contact block assembly, with coupling and lamp socket, gold contacts Pict.: Silver contacts, 1NC+1NO, lamp socket, 1NC+1NO Terminals Contact arrangement Contact materials Lamp socket Order no. screw terminals 1 NC Au BA 9 s 1.20.124.121/0000 screw terminals 1 NO Au BA 9 s 1.20.124.122/0000 screw terminals 1 NC, 1 NC Au BA 9 s 1.20.124.123/0000 screw terminals 1 NO , 1 NO Au BA 9 s 1.20.124.124/0000 screw terminals 1 NO , 1 NC Au BA 9 s 1.20.124.125/0000 screw terminals 1 NC + 1 NO Au BA 9 s 1.20.124.127/0000 screw terminals Au BA 9 s 1.20.124.128/0000 screw terminals 1 NC + 1 NO , 1 NC + 1 NO 2 NC Au BA 9 s 1.20.124.129/0000 screw terminals 2 NO Au BA 9 s 1.20.124.130/0000 clamp cage 1 NC Au BA 9 s 1.20.125.121/0000 clamp cage 1 NO Au BA 9 s 1.20.125.122/0000 clamp cage 1 NC, 1 NC Au BA 9 s 1.20.125.123/0000 clamp cage 1 NO , 1 NO Au BA 9 s 1.20.125.124/0000 clamp cage 1 NO , 1 NC Au BA 9 s 1.20.125.125/0000 Technical data see page 2 - 128 Accessories: Filament lamp, BA 9s base (MBC/MCC), 12 - 15 V: 1.90.060.132/0000 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V: 1.90.060.133/0000 Filament lamp, BA 9s base (MBC/MCC), 110 - 130 V: 1.90.060.137/0000 LED BA 9s (MBC/MCC) superbright, red, 24 V: 1.90.690.341/0000 LED BA 9s (MBC/MCC) superbright, green, 24 V: 1.90.690.342/0000 LED BA 9s (MBC/MCC) superbright, yellow, 24 V: 1.90.690.343/0000 LED BA 9s (MBC/MCC) superbright, blue, 24 V: 1.90.690.344/0000 LED BA 9s (MBC/MCC) superbright, white, 24 V: 1.90.690.345/0000 Contact arrangement example (1 NO = 1 normally open contact, 1 NC = 1 normally closed contact) 1 NO, 1 NC = Two separate contact blocks are mounted on the coupling: One with a normally open contact and one with a normally closed contact 1 NC + 1 NO = One contact block with double contacts (1 normally closed and 1 normally open) is mounted on the coupling. BA 9s (MBC/MCC) = Lamp socket snaps onto coupling centre. Technical data see "Lamp sockets". Control components Stock items are marked by bold printed order numbers. 2 - 131 2 RAFIX 22 QR RAFIX 22 QR Contact blocks with coupling, gold contacts, RJ 12 connector, integrated LED Pict.: with RJ 12 adapter 2 wiring Technical data Dimensions Length Width Height Mounting depth Mechanical design Mounting Contact system RAFIX 22 QR with LED 49.4 mm 29.95 mm 42.1 mm 62 mm snap on actuator bridgecontact self cleaning Au see order block Contact materials Contact arrangement NC contact forcibly actuated acc. to IEC 60947-5-1 Terminals Terminal marking Mounting grid Robustness yes RJ-12 RJ-12 plug 30 x 50 100 N Electrical characteristics Operating voltage AC/DC Operating current AC/DC 24 V 0,01 ... 50 mA 2 - 132 Other specifications Operating life Switching reliability at 24V/5mA DC Ambient temp. operating min. Ambient temp. operating without LED max. Ambient temp. operating with LED max. Storage temperature min. Storage temperature max. Integrated LED LED colour Resistance to constant environment Resistance at variable environment Stock items are marked by bold printed order numbers. 1000000 at 50 mA/24 V DC 10 x 10-6 -25 °C +70 °C +50 °C -30 °C +80 °C see order block see order block IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 Control components RAFIX 22 QR Contact block with coupling, gold contacts, RJ 12 connector, integrated LED Pict.: with RJ 12 adapter Wiring Contact arrangement Operating voltage AC/DC Integrated LED LED colour 1 NO 24 V no 1 NO 24 V yes white 1.20.128.012/0000 1 NO 24 V yes green 1.20.128.042/0000 1 NC + 1 NO 24 V no 1 NC + 1 NO 24 V yes white 1.20.128.013/0000 1 NC + 1 NO 24 V yes red 1.20.128.023/0000 2 NC 24 V no 2 NC 24 V yes white 1.20.128.014/0000 2 NC 24 V yes red 1.20.128.024/0000 2 NO 24 V no 2 NO 24 V yes white 1.20.128.015/0000 2 NO 24 V yes green 1.20.128.045/0000 Order no. 1.20.128.002/0000 1.20.128.003/0000 1.20.128.004/0000 1.20.128.005/0000 Technical data see page 2 - 132 Other contact arrangement versions available on request. Control components Stock items are marked by bold printed order numbers. 2 2 - 133 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR lamp sockets BA 9s (MBC/MCC), screw terminals and cage clamp terminals with contact block 2 Technical data Dimensions Length Width Height Mounting depth without cable Mechanical design Mounting RAFIX 22 QR Other specifications Approvals Robustness Shock resistance acc. to IEC 600 68-2-27 46 mm 10 mm 39.5 mm 56.4 mm Terminals Terminal marking snap on coupling and actuator see order block X1 = anode, X2 = cathode Lamp characteristics Lamp socket Operating voltage AC/DC Lamp power max. Lamp voltage BA 9 s see order block 2W see order block Resistance to vibrations acc. to IEC 600 68-2-6 Resistance to constant environment Resistance at variable environment Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 see order block acc. IEC 60947-5-5 50 g at 11 ms, amplitude half sinusoidal 10 g at 40 ... 500 Hz IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 -25 °C +70 °C -40 °C +80 °C V0 yes Accessories RAFIX 22 QR lamp sockets BA 9s (MBC/MCC), screw terminals and cage clamp terminals Description Photo Order no. Page Filament lamp, BA 9s base (MBC/MCC), 12 - 15 V 1.90.060.132/0000 5 - 8 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V 1.90.060.133/0000 5 - 8 Filament lamp, BA 9s base (MBC/MCC), 110 - 130 V 1.90.060.137/0000 5 - 8 Neon lamp BA 9s (MBC/MCC), 220 V AC (red) 1.90.560.102/0000 5 - 9 LED BA 9s (MBC/MCC) superbright, red, 24 V 1.90.690.341/0000 5 - 19 LED BA 9s (MBC/MCC) superbright, green, 24 V 1.90.690.342/0000 5 - 19 LED BA 9s (MBC/MCC) superbright, yellow, 24 V 1.90.690.343/0000 5 - 19 2 - 134 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR Accessories RAFIX 22 QR lamp sockets BA 9s (MBC/MCC), screw terminals and cage clamp terminals Description Photo Order no. Page LED BA 9s (MBC/MCC) superbright, blue, 24 V 1.90.690.344/0000 5 - 19 LED BA 9s (MBC/MCC) superbright, white, 24 V 1.90.690.345/0000 5 - 19 Coupling with reference numbers 1-3-2, for contact blocks with single contacts 5.05.510.935/0000 2 - 143 Coupling with reference numbers 1/2-5/6-3/4, for contact blocks with double contacts 5.05.510.936/0000 2 - 143 Marking tag for contact blocks/lamp sockets with screw terminals 5.40.010.131/0000 2 - 145 2 RAFIX 22 QR lamp socket, without coupling RAFIX 22 QR Terminals Diode and Approvals resistor Lamp socket Operating voltage AC/DC Lamp voltage Order no. screw terminals no BA 9 s 6 ... 250 V 6 ... 250 V 5.00.070.074/0000 screw terminals yes BA 9 s 250 V 130 V 5.00.070.080/0000 clamp cage no BA 9 sBA 9 s 6 ... 250 V 6 ... 250 V 5.00.070.078/0000 solder/quick connec- no BA 9 s 6 ... 250 V 6 ... 250 V 5.00.070.087/0000 NEW tor 6.3 x 0.8 mm ENEC 10/15; ULc ENEC 10/15; ULc ENEC 10/15; ULc ENEC 10/15; ULc Technical data see page 2 - 134 Control components Stock items are marked by bold printed order numbers. 2 - 135 RAFIX 22 QR RAFIX 22 QR lamp socket assembly, with coupling Pict.: Lamp socket with cage clamp terminals Terminals Diode and resistor screw terminals no 2 screw terminals yes clamp cage no Approvals Lamp socket Operating voltage AC/DC Lamp voltage Order no. ENEC 10/15; ULc ENEC 10/15; ULc ENEC 10/15; ULc BA 9 s 6 ... 250 V 6 ... 250 V 1.71.213.001/0000 BA 9 s 250 V 130 V 1.71.213.004/0000 BA 9 s 6 ... 250 V 6 ... 250 V 1.71.214.001/0000 Technical data see page 2 - 134 RAFIX 22 QR 2 - 136 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR lamp sockets with integrated LED, screw terminals 2 Technical data Dimensions Length Width Height Mounting depth without cable Mechanical design Mounting RAFIX 22 QR Other specifications Approvals Robustness Shock resistance acc. to IEC 600 68-2-27 46 mm 10 mm 39.5 mm 56.4 mm Diode and resistor LED colour Terminals Terminal marking snap on coupling and actuator see order block see order block screw terminals X1 = anode, X2 = cathode Lamp characteristics Operating voltage Max. current, IF see order block see order block Resistance to vibrations acc. to IEC 600 68-2-6 Resistance to constant environment Resistance at variable environment Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 ENEC 10/15; ULc acc. IEC 60947-5-5 50 g at 11 ms, amplitude half sinusoidal 10 g at 40 ... 500 Hz IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 -20 °C +65 °C -40 °C +80 °C V0 yes Accessories RAFIX 22 QR lamp sockets with integrated LED, screw terminals Description Photo Order no. Page Coupling with reference numbers 1-3-2, for contact blocks with single contacts 5.05.510.935/0000 2 - 143 Coupling with reference numbers 1/2-5/6-3/4, for contact blocks with double contacts 5.05.510.936/0000 2 - 143 Marking tag for contact blocks/lamp sockets with screw terminals 5.40.010.131/0000 2 - 145 2 - 138 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR RAFIX 22 QR lamp socket with integrated LED, without coupling Terminals Diode and resistor LED colour Max. current, IF Operating voltage Order no. screw terminals white 15 mA AC/DC 24 V 5.00.070.083/0200 screw terminals red 15 mA AC/DC 24 V 5.00.070.083/0300 screw terminals yellow 15 mA AC/DC 24 V 5.00.070.083/0400 screw terminals green 15 mA AC/DC 24 V 5.00.070.083/0500 screw terminals blue 15 mA AC/DC 24 V 5.00.070.083/0600 screw terminals white 16 mA AC 115 V 5.00.070.085/0200 screw terminals red 16 mA AC 115 V 5.00.070.085/0300 screw terminals yellow 16 mA AC 115 V 5.00.070.085/0400 screw terminals green 16 mA AC 115 V 5.00.070.085/0500 screw terminals blue 16 mA AC 115 V 5.00.070.085/0600 screw terminals white 16 mA AC 230 V 5.00.070.086/0200 screw terminals red 16 mA AC 230 V 5.00.070.086/0300 screw terminals yellow 16 mA AC 230 V 5.00.070.086/0400 screw terminals green 16 mA AC 230 V 5.00.070.086/0500 screw terminals blue 16 mA AC 230 V 5.00.070.086/0600 Technical data see page 2 - 138 Control components Stock items are marked by bold printed order numbers. 2 - 139 2 RAFIX 22 QR RAFIX 22 QR RAFIX 22 QR special accessories light grey/dark grey 2 Accessories RAFIX 22 QR special accessories Description Photo Fixing spanner for ring nut and front ring Order no. Page 5.05.800.062/0000 5 - 23 Housings for flush pushbuttons RAFIX 22 QR Short text Feature 1 Feature 2 Order no. Housings for pushbuttons, round collar, flush lens, momentary 1.30.240.601/0000 Housings for pushbuttons, square collar, flush lens, momentary 1.30.240.602/0000 2 - 140 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR Lenses for flush pushbuttons Pict.: yellow Short text Feature 1 Feature 2 Order no. Lens, with diffuser transparent colourless transparent red flat lens 5.04.926.008/1000 flat lens 5.04.926.008/1300 5.04.926.008/1400 Lens, with diffuser transparent flat lens yellow transparent flat lens green transparent blue flat lens Lens opaque black flat lens 5.49.263.019/0100 Lens opaque white flat lens 5.49.263.019/0200 Lens opaque red flat lens 5.49.263.019/0300 Lens opaque yellow flat lens 5.49.263.019/0400 Lens opaque green flat lens 5.49.263.019/0500 Lens opaque blue flat lens 5.49.263.014/0600 Lens opaque slate-grey flat lens 5.49.263.019/0700 Lens, with diffuser Lens, with diffuser Lens, with diffuser Control components Stock items are marked by bold printed order numbers. 2 5.04.926.008/1500 5.04.926.008/1600 2 - 141 RAFIX 22 QR RAFIX 22 QR Front ring Pict.: metal Short text 2 RAFIX 22 QR Feature 1 Feature 2 Order no. Front ring, metal 5.45.638.015/6030 Front ring, plastic, black 5.45.639.020/0100 Front ring, plastic, red 5.45.639.020/0300 Front ring, plastic, yellow 5.45.639.020/0400 Front ring, plastic, green 5.45.639.020/0500 Front ring, plastic, blue 5.45.639.020/0600 Front ring, plastic, slate grey 5.45.639.020/0700 Front ring, plastic, silver grey 5.45.639.020/0800 RAFIX 22 QR plastic front ring with thermoflex protective cap Pict.: slate-grey Short text Feature 1 Front ring, plastic with protective cap, slate grey slate-grey 5.05.004.914/0700 Front ring, plastic with thermoflex protective cap, silver grey silvergrey black 5.05.004.914/0800 Front ring, plastic with thermoflex protective cap, black 2 - 142 Stock items are marked by bold printed order numbers. Feature 2 Order no. 5.05.004.914/0100 Control components RAFIX 22 QR Label holder Short text Feature 1 Feature 2 Label holder, round collar, with adhesive tape and release liner on back 50 x 30 x 3.6 mm Label holder, square collar, with adhesive tape and release liner on back 50 x 30 x 3.6 mm Order no. 5.07.620.010/0000 5.07.620.011/0000 2 Legend label to clip into label holder 5.07.620.xxx RAFIX 22 QR Short text Feature 1 Feature 2 Label for label holder, without legend, 16 x 28 x 0,9 mm Order no. 5.73.110.000/0000 Coupling Short text Feature 1 Coupling with reference numbers 1-3-2, for contact blocks with single contacts Coupling with reference numbers 1/2-5/6-3/4, for contact blocks with double contacts Control components Stock items are marked by bold printed order numbers. Feature 2 Order no. 5.05.510.935/0000 5.05.510.936/0000 2 - 143 RAFIX 22 QR Blanking cap Short text 2 Feature 1 Feature 2 Order no. Blanking cap IP65, ring nut, square 5.05.800.065/0000 Blanking cap IP65, ring nut, round 5.05.800.064/0000 Ring nut RAFIX 22 QR Short text Feature 1 Feature 2 Order no. Ring nut (spare part) 5.24.279.012/0100 Ring nut with claw (spare part) 5.02.420.001/0000 Lamp tester Short text Feature 1 Lamp tester 2 - 144 Feature 2 Order no. 5.03.771.678/0000 Stock items are marked by bold printed order numbers. Control components RAFIX 22 QR Protective cover, suitable for pushbuttons with flush lens Pict.: protective lid Short text Feature 1 Feature 2 Order no. Protective cover, latching 5.05.511.195/0000 Protective cover, auto-closing 5.05.511.194/0000 2 Marking tag RAFIX 22 QR Short text Feature 1 Marking tag for contact blocks/lamp sockets with screw terminals Control components Stock items are marked by bold printed order numbers. Feature 2 Order no. 5.40.010.131/0000 2 - 145 RAFIX 22 QR Insulating housing IP65 for RAFIX 22 QR Pict.: 3-module 2 RAFIX 22 QR Short text Feature 1 Feature 2 Order no. Insulating housing IP65 for 22 QR, 1-module, light grey/dark grey 100 mm 55 mm 1.20.810.201/0000 Insulating housing IP65 for 22 QR, 1-module, yellow/yellow 100 mm 55 mm 1.20.810.202/0000 Insulating housing IP65 for 22 QR, 2-module, light grey/dark grey 100 mm 115 mm 1.20.820.201/0000 Insulating housing IP65 for 22 QR, 3-module, light grey/dark grey 100 mm 115 mm 1.20.830.201/0000 Insulating housing IP65 for 22 QR, 4-module, light grey/dark grey 100 mm 145 mm 1.20.840.201/0000 Feature 2 Order no. Emergency stop label, yellow, round 60 mm, rigid PVC, with legend „NOT-AUS“ Emergency stop label, yellow, round 60 mm, rigid PVC, with legend „EMERGENCY-STOP/ARRET D’URGENCE“ Emergency stop label, yellow, round 60 mm, PVC adhesive, without legend 60 mm 5.76.207.001/0400 60 mm 5.76.207.002/0400 60 mm 5.76.204.100/0400 Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend „NOT-AUS“ Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend „ARRET D’URGENCE“ Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend „EMERGENCY-STOP“ Emergency stop label, yellow 36 x 64 mm, PVC adhesive, without legend 60 mm 5.76.204.101/0400 60 mm 5.76.204.102/0400 60 mm 5.76.204.103/0400 36 mm 5.76.205.011/0400 • Attractive plastic housing to accommodate up to 4 control components • 2 cable entries prepared: 1-,2-,3-part: M20x1,5, 4-part: M25x1,5 • Degree of protection IP 65 to DIN • All grey housings with overlay, legending possible with legend inserts • Wall mounting with 2 screws through housing bottom prepared • Dimensions: (feature 2) x 100 mm x 74 mm • Accessories: 50 pre-perforated legend inserts on a DIN A4 sheet for printing with a PC printer Emergency stop label plate Short text Feature 1 64 mm Degree of protection: Rigid PVC: IP 40, adhesive foil: IP65. 2 - 146 Stock items are marked by bold printed order numbers. Control components
5.00.100.165/0000 价格&库存
很抱歉,暂时无法提供与“5.00.100.165/0000”相匹配的价格&库存,您可以联系我们找货
