5.46.169.047/0209
5.46.169.047/0209
    RAFI
    RACON 8/12 PLUNGER D 19.0 L 4.80
5.46.169.047/0209 数据手册
RACON short-travel keyswitches General data RACON short-travel keyswitches with sealed contact system and distinct key click, excellent switching reliability. For use under an overlay or with RK 90 keycaps. Print and SMD versions available (suitable for automatic assembly). Content RACON 8 RACON 8, solder terminals for PCB, outward RACON 8, solder terminals for PCB, inward RACON 8, SMD gullwing (Z) terminals 4444- RACON 12 RACON 12, solder terminals for PCB, outward RACON 12, solder terminals for PCB, inward RACON 12, SMD gullwing (Z) terminals 4 - 10 4 - 12 4 - 12 4 - 13 RACON 12 V with vertical adapter RACON 12 V with vertical adapter 4 - 14 4 - 15 RACON 12 i RACON 12 i, solder terminals for PCB 4 - 16 4 - 18 RACON special accessories Plunger for membrane data entry system Square plunger for membrane data entry system 4 - 20 4 - 20 4 - 22 PCB Keyswitches 6 8 8 9 4-5 4 RACON RACON short-travel keyswitches RACON 8 General data RACON 8 short-travel keyswitches offer an extremely high switching reliability while needing very little space. They can be arranged as single keys, in rows or key blocks. When arranged under an overlay, RACON keyswitches should be combined with plungers. The features at a glance: • Suitable for the most common soldering methods• Wave soldering bath for print versions • Reflow soldering (SMD) • Manual soldering • SMD version suitable for processing with an automatic SMD assembly machine 4 Technical data Dimensions Recommended key grid Key grid max. Length of housing Width of housing Overall height see order block see order block 8.4 mm 8.4 mm 4.90+-0.1 mm Mechanical design Mounting Terminals Contact system Contact arrangement Contact materials Illumination soldering see order block snap-action contact 1 NO Au no RACON Mechanical characteristics Operating force Switching travel Electrical characteristics Rated voltage min. Rated voltage max. Rated current min. Rated current max. Rated power max. (ohmic load) Contact resistance when new max. 4-6 3.3+-0.6 N 0.34+-0.1 mm 0.02 V 42 V 0.01 mA 100 mA Insulation resistance Bouncing time max. Other specifications Ambient temp. operating min. Ambient temp. operating max. Resistance to constant environment Resistance at variable environment 109 Ω 5 ms -40 °C +90 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Operating life at RT = 23° C and test force = 1,5 x rated force 1000000 Solderability / solder heat resistance PCB version IEC 600 68-2-20 Solderability / solder heat resistance SMD version EN 61760-1 and DIN IEC 600-68-2-58 Flammability of materials UL 94 HB Packing see order block Produkt code see order block 1W 100 mΩ PCB Keyswitches RACON short-travel keyswitches RACON 8, Typical system assembly with plunger under overlay GH A L SMD gullwing (Z) terminal A L Solder terminal for PCB, inward 0.10 GH A GH L Solder terminal for PCB, outward Variable Declaration A GH L Solder terminal outward Height of keyswitch Overall height Length of plunger Solder terminal inward SMD-terminal A = 4.90 +/- 0.1 mm GH = A + L L = GH - A GH = A + L + 0.1 mm L = GH - A - 0.1 mm RACON 8, PCB hole pattern, smallest grid Solder terminal for PCB, outward Solder terminal for PCB, inward SMD gullwing (Z) terminal 4 view on component side RACON 8, SDM-terminal, tape and reel drawing view on component side view on component side RACON Circuit diagram RACON 8 Switching symbols acc. to IEC 617 form X (twice interrupting) PCB Keyswitches 4-7 RACON short-travel keyswitches Accessories RACON 8 Description Photo Order no. Spacer, round, length 6.25 mm, red 5.30.759.034/0000 Plunger for membrane data entry system 5.46.167.311/0209 Page For other plungers, refer to the chapter „RACON special accessories“; for keycaps, refer to the chapter „RK 90“. RACON 8, solder terminals for PCB, outward PCB footprint, view on component side Terminals Contact arrangement solder terminal 1 NO for PCB, outward Produkt code Packing Order no. A1 tubes à 60 piece 1.14.100.501/0000 Technical data see page 4 - 6 For keycaps refer to chapter „RK 90“, plungers see „RACON special accessories“. 4 RACON 8, solder terminals for PCB, inward RACON Terminals Contact arrangement Produkt code Packing Order no. solder terminal for PCB, inward 1 NO B1 in tubes à 60 piece 1.14.100.502/0000 Technical data see page 4 - 6 For keycaps, refer to RK 90; for plungers, refer to accessories: 4-8 Stock items are marked by bold printed order numbers. PCB Keyswitches RACON short-travel keyswitches RACON 8, SMD gullwing (Z) terminals PCB footprint, view on component side Terminals Contact arrangement Produkt code Packing Order no. SMD Gullwing (Z) terminals 1 NO C1 tape and reel à 1000 piece 1.14.100.503/0000 Technical data see page 4 - 6 For keycaps refer to chapter „RK 90“, plungers see „RACON special accessories“. 4 RACON PCB Keyswitches Stock items are marked by bold printed order numbers. 4-9 RACON short-travel keyswitches RACON 12 General data RACON short-travel keyswitches offer an extremely high switching reliability while needing very little space. They can be arranged as single keys, in rows or key blocks. When arranged under an overlay, RACON keyswitches should be combined with plungers. The features at a glance: • Suitable for the most common soldering methods - Wave soldering bath for print versions - Reflow soldering (SMD) - Manual soldering • SMD version suitable for processing with an automatic SMD assembly machine 4 Technical data Dimensions Recommended key grid Key grid max. Length of housing Width of housing Overall height see order block see order block 12 mm 12 mm 4.95+-0.1 mm Mechanical design Mounting Terminals Contact system Contact arrangement Contact materials Illumination soldering see order block snap-action contact 1 NO Au no RACON Mechanical characteristics Operating force Switching travel Electrical characteristics Rated voltage min. Rated voltage max. Rated current min. Rated current max. Rated power max. (ohmic load) Contact resistance when new max. 4 - 10 3,6+-0,7 N 0,61+-0,1 mm 0.02 V 42 V 0.01 mA 100 mA Insulation resistance Bouncing time max. Other specifications Ambient temp. operating min. Ambient temp. operating max. Resistance to constant environment Resistance at variable environment 109 Ω 5 ms -40 °C +90 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Operating life at RT = 23° C and test force = 1,5 x rated force 1000000 Solderability / solder heat resistance PCB version IEC 600 68-2-20 Solderability / solder heat resistance SMD version EN 61760-1 and DIN IEC 600-68-2-58 Flammability of materials UL 94 HB Packing see order block Produkt code see order block 1W 100 mΩ PCB Keyswitches RACON short-travel keyswitches RACON 12, Typical system assembly with plunger under overlay 0.10 A GH A L GH A GH SMD gullwing (Z) terminal L Solder terminal for PCB, inward L Solder terminal for PCB, outward Variable Declaration A GH L Solder terminal outward Height of keyswitch Overall height Length of plunger Solder terminal inward SMD-terminal A = 4.95 +/- 0.1 mm GH = A + L L = GH - A GH = A + L + 0.1 mm L = GH - A - 0.1 mm RACON 12, PCB hole pattern, smallest grid Solder terminal for PCB, inward SMD gullwing (Z) terminal view on component side RACON 12, SMD-terminal, tape and reel drawing RMmin = 12.50 view on component side 11.30 max 15.80 min RMmin = 16.50 RMmin = 12.50 5.00 Ø 1.20 10.00 ± 0.10 RMmin = 12.50 RMmin =15.24 5.00 Ø 1.20 12.50 ± 0.10 RMmin = 12.50 1.60 5.00 Solder terminal for PCB, outward view on component side RACON Circuit Diagram RACON 12 Switching symbols acc. to IEC 617 form X (twice interrupting) PCB Keyswitches 4 4 - 11 RACON short-travel keyswitches Accessories RACON 12 Description Photo Order no. Spacer, round, length 6.25 mm, red 5.30.759.034/0000 Square plunger or membrane data entry system 5.46.001.057/0209 Plunger for membrane data entry system 5.46.168.050/0209 Page For other plungers, refer to the chapter „RACON special accessories“; for keycaps, refer to the chapter „RK 90“. RACON 12, solder terminals for PCB, outward PCB footprint, view on component side Terminals Contact arrangement solder terminal 1 NO for PCB, outward Produkt code Packing Order no. A1 tubes à 45 piece 1.14.001.501/0000 Technical data see page 4 - 10 4 For keycaps refer to chapter „RK 90“, plungers see „RACON special accessories“. RACON 12, solder terminals for PCB, inward RACON PCB footprint, view on component side Terminals Contact arrangement Produkt code Packing Order no. solder terminal for PCB, inward 1 NO B1 tubes à 45 piece 1.14.001.502/0000 Technical data see page 4 - 10 For keycaps refer to chapter „RK 90“, plungers see „RACON special accessories“. 4 - 12 Stock items are marked by bold printed order numbers. PCB Keyswitches RACON short-travel keyswitches RACON 12, SMD gullwing (Z) terminals PCB footprint, view on component side Terminals Contact arrangement Produkt code Packing Order no. SMD Gullwing (Z) terminals 1 NO C1 tape and reel à 750 piece 1.14.001.503/0000 Technical data see page 4 - 10 For keycaps refer to chapter „RK 90“, plungers see „RACON special accessories“. 4 RACON PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 13 RACON short-travel keyswitches RACON 12 V with vertical adapter General data The RACON 12 V version can be used, for example, for PC plug-in boards and for measurement and control engineering applications. The vertical mounting adapter (support element) absorbs the operating force so that the pressure on the soldered terminals is reduced. For this mounting arrangement, the keyswitch is provided with two horizontal terminals on one side. Technical data 4 RACON Dimensions Length Width Overall height 14.5 mm 13.6 mm 4.95 mm Mechanical design Mounting Terminals Contact system Contact arrangement Contact materials Illumination soldering PCB terminals snap-action contact 1 NO Au no Mechanical characteristics Operating force Switching travel 3,6+-0,7 N 0,61+-0,1 mm Electrical characteristics Rated voltage min. Rated voltage max. Rated current min. Rated current max. Rated power max. (ohmic load) Contact resistance when new max. Insulation resistance Bouncing time max. 4 - 14 0.02 V 42 V 0.01 mA 100 mA 1W Other specifications Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. (product) Storage temperature max. (in tube) Resistance to constant environment Resistance at variable environment Operating life at RT = 23° C and test force = 1,5 x rated force Solderability / solder heat resistance Flammability of materials Packing Produkt code -40 °C +80 °C -50 °C +85 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 1000000 according to IEC 600 68-2-20 UL 94 HB in boxes à 100 piece F1 100 mΩ 109 Ω 5 ms PCB Keyswitches RACON short-travel keyswitches PCB footprint RACON 12V 10.00 ± 0.10 Drilling hole diagramm view on component side 8.20 14.60 6.20 5.00 2.10 6.00 ± 0.10 Ø1.20 (2x) Circuit Diagram RACON 12V Ø1.50 (3x) 2.20 ± 0.20 Hatched areas: In this area no components and no conductor tracks 15.00 Switching symbols acc. to IEC 617 form X (twice interrupting) view on component side 13.50 5.00 RACON 12 V with vertical adapter 13.60 PCB 6.60 12.70 Terminals Contact arrangement Produkt code Packing Order no. solder terminal tin-plated 1 NO F1 in boxes à 100 piece 1.14.001.505/0000 4 Technical data see page 4 - 14 Plungers for overall height of 6.5 mm may not be used. RACON PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 15 RACON short-travel keyswitches RACON 12 i General data Application note Low-profile keyboards with RACON 12 i components should be designed with a grid spacing of 15.24 mm. With this grid, frame webs remain free between the individual keys. The overlay can be glued onto these frame webs; we recommend area embossing over the keys for the overlays. If our RK 90 system design is used, we recommend the 9 x 9 mm keycaps. Technical data General information Colour of lens Recommended key grid Key grid max. Bouncing time max. see order block 15.24 x 15.24 mm 12.5 x 12.5 mm 4 Dimensions Length Width Overall height 11.35 mm 11.35 mm 9.7 mm RACON Mechanical design Mounting Terminals Contact system Contact arrangement Contact materials Illumination LED colour LED type soldering PCB terminals snap-action contact 1 NO Au fully illuminated 2 LEDs see order block standard 2 mm Mechanical characteristics Operating force Switching travel Electrical characteristics Rated voltage min. Rated voltage max. Rated current min. Rated current max. Rated power max. (ohmic load) Contact resistance when new max. Dielectric strength AC min. Insulation resistance 4 - 16 Other specifications Ambient temp. operating min. Ambient temp. operating max. Resistance to constant environment Resistance at variable environment Operating life at RT = 23° C and test force = 1,5 x rated force Solderability / solder heat resistance Flammability of materials Packing 3.3+-0.6 N 0.34+-0.1 mm 0.02 V 42 V 0.01 mA 100 mA 1W 100 mΩ 750 V 109 Ω 5 ms -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 1000000 according to IEC 600 68-2-20 UL 94 HB tubes à 45 piece Electrical characteristics of LED LED rated current max. IF at 25°C red/green: 30, yellow: 50 mA LED current reduction beginning with 50 degree C red: 0.5 mA/degree C, yellow 0.8 mA/degree C LED wavelength typ. red 639, green 510-535, yellow 590 LED forward voltage UF at 20 mA red: 1.8 V/20 mA, yellow: 1.9 V/20 mA LED breakdown voltage UR at 25°C min. 5 V/0.1 mA PCB Keyswitches RACON short-travel keyswitches RACON 12i typical system assembly RACON 12i smallest grid 12.50 8.90 1.00 4.50 12.50 9.2 ± 0.1 12.00 15.24 7.60 view on component side 8.50 view on component side Explanation Recommended area embossing 0.35 mm at glue spacer thickness of 0.15 mm LED hole patterns Circuit Diagram RACON 12i 7.60 - 1.00 (8x) 4.50 8.90 + - view on component side 8.50 + LED Switching symbols acc. to IEC 60 617 form X (twice interrupting) 4 RACON PCB Keyswitches 4 - 17 RACON short-travel keyswitches RACON 12 i, solder terminals for PCB illuminated are lens red Terminals Contact arrangement Illumination Colour of lens LED colour Order no. PCB terminals 1 NO red red 1.14.001.551/0000 PCB terminals 1 NO green green 1.14.001.552/0000 PCB terminals 1 NO yellow yellow 1.14.001.553/0000 PCB terminals 1 NO orange yellow 1.14.001.554/0000 fully illuminated 2 LEDs fully illuminated 2 LEDs fully illuminated 2 LEDs fully illuminated 2 LEDs Technical data see page 4 - 16 If keycaps are used we recommend RK 90 keycaps 9 x 9 mm. 4 RACON 4 - 18 Stock items are marked by bold printed order numbers. PCB Keyswitches RACON short-travel keyswitches RACON special accessories Pict.: 8 mm Plunger for membrane data entry system 0.50 ø 9.00 figured plunger ø 8.00 2 1 min. 12.00 Pict.: 8 mm 4 RACON min. 4.50 min. 6.50 ± 0.15 3 metal web min. 3.00 Overall height GH Plunger diameter/size RACON version Length of plunger L Order no. 6.5 mm 8 mm RACON 8 Pin 1.6 mm 5.46.167.101/0209 6.5 mm 8 mm RACON 8 SMD 1.5 mm 5.46.167.102/0209 6.5 mm 11.5 mm RACON 8 Pin 1.6 mm 5.46.167.060/0209 6.5 mm 11.5 mm RACON 8 SMD 1.5 mm 5.46.167.061/0209 6.5 mm 14.5 mm RACON 8 Pin 1.6 mm 5.46.168.060/0209 6.5 mm 14.5 mm RACON 8 SMD 1.5 mm 5.46.168.061/0209 6.5 mm 19 mm RACON 8 Pin 1.6 mm 5.46.169.060/0209 6.5 mm 19 mm RACON 8 SMD 1.5 mm 5.46.169.061/0209 7 mm 8 mm RACON 8/12 Pin 2.1 mm 5.46.167.107/0209 7 mm 8 mm RACON 8/12 SMD 2 mm 5.46.167.106/0209 7 mm 11.5 mm RACON 8/12 Pin 2.1 mm 5.46.167.064/0209 7 mm 11.5 mm RACON 8/12 SMD 2 mm 5.46.167.067/0209 7 mm 14.5 mm RACON 8/12 Pin 2.1 mm 5.46.168.064/0209 7 mm 14.5 mm RACON 8/12 SMD 2 mm 5.46.168.067/0209 7 mm 19 mm RACON 8/12 Pin 2.1 mm 5.46.169.064/0209 4 - 20 Stock items are marked by bold printed order numbers. PCB Keyswitches RACON short-travel keyswitches Overall height GH Plunger diameter/size RACON version Length of plunger L Order no. 7 mm 19 mm RACON 8/12 SMD 2 mm 5.46.169.067/0209 9.7 mm 8 mm RACON 8/12 Pin 4.8 mm 5.46.167.094/0209 9.7 mm 8 mm RACON 8/12 SMD 4.7 mm 5.46.167.311/0209 9.7 mm 11.5 mm RACON 8/12 Pin 4.8 mm 5.46.167.047/0209 9.7 mm 11.5 mm RACON 8/12 SMD 4.7 mm 5.46.167.050/0209 9.7 mm 14.5 mm RACON 8/12 Pin 4.8 mm 5.46.168.047/0209 9.7 mm 14.5 mm RACON 8/12 SMD 4.7 mm 5.46.168.050/0209 9.7 mm 19 mm RACON 8/12 Pin 4.8 mm 5.46.169.047/0209 9.7 mm 19 mm RACON 8/12 SMD 4.7 mm 5.46.169.050/0209 12.5 mm 8 mm RACON 8/12 Pin 0.36 mm 5.46.167.096/0209 12.5 mm 8 mm RACON 8/12 SMD 7.5 mm 5.46.167.099/0209 12.5 mm 11.5 mm RACON 8/12 Pin 0.36 mm 5.46.167.058/0209 12.5 mm 11.5 mm RACON 8/12 SMD 7.5 mm 5.46.167.059/0209 12.5 mm 14.5 mm RACON 8/12 Pin 0.36 mm 5.46.168.058/0209 12.5 mm 14.5 mm RACON 8/12 SMD 7.5 mm 5.46.168.059/0209 12.5 mm 19 mm RACON 8/12 Pin 0.36 mm 5.46.169.058/0209 12.5 mm 19 mm RACON 8/12 SMD 7.5 mm 5.46.169.059/0209 4 Front panel cut-out = Plunger diameter + 1 mm. RACON PCB Keyswitches Stock items are marked by bold printed order numbers. 4 - 21 RACON short-travel keyswitches Square plunger for membrane data entry system plunger 3 14.00 2 1 min. 19.05 min. 4.50 min. 7.00 ± 0.15 0.50 15.00 web min. 3.00 Overall height GH Plunger diameter/size RACON version Length of plunger L Order no. 7 mm 14 x 14 mm RACON 12 Pin 2.1 mm 5.46.001.064/0209 9.7 mm 14 x 14 mm RACON 12 Pin 4.8 mm 5.46.001.060/0209 12.5 mm 14 x 14 mm RACON 12 Pin 0.36 mm 5.46.001.063/0209 7 mm 14 x 14 mm RACON 12 SMD 2 mm 5.46.001.057/0209 9.7 mm 14 x 14 mm RACON 12 SMD 4.7 mm 5.46.001.058/0209 12.5 mm 14 x 14 mm RACON 12 SMD 7.5 mm 5.46.001.059/0209 Front panel cut-out = 15 x 15 mm. 4 RACON 4 - 22 Stock items are marked by bold printed order numbers. PCB Keyswitches
5.46.169.047/0209 价格&库存
很抱歉,暂时无法提供与“5.46.169.047/0209”相匹配的价格&库存,您可以联系我们找货
5.46.169.047/0209
  • 159+5.68278
  • 500+4.77595
  • 1000+4.50995
  • 2200+4.23185
  • 2500+4.06258
库存:485
5.46.169.047/0209
    • 1000+7.422381000+0.96098
