1.15.108.151/0000
1.15.108.151/0000
    RAFI
    按动开关
1.15.108.151/0000 数据手册
LUMOTAST 75 IP40 1 LUMO 75 (40) General data LUMOTAST 75 IP40 pushbutton range Illuminated pushbuttons, signal lamps and keylock switches • Mounting hole diameter 16.2 mm • Degree of protection IP40 • Solder terminals for the following wire cross-sections: - Installed 0.5 mm2 max. - Factory terminated 0.35 mm2 max. • 250 V/4 A max. • 3 NC + 3 NO max. • Lamp socket T 4.5 Content LUMOTAST 75 illuminated pushbutton IP40 LUMOTAST 75 illuminated pushbutton IP40, protruding lens, round collar LUMOTAST 75 illuminated pushbutton IP40, flush lens, square collar LUMOTAST 75 illuminated pushbutton IP40, flush lens, rectangular collar LUMOTAST 75 illuminated pushbutton IP40, protruding lens, square collar 1 - 38 1 - 40 1 - 41 1 - 42 1 - 43 LUMOTAST 75 keylock switch IP40 LUMOTAST 75 keylock switch IP40, round collar LUMOTAST 75 keylock switch IP40, rectangular collar 1 - 44 1 - 45 1 - 46 LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5 LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5, round collar, protruding lens LUMOTAST 75 IP40, signal lamp, square collar, flush lens LUMOTAST 75 IP40 signal lamp, rectangular collar, flush lens LUMOTAST 75 IP40 signal lamp, square collar, protruding lens 1 - 48 1 - 49 1 - 50 1 - 50 1 - 51 Pushbuttons 1 - 37 Stock items are marked by bold printed order numbers. LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40 1 Pict.: colourless Mounting hole Technical data LUMO 75 (40) General information Form of lens Form of collar Colour of collar Dimensions Length of collar Width of collar Diameter of collar Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Rated current AC max. Rated current DC max. Rated current AC/DC min. Contact resistance acc. to life max. Protection class see order block see order block see order block see order block see order block see order block 7.5 mm 41,5/49,5/57,5 mm 16.2 mm Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut solder terminals, tin-plated snap-action bridge contact see order block see order block Ag yes T 4.5 Mechanical characteristics Operating force max. Operating travel Switching travel NC Switching travel NO Robustness min. 3 ... 6.5 N 2.7 mm 1.6 mm 0.9 mm 100 N Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated voltage AC/DC min. 250 V 220 V 12 V Other specifications Operating life, at 250 V/2 A (operations) Operating life, at 250 V/4 A (operations) Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Approvals Flame class acc. to UL 94 Hot wire ignition acc. to IEC 695-2-1 4A 0.2 A 5 mA 200 mΩ II 200000 (momentary) 60000 (momentary), 10000 (latching) IP40 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 ENEC 25 T 55 (70), UL, CSA V1 yes Accessories LUMOTAST 75 illuminated pushbutton IP40 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 1 - 38 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 Accessories LUMOTAST 75 illuminated pushbutton IP40 Description Photo Order no. Page LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 20 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 20 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 20 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 20 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 20 LED T 4.5, red, 3 V 1.90.692.001/0000 5 - 19 LED T 4.5, green, 3 V 1.90.692.002/0000 5 - 19 LED T 4.5, yellow, 3 V 1.90.692.003/0000 5 - 19 Lamp extractor for T 4.5/5.5, lamp diameter 4 mm 1.90.900.002/0000 5 - 24 Lamp extractor for lamp diameter 5-6 mm 1.90.900.004/0000 5 - 24 Protective cap (for 18 x 24 collar) 5.05.800.027/0000 5 - 30 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 33 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 33 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 33 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 25 Pushbuttons Stock items are marked by bold printed order numbers. 1 LUMO 75 (40) 1 - 39 LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, protruding lens, round collar 1 Pict.: colourless Mounting hole Contact arrangement Contact function LUMO 75 (40) Colour of collar Order no. without lens 1.15.108.451/0000 Please include the desired lens and diffuser in your order. 1.15.108.551/0000 Please include the desired lens and diffuser in your order. 1.15.108.452/0000 Please include the desired lens and diffuser in your order. 1.15.108.552/0000 Please include the desired lens and diffuser in your order. 1.15.108.453/0000 Please include the desired lens and diffuser in your order. 1.15.108.553/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 38 Lens, round, transparent colourless, for filament lamp or LED: 5.49.257.011/1002 Lens, round, transparent red, for LED: 5.49.257.011/1301 Lens, round, transparent red, for filament lamp: 5.49.257.011/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.257.011/1402 Lens, round, transparent green, for filament lamp: 5.49.257.011/1502 Lens, round, transparent green, for LED: 5.49.257.011/1503 Lens, round, transparent blue, for filament lamp: 5.49.257.011/1601 Accessories: Diffuser, round, for filament lamp, without legend: 5.72.050.000/0202 Diffuser, round, for LED, without legend: 5.72.050.000/0214 1 - 40 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, flush lens, square collar 1 Pict.: red, without ring nut Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.251/0000 Please include the desired lens and diffuser in your order. 1.15.108.351/0000 Please include the desired lens and diffuser in your order. 1.15.108.252/0000 Please include the desired lens and diffuser in your order. 1.15.108.352/0000 Please include the desired lens and diffuser in your order. 1.15.108.253/0000 Please include the desired lens and diffuser in your order. 1.15.108.353/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 38 Lens, square, transparent colourless, for filament lamp or LED: 5.49.275.036/1002 Lens, square, transparent red, for LED: 5.49.275.036/1301 Lens, square, transparent red, for filament lamp: 5.49.275.036/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.275.036/1402 Lens, square, transparent green, for filament lamp: 5.49.275.036/1502 Lens, square, transparent green, for LED: 5.49.275.036/1503 Lens, square, transparent blue, for filament lamp: 5.49.275.036/1601 Accessories: Sealing cap IP65 (for 18 x 18 collar): 5.05.200.009/0000 Protective cap (for 18 x 18 collar): 5.05.800.030/0000 Diffuser, square, for filament lamp, without legend: 5.73.013.000/0202 Diffuser, square, for LED, without legend: 5.73.013.000/0214 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 41 LUMO 75 (40) LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, flush lens, rectangular collar 1 Pict.: green Contact arrangement Contact function LUMO 75 (40) Colour of collar Order no. without lens 1.15.108.051/0000 Please include the desired lens and diffuser in your order. 1.15.108.151/0000 Please include the desired lens and diffuser in your order. 1.15.108.052/0000 Please include the desired lens and diffuser in your order. 1.15.108.152/0000 Please include the desired lens and diffuser in your order. 1.15.108.053/0000 Please include the desired lens and diffuser in your order. 1.15.108.153/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 38 Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.275.032/1002 Lens, rectangular, transparent red, for LED: 5.49.275.032/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.275.032/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.275.032/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.275.032/1502 Lens, rectangular, transparent green, for LED: 5.49.275.032/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.275.032/1601 Accessories: Sealing cap IP65 (for 18 x 24 collar): 5.05.200.008/0000 Protective cap (for 18 x 24 collar): 5.05.800.027/0000 Diffuser, rectangular, for filament lamp, without legend: 5.73.012.000/0202 Diffuser, rectangular, for LED, without legend: 5.73.012.000/0214 1 - 42 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, protruding lens, square collar 1 Pict.: colourless Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.256/0000 Please include the desired lens and diffuser in your order. 1.15.108.356/0000 Please include the desired lens and diffuser in your order. 1.15.108.257/0000 Please include the desired lens and diffuser in your order. 1.15.108.357/0000 Please include the desired lens and diffuser in your order. 1.15.108.258/0000 Please include the desired lens and diffuser in your order. 1.15.108.358/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 38 Lens, square, transparent colourless, for filament lamp or LED: 5.49.275.036/1002 Lens, square, transparent red, for LED: 5.49.275.036/1301 Lens, square, transparent red, for filament lamp: 5.49.275.036/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.275.036/1402 Lens, square, transparent green, for filament lamp: 5.49.275.036/1502 Lens, square, transparent green, for LED: 5.49.275.036/1503 Lens, square, transparent blue, for filament lamp: 5.49.275.036/1601 Accessories: Sealing cap IP65 (for 18 x 18 collar): 5.05.200.009/0000 Protective cap (for 18 x 18 collar): 5.05.800.030/0000 Diffuser, square, for filament lamp, without legend: 5.73.013.000/0202 Diffuser, square, for LED, without legend: 5.73.013.000/0214 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 43 LUMO 75 (40) LUMOTAST 75 IP40 LUMOTAST 75 keylock switch IP40 1 Mounting hole Technical data LUMO 75 (40) General information Form of lens Colour of collar Form of collar Dimensions Length of collar Diameter of collar Width of collar Overall height (without key) Mounting depth Mounting hole Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lock Wafers Lock type Number of locking positions Main key Symmetric key Key removal position Mechanical characteristics Rotating angle Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated voltage AC/DC min. Rated current AC max. Rated current DC max. Rated current AC/DC min. Contact resistance acc. to life max. Bouncing time max. ESD-strength min. see order block see order block see order block see order block see order block see order block 7.5 mm see order block 16.2 mm ring nut solder terminals, tin-plated snap-action bridge contact see order block see order block Ag no cylinder lock 4 pins 1D 21 45 no no see order block Other specifications Operating life, at 250 V/2 A (operations) Operating life, at 250 V/4 A (operations) Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Weight max. Approvals see order block Flame class acc. to UL 94 Hot wire ignition acc. to IEC 695-2-1 250 V 220 V 12 V 4A 0.02 A 5 mA 200 mΩ 10 ms 14 kV 50000 (momentary) 50000 (momentary) IP40 -25 °C +70 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 35 g ENEC 25 T 55 (70), UL, CSA V1 yes Accessories LUMOTAST 75 keylock switch IP40 Description Photo Order no. Page Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 33 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 33 1 - 44 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 Accessories LUMOTAST 75 keylock switch IP40 Description Photo Order no. Page Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 25 Spare key for LUMO 75 5.58.002.030/0000 Key cap for LUMO 75 5.58.004.721/0000 1 LUMOTAST 75 keylock switch IP40, round collar LUMO 75 (40) Mounting hole Contact arrangement Contact function Rotating angle Key removal position Colour of collar Order no. complete 1 NC + 1 NO latching 90° 0 black 1.15.108.851/0000 1 NC + 1 NO latching 90° 0+1 black 1.15.108.911/0000 1 NC + 1 NO momentary 45° 0 black 1.15.108.941/0000 2 NC + 2 NO latching 90° 0 black 1.15.108.852/0000 2 NC + 2 NO latching 90° 0+1 black 1.15.108.912/0000 Technical data see page 1 - 44 Included: 2 keys. Other lock variants and contacts available on request. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 45 LUMOTAST 75 IP40 LUMOTAST 75 keylock switch IP40, rectangular collar 1 Panel cut-out Contact arrangement LUMO 75 (40) Contact function Rotating angle Key removal position Colour of collar Order no. complete 1 NC + 1 NO latching 90° 0 black 1.15.108.571/0100 1 NC + 1 NO latching 90° 0+1 black 1.15.108.631/0100 1 NC + 1 NO momentary 45° 0 black 1.15.108.661/0100 2 NC + 2 NO latching 90° 0 black 1.15.108.572/0100 2 NC + 2 NO latching 90° 0+1 black 1.15.108.632/0100 Technical data see page 1 - 44 Included: 2 keys. Other lock variants and contacts available on request. 1 - 46 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5 1 Pict.: blue Mounting hole Technical data LUMO 75 (40) General information Form of lens Form of collar Colour of collar see order block see order block see order block Dimensions Length of collar Width of collar Diameter of collar Overall height Mounting depth Mounting hole see order block see order block see order block 7.5 mm 33.5 mm 16.2 mm Mechanical design Mounting Terminals Other specifications Degree of protection from front side Weight Approvals Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Lamp socket Lamp ring nut solder terminals, tin-plated T 4.5 filament lamp / LED Electrical characteristics Voltage limit max. Power limit max. 42 V 1.2 W Resistance at variable environment IP40 5g ENEC 25 T 55 (70), UL, CSA -25 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 20 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 20 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 20 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 20 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 20 1 - 48 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 Accessories LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5 Description Photo Order no. Page LED T 4.5, red, 3 V 1.90.692.001/0000 5 - 19 LED T 4.5, green, 3 V 1.90.692.002/0000 5 - 19 LED T 4.5, yellow, 3 V 1.90.692.003/0000 5 - 19 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 33 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 33 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 33 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 25 1 LUMO 75 (40) LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5, round collar, protruding lens Pict.: blue Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Colour of collar Order no. without lens 1.2 W T 4.5 black Note 1.65.111.071/0000 Please include the desired lens and diffuser in your order. Technical data see page 1 - 48 Lens, round, transparent colourless, for filament lamp or LED: 5.49.257.011/1002 Lens, round, transparent red, for LED: 5.49.257.011/1301 Lens, round, transparent red, for filament lamp: 5.49.257.011/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.257.011/1402 Lens, round, transparent green, for filament lamp: 5.49.257.011/1502 Lens, round, transparent green, for LED: 5.49.257.011/1503 Lens, round, transparent blue, for filament lamp: 5.49.257.011/1601 Accessories: Diffuser, round, for filament lamp, without legend: 5.72.050.000/0202 Diffuser, round, for LED, without legend: 5.72.050.000/0214 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 49 LUMOTAST 75 IP40 LUMOTAST 75 IP40, signal lamp, square collar, flush lens 1 Pict.: yellow Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Colour of collar Order no. without lens 1.2 W T 4.5 black Note 1.65.111.061/0000 Please include the desired lens and diffuser in your order. Technical data see page 1 - 48 LUMO 75 (40) Lens, square, transparent colourless, for filament lamp or LED: 5.49.275.036/1002 Lens, square, transparent red, for LED: 5.49.275.036/1301 Lens, square, transparent red, for filament lamp: 5.49.275.036/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.275.036/1402 Lens, square, transparent green, for filament lamp: 5.49.275.036/1502 Lens, square, transparent green, for LED: 5.49.275.036/1503 Lens, square, transparent blue, for filament lamp: 5.49.275.036/1601 Accessories: Diffuser, square, for filament lamp, without legend: 5.73.013.000/0202 Diffuser, square, for LED, without legend: 5.73.013.000/0214 LUMOTAST 75 IP40 signal lamp, rectangular collar, flush lens Pict.: green Voltage limit max. 42 V Power limit max. Lamp socket Colour of collar Order no. without lens 1.2 W T 4.5 black Note 1.65.111.051/0000 Please include the desired lens and diffuser in your order. Technical data see page 1 - 48 Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.275.032/1002 Lens, rectangular, transparent red, for LED: 5.49.275.032/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.275.032/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.275.032/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.275.032/1502 Lens, rectangular, transparent green, for LED: 5.49.275.032/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.275.032/1601 Accessories: Diffuser, rectangular, for filament lamp, without legend: 5.73.012.000/0202 Diffuser, rectangular, for LED, without legend: 5.73.012.000/0214 1 - 50 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 LUMOTAST 75 IP40 signal lamp, square collar, protruding lens 1 Mounting hole Voltage limit max. 42 V Power limit max. Lamp socket Colour of collar Order no. without lens 1.2 W T 4.5 black Note 1.65.111.081/0000 Please include the desired lens and diffuser in your order. Technical data see page 1 - 48 Lens, square, transparent colourless, for filament lamp or LED: 5.49.275.036/1002 Lens, square, transparent red, for LED: 5.49.275.036/1301 Lens, square, transparent red, for filament lamp: 5.49.275.036/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.275.036/1402 Lens, square, transparent green, for filament lamp: 5.49.275.036/1502 Lens, square, transparent green, for LED: 5.49.275.036/1503 Lens, square, transparent blue, for filament lamp: 5.49.275.036/1601 LUMO 75 (40) Accessories: Diffuser, square, for filament lamp, without legend: 5.73.013.000/0202 Diffuser, square, for LED, without legend: 5.73.013.000/0214 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 51 LUMOTAST 75 IP65 1 General data LUMO 75 (65) LUMOTAST 75 IP65 pushbutton range Illuminated pushbuttons and signal lamps with lamp socket T 4.5 • Mounting hole diameter 16.2 mm • Degree of protection IP65 • Solder terminals for the following wire cross-sections: - Installed 0.5 mm2 max. - Factory terminated 0.35 mm2 max. • 250 V/4 A max. • 3 NC + 3 NO max. Content LUMOTAST 75 illuminated pushbutton IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, square collar LUMOTAST 75 illuminated pushbutton IP65, protruding lens, square collar LUMOTAST 75 illuminated pushbutton IP65, flush lens, round collar LUMOTAST 75 illuminated pushbutton IP65, protruding lens, round collar LUMOTAST 75 illuminated pushbutton IP65, flush lens, rectangular collar 1 - 54 1 - 56 1 - 57 1 - 58 1 - 59 1 - 60 LUMOTAST 75 signal lamp IP65 LUMOTAST 75 signal lamp IP65, flush lens, square collar LUMOTAST 75 signal lamp IP65, protruding lens, square collar LUMOTAST 75 signal lamp IP65, flush lens, round collar LUMOTAST 75 signal lamp IP65, protruding lens, round collar LUMOTAST 75 signal lamp IP65, flush lens, rectangular collar 1 - 62 1 - 63 1 - 64 1 - 64 1 - 65 1 - 65 Pushbuttons 1 - 53 Stock items are marked by bold printed order numbers. LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65 1 Pict.: red Mounting hole Technical data LUMO 75 (65) General information Form of lens Colour of lens Form of collar Colour of collar see order block see order block see order block black Dimensions Length of collar Diameter of collar Width of collar Overall height Mounting depth Mounting hole see order block see order block see order block 10.5 mm see order block 16.2 mm Mechanical design Mounting Terminals Rated current AC max. Rated current DC max. Rated current AC/DC min. Contact resistance acc. to life max. Protection class ESD-strength min. Other specifications Operating life, at 250 V/2 A (operations) Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut solder terminals, tin-plated snap-action bridge contact see order block see order block Ag yes T 4.5 Mechanical characteristics Operating force Operating travel Switching travel NC Switching travel NO Robustness min. 3 ... 6.5 N 2.5 mm 1.8 mm 0.9 mm 100 N Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated voltage AC/DC min. 250 V 220 V 12 V Operating life, at 250 V/4 A (operations) Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Weight Approvals Flame class acc. to UL 94 Hot wire ignition acc. to IEC 695-2-1 4A 0.2 A 5 mA 200 mΩ II 14 kV 200000 (momentary), 50000 (latching) 60000 (momentary) IP65 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 15 g ENEC 25 T 55 (70), UL, CSA V0 yes Accessories LUMOTAST 75 illuminated pushbutton IP65 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 1 - 54 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 Accessories LUMOTAST 75 illuminated pushbutton IP65 Description Photo Order no. Page LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 20 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 20 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 20 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 20 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 20 LED T 4.5, red, 3 V 1.90.692.001/0000 5 - 19 LED T 4.5, green, 3 V 1.90.692.002/0000 5 - 19 LED T 4.5, yellow, 3 V 1.90.692.003/0000 5 - 19 Lamp extractor for T 4.5/5.5, lamp diameter 4 mm 1.90.900.002/0000 5 - 24 Lamp extractor for lamp diameter 5-6 mm 1.90.900.004/0000 5 - 24 Protective cap (for 18 x 24 collar) 5.05.800.027/0000 5 - 30 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 33 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 33 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 33 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 25 Pushbuttons Stock items are marked by bold printed order numbers. 1 LUMO 75 (65) 1 - 55 LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, square collar 1 Pict.: red Mounting hole Contact arrangement Contact function LUMO 75 (65) Colour of collar Order no. without lens 1.15.108.276/0000 Please include the desired lens in your order. 1.15.108.376/0000 Please include the desired lens in your order. 1.15.108.277/0000 Please include the desired lens in your order. 1.15.108.377/0000 Please include the desired lens in your order. 1.15.108.278/0000 Please include the desired lens in your order. 1.15.108.378/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 54 Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, square, without legend: 5.70.629.000/2000 1 - 56 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, protruding lens, square collar 1 Pict.: yellow Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.281/0000 Please include the desired lens in your order. 1.15.108.381/0000 Please include the desired lens in your order. 1.15.108.282/0000 Please include the desired lens in your order. 1.15.108.382/0000 Please include the desired lens in your order. 1.15.108.283/0000 Please include the desired lens in your order. 1.15.108.383/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 54 Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, square, without legend: 5.70.629.000/2000 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 57 LUMO 75 (65) LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, round collar 1 Pict.: blue Mounting hole Contact arrangement Contact function LUMO 75 (65) Colour of collar Order no. without lens 1.15.108.481/0000 Please include the desired lens in your order. 1.15.108.981/0000 Please include the desired lens in your order. 1.15.108.482/0000 Please include the desired lens in your order. 1.15.108.982/0000 Please include the desired lens in your order. 1.15.108.483/0000 Please include the desired lens in your order. 1.15.108.983/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 54 Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 Accessories: Legend insert, round, without legend: 5.70.059.000/2000 1 - 58 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, protruding lens, round collar 1 Pict.: colourless Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.476/0000 Please include the desired lens in your order. 1.15.108.976/0000 Please include the desired lens in your order. 1.15.108.477/0000 Please include the desired lens in your order. 1.15.108.977/0000 Please include the desired lens in your order. 1.15.108.478/0000 Please include the desired lens in your order. 1.15.108.978/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 54 Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 Accessories: Legend insert, round, without legend: 5.70.059.000/2000 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 59 LUMO 75 (65) LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, rectangular collar 1 Pict.: green Contact arrangement Contact function LUMO 75 (65) Colour of collar Order no. without lens 1.15.108.076/0000 Please include the desired lens in your order. 1.15.108.176/0000 Please include the desired lens in your order. 1.15.108.077/0000 Please include the desired lens in your order. 1.15.108.177/0000 Please include the desired lens in your order. 1.15.108.078/0000 Please include the desired lens in your order. 1.15.108.178/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black 3 NC + 3 NO momentary black 3 NC + 3 NO latching black Note Technical data see page 1 - 54 Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.277.058/1002 Lens, rectangular, transparent red, for LED: 5.49.277.058/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.277.058/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.277.058/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.277.058/1502 Lens, rectangular, transparent green, for LED: 5.49.277.058/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.277.058/1601 Accessories: Legend insert, rectangular without legend: 5.70.630.000/2000 1 - 60 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 signal lamp IP65 1 Pict.: red Mounting hole Technical data General information Form of lens Form of collar Diameter of collar LUMO 75 (65) Dimensions Length of collar Width of collar Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp Electrical characteristics Voltage limit max. Power limit max. see order block see order block see order block Other specifications Degree of protection from front side Weight Approvals see order block see order block 10.5 mm 33.5 mm 16.2 mm Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. ring nut solder terminals, tin-plated T 4.5 filament lamp / LED 42 V 1.2 W IP65 5g ENEC 25 T 55 (70), UL, CSA -25 °C +55 °C -40 °C +80 °C Accessories LUMOTAST 75 signal lamp IP65 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 20 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 20 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 20 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 20 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 20 LED T 4.5, red, 3 V 1.90.692.001/0000 5 - 19 1 - 62 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 Accessories LUMOTAST 75 signal lamp IP65 Description Photo Order no. Page LED T 4.5, yellow, 3 V 1.90.692.003/0000 5 - 19 Lamp extractor for T 4.5/5.5, lamp diameter 4 mm 1.90.900.002/0000 5 - 24 Lamp extractor for lamp diameter 5-6 mm 1.90.900.004/0000 5 - 24 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 33 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 33 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 33 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 25 1 LUMO 75 (65) LUMOTAST 75 signal lamp IP65, flush lens, square collar Pict.: red Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens Note 1.2 W T 4.5 square 1.65.111.066/0000 Please include the desired lens in your order. Technical data see page 1 - 62 Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, square: 5.70.629.000/2000 For assembly, press the lens as far as possible. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 63 LUMOTAST 75 IP65 LUMOTAST 75 signal lamp IP65, protruding lens, square collar 1 Pict.: green Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens Note 1.2 W T 4.5 square 1.65.111.086/0000 Please include the desired lens in your order. Technical data see page 1 - 62 LUMO 75 (65) Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, round, without legend: 5.70.629.000/2000 For assembly, press the lens as far as possible. LUMOTAST 75 signal lamp IP65, flush lens, round collar Pict.: yellow Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens Note 1.2 W T 4.5 round 1.65.111.096/0000 Please include the desired lens in your order. Technical data see page 1 - 62 Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 Accessories: Legend insert, round, without legend: 5.70.059.000/2000 For assembly, press the lens as far as possible. 1 - 64 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 signal lamp IP65, protruding lens, round collar 1 Pict.: blue Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens Note 1.2 W T 4.5 round 1.65.111.076/0000 Please include the desired lens in your order. Technical data see page 1 - 62 Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 LUMO 75 (65) Accessories: Legend insert, round, without legend: 5.70.059.000/2000 For assembly, press the lens as far as possible. LUMOTAST 75 signal lamp IP65, flush lens, rectangular collar Pict.: colourless Voltage limit max. 42 V Power limit max. Lamp socket Form of collar Order no. without lens Note 1.2 W T 4.5 rectangular 1.65.111.056/0000 Please include the desired lens in your order. Technical data see page 1 - 62 Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.277.058/1002 Lens, rectangular, transparent red, for LED: 5.49.277.058/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.277.058/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.277.058/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.277.058/1502 Lens, rectangular, transparent green, for LED: 5.49.277.058/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.277.058/1601 Accessories: Legend insert, rectangular without legend: 5.70.630.000/2000 For assembly, press the lens as far as possible. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 65
1.15.108.151/0000
物料型号: - LUMOTAST 75 IP40系列:包括照明按钮、钥匙开关和信号灯,具有不同的镜头形状、领口形状和颜色。 - LUMOTAST 75 IP65系列:与IP40系列类似,但具有更高的防护等级。
器件简介: - 这些产品由Cannon ITT Industries制造,设计用于长期工程使用。 - 提供多种安装孔径和保护等级(IP40和IP65)。 - 有多种电线截面的焊接端子供选择。
引脚分配: - 提供了多种接触安排,如1NC+1NO、2NC+2NO、3NC+3NO等。
参数特性: - 额定电流AC/DC最大值、最小值。 - 接触电阻、操作力、操作行程、切换行程等。 - 环境温度范围、存储温度范围。
功能详解: - 照明按钮和信号灯具有发光功能,有多种颜色的镜头和领口可供选择。 - 钥匙开关提供了多种锁定位置和钥匙移除位置的选项。
应用信息: - 适用于需要按钮操作和指示灯显示的工业环境。
封装信息: - 提供了详细的机械设计参数,如领口长度、直径、宽度,以及整体高度等。 - 还提供了安装深度和安装孔径信息。
1.15.108.151/0000 价格&库存
很抱歉,暂时无法提供与“1.15.108.151/0000”相匹配的价格&库存,您可以联系我们找货
