1.14.002.111/0000
1.14.002.111/0000
    RAFI
    SMD
1.14.002.111/0000 数据手册
technical data sheet 1.14.002.101/0000 MICON 5, SMT standard, 2,9 N, 1 NO fields of application special features  Measurement-control-regulation  Mechanical and system engineering  Automotive  Electro-medical  Gold contacts, reliable switching with low currents  Special tactile feedback  High packing density due to small form factor (5.1 x 6.4 mm)  Different operating forces  Ring and full illumination of the button surface due to plunger  Variable overall heights due to plunger  Terminal technology: SMT  Traceability through product identification in accordance with DIN EN ISO 9001 description MICON 5 tactile switches offer extreme switching reliability, with a very small space requirement. They can be arranged individually, in rows or as key blocks. For use beneath overlays, we recommend combining the MICON 5 key switches with plungers. Here are the properties at a glance:  Suitable for the most important soldering techniques  Soldering bath for THT versions  Reflow soldering for SMT versions  Vapor phase soldering for SMT versions  Manual soldering  Processing of the SMT design with SMT automatic assembly machines  IMDS entry  Packaging in blister tape, spool with 2,100 pieces  Proposal for stencil printing: 150 µm stencil with 10% pad reduction on area The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and other information about our products are the mere results of individual technical testing. These descriptions and other product features are only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own purposes may infringe the rights of the respective entity holding those rights. date: Feb 15, 2021  page: 1/3 Downloaded from Arrow.com. RAFI GmbH & Co. KG Ravensburger Str. 128-134 88276 Berg / Ravensburg Germany www.rafi.de, info@rafi.de technical data sheet 1.14.002.101/0000 technical data general Operating temperature, min. -40 °C direct links Storage temperature, min. -40 °C  RAFI eCatalog Operating temperature, max. 90 °C Storage temperature, max. 90 °C illuminated No Soldering Reflow Solder heat resistance according to standard DIN EN 60068-2-58 DIN EN 61760-1 Packaging Blister Packaging unit 2,100 pcs. net weight 0.3 g Operating life 1,000,000 Cycles B10 1,300,000 Cycles Shock resistance according to standard IEC 60068-2-27 100 g at 6 ms amplitude semi-sinusoidal oscillation restistance according to standard IEC 60068-2-6 5 g at 10...500 Hz MOQ order 2,100 RoHS compliant Yes REACH compliant Yes Installation height 3.85 mm Grid, min. 6 x 7,8 mm Outside dimension, length 6.4 mm Outside dimension, width 5.1 mm Outside dimension, height 3.85 mm Actuation function momentary contact function Operating force, min. 2,9 N Switching travel 0.7 mm Contact function 1 NO Contact system Snap-action contact Contact material Gold Terminal on the rear SMT Solderability Yes mounting diameters mechanical data  electrical data Rated voltage, min. 0.02 V Rated voltage, max. 35 V Dielectric strength 250 V Rated current, min. 0.00001 A Rated current, max. 0.1 A Rated power, max. 1W The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and other information about our products are the mere results of individual technical testing. These descriptions and other product features are only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own purposes may infringe the rights of the respective entity holding those rights. date: Feb 15, 2021  page: 2/3 Downloaded from Arrow.com. RAFI GmbH & Co. KG Ravensburger Str. 128-134 88276 Berg / Ravensburg Germany www.rafi.de, info@rafi.de technical data sheet 1.14.002.101/0000 drawings Dimensioned drawing System drawing PCB drawing PCB drawing Schematic diagram Product labeling drawing Packaging drawing The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and other information about our products are the mere results of individual technical testing. These descriptions and other product features are only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own purposes may infringe the rights of the respective entity holding those rights. date: Feb 15, 2021  page: 3/3 Downloaded from Arrow.com. RAFI GmbH & Co. KG Ravensburger Str. 128-134 88276 Berg / Ravensburg Germany www.rafi.de, info@rafi.de
1.14.002.111/0000 价格&库存
很抱歉,暂时无法提供与“1.14.002.111/0000”相匹配的价格&库存,您可以联系我们找货
1.14.002.111/0000
  • 2100+13.02777
  • 10500+12.41079
  • 21000+12.17349
  • 42000+11.92433
库存:2100
1.14.002.111/0000
  • 1+22.283691+2.79442
  • 10+18.7440810+2.35055
  • 25+17.3880925+2.18050
  • 100+15.48621100+1.94200
  • 250+14.37089250+1.80214
  • 500+13.61090500+1.70684
  • 1000+12.924811000+1.62080
库存:13210
