5.58.002.027/7705
5.58.002.027/7705
    RAFI
5.58.002.027/7705 数据手册
LUMOTAST 75 IP65 1 General data LUMO 75 (65) LUMOTAST 75 IP65 pushbutton range Illuminated pushbuttons and signal lamps with lamp socket T 4.5 • Mounting hole diameter 16.2 mm • Degree of protection IP65 • Solder terminals for the following wire cross-sections: - Installed 0.5 mm2 max. - Factory terminated 0.35 mm2 max. • 250 V/4 A max. • 2 NC + 2 NO max. (3 NC + 3 NO on request) Content LUMOTAST 75 illuminated pushbutton IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, square collar LUMOTAST 75 illuminated pushbutton IP65, protruding lens, square collar LUMOTAST 75 illuminated pushbutton IP65, flush lens, round collar LUMOTAST 75 illuminated pushbutton IP65, protruding lens, round collar LUMOTAST 75 illuminated pushbutton IP65, flush lens, rectangular collar 1 - 54 1 - 56 1 - 57 1 - 58 1 - 59 1 - 60 LUMOTAST 75 signal lamp IP65 LUMOTAST 75 signal lamp IP65, flush lens, square collar LUMOTAST 75 signal lamp IP65, protruding lens, square collar LUMOTAST 75 signal lamp IP65, flush lens, round collar LUMOTAST 75 signal lamp IP65, protruding lens, round collar LUMOTAST 75 signal lamp IP65, flush lens, rectangular collar 1 - 62 1 - 63 1 - 64 1 - 64 1 - 65 1 - 65 Pushbuttons 1 - 53 LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65 1 Pict.: with red lens Mounting hole Technical data LUMO 75 (65) Rated current DC max. Rated current AC/DC min. Contact resistance acc. to life max. Protection class ESD-strength min. General information Form of lens Colour of lens Form of collar Colour of collar see order block see order block see order block black Dimensions Length of collar Diameter of collar Width of collar Overall height Mounting depth Mounting hole see order block see order block see order block 10.5 mm see order block 16.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut solder terminals snap-action bridge contact see order block see order block Ag yes T 4.5 Mechanical characteristics Operating force Operating travel Switching travel NC Switching travel NO Robustness min. 3 ... 6.5 N 2.5 mm 1.8 mm 0.9 mm 100 N Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated voltage AC/DC min. Rated current AC max. 250 V 220 V 12 V 4A Other specifications Operating life, at 250 V/2 A (operations) Operating life, at 250 V/4 A (operations) Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Weight Approvals Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 0.2 A 5 mA 200 mΩ II 14 kV 200000 (momentary), 50000 (latching) 60000 (momentary) IP65 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 15 g ENEC 25 T 55 (70), UL, CSA V0 yes Accessories LUMOTAST 75 illuminated pushbutton IP65 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 1 - 54 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 Accessories LUMOTAST 75 illuminated pushbutton IP65 Description Photo Order no. Page LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 18 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 18 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 18 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 18 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 18 LED T 4.5, red, 2-3 V 1.90.692.001/0000 5 - 18 LED T 4.5, green, 2-3 V 1.90.692.002/0000 5 - 18 LED T 4.5, yellow, 2-3 V 1.90.692.003/0000 5 - 18 1 LUMO 75 (65) Lamp extractor for T 4.5/5.5, lamp diameter 4 mm 1.90.900.002/0000 5 - 22 Lamp extractor for lamp diameter 5-6 mm 1.90.900.004/0000 5 - 22 Protective cap (for 18 x 24 collar) 5.05.800.027/0000 5 - 26 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 28 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 28 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 28 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 55 LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, square collar 1 Pict.: with red lens Mounting hole Contact arrangement Contact function LUMO 75 (65) Colour of collar Order no. without lens 1.15.108.276/0000 Please include the desired lens in your order. 1.15.108.376/0000 Please include the desired lens in your order. 1.15.108.277/0000 Please include the desired lens in your order. 1.15.108.377/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 54 Lenses: Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, square, without legend: 5.70.629.000/2000 1 - 56 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, protruding lens, square collar 1 Pict.: with yellow lens Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.281/0000 Please include the desired lens in your order. 1.15.108.381/0000 Please include the desired lens in your order. 1.15.108.282/0000 Please include the desired lens in your order. 1.15.108.382/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 54 LUMO 75 (65) Lenses: Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, square, without legend: 5.70.629.000/2000 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 57 LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, round collar 1 Pict.: with blue lens Mounting hole Contact arrangement Contact function LUMO 75 (65) Colour of collar Order no. without lens 1.15.108.481/0000 Please include the desired lens in your order. 1.15.108.981/0000 Please include the desired lens in your order. 1.15.108.482/0000 Please include the desired lens in your order. 1.15.108.982/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 54 Lenses: Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 Accessories: Legend insert, round, without legend: 5.70.059.000/2000 1 - 58 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, protruding lens, round collar 1 Pict.: with colourless lens Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.476/0000 Please include the desired lens in your order. 1.15.108.976/0000 Please include the desired lens in your order. 1.15.108.477/0000 Please include the desired lens in your order. 1.15.108.977/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 54 LUMO 75 (65) Lenses: Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 Accessories: Legend insert, round, without legend: 5.70.059.000/2000 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 59 LUMOTAST 75 IP65 LUMOTAST 75 illuminated pushbutton IP65, flush lens, rectangular collar 1 Pict.: with green lens, without threaded ring Contact arrangement Contact function LUMO 75 (65) Colour of collar Order no. without lens 1.15.108.076/0000 Please include the desired lens in your order. 1.15.108.176/0000 Please include the desired lens in your order. 1.15.108.077/0000 Please include the desired lens in your order. 1.15.108.177/0000 Please include the desired lens in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 54 Lenses: Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.277.058/1002 Lens, rectangular, transparent red, for LED: 5.49.277.058/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.277.058/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.277.058/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.277.058/1502 Lens, rectangular, transparent green, for LED: 5.49.277.058/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.277.058/1601 Accessories: Legend insert, rectangular without legend: 5.70.630.000/2000 1 - 60 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 signal lamp IP65 1 Pict.: with red lens Mounting hole Technical data General information Form of lens Form of collar Diameter of collar LUMO 75 (65) Dimensions Length of collar Width of collar Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp Electrical characteristics Voltage limit max. Power limit max. see order block see order block see order block Other specifications Degree of protection from front side Weight Approvals see order block see order block 10.5 mm 33.5 mm 16.2 mm Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. ring nut solder terminals T 4.5 filament lamp / LED 42 V 1.2 W IP65 5g ENEC 25 T 55 (70), UL, CSA -25 °C +55 °C -40 °C +80 °C Accessories LUMOTAST 75 signal lamp IP65 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 18 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 18 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 18 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 18 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 18 LED T 4.5, red, 2-3 V 1.90.692.001/0000 5 - 18 1 - 62 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 Accessories LUMOTAST 75 signal lamp IP65 Description Photo Order no. Page LED T 4.5, yellow, 2-3 V 1.90.692.003/0000 5 - 18 Lamp extractor for T 4.5/5.5, lamp diameter 4 mm 1.90.900.002/0000 5 - 22 Lamp extractor for lamp diameter 5-6 mm 1.90.900.004/0000 5 - 22 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 28 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 28 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 28 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 1 LUMO 75 (65) LUMOTAST 75 signal lamp IP65, flush lens, square collar Pict.: with red lens Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens 1.2 W T 4.5 square 1.65.111.066/0000 Please include the desired lens in your order. Note Technical data see page 1 - 62 Lenses: Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, square: 5.70.629.000/2000 For assembly, press the lens as far as possible. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 63 LUMOTAST 75 IP65 LUMOTAST 75 signal lamp IP65, protruding lens, square collar 1 Pict.: with green lens Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens 1.2 W T 4.5 square 1.65.111.086/0000 Please include the desired lens in your order. Note Technical data see page 1 - 62 LUMO 75 (65) Lenses: Lens, square, transparent colourless, for filament lamp or LED: 5.49.277.052/1002 Lens, square, transparent red, for LED: 5.49.277.052/1301 Lens, square, transparent red, for filament lamp: 5.49.277.052/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.277.052/1402 Lens, square, transparent green, for filament lamp: 5.49.277.052/1502 Lens, square, transparent green, for LED: 5.49.277.052/1503 Lens, square, transparent blue, for filament lamp: 5.49.277.052/1601 Accessories: Legend insert, round, without legend: 5.70.629.000/2000 For assembly, press the lens as far as possible. LUMOTAST 75 signal lamp IP65, flush lens, round collar Pict.: with yellow lens Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens 1.2 W T 4.5 round 1.65.111.096/0000 Please include the desired lens in your order. Note Technical data see page 1 - 62 Lenses: Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 Accessories: Legend insert, round, without legend: 5.70.059.000/2000 For assembly, press the lens as far as possible. 1 - 64 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP65 LUMOTAST 75 signal lamp IP65, protruding lens, round collar 1 Pict.: with blue lens Voltage limit max. 42 V Mounting hole Power limit max. Lamp socket Form of collar Order no. without lens 1.2 W T 4.5 round 1.65.111.076/0000 Please include the desired lens in your order. Note Technical data see page 1 - 62 Lenses: Lens, round, transparent colourless, for filament lamp or LED: 5.49.259.013/1002 Lens, round, transparent red, for LED: 5.49.259.013/1301 Lens, round, transparent red, for filament lamp: 5.49.259.013/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.259.013/1402 Lens, round, transparent green, for filament lamp: 5.49.259.013/1502 Lens, round, transparent green, for LED: 5.49.259.013/1503 Lens, round, transparent blue, for filament lamp: 5.49.259.013/1601 LUMO 75 (65) Accessories: Legend insert, round, without legend: 5.70.059.000/2000 For assembly, press the lens as far as possible. LUMOTAST 75 signal lamp IP65, flush lens, rectangular collar Pict.: with colourless lens Voltage limit max. 42 V Power limit max. Lamp socket Form of collar Order no. without lens 1.2 W T 4.5 rectangular 1.65.111.056/0000 Please include the desired lens in your order. Note Technical data see page 1 - 62 Lenses: Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.277.058/1002 Lens, rectangular, transparent red, for LED: 5.49.277.058/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.277.058/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.277.058/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.277.058/1502 Lens, rectangular, transparent green, for LED: 5.49.277.058/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.277.058/1601 Accessories: Legend insert, rectangular without legend: 5.70.630.000/2000 For assembly, press the lens as far as possible. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 65
5.58.002.027/7705 价格&库存
很抱歉,暂时无法提供与“5.58.002.027/7705”相匹配的价格&库存,您可以联系我们找货
