Control components
Page
RAFIX 16
RAFIX 16 pushbutton
RAFIX 16 selector switch
RAFIX 16 keylock switch MICROMEC
RAFIX 16 keylock switch, RONIS
RAFIX 16 mushroom-headed pushbutton
RAFIX 16 emergency stop pushbutton
RAFIX 16 toggle switch
RAFIX 16 potentiometer drive
RAFIX 16 buzzer
RAFIX 16 signal indicator
RAFIX 16 contact blocks with gold contacts
RAFIX 16 contact blocks with silver contacts
RAFIX 16 lamp socket
RAFIX 16 special accessories
RAFIX 16 F
RAFIX 16 F pushbutton
RAFIX 16 F selector switch
RAFIX 16 F keylock switch MICROMEC
RAFIX 16 F emergency stop pushbutton
RAFIX 16 F signal indicator
RAFIX 16 F special accessories
RAFIX 22 QR
RAFIX 22 QR pushbutton
RAFIX 22 QR selector switch
RAFIX 22 QR keylock switch
RAFIX 22 QR mushroom-headed pushbutton
RAFIX 22 QR emergency stop pushbutton, dupe-proof to EN 418
RAFIX 22 QR toggle switch
RAFIX 22 QR twin pushbutton
RAFIX 22 QR potentiometer drive
RAFIX 22 QR buzzer
RAFIX 22 QR signal indicator
RAFIX 22 QR contact blocks with silver contacts
RAFIX 22 QR contact blocks with gold contacts
Contact blocks with coupling, gold contacts, RJ 12 connector, integrated LED
RAFIX 22 QR lamp sockets BA 9s (MBC/MCC), screw terminals and cage clamp terminals
RAFIX 22 QR lamp sockets with integrated LED, screw terminals
RAFIX 22 QR special accessories
RAFIX 22 FS
RAFIX 22 FS pushbuttons
RAFIX 22 FS selector switches
RAFIX 22 FS keylock switch
RAFIX 22 FS emergency stop pushbutton
RAFIX 22 FS signal indicator
RAFIX 22 FS contact blocks with gold contacts
RAFIX 22 FS contact blocks with silver contacts
RAFIX 22 FS special accessories
Control components
2- 3
2- 8
2 - 18
2 - 22
2 - 26
2 - 30
2 - 34
2 - 40
2 - 42
2 - 44
2 - 46
2 - 52
2 - 56
2 - 60
2 - 62
2 - 69
2 - 70
2 - 74
2 - 76
2 - 78
2 - 80
2 - 82
2 - 83
2 - 88
2 - 96
2 - 102
2 - 106
2 - 110
2 - 114
2 - 116
2 - 118
2 - 120
2 - 122
2 - 124
2 - 128
2 - 132
2 - 134
2 - 138
2 - 140
2 - 147
2 - 152
2 - 160
2 - 164
2 - 168
2 - 172
2 - 174
2 - 176
2 - 178
2-1
2
RAFIX 16
2
RAFIX
16
General data
RAFIX 16 control component range
• For a mounting hole diameter of 16.2 mm to IEC 60947
• 250V/6A max.
• Water-jet proof IP65
• Contact blocks: Gold and silver contacts with quick-connect terminals 2.8 x 0.8 mm; Option: PCB plug-in socket
• 3 collar shapes, low-profile design
• The lamps of the pushbuttons can be replaced from the front or rear.
• The contact blocks snap directly onto the actuators without a coupling element and can be easily removed by turning =
cost reducing assembly.
The specified data apply only if actuators/signal indicators are combined with contact blocks and lamp sockets within the
same product range.
Content
RAFIX 16 pushbutton
RAFIX 16 pushbutton, flush lens, square collar
RAFIX 16 pushbutton, protruding lens, square collar
RAFIX 16 pushbutton, protruding collar, square collar
RAFIX 16 pushbutton, flush lens, round collar
RAFIX 16 pushbutton IP66 with protective cap
RAFIX 16 pushbutton, protruding lens, round collar
RAFIX 16 pushbutton, protruding collar, round collar
RAFIX 16 pushbutton, flush lens, square collar, alignable without gaps
2- 8
2- 9
2 - 10
2 - 11
2 - 12
2 - 13
2 - 14
2 - 15
2 - 16
RAFIX 16 selector switch, square collar
RAFIX 16 selector switch, round collar
RAFIX 16 selector switch, square collar, alignable without gaps
2 - 18
2 - 19
2 - 20
2 - 21
RAFIX 16 keylock switch MICROMEC, square collar
RAFIX 16 keylock switch MICROMEC, round collar
RAFIX 16 keylock switch MICROMEC, square collar, alignable without gaps
2 - 22
2 - 23
2 - 24
2 - 25
RAFIX 16 keylock switch, RONIS, square collar
RAFIX 16 keylock switch, RONIS, round collar
Keylock switch, RONIS, square collar, alignable without gaps
2 - 26
2 - 27
2 - 28
2 - 29
Control components
2-3
RAFIX 16
2
RAFIX
16
RAFIX 16 mushroom-headed pushbutton, square collar
RAFIX 16 mushroom-headed pushbutton, round collar
RAFIX 16 mushroom-headed pushbutton, square collar, alignable without gaps
2 - 30
2 - 31
2 - 31
2 - 32
RAFIX 16 emergency stop pushbutton, square collar, illuminated
RAFIX 16 emergency stop pushbutton, square collar, dupe-proof
RAFIX 16 emergency stop pushbutton, round collar, illuminated
RAFIX 16 emergency stop pushbutton, round collar, dupe-proof
RAFIX 16 emergency stop pushbutton, square collar, alignable without gaps, illuminated
RAFIX 16 emergency stop pushbutton, square collar, alignable without gaps, dupe-proof
RAFIX 16 safety emergency stop pushbutton, round collar, dupe-proof, non-blocking
RAFIX 16 safety emergency stop pushbutton, round collar, conical, dupe-proof, non-blocking
2 - 34
2 - 35
2 - 35
2 - 36
2 - 36
2 - 37
2 - 37
2 - 38
2 - 38
RAFIX 16 toggle switch, square collar
RAFIX 16 toggle switch, round collar
RAFIX 16 toggle switch, square collar, alignable without gaps
2 - 40
2 - 41
2 - 41
2 - 41
RAFIX 16 potentiometer drive, square collar
RAFIX 16 potentiometer drive, round collar
RAFIX 16 potentiometer drive, square collar, alignable without gaps
2 - 42
2 - 43
2 - 43
2 - 43
RAFIX 16 buzzer
RAFIX 16 buzzer, square collar
RAFIX 16 buzzer, round collar
RAFIX 16 buzzer, square collar, alignable without gaps
2 - 44
2 - 45
2 - 45
2 - 45
RAFIX 16 signal indicator, square lens
RAFIX 16 signal indicator, square collar, flush lens
RAFIX 16 signal indicator, round lens
RAFIX 16 signal indicator, square collar, protruding lens
RAFIX 16 signal indicator, round collar, flush lens
RAFIX 16 signal indicator, round collar, protruding lens
RAFIX 16 signal indicator, square collar, alignable without gaps, flush lens
RAFIX 16 signal indicator, square collar, alignable without gaps, protruding lens
2 - 46
2 - 47
2 - 47
2 - 48
2 - 48
2 - 49
2 - 49
2 - 50
2 - 50
RAFIX 16 standard contact block, gold contacts, with lamp socket
RAFIX 16 standard contact block, gold contacts, without lamp socket
RAFIX 16 universal contact block, gold contacts, with lamp socket
RAFIX 16 universal contact block, gold contacts, without lamp socket
2 - 52
2 - 54
2 - 54
2 - 55
2 - 55
RAFIX 16 standard contact block, silver contacts, with lamp socket
RAFIX 16 standard contact block, silver contacts, without lamp socket
RAFIX 16 universal contact block, silver contacts, with lamp socket
RAFIX 16 universal contact block, silver contacts, without lamp socket
2 - 56
2 - 58
2 - 58
2 - 59
2 - 59
RAFIX 16 lamp socket W 2 x 4.6 d
2 - 60
2 - 61
2 - 61
PCB plug-in socket
Multipole connector
Female quick-connect terminal DIN 46340-B 2.8-1-MS
Plug distributor
Protection against contact
Series capacitor
Disassembly tool
Protective cover, suitable for lead seal, for pushbuttons, alignable without gaps
Fixing spanner for hexagon nut
RAFIX 16 insulating housing
RAFIX 16 label holder, flush, for square collar
RAFIX 16 label holder, flush, for round collar
RAFIX 16 label holder, protruding, for square flush fitting collar
Emergency stop label, yellow, round 60 mm, PVC adhesive
LUMOTAST 25, RAFIX 16 blanking cap complete with sealing disc and ring nut
2 - 62
2 - 62
2 - 63
2 - 63
2 - 63
2 - 64
2 - 64
2 - 64
2 - 65
2 - 65
2 - 65
2 - 66
2 - 66
2 - 67
2 - 67
2 - 68
2 - 68
2-4
Control components
RAFIX 16
General information
RAFIX 16 is a complete control component series for a mounting hole diameter of 16.2 mm. It enables you to design attractive control panels with a minimum of space requirements and at the same time sufficiently large actuating areas.
Actuators
Contact blocks
– Mounting hole ø 16.2 mm to DIN EN 50 007
– Standard (for actuators with one-way operation)
• with latching mechanism (latching switch)
• without latching mechanism (momentary switch)
– Universal (for actuators with two-way operation, e. g.
selector switches)
2
Contact material
RAFIX
16
– Silver contacts for mains voltage
– Gold contacts for electronic circuits
Illumination
- Wedge base lamp W 2 x 4.6 d
Assembly
Single-handed cost-effectiv assembly method
Panel thickness 0.5 … 5 mm
Fixing with hexagon nut
Starting torque 1.2 Nm max.
Shock-resistance according to IEC 600 68-2-27
– Shock amplitude: ≤ 50 g
– Shock time: 11 ms
– Shock type: half sinusoidal
– Locating lug (easily removable).
The locating lug can be easily removed using a screwdriver.
– Degree of protection IP 65 on panel.
This is achieved by a reliable, tried and tested special
seal.
– Grid spacing 25 x 25 mm
– Low-profile design, 7 mm height from front panel
– Three collar shapes, in black
• Square 25 x 25 mm
• Round 25 mm
• Square 25 x 25 mm, alignable in flush fitting rows,
which avoids accumulation of dirt between the collars.
Control Components
Environment conditions
– Constant environment: acc. to IEC 600 68-2-3 and 2-30
– Variable environment: acc. to IEC 600 68-2-14 and 2-33
Temperature range
– Operating temperature:
non-illuminated: - 25 … + 70 ° C
illuminated: - 25 … + 55° C
– Storage temperature: - 40 … + 85° C
2-5
RAFIX 16
CE-Conformity RAFIX 16
Combination
actuator and
contact block
Order no.
Limit
All actuators
All contact blocks with silver contacts
Emergency stop
Contact blocks with silver contacts
Emergency stop, Universal
Signal indicator
lamp socket
1.3007–.– – –
1.2012–.– – –
1.30074.– – –
1.20123.– – –
1.30074.– – –
1.20123.– – –
1.62124.– – –
1.71212.– – –
EU-Directive
NSR 73/23
6(4) A/250 V AC
6(4) A/250 V AC
250 mA/42 V AC/DC
1,2 W/60 V AC/DC
Ma. Dir. 89/392
2
Assembly
– Insert the actuator through the panel cut-out from the
front.
If there is no locating indent provided in the cut-out,
first remove the locating lug using a screwdriver.
– Screw the hexagon nut onto the actuator or signal indicator from the rear and tighten it using a fixing spanner.
– Slide the contact block onto the actuator from the rear
with an audible click.
– Install protection against accidental contact, if applicable.
– Connect quick-connect terminals.
– Alternatively, connect crimped female quick-connect
terminals to multipole connector and plug it onto the
contact block.
– Alternatively, conntact the plug-in socket soldered onto
the PCB.
RAFIX
16
Assembly/Disassembly
Disassembly
– Turn the contact block by approx. 20° to the left or
right – the latches open.
– Pull the contact block off towards the rear (commercially available flat nose pliers recommended).
To dismount a PCB, pull the PCB with the soldered plug-in
sockets off the mounted contact blocks.
2-6
Control Components
RAFIX 16
Legending
Lamp replacement from front
All elements can be labelled using a separate label holder.
The label holder is mounted together with the actuator/
signal indicator. For order numbers and standard legend,
refer to the section ”Legending”. Non-illuminated pushbuttons and mushroom-headed pushbuttons can be printed or laser engraved.
All illuminated pushbuttons and the majority of the signal
indicators can be labelled by means of legend inserts.
The legend inserts are fitted between actuator body and
lens and can be easily changed.
RAFI can also provide you custom legending. Price and
delivery on request.
Use the disassembly tool to grasp the actuator body and
pull it towards the front with the lens.
Alternatively, you can use a screwdriver in place of the
disassembly tool. In this case, insert the screwdriver
between actuator body and collar and carefully raise the
actuator body.
Replace the lamp using a lamp extractor or a suitable
insulation sleeve.
2
RAFIX
16
Control Components
2-7
RAFIX 16
RAFIX 16 pushbutton
Pict.: transparent red
2
RAFIX
16
with contact block
Panel cut-out
Technical data
General information
Form of lens
Colour of lens
Form of collar
Mechanical characteristics
Operating travel
Robustness min.
mushroom
see order block
see order block
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
see order block
see order block
25 x 25 mm
see order block
see order block
44.7 mm
16.2 mm
Mechanical design
Mounting
Contact function
Contact arrangement
Illuminability
ring nut
according to contact block
see order block
Other specifications
Operating life
from front side
Ambient temp. operating
min.
without lamp max.
Storage temperature min.
Storage temperature max.
Resistance to constant
environment
Resistance at variable
environment
3 mm
100 N
2000000
IP65
-25 °C
+70 °C
-40 °C
+85 °C
according to
according to
Accessories RAFIX 16 pushbutton
Description
Order no.
Page
RAFIX 16 standard contact block, 1 NC + 1 NO,
momentary, silver contacts, with lamp socket
1.20.122.001/0000 2 - 58
momentary, gold contacts, with lamp socket
1.20.122.011/0000 2 - 54
momentary, silver contacts, without lamp socket
1.20.122.021/0000 2 - 58
momentary, gold contacts, without lamp socket
1.20.122.031/0000 2 - 54
LED W 2 x 4.6d superbright, white, 24 V
1.90.690.365/0000 5 - 16
Disassembly tool for LUMOTAST 25, RAFIX 16
5.05.800.042/0000 2 - 65
5 - 24
Label holder, flush, for square collar
5.07.620.004/0000 2 - 66
2-8
Stock items are marked
by bold printed order numbers.
Control components
RAFIX 16
Description
Order no.
Page
5.58.002.034/0000 2 - 65
Legend insert, blank, use only for transparent lenses
5.70.635.000/2000
2
Pict.: transparent white
Illuminability
Panel cut-out
Colour of lens
Order no. complete
RAFIX
16
Order no. single parts
Housing
Lens
yes
transparent colourless
1.30.070.001/1002 1.30.070.501/0000 5.49.077.011/1002
yes
transparent red
1.30.070.001/1306 1.30.070.501/0000 5.49.077.011/1306
yes
transparent yellow
1.30.070.001/1403 1.30.070.501/0000 5.49.077.011/1403
yes
transparent green
1.30.070.001/1505 1.30.070.501/0000 5.49.077.011/1505
yes
transparent blue
1.30.070.001/1607 1.30.070.501/0000 5.49.077.011/1607
no
opaque black
1.30.070.251/0100 1.30.070.751/0000 5.05.510.640/0100
no
opaque white
1.30.070.251/0200 1.30.070.751/0000 5.05.510.640/0200
no
opaque red
1.30.070.251/0300 1.30.070.751/0000 5.05.510.640/0300
no
opaque yellow
1.30.070.251/0400 1.30.070.751/0000 5.05.510.640/0400
no
opaque green
1.30.070.251/0500 1.30.070.751/0000 5.05.510.640/0500
no
opaque blue
1.30.070.251/0600 1.30.070.751/0000 5.05.510.640/0600
Technical data see page 2 - 8
Accessories:
Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000
For the „latching“ function, please use the standard contact block with „latching“ function.
Control components
2-9
RAFIX 16
Pict.: opaque yellow
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
2
RAFIX
16
Lens
yes
1.30.070.051/1002 1.30.070.551/0000 5.49.077.012/1002
yes
transparent red
1.30.070.051/1306 1.30.070.551/0000 5.49.077.012/1306
yes
transparent yellow
1.30.070.051/1403 1.30.070.551/0000 5.49.077.012/1403
yes
transparent green
1.30.070.051/1505 1.30.070.551/0000 5.49.077.012/1505
yes
transparent blue
1.30.070.051/1607 1.30.070.551/0000 5.49.077.012/1607
no
opaque black
1.30.070.301/0100 -
no
opaque white
1.30.070.301/0200 -
no
opaque red
1.30.070.301/0300 -
no
opaque yellow
1.30.070.301/0400 -
no
opaque green
1.30.070.301/0500 -
no
opaque blue
1.30.070.301/0600 -
Accessories:
2 - 10
Control components
RAFIX 16
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
Lens
yes
1.30.070.101/1002 1.30.070.601/0000 5.49.077.011/1002
yes
transparent red
1.30.070.101/1306 1.30.070.601/0000 5.49.077.011/1306
yes
transparent yellow
1.30.070.101/1403 1.30.070.601/0000 5.49.077.011/1403
yes
transparent green
1.30.070.101/1505 1.30.070.601/0000 5.49.077.011/1505
yes
transparent blue
1.30.070.101/1607 1.30.070.601/0000 5.49.077.011/1607
no
opaque black
1.30.070.351/0100 1.30.070.851/0000 5.05.510.640/0100
no
opaque white
1.30.070.351/0200 1.30.070.851/0000 5.05.510.640/0200
no
opaque red
1.30.070.351/0300 1.30.070.851/0000 5.05.510.640/0300
no
opaque yellow
1.30.070.351/0400 1.30.070.851/0000 5.05.510.640/0400
no
opaque green
1.30.070.351/0500 1.30.070.851/0000 5.05.510.640/0500
no
opaque blue
1.30.070.351/0600 1.30.070.851/0000 5.05.510.640/0600
Accessories:
The protruding collar offers protection against inadvertent operation and thereby fulfils the safety requirements of various machinery
manufacturers, particularly in the printing industry.
For the "latching" function, please use the standard contact block with "latching" function.
Control components
2 - 11
2
RAFIX
16
RAFIX 16
Pict.: opaque blue
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
2
RAFIX
16
Lens
yes
1.30.070.021/1002 1.30.070.521/0000 5.49.259.017/1002
yes
transparent red
1.30.070.021/1306 1.30.070.521/0000 5.49.259.017/1306
yes
transparent yellow
1.30.070.021/1403 1.30.070.521/0000 5.49.259.017/1403
yes
transparent green
1.30.070.021/1505 1.30.070.521/0000 5.49.259.017/1505
yes
transparent blue
1.30.070.021/1607 1.30.070.521/0000 5.49.259.017/1607
no
opaque black
1.30.070.271/0100 1.30.070.771/0000 5.05.510.641/0100
no
opaque white
1.30.070.271/0200 1.30.070.771/0000 5.05.510.641/0200
no
opaque red
1.30.070.271/0300 1.30.070.771/0000 5.05.510.641/0300
no
opaque yellow
1.30.070.271/0400 1.30.070.771/0000 5.05.510.641/0400
no
opaque green
1.30.070.271/0500 1.30.070.771/0000 5.05.510.641/0500
no
opaque blue
1.30.070.271/0600 1.30.070.771/0000 5.05.510.641/0600
Accessories:
Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000
2 - 12
Control components
RAFIX 16
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
Lens
yes
1.30.070.026/1002 -
yes
transparent red
1.30.070.026/1306 -
yes
transparent yellow
1.30.070.026/1403 -
yes
transparent green
1.30.070.026/1505 -
yes
transparent blue
1.30.070.026/1607 -
no
opaque black
1.30.070.276/0100 -
no
opaque white
1.30.070.276/0200 -
no
opaque red
1.30.070.276/0300 -
no
opaque yellow
1.30.070.276/0400 -
no
opaque green
1.30.070.276/0500 -
no
opaque blue
1.30.070.276/0600 -
2
RAFIX
16
Accessories:
Pushbutton for use in hostile environments. A transparent protective cap ensures a degree of protection of IP 66 to DIN/IEC. Operating
life: 500,000 operations.
Control components
2 - 13
RAFIX 16
Pict.: opaque red
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
2
RAFIX
16
Lens
yes
1.30.070.071/1002 1.30.070.571/0000 5.49.259.018/1002
yes
transparent red
1.30.070.071/1306 1.30.070.571/0000 5.49.259.018/1306
yes
transparent yellow
1.30.070.071/1403 1.30.070.571/0000 5.49.259.018/1403
yes
transparent green
1.30.070.071/1505 1.30.070.571/0000 5.49.259.018/1505
yes
transparent blue
1.30.070.071/1607 1.30.070.571/0000 5.49.259.018/1607
no
opaque black
1.30.070.321/0100 -
no
opaque white
1.30.070.321/0200 -
no
opaque red
1.30.070.321/0300 -
no
opaque yellow
1.30.070.321/0400 -
no
opaque green
1.30.070.321/0500 -
no
opaque blue
1.30.070.321/0600 -
Accessories:
2 - 14
Control components
RAFIX 16
Pict.: opaque red
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
Lens
yes
1.30.070.121/1002 1.30.070.621/0000 5.49.259.017/1002
yes
transparent red
1.30.070.121/1306 1.30.070.621/0000 5.49.259.017/1306
yes
transparent yellow
1.30.070.121/1403 1.30.070.621/0000 5.49.259.017/1403
yes
transparent green
1.30.070.121/1505 1.30.070.621/0000 5.49.259.017/1505
yes
transparent blue
1.30.070.121/1607 1.30.070.621/0000 5.49.259.017/1607
no
opaque black
1.30.070.371/0100 1.30.070.871/0000 5.05.510.641/0100
no
opaque white
1.30.070.371/0200 1.30.070.871/0000 5.05.510.641/0200
no
opaque red
1.30.070.371/0300 1.30.070.871/0000 5.05.510.641/0300
no
opaque yellow
1.30.070.371/0400 1.30.070.871/0000 5.05.510.641/0400
no
opaque green
1.30.070.371/0500 1.30.070.871/0000 5.05.510.641/0500
no
opaque blue
1.30.070.371/0600 1.30.070.871/0000 5.05.510.641/0600
Accessories:
Control components
2 - 15
2
RAFIX
16
RAFIX 16
Pict.: opaque black
Illuminability
Panel cut-out
Colour of lens
Order no. complete
Housing
2
RAFIX
16
Lens
yes
1.30.070.201/1002 1.30.070.701/0000 5.49.077.011/1002
yes
transparent red
1.30.070.201/1306 1.30.070.701/0000 5.49.077.011/1306
yes
transparent yellow
1.30.070.201/1403 1.30.070.701/0000 5.49.077.011/1403
yes
transparent green
1.30.070.201/1505 1.30.070.701/0000 5.49.077.011/1505
yes
transparent blue
1.30.070.201/1607 1.30.070.701/0000 5.49.077.011/1607
no
opaque black
1.30.070.451/0100 1.30.070.951/0000 5.05.510.640/0100
no
opaque white
1.30.070.451/0200 1.30.070.951/0000 5.05.510.640/0200
no
opaque red
1.30.070.451/0300 1.30.070.951/0000 5.05.510.640/0300
no
opaque yellow
1.30.070.451/0400 1.30.070.951/0000 5.05.510.640/0400
no
opaque green
1.30.070.451/0500 1.30.070.951/0000 5.05.510.640/0500
no
opaque blue
1.30.070.451/0600 1.30.070.951/0000 5.05.510.640/0600
Accessories:
2 - 16
Control components
RAFIX 16
Pict.: red
2
RAFIX
16
Panel cut-out
Technical data
General information
Actuator
Colour of mushroom
Form of collar
Operating travel
Robustness min.
mushroom
red
see order block
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
see order block
see order block
25 x 25 mm
see order block
see order block
see order block
see order block
Mechanical design
Mounting
Contact function
Contact arrangement
Illuminability
ring nut
no
Operating life
from front side
min.
without lamp max.
environment
environment
3 mm
100 Nm
2000000
IP65
-25 °C
+70 °C
-40 °C
+85 °C
according to
according to
Accessories RAFIX 16 mushroom-headed pushbutton
Description
Order no.
Page
For other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“.
2 - 30
Control components
RAFIX 16
Pict.: red
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
opaque black
1.30.071.001/0100
no
opaque red
1.30.071.001/0300
2
Technical data see page 2 - 30
RAFIX
16
Pict.: red
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
opaque black
1.30.071.021/0100
no
opaque red
1.30.071.021/0300
Control components
2 - 31
RAFIX 16
Pict.: red
2
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
opaque black
1.30.071.041/0100
no
opaque red
1.30.071.041/0300
RAFIX
16
2 - 32
Control components
RAFIX 16
Pict.: red
2
RAFIX
16
Panel cut-out
Technical data
General information
Actuator
Colour of mushroom
Form of collar
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
Mechanical design
Mounting
Contact function
Contact arrangement
Illuminability
Reset
Robustness min.
Robustness
mushroom
see order block
see order block
see order block
see order block
25 x 25 mm
see order block
see order block
see order block
see order block
ring nut
latching
see order block
counterclockwise or clockwise rotation
Operating life
from front side
min.
without lamp max.
with lamp max.
environment
environment
Corresponding to CE
Ma-Dir. 89/392
Approvals
100 N
acc. IEC 60947-5-5
30000
IP65
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
according to
according to
yes
IEC 60204, IEC 73
Accessories RAFIX 16 emergency stop pushbutton
Description
Order no.
Page
RAFIX 16 universal contact block, 1 NC, momentary,
1.20.123.022/0000 2 - 59
1.20.123.032/0000 2 - 55
Emergency stop label, yellow, round 60 mm, PVC adhesive, without legend
5.76.204.400/0400 2 - 68
For suitable LEDs, filament lamps and other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories,
2 - 34
Control components
RAFIX 16
Pict.: red
Panel cut-out
Illuminability
Colour of mushroom
Order no.
yes
translucent red
1.30.074.501/0304
2
Technical data see page 2 - 34
Only use universal contact blocks.
RAFIX
16
Pict.: red
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
opaque red
1.30.074.101/0301
The positively driven mechanical arrangement is dupe-proof to EN 418.
Control components
2 - 35
RAFIX 16
Pict.: red
2
Panel cut-out
Illuminability
Colour of mushroom
Order no.
yes
translucent red
1.30.074.521/0304
RAFIX
16
Pict.: red
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
opaque red
1.30.074.121/0301
2 - 36
Control components
RAFIX 16
illuminated
19,20
25,00
M16x1
R50
15,40
0,5...5,0
19,30
Pict.: red
Panel cut-out
Illuminability
Colour of mushroom
Order no.
yes
translucent red
1.30.074.541/0304
2
dupe-proof
Pict.: red
RAFIX
16
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
opaque red
1.30.074.141/0301
Control components
2 - 37
RAFIX 16
Panel cut-out
2
Illuminability
Colour of mushroom
Order no.
no
opaque red, collar yellow
1.30.074.821/0000
Special shape prevents blocking: Actuation cannot be interrupted by any jamming objects.
RAFIX
16
non-blocking
Panel cut-out
Illuminability
Colour of mushroom
Order no.
no
1.30.074.281/0300
2 - 38
Control components
RAFIX 16
Pict.: black
2
RAFIX
16
Panel cut-out
Technical data
General information
Actuator
Colour of toggle
Form of collar
from front side
min.
without lamp max.
with lamp max.
environment
toggle
see order block
see order block
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
see order block
see order block
25 x 25 mm
see order block
18.4 mm
44.7 mm
16.2 mm
Mechanical design
Mounting
Contact function
Contact arrangement
Illuminability
ring nut
latching
no
Robustness min.
100 N
environment
Operating life
(operations)
IP65
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
according to
according to
300000
Accessories RAFIX 16 toggle switch
Description
Order no.
Page
2 - 40
Control components
RAFIX 16
Pict.: black handle
Panel cut-out
Contact function
Illuminability
Colour of toggle
Order no.
latching
no
opaque black
1.30.075.001/0104
2
Technical data see page 2 - 40
Only use contact blocks with "momentary" contact function.
RAFIX
16
Pict.: black handle
Panel cut-out
Contact function
Illuminability
Colour of toggle
Order no.
latching
no
opaque black
1.30.075.021/0104
Pict.: black
Panel cut-out
Contact function
Illuminability
Colour of toggle
Order no.
latching
no
opaque black
1.30.075.041/0104
Only use contact blocks with „momentary“ contact function.
Control components
2 - 41
RAFIX 16
Pict.: with potentiometer (not included)
2
Panel cut-out
General data
To operate potentiometers with a shaft diameter of 6 mm.
Suitable for potentiometers to DIN 41 450 with a shaft length of 32 mm.
Potentiometer not included.
RAFIX
16
Technical data
General information
Form of lens
Colour of handle
Form of collar
from front side
min.
max.
environment
environment
handle
black
see order block
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
see order block
see order block
25 x 25 mm
see order block
23.65 mm
19.2 mm
16.2 mm
Mechanical design
Mounting
Threaded sleeve
ring nut
M 10 x 0.75
IP65
-25 °C
+70 °C
-40 °C
+85 °C
Accessories RAFIX 16 potentiometer drive
Description
Order no.
Page
For additional accessories, refer to the chapter „RAFIX 16 special accessories“.
2 - 42
Control components
RAFIX 16
Panel cut-out
Form of lens
Form of collar
Colour of handle
Order no.
handle
square
black
1.30.077.001/0000
2
Technical data see page 2 - 42
RAFIX
16
Panel cut-out
Form of lens
Form of collar
Colour of handle
Order no.
handle
round
black
1.30.077.021/0000
Pict.: delivery content
Panel cut-out
Form of lens
Form of collar
Colour of handle
Order no.
handle
square alignable
black
1.30.077.041/0000
Control components
2 - 43
RAFIX 16
RAFIX 16 buzzer
Panel cut-out
2
RAFIX
16
Technical data
General information
Form of lens
Colour of lens
Form of collar
Sound
flat lens
opaque black
see order block
see order block
Robustness min.
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
see order block
see order block
25 x 25 mm
see order block
6.95 mm
30.5 mm
16.2 mm
from front side
min.
max.
environment
Mechanical design
Mounting
ring nut
environment
Acoustic characteristics
Sonic pressure, 1 m
distance min.
see order block
Electrical characteristics
Operating voltage DC
Input current
Frequency of intervall
beep
100 N
IP65
-25 °C
+70 °C
-40 °C
+85 °C
according to
according to
24 V
see order block
2300 Hz
Accessories RAFIX 16 buzzer
Description
Order no.
Page
2 - 44
Control components
RAFIX 16
Panel cut-out
Sound
Input current
Sonic pressure, 1 m distance min.
Order no.
continuos beep
24 V
25 mA
70 dB
1.30.078.001/0100
2
Technical data see page 2 - 44
12 V DC available on request.
RAFIX
16
Panel cut-out
Sound
Input current
Order no.
continuos beep
24 V
25 mA
70 dB
1.30.078.021/0100
Panel cut-out
Sound
Input current
Order no.
continuos beep
24 V
25 mA
70 dB
1.30.078.041/0100
Control components
2 - 45
RAFIX 16
Pict.: transparent yellow
2
RAFIX
16
with contact block
Panel cut-out
Technical data
General information
Form of lens
Colour of lens
Form of collar
from front side
min.
without lamp max.
with lamp max.
environment
see order block
see order block
see order block
Dimensions
Length of collar
Diameter of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
see order block
see order block
25 x 25 mm
see order block
see order block
30,5/44,7 mm
16.2 mm
Mechanical design
Mounting
Illuminability
ring nut
yes
Robustness min.
100 N
environment
IP65
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
according to
according to
Accessories RAFIX 16 signal indicator
Description
Order no.
Page
1.71.212.001/0000 2 - 61
1.71.212.011/0000 2 - 61
5 - 24
For suitable LEDs and filament lamps, refer to the chapter „RAFIX 16 lamp sockets“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“.
2 - 46
Control components
RAFIX 16
Pict.: transparent green
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
lens square
Lens
1.65.124.001/1002 1.65.124.101/0000 5.49.263.006/1002
lens square
transparent
colourless
transparent red
lens square
transparent yellow
1.65.124.001/1403 1.65.124.101/0000 5.49.263.006/1403
lens square
transparent green
1.65.124.001/1505 1.65.124.101/0000 5.49.263.006/1505
lens square
transparent blue
1.65.124.001/1607 1.65.124.101/0000 5.49.263.006/1607
1.65.124.001/1306 1.65.124.101/0000 5.49.263.006/1306
Technical data see page 2 - 46
Legending can only be made externally on a label holder.
Pict.: transparent colourless
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
flat lens
square
flat lens
Lens
1.65.124.301/1002 1.65.124.401/0000 5.49.077.011/1002
square
transparent
colourless
transparent red
flat lens
square
transparent yellow
1.65.124.301/1403 1.65.124.401/0000 5.49.077.011/1403
flat lens
square
transparent green
1.65.124.301/1505 1.65.124.401/0000 5.49.077.011/1505
flat lens
square
transparent blue
1.65.124.301/1607 1.65.124.401/0000 5.49.077.011/1607
1.65.124.301/1306 1.65.124.401/0000 5.49.077.011/1306
Accessories:
Control components
2 - 47
2
RAFIX
16
RAFIX 16
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
2
RAFIX
16
protruding lens
square
protruding lens
Lens
1.65.124.351/1002 1.65.124.451/0000 5.49.077.012/1002
square
transparent
colourless
transparent red
protruding lens
square
transparent yellow
1.65.124.351/1403 1.65.124.451/0000 5.49.077.012/1403
protruding lens
square
transparent green
1.65.124.351/1505 1.65.124.451/0000 5.49.077.012/1505
protruding lens
square
transparent blue
1.65.124.351/1607 1.65.124.451/0000 5.49.077.012/1607
1.65.124.351/1306 1.65.124.451/0000 5.49.077.012/1306
Accessories:
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
lens round
round
lens round
Lens
1.65.124.021/1002 1.65.124.101/0000 5.49.263.007/1002
round
transparent
colourless
transparent red
lens round
round
transparent yellow
1.65.124.021/1403
lens round
round
transparent green
1.65.124.021/1505 1.65.124.101/0000 5.49.263.007/1505
lens round
round
transparent blue
1.65.124.021/1607 1.65.124.101/0000 5.49.263.007/1607
1.65.124.021/1306 1.65.124.101/0000 5.49.263.007/1306
5.49.263.007/1403
2 - 48
Control components
RAFIX 16
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
flat lens
round
flat lens
Lens
5.49.259.017/1002
1.65.124.321/1002
round
transparent
colourless
transparent red
flat lens
round
transparent yellow
1.65.124.321/1403 1.65.124.421/0000 5.49.259.017/1403
flat lens
round
transparent green
1.65.124.321/1505 1.65.124.421/0000 5.49.259.017/1505
flat lens
round
transparent blue
1.65.124.321/1607 1.65.124.421/0000 5.49.259.017/1607
1.65.124.321/1306 1.65.124.421/0000 5.49.259.017/1306
Accessories:
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
protruding lens
round
protruding lens
Lens
1.65.124.371/1002 1.65.124.471/0000 5.49.259.018/1002
round
transparent
colourless
transparent red
protruding lens
round
transparent yellow
1.65.124.371/1403 1.65.124.471/0000 5.49.259.018/1403
protruding lens
round
transparent green
1.65.124.371/1505 1.65.124.471/0000 5.49.259.018/1505
protruding lens
round
transparent blue
1.65.124.371/1607 1.65.124.471/0000 5.49.259.018/1607
1.65.124.371/1306 1.65.124.471/0000 5.49.259.018/1306
Accessories:
Control components
2 - 49
2
RAFIX
16
RAFIX 16
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
2
RAFIX
16
flat lens
square alignable
flat lens
Lens
1.65.124.551/1002 1.65.124.651/0000 5.49.077.011/1002
square alignable
transparent
colourless
transparent red
flat lens
square alignable
transparent yellow
1.65.124.551/1403 1.65.124.651/0000 5.49.077.011/1403
flat lens
square alignable
transparent green
1.65.124.551/1505 1.65.124.651/0000 5.49.077.011/1505
flat lens
square alignable
transparent blue
1.65.124.551/1607 1.65.124.651/0000 5.49.077.011/1607
1.65.124.551/1306 1.65.124.651/0000 5.49.077.011/1306
Accessories:
Form of lens
Panel cut-out
Form of collar
Colour of lens
Order no. complete
Housing
protruding lens
square alignable
protruding lens
Lens
1.65.124.501/1002 1.65.124.661/0000 5.49.077.012/1002
square alignable
transparent
colourless
transparent red
protruding lens
square alignable
transparent yellow
1.65.124.501/1403 1.65.124.661/0000 5.49.077.012/1403
protruding lens
square alignable
transparent green
1.65.124.501/1505 1.65.124.661/0000 5.49.077.012/1505
protruding lens
square alignable
transparent blue
1.65.124.501/1607 1.65.124.661/0000 5.49.077.012/1607
1.65.124.501/1306 1.65.124.661/0000 5.49.077.012/1306
Accessories:
2 - 50
Control components
RAFIX 16
with contact block
2
RAFIX
16
Technical data
Dimensions
Length
Width
Height
Mounting depth (with
actuator / indicator)
Mechanical design
Mounting
Contact system
Operating life switching
element (momentary)
Contact resistance when
new max.
see order block
see order block
see order block
see order block
Operating travel
Robustness
snap on actuator
bridgecontact self
cleaning
Au
see order block
see order block
see order block
quick connector 2.8 x 0.8
according to DIN 50013,
X1 = +, X2 = 3 mm
100 N
Robustness
acc. IEC 60947-5-5
Contact materials
Contact arrangement
Contact function
Lamp socket
Terminals
Terminal marking
Rated voltage min.
Rated voltage max.
(AC/DC)
Rated current min.
Rated current max.
see order block
42 V
see order block
see order block
Protection class
Shock resistance acc. to
IEC 600 68-2-27
min.
without lamp max.
with lamp max.
Colour code
environment
environment
Mechanical operating
life latching (operations)
Resistance to vibrations
acc. to IEC 600 68-2-6
Flame class acc. to UL 94
Hot wire ignition acc.
to IEC 60695-2-1
2000000
50 mΩ
II
see order block
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
white bottom
see order block
10 g at 20 ... 500 Hz
V0
yes
Accessories RAFIX 16 contact blocks with gold contacts
Description
Order no.
Page
Filament lamp, W 2 x 4.6d base, 24 - 30 V
1.90.120.005/0000 5 - 4
Filament lamp, W 2 x 4.6d base, 60 V
1.90.120.009/0000 5 - 4
Filament lamp, W 2 x 4.6d base, 48 V
1.90.120.010/0000 5 - 4
Filament lamp, W 2 x 4.6d base, 24 V
1.90.120.011/0000 5 - 4
2 - 52
Control components
RAFIX 16
Description
Order no.
Page
Filament lamp, W 2 x 4.6d base, 12 V
1.90.120.012/0000 5 - 4
Filament lamp, W 2 x 4.6d base, 6 V
1.90.120.013/0000 5 - 4
LED W 2 x 4.6d superbright, red, 24 V
1.90.690.361/0000 5 - 16
LED W 2 x 4.6d superbright, green, 24 V
1.90.690.362/0000 5 - 16
LED W 2 x 4.6d superbright, yellow, 24 V
1.90.690.363/0000 5 - 16
LED W 2 x 4.6d superbright, blue, 24 V
1.90.690.364/0000 5 - 16
Multipole connector
5.05.510.421/0000 2 - 63
PCB plug-in socket, 10 contacts (universal application)
5.05.510.644/0000 2 - 62
5.37.540.024/8622 2 - 63
Plug distributor
5.37.540.029/6000 2 - 63
5.55.103.105/0100 2 - 64
Control components
2
RAFIX
16
2 - 53
RAFIX 16
with contact block
2
RAFIX
16
Contact function
Contact arrangement Lamp socket
Rated voltage max.
(AC/DC)
Rated current max.
Order no.
momentary
1 NC + 1 NO
W 2 x 4.6d
42 V
0.25 A
1.20.122.011/0000
momentary
2 NO
W 2 x 4.6d
42 V
0.25 A
1.20.122.012/0000
momentary
2 NC
W 2 x 4.6d
42 V
0.25 A
1.20.122.013/0000
latching
1 NC + 1 NO
W 2 x 4.6d
42 V
0.25 A
1.20.122.051/0000
latching
2 NO
W 2 x 4.6d
42 V
0.25 A
1.20.122.052/0000
Technical data see page 2 - 52
Standard contact blocks have one common contact chamber and one actuator plunger.
Contact blocks with „latching“ contact function are used as switches. When combined with pushbuttons and mushroom actuators, the
switching position is visible, releasing is effected by actuating again.
with contact block
Contact function
Rated voltage max.
(AC/DC)
Rated current max.
Order no.
momentary
1 NC + 1 NO
42 V
0.25 A
1.20.122.031/0000
momentary
2 NO
42 V
0.25 A
1.20.122.032/0000
momentary
2 NC
42 V
0.25 A
1.20.122.033/0000
latching
1 NC + 1 NO
42 V
0.25 A
1.20.122.071/0000
latching
2 NO
42 V
0.25 A
1.20.122.072/0000
2 - 54
Control components
RAFIX 16
with contact block
Contact function
Rated voltage max.
(AC/DC)
Rated current max.
Order no.
momentary
1 NC + 1 NO
W 2 x 4.6d
42 V
0.25 A
1.20.123.011/0000
momentary
1 NC
W 2 x 4.6d
42 V
0.25 A
1.20.123.012/0000
momentary
1 NO
W 2 x 4.6d
42 V
0.25 A
1.20.123.013/0000
momentary
2 NC
W 2 x 4.6d
42 V
0.25 A
1.20.123.014/0000
momentary
2 NO
W 2 x 4.6d
42 V
0.25 A
1.20.123.015/0000
Universal contact blocks have two separate contact chambers and two actuator plungers for alternating actuation directions. Two different polarities can be switched. The NC contacts are positive opening contacts to IEC 60947-5-1.
with contact block
Contact function
Rated voltage max.
(AC/DC)
Rated current max.
Order no.
momentary
1 NC + 1 NO
42 V
0.25 A
1.20.123.031/0000
momentary
1 NC
42 V
0.25 A
1.20.123.032/0000
momentary
1 NO
42 V
0.25 A
1.20.123.033/0000
momentary
2 NC
42 V
0.25 A
1.20.123.034/0000
momentary
2 NO
42 V
0.25 A
1.20.123.035/0000
Control components
2 - 55
2
RAFIX
16
RAFIX 16
with contact block
2
RAFIX
16
Technical data
Dimensions
Length
Width
Height
Mechanical design
Mounting
Contact system
Contact materials
Contact arrangement
Contact function
Lamp socket
Terminals
Terminal marking
Operating travel
Robustness
Robustness
Rated insulation voltage
acc. to VDE 0110, AC
acc. to VDE 0110, DC
Ohmic rated current
IR
Rated motor current
IM nenn
Application category
acc. to VDE 0660 Teil 200
UI , AC
UI , DC
Rated voltage
UE / Rated current IE , AC
Rated voltage
UE / Rated current IE ,DAC
Thermic rated current
Ithe , AC
2 - 56
22.2 mm
22.2 mm
34.4 mm
44.7 mm
snap on actuator
bridgecontact self
cleaning
Ag
see order block
see order block
see order block
X1 = +, X2 = 3 mm
100 N
Ithe , DC
element AC
element DC
Rated power DC
Rated power AC
new max.
Protection class
Approvals
6A
4A
min.
without lamp max.
with lamp max.
Colour code
environment
AC 15B 300 V
DC 13Q 300 V
250 V
300 V
250 V/1,5 A, 120 V/3,0 A V
250 V/0,27 A, 125 V/0,55 A,
60 V/1 A, 24 V/2 A V
250000 at 220 V/0.2 A,
1000000 at 24 V/2 A
10 x IE
1,1 x IE
20 mΩ
II
ENEC 25 T 70 (55), UL,
CSA
72/73
yes
acc. IEC 60947-5-5
300 V
100000 at 6A, 800000 at 2A
Corresponding to EU
directive N
IEC 600 68-2-27
250 V
2,5 A
environment
to IEC 60695-2-1
amplitude ‹ 50g, 11ms,
half sinusoidal
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
grey bottom
according to
according to
100000
V0
yes
5A
Control components
RAFIX 16
Accessories RAFIX 16 contact blocks with silver contacts
Description
Order no.
Page
Multipole connector
Plug distributor
Control components
2
RAFIX
16
2 - 57
RAFIX 16
with contact block
2
RAFIX
16
Contact function
Rated insulation
voltage UI , AC
Ohmic rated current
IR
Order no.
momentary
1 NC + 1 NO
W 2 x 4.6d
250 V
6A
1.20.122.001/0000
momentary
2 NO
W 2 x 4.6d
250 V
6A
1.20.122.002/0000
momentary
2 NC
W 2 x 4.6d
250 V
6A
1.20.122.003/0000
latching
1 NC + 1 NO
W 2 x 4.6d
250 V
6A
1.20.122.041/0000
latching
2 NO
W 2 x 4.6d
250 V
6A
1.20.122.042/0000
Technical data see page 2 - 56
with contact block
Contact function
Rated insulation
voltage UI , AC
Ohmic rated current
IR
Order no.
momentary
1 NC + 1 NO
250 V
6A
1.20.122.021/0000
momentary
2 NO
250 V
6A
1.20.122.022/0000
momentary
2 NC
250 V
6A
1.20.122.023/0000
latching
1 NC + 1 NO
250 V
6A
1.20.122.061/0000
latching
2 NO
250 V
6A
1.20.122.062/0000
2 - 58
Control components
RAFIX 16
with contact block
Contact function
Rated insulation
voltage UI , AC
Ohmic rated current
IR
Order no.
momentary
1 NC + 1 NO
W 2 x 4.6d
250 V
6A
1.20.123.001/0000
momentary
1 NC
W 2 x 4.6d
250 V
6A
1.20.123.002/0000
momentary
1 NO
W 2 x 4.6d
250 V
6A
1.20.123.003/0000
momentary
2 NC
W 2 x 4.6d
250 V
6A
1.20.123.004/0000
momentary
2 NO
W 2 x 4.6d
250 V
6A
1.20.123.005/0000
Universal contact blocks have two separate contact chambers and two actuator plungers. This makes it possible to switch two different
polarities. The NC contacts are positive opening contacts to IEC 60947-5-1.
with contact block
Contact function
Rated insulation
voltage UI , AC
Ohmic rated current
IR
Order no.
momentary
1 NC + 1 NO
250 V
6A
1.20.123.021/0000
momentary
1 NC
250 V
6A
1.20.123.022/0000
momentary
1 NO
250 V
6A
1.20.123.023/0000
momentary
2 NC
250 V
6A
1.20.123.024/0000
momentary
2 NO
250 V
6A
1.20.123.025/0000
Control components
2 - 59
2
RAFIX
16
RAFIX 16
with contact block
2
RAFIX
16
Technical data
IEC 600 68-2-27
Dimensions
Length
Width
Height
Mounting depth
see order block
see order block
see order block
see order block
Mechanical design
Mounting
Lamp socket
Terminals
Terminal marking
Robustness
see order block
wedge-base W 2 x 4.6d
X1 = anode, X2 = cathode
100 N
Rated voltage max.
Rated power max.
Approvals
min.
with lamp max.
environment
environment
60 V
1.2 W
CSA
to IEC 60695-2-1
half sinusoidal
-25 °C
+55 °C
-40 °C
+85 °C
according to
according to
V0
yes
Accessories RAFIX 16 lamp socket
Description
Order no.
Page
2 - 60
Control components
RAFIX 16
Description
Order no.
Page
PCB plug-in socket, 2 contacts (lamp socket)
5.05.510.649/0000 2 - 62
2
RAFIX
16
with contact block
Rated voltage max.
Rated power max.
Lamp socket
Mounting
Mounting depth
Order no.
60 V
1.2 W
wedge-base
W 2 x 4.6d
click on signal
indicator
44.7 mm
1.71.212.001/0000
Technical data see page 2 - 60
A notch on the lamp socket identifies the cathode side.
Rated voltage max.
Rated power max.
Lamp socket
Mounting
Mounting depth
Order no.
60 V
1.2 W
wedge-base
W 2 x 4.6d
snap into
signal indicator
30.5 mm
1.71.212.011/0000
Control components
2 - 61
RAFIX 16
3-module
2
PCB plug-in socket
RAFIX
16
Short text
Feature 1
Feature 2
Order no.
22 mm
24 mm
5.05.510.644/0000
PCB plug-in socket, 6 contacts (2 NO, lamp socket)
22 mm
24 mm
5.05.510.645/0000
PCB plug-in socket, 6 contacts (1 NC, 1 NO, lamp socket)
22 mm
24 mm
5.05.510.646/0000
PCB plug-in socket, 6 contacts (2 NC, lamp socket)
22 mm
24 mm
5.05.510.647/0000
PCB plug-in socket, 4 contacts (2 NC)
22 mm
24 mm
5.05.510.648/0000
22 mm
24 mm
5.05.510.649/0000
For soldering onto PCBs. The PCB carrying the plug-in sockets is plugged onto the contact blocks/lamp sockets. Additional fixing of the
PCB to the contact block is not required. Solder terminals for PCB 3.5 mm long, for 1.3 mm hole.
2 - 62
Control components
RAFIX 16
Multipole connector
Short text
Feature 1
Feature 2
Order no.
Multipole connector
21.8 mm
23.2 mm
5.05.510.421/0000
Makes it possible to simultaneously connect all terminals of a contact block. Can be fitted with 2.8 mm female quick-connect terminals.
Short text
RAFIX
16
Feature 1
Feature 2
Order no.
5.37.540.024/8622
With latching detent for mating with a multipole connector.
Plug distributor
Short text
Feature 1
Plug distributor
Feature 2
Order no.
5.37.540.029/6000
For mounting on the quick-connect terminals of contact blocks. The double number of contacts facilitates loop-through.
Control components
2
2 - 63
RAFIX 16
Short text
Feature 1
Feature 2
2
RAFIX
16
Order no.
5.55.103.105/0100
Assembly sequence: Snap the protection against contact onto the contact block, connect wires to quick-connect terminals of contact
block, pull protection against contact over the terminals; this ensures finger-proof condition to VBG 4.
Short text
Feature 1
Feature 2
Protection against contact (VBG 4 with lamp socket 1.71.212.011)
Order no.
5.55.103.134/0700
You can use the protection against contact to cover the terminals of the lamp socket 1.71.212.011/0000 so that they are finger-proof to
VBG 4.
Series capacitor
Short text
Feature 1
Feature 2
Order no.
Series capacitor, 125 V/48 V~, 50 Hz, 25 mA
5.03.771.333/0000
Series capacitor, 230 V/48 V~, 50 Hz, 25 mA
5.03.771.334/0000
Fully encapsulated, with a 2.8 x 0.8 mm quick-connect tab in a touch-proof arrangement.
2 - 64
Control components
RAFIX 16
Disassembly tool
Short text
Feature 1
Feature 2
Feature 2
5.05.800.042/0000
2
For replacing pushbutton and signal indicator lenses.
Short text
Feature 1
Feature 2
RAFIX
16
Feature 2
5.05.800.055/0000
To prevent inadvertent operation. The legend is easily visible even when the cap is closed.
Short text
Feature 1
Control components
Feature 2
Order no.
5.58.002.034/0000
2 - 65
RAFIX 16
Pict.: 3-module
2
RAFIX
16
Short text
Feature 1
Feature 2
Order no.
RAFIX 16 insulating housing, 1-module, light grey/dark grey
55 mm
100 mm
1.20.810.001/0000
RAFIX 16 insulating housing, 1-module, yellow/yellow
55 mm
100 mm
1.20.810.002/0000
RAFIX 16 insulating housing, 2-module, light grey/dark grey
115 mm
100 mm
1.20.820.001/0000
RAFIX 16 insulating housing, 3-module, light grey/dark grey
115 mm
100 mm
1.20.830.001/0000
RAFIX 16 insulating housing, 4-module, light grey/dark grey
145 mm
100 mm
1.20.840.001/0000
Label sheet for housings
5.40.451.283/0000
• Attractive plastic housing to accommodate up to 4 control components
• 2 cable entries prepared: 1-,2-,3-part: M20x1,5, 4-part: M25x1,5
• Degree of protection IP 65 to DIN
• All grey housings with overlay, legending possible with legend inserts
• Wall mounting with 2 screws through housing bottom prepared
• Dimensions (feature 2) x 100 mm x 74 mm
• Accessories: 50 pre-perforated legend inserts on a DIN A4 sheet for printing with a PC printer
Short text
Feature 1
Feature 2
Order no.
5.07.620.004/0000
Accessories:
Legend label 23 x 16 for label holder, without legend: 5.73.111.000/0000
Legending available on request.
2 - 66
Control components
RAFIX 16
Short text
Feature 1
Feature 2
Label holder, flush, for round collar
Order no.
5.07.620.006/0000
2
Accessories:
Beschriftungsschild 23 x 16 für Schildträger, ohne Beschriftung: 5.73.111.000/0000
RAFIX
16
Short text
Feature 1
Label holder, protruding, for square flush fitting collar
Feature 2
Order no.
5.07.620.007/0000
Accessories:
Legend label 23 x 16, without legend: 5.73.112.000/0000
Control components
2 - 67
RAFIX 16
2
Short text
Feature 1
Feature 2
Order no.
60 mm
5.76.204.400/0400
Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend
„NOT-AUS“
„EMERGENCY STOP“
60 mm
5.76.204.401/0400
60 mm
5.76.204.403/0400
RAFIX
16
Short text
Feature 1
Blanking cap complete with sealing disc and ring nut,
square
round
square, alignable without gaps
2 - 68
Feature 2
Order no.
5.05.800.049/0100
5.05.800.050/0100
5.05.800.051/0100
Control components
RAFIX 16 F
2
General data
RAFIX 16 F control component range
• Extremely low profile
• 250 V/6 A max.
• The contact blocks snap directly onto the actuators without a coupling element and can be removed by turning = cost
reducing mounting.
• For contact blocks and accessories, refer to RAFIX 16.
• Versions with round collars on request
same product range.
Content
RAFIX 16 F pushbutton, flush lens
RAFIX 16 F pushbutton, protruding lens
2 - 70
2 - 71
2 - 72
2 - 74
2 - 75
2 - 76
2 - 77
2 - 78
2 - 79
RAFIX 16 F signal indicator, flush lens
RAFIX 16 F signal indicator, protruding lens
2 - 80
2 - 81
2 - 81
RAFIX 16 F, blanking cap
RAFIX 16 F, insulating housing IP65
2 - 82
2 - 82
2 - 82
Control components
2 - 69
RAFIX
16 F
RAFIX 16 F
2
Technical data
General information
Form of lens
Colour of lens
Form of collar
RAFIX
16 F
Operating life
see order block
see order block
square
Dimensions
Length of collar
Width of collar
Overall height
Mounting depth
Key grid
Mounting hole
24.9 mm
24.9 mm
see order block
51.7 mm
25 x 25 mm
23.1 x 23.1 mm
Mechanical design
Mounting
Contact function
Illuminability
ring nut
see order block
Robustness min.
from front side
min.
without lamp max.
with lamp max.
environment
environment
2000000 momentary/100000 latching
IP65
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
according to
according to
100 N
Accessories RAFIX 16 F pushbutton
Description
Order no.
Page
5 - 24
2 - 70
Control components
RAFIX 16 F
Description
Order no.
Page
5.70.635.000/2000
2
Form of lens
Panel cut-out
Illuminability
Colour of lens
Order no. complete
Housing
Lens
RAFIX
16 F
flat lens
no
opaque black
1.30.090.251/0100 -
flat lens
no
opaque white
1.30.090.251/0200 -
flat lens
no
opaque red
1.30.090.251/0300 -
flat lens
no
opaque yellow
1.30.090.251/0400 -
flat lens
no
opaque green
1.30.090.251/0500 -
flat lens
no
opaque blue
1.30.090.251/0600 -
flat lens
yes
1.30.090.001/1000 1.30.090.501/0000 5.49.077.011/1002
flat lens
yes
transparent
colourless
transparent red
flat lens
yes
transparent yellow
1.30.090.001/1400 1.30.090.501/0000 5.49.077.011/1403
flat lens
yes
transparent green
1.30.090.001/1500 1.30.090.501/0000 5.49.077.011/1505
flat lens
yes
transparent blue
1.30.090.001/1600 1.30.090.501/0000 5.49.077.011/1607
1.30.090.001/1300 1.30.090.501/0000 5.49.077.011/1306
Technical data see page 2 - 70
Accessories:
For the "latching" function, please use the RAFIX 16 standard contact block with "latching" function.
Control components
2 - 71
RAFIX 16 F
Form of lens
Panel cut-out
Illuminability
Colour of lens
Order no. complete
Housing
2
RAFIX
16 F
Lens
protruding lens
no
opaque black
1.30.090.301/0100 -
protruding lens
no
opaque white
1.30.090.301/0200 -
protruding lens
no
opaque red
1.30.090.301/0300 -
protruding lens
no
opaque yellow
1.30.090.301/0400 -
protruding lens
no
opaque green
1.30.090.301/0500 -
protruding lens
no
opaque blue
1.30.090.301/0600 -
protruding lens
yes
1.30.090.051/1000 1.30.090.551/0000 5.49.077.012/1002
protruding lens
yes
transparent
colourless
transparent red
protruding lens
yes
transparent yellow
1.30.090.051/1400 1.30.090.551/0000 5.49.077.012/1403
protruding lens
yes
transparent green
1.30.090.051/1500 1.30.090.551/0000 5.49.077.012/1505
protruding lens
yes
transparent blue
1.30.090.051/1600 1.30.090.551/0000 5.49.077.012/1607
1.30.090.051/1300 1.30.090.551/0000 5.49.077.012/1306
Accessories:
2 - 72
Control components
RAFIX 16 F
Pict.: Handle marking opaque white
2
Panel cut-out
General data
The illuminated selector switches are provided with translucent handle markings. These are opaque on the non-illuminated versions.
Technical data
RAFIX
16 F
Operating life
from front side
min.
without lamp max.
with lamp max.
environment
General information
Form of lens
Colour of handle marking
Form of collar
handle
see order block
square
Dimensions
Length of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
24.9 mm
25 x 25 mm
24.9 mm
23 mm
51.7 mm
23.1 x 23.1 mm
Mechanical design
Mounting
Contact function
Illuminability
Rotating angle
ring nut
see order block
see order block
Torque max.
1,3 Nm
environment
30000
IP65
-25 °C
+70 °C
+55 °C
-40 °C
+85 °C
according to
according to
Accessories RAFIX 16 F selector switch
Description
Order no.
Page
RAFIX 16 universal contact block, 1 NC + 1 NO,
1.20.123.001/0000 2 - 59
1.20.123.011/0000 2 - 55
2 - 74
Control components
RAFIX 16 F
Contact function
Panel cut-out
Illuminability
Rotating angle
Colour of handle
marking
Order no.
momentary
yes
1 x 40°
translucent white
1.30.093.551/2000
momentary
yes
2 x 40°
translucent white
1.30.093.651/2000
latching
yes
L, 1 x 90°
translucent white
1.30.093.501/2000
latching
yes
V, 1 x 90°
translucent white
1.30.093.601/2000
latching
yes
2 x 60°
translucent white
1.30.093.701/2000
momentary
no
1 x 40°
opaque white
1.30.093.550/0200
momentary
no
2 x 40°
opaque white
1.30.093.650/0200
latching
no
L, 1 x 90°
opaque white
1.30.093.500/0200
latching
no
V, 1 x 90°
opaque white
1.30.093.600/0200
latching
no
2 x 60°
opaque white
1.30.093.700/0200
Technical data see page 2 - 74
Only use RAFIX 16 contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use
universal contact blocks only.
Other contact funcions and handle markings available on request.
Control components
2 - 75
2
RAFIX
16 F
RAFIX 16 F
Panel cut-out
2
Technical data
General information
Form of lens
Colour of lens
Form of collar
RAFIX
16 F
Dimensions
Length of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
Mechanical design
Mounting
Contact function
Illuminability
Lock
Wafers
Lock type
Number of locking
positions
Main key
Symmetric key
Rotating angle
Key removal position
Group key
General key
flat lens
opaque black
square
24.9 mm
25 x 25 mm
24.9 mm
11 mm
51.7 mm
23.1 x 23.1 mm
ring nut
no
Micromec
5
001
500
on request
no
see order block
see order block
on request
on request
Torque max.
1,3 Nm
Protection class
II
Operating life
from front side
min.
max.
environment
environment
ESD-strength lock /
contact
ESD-strength key/ front
panel
65000
IP65
-25 °C
+70 °C
-40 °C
+85 °C
according to
according to
15 kV
4 kV
Accessories RAFIX 16 F keylock switch MICROMEC
Description
Order no.
Page
1.20.123.021/0000 2 - 59
1.20.123.031/0000 2 - 55
Spare key, for single action, e.g. 1 x 90°
5.58.007.001/0000
2 - 76
Control components
RAFIX 16 F
Description
Spare key, for double action, e.g. 2 x 90°
Order no.
Page
5.58.008.001/0000
2
Panel cut-out
Contact function
Colour of lens
Rotating angle
Key removal
position
Order no.
momentary
opaque black
1 x 40°
1.30.096.501/0000
momentary
opaque black
2 x 40°
1.30.096.701/0000
latching
opaque black
L, 1 x 90°
0+1
1.30.096.051/0000
latching
opaque black
V, 1 x 90°
0+1
1.30.096.151/0000
latching
opaque black
2 x 90°
0+1+2
1.30.096.401/0000
Technical data see page 2 - 76
Control components
2 - 77
RAFIX
16 F
RAFIX 16 F
with contact block
2
RAFIX
16 F
Panel cut-out
Technical data
General information
Actuator
Colour of mushroom
Form of collar
conical mushroom form
red, collar yellow
square
Dimensions
Length of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
24.9 mm
25 x 25 mm
24.9 mm
23.5 mm
51.7 mm
23.1 x 23.1 mm
Mechanical design
Mounting
Contact function
Illuminability
ring nut
latching
no
Robustness min.
100 N
Operating life
from front side
min.
without lamp max.
environment
environment
Approvals
10000
IP65
-25 °C
+70 °C
-40 °C
+85 °C
according to
according to
IEC 60 947, EN 418
Accessories RAFIX 16 F emergency stop pushbutton
Description
Order no.
Page
2 - 78
Control components
RAFIX 16 F
Panel cut-out
Contact function
Illuminability
Colour of mushroom
Mounting hole
Order no.
latching
no
red, collar yellow
23.1 x 23.1 mm
1.30.094.001/0300
2
Technical data see page 2 - 78
RAFIX
16 F
Control components
2 - 79
RAFIX 16 F
2
Panel cut-out
Technical data
General information
Form of lens
Colour of lens
Form of collar
RAFIX
16 F
transparent green
Dimensions
Length of collar
Key grid
Width of collar
Overall height
Mounting depth
Mounting hole
Mechanical design
Mounting
Illuminability
from front side
min.
max.
environment
see order block
see order block
square
24.9 mm
25 x 25 mm
24.9 mm
see order block
51,7 (37,5) mm
23.1 x 23.1 mm
environment
ring nut
yes
IP65
-25 °C
+55 °C
-40 °C
+85 °C
according to
according to
Accessories RAFIX 16 F signal indicator
Description
Order no.
Page
5.70.635.000/2000
2 - 80
Control components
RAFIX 16 F
Form of lens
Panel cut-out
Overall height
Colour of lens
Order no. complete
Housing
flat lens
1.7 mm
flat lens
Lens
1.65.126.301/1000 1.65.126.401/0000 5.49.077.011/1002
1.7 mm
transparent
colourless
transparent red
flat lens
1.7 mm
transparent yellow
1.65.126.301/1400 1.65.126.401/0000 5.49.077.011/1403
flat lens
1.7 mm
transparent green
1.65.126.301/1500 1.65.126.401/0000 5.49.077.011/1505
flat lens
1.7 mm
transparent blue
1.65.126.301/1600 1.65.126.401/0000 5.49.077.011/1607
1.65.126.301/1300 1.65.126.401/0000 5.49.077.011/1306
RAFIX
16 F
Technical data see page 2 - 80
Accessories:
Form of lens
Panel cut-out
Overall height
Colour of lens
Order no. complete
Housing
protruding lens
4.5 mm
protruding lens
Lens
1.65.126.351/1000 1.65.126.451/0000 5.49.077.012/1002
4.5 mm
transparent
colourless
transparent red
protruding lens
4.5 mm
transparent yellow
1.65.126.351/1400 1.65.126.451/0000 5.49.077.012/1403
protruding lens
4.5 mm
transparent green
1.65.126.351/1500 1.65.126.451/0000 5.49.077.012/1505
protruding lens
4.5 mm
transparent blue
1.65.126.351/1600 1.65.126.451/0000 5.49.077.012/1607
1.65.126.351/1300 1.65.126.451/0000 5.49.077.012/1306
Accessories:
Control components
2
2 - 81
RAFIX 16 F
Pict.: opaque black
Cut-out for RAFIX 16F
2
Pict.: opaque black
Short text
Feature 1
Feature 2
Order no.
RAFIX 16 F, blanking cap, black
opaque
black
23.1 x
23.1 mm
5.05.800.063/0000
RAFIX
16 F
Pict.: Cut-out for RAFIX 16F
Short text
Feature 1
Feature 2
Order no.
RAFIX 16 F, insulating housing IP65, 1-module, light grey/dark grey
light grey/dark
grey
yellow/yellow
55 mm
1.20.810.101/0000
55 mm
1.20.810.102/0000
light grey/dark
grey
light grey/dark
grey
light grey/dark
grey
white
115 mm
1.20.820.101/0000
115 mm
1.20.830.101/0000
145 mm
1.20.840.101/0000
RAFIX 16 F, insulating housing IP65, 1-module, yellow/yellow
RAFIX 16 F, insulating housing IP65, 2-module, light grey/dark grey
RAFIX 16 F, insulating housing IP65, 3-module, light grey/dark grey
RAFIX 16 F, insulating housing IP65, 4-module, light grey/dark grey
Label sheet for insulating housing, 50 labels on a DIN A4 sheet
5.40.451.284/0000
• Formschönes Kunststoff-Gehäuse zur Aufnahme von bis zu 4 Befehlsgeräten
• 2 Kabeleinführungen vorbereitet: 1-,2-,3-tlg: M20x1,5, 4-tlg: M25x1,5
• Schutzart IP 65 nach DIN
• Alle grauen Gehäuse mit Frontfolie, Beschriftung durch Einschubstreifen möglich
• Wandbefestigung des Gehäusebodens mit 2 Schrauben, Bohrung vorbereitet
• Maße (Merkmal 2) x 100 mm x 74 mm
• Zubehör: 50 Folien-Einschubstreifen auf DIN A4-Bogen vorgestanzt, mit PC-Drucker beschriftbar
2 - 82
Control components
