1.10.001.001/0104
1.10.001.001/0104
    RAFI
    插件
    按动开关 直插 单刀单掷-常开 700mA -25℃~+85℃
1.10.001.001/0104 数据手册
PUSHBUTTONS PUSHBUTTONS NON-ILLUMINATED - MOUNTING HOLE DIAMETER 15.2 MM PUSHBUTTONS NON-ILLUMINATED 15.2 mm, 250 V / 0.7 A 1 Technical Data £ £ £ £ £ £ General information Form of lens Color of lens Form of collar protruding lens see order block round Dimensions Diameter of collar Overall height Mounting depth Mounting hole 19 mm 8.2 mm 21.5 mm 15.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illumination Lamp socket ring nut see order block bridge contact momentary see order block Ag no no Mechanical characteristics Operating force max. Operating travel Switching travel NC Switching travel NO Robustness max. 7.5 N 3 mm 1.2 mm 2.0 mm 100 N Electrical characteristics Rated voltage AC max. Rated current max. Contact resistance when new max. Contact resistance acc. to life max. 250 V 0.7 A 50 mE 300 mE Other specifications Operating life (operations) Degree of protection from front side Operation temperature min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Environmental resistance Weight Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 ROHS compliant REACH compliant Other Pushb. Panel cut-out Approvals ENEC 25T85 25,000 IP40 acc. to DIN EN 60529 (IP65 with sealing cap) -25 °C +85 °C -40 °C +90 °C acc. to IEC 60068-2-14, -30, -33 and -78 7g V0 yes yes yes 1-79 PUSHBUTTONS PUSHBUTTONS NON-ILLUMINATED - MOUNTING HOLE DIAMETER 15.2 MM Accessories Pushbutton non-illuminated - 15.2 mm, 250 V / 0.7 A £ 1 Description Photo Order no. Additional accessories see page Sealing cap, transparent, for protection acc. to IP65 5.52.008.115/0000 - Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 25 Pushbutton non-illuminated mounting hole diameter 15.2 mm Technical data see page 1 - 79 Other Pushb. screw terminals £ Contact arrangement Contact function Color of lens Terminals Order no. 1 NO momentary opaque red screw terminals 1.10.001.001/0301 1 NO momentary opaque red solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm 1.10.001.011/0301 1 NO momentary opaque green screw terminals 1.10.001.001/0507 1 NO momentary opaque green solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm 1.10.001.011/0507 1 NO momentary opaque white screw terminals 1.10.001.001/0205 1 NO momentary opaque white solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm 1.10.001.011/0205 1 NO momentary opaque black screw terminals 1.10.001.001/0104 1 NO momentary opaque black solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm 1.10.001.011/0104 1 NC momentary opaque red screw terminals 1.10.001.151/0301 1 NC momentary opaque red solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm 1.10.001.161/0301 1 NC momentary opaque black screw terminals 1.10.001.151/0104 1 NC momentary opaque black solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm 1.10.001.161/0104 Quick-connector 6.3 x 0.8 mm. The connector is splitted and also usable for two connectors 2.8 x 0.8 mm. 1-80 Panel cut-out
1.10.001.001/0104 价格&库存
很抱歉,暂时无法提供与“1.10.001.001/0104”相匹配的价格&库存,您可以联系我们找货
