1.10.102.001/0104
1.10.102.001/0104
    RAFI
1.10.102.001/0104 数据手册
Other pushbuttons Pushbutton, opaque, mounting hole diameter 16.2 mm, 250 V/2 A 1 Pict.: green Technical data General information Form of lens Colour of lens Form of collar Other Pushb. Electrical characteristics Rated voltage AC max. Rated current max. Contact resistance when new max. protruding lens see order block round Dimensions Diameter of collar Overall height Mounting depth Mounting hole 20 mm 9 mm 41 mm 16.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut screw terminals bridge contact momentary see order block Ag no no Mechanical characteristics Operating force max. Operating travel Switching travel NC Switching travel NO Robustness min. Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 7.5 N 4.3 mm 1.3 mm 2.2 mm 100 N Weight Approvals Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 250 V 2A 100 mΩ 150000 IP40 (IP65 with sealing cap) -25 °C +85 °C -40 °C +90 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 11 g ENEC 25 T 85 V0 yes Accessories Pushbutton, opaque, mounting hole diameter 16.2 mm, 250 V/2 A Description Photo Order no. Page Sealing cap, black (IP65) 5.52.008.101/0100 Sealing cap, red (IP65) 5.52.008.101/0300 Protective sleeve for terminals 5.52.011.026/0100 Protection against contact to VBG 4 5.55.101.715/0200 5 - 27 1 - 80 Stock items are marked by bold printed order numbers. Pushbuttons Other pushbuttons Accessories Pushbutton, opaque, mounting hole diameter 16.2 mm, 250 V/2 A Description Photo Fixing spanner M 15, M 16 Order no. Page 5.58.002.019/0105 5 - 23 1 Pushbutton, opaque, mounting hole diameter 16.2 mm, 250 V/2 A Pict.: green Contact arrangement Contact function Illuminability Rated voltage AC max. Colour of lens Order no. 1 NO momentary no 250 V opaque black 1.10.102.001/0104 1 NO momentary no 250 V opaque white 1.10.102.001/0205 1 NO momentary no 250 V opaque red 1.10.102.001/0301 1 NO momentary no 250 V opaque green 1.10.102.001/0507 1 NC momentary no 250 V opaque black 1.10.102.011/0104 1 NC momentary no 250 V opaque red 1.10.102.011/0301 Technical data see page 1 - 80 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 81 Other Pushb.
1.10.102.001/0104 价格&库存
很抱歉,暂时无法提供与“1.10.102.001/0104”相匹配的价格&库存,您可以联系我们找货
1.10.102.001/0104
  • 100+62.81763100+8.13600
1.10.102.001/0104
  • 9+108.37166
  • 25+91.15407
  • 55+85.65266
  • 100+76.54814
库存:1
