5.49.075.015/1002
5.49.075.015/1002
    RAFI
5.49.075.015/1002 数据手册
LUMOTAST FK 1 LUMO FK General data LUMOTAST FK illuminated pushbutton range • Illuminable pushbuttons and signal lamps with lamp socket T 1/T 11/4. Please order lamps / LEDs separately. • Mounting hole diameter 16.2 mm • 42 V/100 mA max. • Water-jet proof IP65 • Low profile • Keyed socket connector and flat ribbon cable in insulation displacement (IDC) technology or PCB plug-in socket • Time-saving click fixing method: Insert pushbutton into front panel and press pushbutton once to fix it. Content LUMOTAST FK illuminated pushbutton, 42 V/100 mA LUMOTAST FK illuminated pushbutton, square collar, 42 V/100 mA LUMOTAST FK illuminated pushbutton, round collar, 42 V/100 mA LUMOTAST FK illuminated pushbutton, rectangular collar, 42 V/100 mA 1 - 12 1 - 13 1 - 14 1 - 14 LUMOTAST FK signal lamp LUMOTAST FK signal lamp, square collar LUMOTAST FK signal lamp, round collar LUMOTAST FK signal lamp, rectangular collar 1 - 16 1 - 17 1 - 18 1 - 18 Pushbuttons 1-9 LUMOTAST FK Series LUMOTAST FK 16.2 mm mounting hole diameter 1 Design ➁ ➂ LUMO FK ➃ ➀ ➀ Pushbutton as supplied ➁ Insert pushbutton into panel cut-out ➂ Press once to fit ➃ Attach connector with flat-ribbon cable Disassembly 1. Grip body/lens 2. Pull out body/lens 3. Release click lever 4. Pull out pushbutton/signal lamp with cable 1 - 10 Pushbuttons LUMOTAST FK Dimensional drawing With quick connector and flat-ribbon cable Connection diagram (PCB top view) 1 LUMO FK 1 + 4 = pushbutton connection, 2 + 3 = lamp connection With plug-in socket Plug-in socket for PCB Front panel top view PCB hole diagram PCB top view Pushbuttons 1 - 11 LUMOTAST FK 1 LUMO FK General data LUMOTAST FK illuminated pushbutton range • Illuminable pushbuttons and signal lamps with lamp socket T 1/T 11/4. Please order lamps / LEDs separately. • Mounting hole diameter 16.2 mm • 42 V/100 mA max. • Water-jet proof IP65 • Low profile • Keyed socket connector and flat ribbon cable in insulation displacement (IDC) technology or PCB plug-in socket • Time-saving click fixing method: Insert pushbutton into front panel and press pushbutton once to fix it. Content LUMOTAST FK illuminated pushbutton, 42 V/100 mA LUMOTAST FK illuminated pushbutton, square collar, 42 V/100 mA LUMOTAST FK illuminated pushbutton, round collar, 42 V/100 mA LUMOTAST FK illuminated pushbutton, rectangular collar, 42 V/100 mA 1 - 12 1 - 13 1 - 14 1 - 14 LUMOTAST FK signal lamp LUMOTAST FK signal lamp, square collar LUMOTAST FK signal lamp, round collar LUMOTAST FK signal lamp, rectangular collar 1 - 16 1 - 17 1 - 18 1 - 18 Pushbuttons 1-9 LUMOTAST FK Series LUMOTAST FK 16.2 mm mounting hole diameter 1 Design ➁ ➂ LUMO FK ➃ ➀ ➀ Pushbutton as supplied ➁ Insert pushbutton into panel cut-out ➂ Press once to fit ➃ Attach connector with flat-ribbon cable Disassembly 1. Grip body/lens 2. Pull out body/lens 3. Release click lever 4. Pull out pushbutton/signal lamp with cable 1 - 10 Pushbuttons LUMOTAST FK Dimensional drawing With quick connector and flat-ribbon cable Connection diagram (PCB top view) 1 LUMO FK 1 + 4 = pushbutton connection, 2 + 3 = lamp connection With plug-in socket Plug-in socket for PCB Front panel top view PCB hole diagram PCB top view Pushbuttons 1 - 11 LUMOTAST FK LUMOTAST FK illuminated pushbutton, 42 V/100 mA 1 Pict.: with socket connector with plug-in socket for PCB Panel cut-out LUMO FK Technical data General information Actuator Colour of mushroom Form of collar Dimensions Length of collar Width of collar Diameter of collar Overall height Mounting depth with connector Mounting depth with plug-in socket Mounting hole Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket Mechanical characteristics Operating force max. Operating travel Switching travel Robustness min. Electrical characteristics Rated voltage AC/DC max. Rated voltage AC/DC min. Rated current AC/DC max. Rated current AC/DC min. Contact resistance when new max. Contact resistance acc. to life max. Bouncing time max. flat lens see order block see order block see order block see order block see order block 6.6 mm 30.7 mm 33.4 mm 16.2 mm click quick connection pin connector 4-pol./ plug-in socket snap-action contact momentary 1 NO Au yes Bi-Pin T 1/T 1º Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 6N 3 mm 1.9 mm 100 N Weight 42 V 0.02 V 100 mA 0.01 mA 100 mΩ 300 mΩ 5 ms 1,000,000 IP65 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 6g Accessories LUMOTAST FK illuminated pushbutton, 42 V/100 mA Description Photo Order no. Page Filament lamp, Bi-Pin T 11/4 base, 12 V 1.90.180.474/0000 5 - 5 Filament lamp, Bi-Pin T 11/4 base, 28 V 1.90.180.475/0000 5 - 5 LED Bi-Pin T 1 superbright, red, 24 V 1.90.690.351/0000 5 - 17 1 - 12 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST FK LUMOTAST FK illuminated pushbutton, 42 V/100 mA 1 Pict.: with socket connector with plug-in socket for PCB Panel cut-out LUMO FK Technical data General information Actuator Colour of mushroom Form of collar Dimensions Length of collar Width of collar Diameter of collar Overall height Mounting depth with connector Mounting depth with plug-in socket Mounting hole Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket Mechanical characteristics Operating force max. Operating travel Switching travel Robustness min. Electrical characteristics Rated voltage AC/DC max. Rated voltage AC/DC min. Rated current AC/DC max. Rated current AC/DC min. Contact resistance when new max. Contact resistance acc. to life max. Bouncing time max. flat lens see order block see order block see order block see order block see order block 6.6 mm 30.7 mm 33.4 mm 16.2 mm click quick connection pin connector 4-pol./ plug-in socket snap-action contact momentary 1 NO Au yes Bi-Pin T 1/T 1º Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 6N 3 mm 1.9 mm 100 N Weight 42 V 0.02 V 100 mA 0.01 mA 100 mΩ 300 mΩ 5 ms 1,000,000 IP65 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 6g Accessories LUMOTAST FK illuminated pushbutton, 42 V/100 mA Description Photo Order no. Page Filament lamp, Bi-Pin T 11/4 base, 12 V 1.90.180.474/0000 5 - 5 Filament lamp, Bi-Pin T 11/4 base, 28 V 1.90.180.475/0000 5 - 5 LED Bi-Pin T 1 superbright, red, 24 V 1.90.690.351/0000 5 - 17 1 - 12 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST FK Accessories LUMOTAST FK illuminated pushbutton, 42 V/100 mA Description Photo Order no. Page LED Bi-Pin T 1 superbright, green, 24 V 1.90.690.352/0000 5 - 17 LED Bi-Pin T 1 superbright, yellow, 24 V 1.90.690.353/0000 5 - 17 LED Bi-Pin T 1 superbright, blue, 24 V 1.90.690.354/0000 5 - 17 LED Bi-Pin T 1 superbright, white, 24 V 1.90.690.355/0000 5 - 17 LED Bi-Pin T 1, red, 3 V 1.90.691.026/0000 5 - 17 LED Bi-Pin T 1, green, 3 V 1.90.691.027/0000 5 - 17 LED Bi-Pin T 1, yellow, 3 V 1.90.691.028/0000 5 - 17 Plug-in socket for PCB 5.00.645.036/0000 5 - 25 Cable (flat ribbon cable 10 cm with socket connector and male quick connector, AMP 4-pin) 5.03.771.306/0000 5 - 24 Disassembly tool for LUMOTAST FK 5.05.800.041/0000 5 - 24 Flat ribbon cable, 4-wire, 1 m long 5.37.700.124/0000 5 - 25 Socket connector, 4-pin 5.92.025.368/0000 5 - 24 1 LUMO FK LUMOTAST FK illuminated pushbutton, square collar, 42 V/100 mA Pict.: with yellow lens Panel cut-out Contact function Contact arrangement Order no. without lens momentary 1 NO 1.15.114.906/0000 Please include the desired lens in your order. Note Technical data see page 1 - 12 Lenses: Lens, square, transparent colourless: 5.49.075.015/1002 Lens, square, transparent red: 5.49.075.015/1306 Lens, square, transparent yellow: 5.49.075.015/1403 Lens, square, transparent green: 5.49.075.015/1505 Lens, square, transparent blue: 5.49.075.015/1607 A notch on the lamp socket identifies the cathode side. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 13 LUMOTAST FK LUMOTAST FK illuminated pushbutton, round collar, 42 V/100 mA 1 Pict.: with green lens LUMO FK Contact function Contact arrangement Order no. without lens momentary 1 NO 1.15.114.936/0000 Please include the desired lens in your order. Note Technical data see page 1 - 12 Lenses: Lens, round, transparent colourless: 5.49.075.016/1002 Lens, round, transparent red: 5.49.075.016/1306 Lens, round, transparen yellow: 5.49.075.016/1403 Lens, round, transparent green: 5.49.075.016/1505 Lens, round, transparent blue: 5.49.075.016/1607 A notch on the lamp socket identifies the cathode side. LUMOTAST FK illuminated pushbutton, rectangular collar, 42 V/100 mA Pict.: with red lens Panel cut-out Contact function Contact arrangement Order no. without lens momentary 1 NO 1.15.114.966/0000 Please include the desired lens in your order. Note Technical data see page 1 - 12 Lenses: Lens, rectangular, transparen colourless: 5.49.075.017/1002 Lens, rectangular, transparent red: 5.49.075.017/1306 Lens, rectangular, transparent yellow: 5.49.075.017/1403 Lens, rectangular, transparent green: 5.49.075.017/1505 Lens, rectangular, transparent blue: 5.49.075.017/1607 A notch on the lamp socket identifies the cathode side. 1 - 14 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST FK LUMOTAST FK signal lamp 1 Pict.: with socket connector with plug-in socket for PCB Panel cut-out LUMO FK Technical data General information Form of lens Colour of lens Form of collar Dimensions Length of collar Width of collar Mounting depth with connector Mounting depth with plug-in socket Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp Electrical characteristics Voltage limit max. Power limit max. flat lens see order block see order block see order block see order block 30.7 mm 33.4 mm 16.2 mm click quick connection pin connector 4-pol./ plug-in socket Bi-Pin T 1/T 11/4 filament lamp / LED Other specifications Degree of protection from front side Weight Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 24 V 0,7 W IP65 5g -25 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories LUMOTAST FK signal lamp Description Photo Order no. Page Filament lamp, Bi-Pin T 11/4 base, 12 V 1.90.180.474/0000 5 - 5 Filament lamp, Bi-Pin T 11/4 base, 28 V 1.90.180.475/0000 5 - 5 LED Bi-Pin T 1 superbright, red, 24 V 1.90.690.351/0000 5 - 17 LED Bi-Pin T 1 superbright, green, 24 V 1.90.690.352/0000 5 - 17 LED Bi-Pin T 1 superbright, yellow, 24 V 1.90.690.353/0000 5 - 17 LED Bi-Pin T 1 superbright, blue, 24 V 1.90.690.354/0000 5 - 17 LED Bi-Pin T 1 superbright, white, 24 V 1.90.690.355/0000 5 - 17 1 - 16 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST FK Accessories LUMOTAST FK signal lamp Description Photo Order no. Page LED Bi-Pin T 1, red, 3 V 1.90.691.026/0000 5 - 17 LED Bi-Pin T 1, green, 3 V 1.90.691.027/0000 5 - 17 LED Bi-Pin T 1, yellow, 3 V 1.90.691.028/0000 5 - 17 Plug-in socket for PCB 5.00.645.036/0000 5 - 25 Cable (flat ribbon cable 10 cm with socket connector and male quick connector, AMP 4-pin) 5.03.771.306/0000 5 - 24 Disassembly tool for LUMOTAST FK 5.05.800.041/0000 5 - 24 Flat ribbon cable, 4-wire, 1 m long 5.37.700.124/0000 5 - 25 Socket connector, 4-pin 5.92.025.368/0000 5 - 24 1 LUMO FK LUMOTAST FK signal lamp, square collar Pict.: with red lens Power limit max. 0.7 W Panel cut-out Voltage limit max. Lamp socket Order no. without lens Note 24 V Bi-Pin T 1/T 11/4 1.65.121.906/0000 Please include the desired lens in your order. Technical data see page 1 - 16 Lenses: Lens, square, transparent colourless: 5.49.075.015/1002 Lens, square, transparent red: 5.49.075.015/1306 Lens, square, transparent yellow: 5.49.075.015/1403 Lens, square, transparent green: 5.49.075.015/1505 Lens, square, transparent blue: 5.49.075.015/1607 Do not press in lens in disassembled condition. A notch on the lamp socket identifies the cathode side. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 17 LUMOTAST FK LUMOTAST FK signal lamp, round collar 1 Pict.: with yellow lens Power limit max. 0.7 W LUMO FK Voltage limit max. Lamp socket Order no. without lens 24 V Bi-Pin T 1/T 11/4 1.65.121.936/0000 Please include the desired lens in your order. Note Technical data see page 1 - 16 Lenses: Lens, round, transparent colourless: 5.49.075.016/1002 Lens, round, transparent red: 5.49.075.016/1306 Lens, round, transparent yellow: 5.49.075.016/1403 Lens, round, transparent green: 5.49.075.016/1505 Lens, round, transparent blue: 5.49.075.016/1607 Do not press in lens in disassembled condition. A notch on the lamp socket identifies the cathode side. LUMOTAST FK signal lamp, rectangular collar Pict.: with blue lens Power limit max. 0.7 W Panel cut-out Voltage limit max. Lamp socket Order no. without lens Note 24 V Bi-Pin T 1/T 11/4 1.65.121.966/0000 Please include the desired lens in your order. Technical data see page 1 - 16 Lenses: Lens, rectangular, transparent colourless: 5.49.075.017/1002 Lens, rectangular, transparent red: 5.49.075.017/1306 Lens, rectangular, transparent yellow: 5.49.075.017/1403 Lens, rectangular, transparent green: 5.49.075.017/1505 Lens, rectangular, transparent blue: 5.49.075.017/1607 Do not press in lens in disassembled condition. A notch on the lamp socket identifies the cathode side. 1 - 18 Stock items are marked by bold printed order numbers. Pushbuttons
5.49.075.015/1002 价格&库存
很抱歉,暂时无法提供与“5.49.075.015/1002”相匹配的价格&库存,您可以联系我们找货
