1.01.102.001/0104
1.01.102.001/0104
    RAFI
    插件
    按动开关 直插 双刀单掷-常开 2A -25℃~+85℃
1.01.102.001/0104 数据手册
Other pushbuttons Pushbutton, opaque, mounting hole diameter 18.2 mm, 250 V/2 A 1 Pict.: green Mounting hole Technical data General information Form of lens Colour of lens Form of collar Other Pushb. Electrical characteristics Rated voltage AC max. Rated current max. Contact resistance acc. to life max. protruding lens see order block round Dimensions Diameter of collar Overall height Mounting depth Mounting hole 22 mm 10.5 mm 34 mm 18.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut see order block sliding bridge contact momentary see order block Ag no no Mechanical characteristics Operating force max. Operating travel Switching travel NC Switching travel NO Robustness min. Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 9.5 N 5 mm 2.1 mm 3.7 mm 100 N Weight Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 250 V 2A 200 mΩ 50000 IP40 (IP65 with sealing cap) -25 °C +85 °C -40 °C +90 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 14 g V0 yes Accessories Pushbutton, opaque, mounting hole diameter 18.2 mm, 250 V/2 A Description Photo Order no. Neoprene sealing cap, black 5.52.008.061/0100 Neoprene sealing cap, red 5.52.008.061/0300 Neoprene sealing cap, green 5.52.008.061/0500 Protective sleeve for terminals 5.52.011.028/0100 1 - 82 Stock items are marked by bold printed order numbers. Page Pushbuttons Other pushbuttons Accessories Pushbutton, opaque, mounting hole diameter 18.2 mm, 250 V/2 A Description Photo Fixing spanner M 18, M 19 Order no. Page 5.58.002.017/0105 5 - 23 1 Pushbutton, opaque, mounting hole diameter 18.2 mm, 250 V/2 A Pict.: green Mounting hole Contact arrangement Contact function Illuminability Terminals Colour of lens Order no. 2 NO momentary no screw terminals opaque black 1.01.102.001/0104 2 NO momentary no screw terminals opaque red 1.01.102.001/0301 2 NO momentary no screw terminals opaque green 1.01.102.001/0507 1 NC + 1 NO momentary no screw terminals opaque black 1.01.102.011/0104 1 NC + 1 NO momentary no screw terminals opaque white 1.01.102.011/0205 1 NC + 1 NO momentary no screw terminals opaque red 1.01.102.011/0301 1 NC + 1 NO momentary no screw terminals opaque green 1.01.102.011/0507 Technical data see page 1 - 82 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 83 Other Pushb.
1.01.102.001/0104 价格&库存
很抱歉,暂时无法提供与“1.01.102.001/0104”相匹配的价格&库存,您可以联系我们找货
1.01.102.001/0104
  • 100+110.71607100+14.33970
1.01.102.001/0104
  • 6+160.38715
  • 17+134.87513
  • 36+126.84671
  • 76+119.72511
  • 100+113.32897
库存:5
