5.49.227.005/1002
5.49.227.005/1002
    RAFI
    CONFIG SWITCH LENS CLEAR ROUND
5.49.227.005/1002 数据手册
Signal lamps with lamp socket General data Signal lamps with lamp socket. The standard illumination is by a filament lamp; illumination with LED is available on request. The mm specification in the product name indicates the appropriate mounting hole diameter of the signal lamps. For further signal lamps, refer to the „8 mm“ and „LUMOTAST“ pushbutton ranges as well as the signal indicators of the „RAFIX“ control component ranges. 3 Content Signal lamps with lamp socket W 2 x 4.6d, 9.1 mm Signal lamps with lamp socket W 2 x 4.6d, 9.1 mm, round lens 3 - 32 3 - 33 Signal lamps with lamp socket T 4.6, 9.1 mm Signal lamps with lamp socket T 4.6, 9.1 mm, round lens Signal lamps with lamp socket T 4.6, 9.1 mm, round lens 3 - 34 3 - 35 3 - 35 Signal lamps with lamp socket W 2x4,6d, 11.1 mm Signal lamps with lamp socket W 2x4,6d, 11.1 mm, round lens 3 - 36 3 - 37 Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm, round lens Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm, round lens 3 - 38 3 - 39 3 - 39 Signal lamps with lamp socket E 10 (MES), 16.2 mm Signal lamps with lamp socket E 10 (MES), 16.2 mm, round lens Signal lamps with lamp socket E 10 (MES), 16.2 mm, round lens Signal lamps with lamp socket E 10 (MES), 16.2 mm, round lens 3 - 40 3 - 41 3 - 41 3 - 42 Signal lamps with lamp socket BA 9s (MBC/MCC), 18.2 mm Signal lamps with lamp socket BA 9s (MBC/MCC), 18.2 mm, round lens 3 - 44 3 - 45 Signal lamps with lamp socket E 14, 22.3 mm Signal lamps with lamp socket E 14, IP40, 22.3 mm Signal lamps with lamp socket E 14, 22.3 mm, screw-on lens, IP40 3 - 46 3 - 47 3 - 47 Signal lamps with lamp socket E 14, 30.5 mm Signal lamps with lamp socket E 14, IP40, 30.5 mm Signal lamps with lamp socket E 14, IP40, 30.5 mm Signal lamps with lamp socket E 14, IP40, 30.5 mm 3 - 48 3 - 49 3 - 49 3 - 50 Signal lamps with lamp socket BA 15d, 30.5 mm Signal lamps with lamp socket BA 15d, IP40, 30.5 mm Signal lamps with lamp socket BA 15d, IP40, 30.5 mm Signal lamps with lamp socket BA 15d, IP40, 30.5 mm 3 - 52 3 - 53 3 - 54 3 - 54 Signal lamps 3 - 31 With Socket Signal lamps with lamp socket Signal lamps with lamp socket W 2 x 4.6d, 9.1 mm Pict.: red Mounting hole Technical data General information Form of lens Colour of lens Diameter of collar 3 Dimensions Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp round see order block 11 mm 7 mm 25.5 mm 9.1 mm Electrical characteristics Voltage limit max. Power limit max. 42 V 1.2 W Other specifications Degree of protection from front side Weight IP40 1g ring nut quick connecter 2.8 x 0.5 tin plated W 2 x 4.6d filament lamp Accessories Signal lamps with lamp socket W 2 x 4.6d, 9.1 mm With Socket Description Photo Order no. Page Filament lamp, W 2 x 4.6d base, 24 - 30 V 1.90.120.005/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 60 V 1.90.120.009/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 48 V 1.90.120.010/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 24 V 1.90.120.011/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 12 V 1.90.120.012/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 6 V 1.90.120.013/0000 5 - 4 Fixing spanner M 9, M 10 5.58.002.025/0105 5 - 23 3 - 32 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket W 2 x 4.6d, 9.1 mm, round lens Pict.: red Mounting hole Power Lamp Voltage limit max. limit max. Colour of lens 42 V 1.2 W filament lamp 42 V 1.2 W filament lamp 42 V 1.2 W filament lamp 42 V 1.2 W filament lamp 42 V 1.2 W filament lamp transparent colourless transparent red transparent yellow transparent green transparent blue Order no. complete Order no. single parts Housing Lens 1.66.001.011/1002 1.66.001.026/0000 5.49.255.002/1002 1.66.001.011/1301 1.66.001.026/0000 5.49.255.002/1301 1.66.001.011/1402 1.66.001.026/0000 5.49.255.002/1402 1.66.001.011/1502 1.66.001.026/0000 5.49.255.002/1502 1.66.001.011/1601 1.66.001.026/0000 5.49.255.002/1601 Technical data see page 3 - 32 3 Please order luminous elements separately. With Socket Signal lamps Stock items are marked by bold printed order numbers. 3 - 33 Signal lamps with lamp socket Signal lamps with lamp socket T 4.6, 9.1 mm Pict.: red colourless Mounting hole Technical data General information Form of lens Colour of lens Diameter of collar 3 see order block see order block 11 mm Dimensions Overall height Mounting depth Mounting hole see order block 30.5 mm 9.1 mm Mechanical design Mounting Terminals Lamp socket Lamp ring nut solder terminals T 4.6 filament lamp Electrical characteristics Voltage limit max. Power limit max. 42 V 1W Other specifications Degree of protection from front side Weight IP40 1g Accessories Signal lamps with lamp socket T 4.6, 9.1 mm Description With Socket Photo Order no. Page Filament lamp, T 4.6 base, 12 V 1.90.100.012/0000 5 - 6 Filament lamp, T 4.6 base, 24 V 1.90.100.013/0000 5 - 6 Fixing spanner M 9, M 10 5.58.002.025/0105 5 - 23 3 - 34 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket T 4.6, 9.1 mm, round lens Pict.: red Mounting hole Lamp Voltage limit max. socket Lamp 42 V T 4.6 filament lamp 42 V T 4.6 filament lamp 42 V T 4.6 filament lamp 42 V T 4.6 filament lamp Colour of lens Order no. complete Order no. single parts Housing transparent colourless transparent red transparent yellow transparent green Lens 1.02.157.001/1002 1.02.157.021/0000 5.49.255.001/1002 1.02.157.001/1307 1.02.157.021/0000 5.49.255.001/1307 1.02.157.001/1403 1.02.157.021/0000 5.49.255.001/1403 1.02.157.001/1510 1.02.157.021/0000 5.49.255.001/1510 Technical data see page 3 - 34 3 Signal lamps with lamp socket T 4.6, 9.1 mm, round lens Pict.: colourless Mounting hole Lamp Voltage limit max. socket Lamp 42 V T 4.6 filament lamp 42 V T 4.6 filament lamp 42 V T 4.6 filament lamp 42 V T 4.6 filament lamp Colour of lens Order no. complete Order no. single parts Housing transparent colourless transparent red transparent yellow transparent green With Socket Lens 1.02.157.011/1002 1.02.157.021/0000 5.49.255.002/1002 1.02.157.011/1301 1.02.157.021/0000 5.49.255.002/1301 1.02.157.011/1402 1.02.157.021/0000 5.49.255.002/1402 1.02.157.011/1502 1.02.157.021/0000 5.49.255.002/1502 Technical data see page 3 - 34 Signal lamps Stock items are marked by bold printed order numbers. 3 - 35 Signal lamps with lamp socket Signal lamps with lamp socket W 2x4,6d, 11.1 mm Pict.: green Mounting hole Technical data General information Form of lens Colour of lens Diameter of collar 3 round see order block 11 Dimensions Overall height Mounting depth Mounting hole 8.5 mm 28.5 mm 11.10 mm Mechanical design Mounting Terminals Lamp socket Lamp ring nut quick connector A 2.8 x 0.5 W 2 x 4.6 d filament lamp Electrical characteristics Voltage limit max. Power limit max. 42 V 1.2 W Other specifications Degree of protection from front side Weight IP40 1.4 g Accessories Signal lamps with lamp socket W 2x4,6d Description With Socket Photo Order no. Page Filament lamp, W 2 x 4.6d base, 24 V 1.90.120.005/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 60 V 1.90.120.009/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 48 V 1.90.120.010/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 24 V 1.90.120.011/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 12 V 1.90.120.012/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 6 V 1.90.120.013/0000 5 - 4 Protective sleeve made of Buna N (NBR), 8 x 30 5.52.011.023/0100 Fixing spanner M 11, M 13 5.58.002.026/0105 5 - 23 3 - 36 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket W 2x4,6d, 11.1 mm, round lens Pict.: green Mounting hole Voltage limit max. Power limit max. Lamp socket 42 V 1.2 W W 2 x 4.6 d Colour of lens Order no. without lens Note 1.66.003.001/0000 Please include the desired lens in your order. Technical data see page 3 - 36 Accessories: Lens tranparent colourless: 5.49.255.003/1002 Lens transparent red: 5.49.255.003/1301 Lens transparent yellow: 5.49.255.003/1402 Lens transparent green: 5.49.255.003/1502 Lens transparent blue: 5.49.255.003/1601 Please order luminous elements separately. 3 With Socket Signal lamps Stock items are marked by bold printed order numbers. 3 - 37 Signal lamps with lamp socket Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm Pict.: colourless yellow Panel cut-out Technical data General information Form of lens Colour of lens Diameter of collar 3 Dimensions Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp see order block see order block see order block see order block 45.8 mm 16.2 mm Electrical characteristics Voltage limit max. Power limit max. 250 V 2W Other specifications Degree of protection from front side Weight Approvals see order block 10 g SEV at 2 W ring nut quick connecter 6.3 x 0.8 / 2 x 2.8 x 0.8 tin plated BA 9 s filament lamp Accessories Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm With Socket Description Photo Order no. Page Protective sleeve for terminals made of Buna N (NBR) 5.52.011.027/0100 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 3 - 38 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm, round lens Pict.: colourless Panel cut-out Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 2W IP40 250 V 2W IP40 250 V 2W IP40 250 V 2W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.63.004.001/1002 1.63.004.091/0000 5.49.205.013/1002 1.63.004.001/1301 1.63.004.091/0000 5.49.205.013/1301 1.63.004.001/1402 1.63.004.091/0000 5.49.205.013/1402 1.63.004.001/1502 1.63.004.091/0000 5.49.205.013/1502 Technical data see page 3 - 38 Technical data lamps see chapter 5 3 Accessories: Filament lamp, BA 9s base (MBC/MCC), 12 - 15 V: 1.90.060.132/0000 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V: 1.90.060.133/0000 Filament lamp, BA 9s base (MBC/MCC), 110 - 130 V: 1.90.060.137/0000 Neon lamp BA 9s (MBC/MCC), 220 V AC (red): 1.90.560.102/0000 Neon lamp, BA 9s base (MBC/MCC), 220 V AC (green): 1.90.560.104/0000 Signal lamps with lamp socket BA 9s (MBC/MCC), 16.2 mm, round lens With Socket Pict.: yellow Panel cut-out Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 2W IP65 250 V 2W IP65 250 V 2W IP65 250 V 2W IP65 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.63.004.010/1002 1.63.004.100/0000 5.49.227.007/1002 1.63.004.010/1301 1.63.004.100/0000 5.49.227.007/1301 1.63.004.010/1402 1.63.004.100/0000 5.49.227.007/1402 1.63.004.010/1502 1.63.004.100/0000 5.49.227.007/1502 Technical data see page 3 - 38 Technical data lamps see chapter 5 Accessories: Filament lamp, BA 9s base (MBC/MCC), 12 - 15 V: 1.90.060.003/0000 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V: 1.90.060.014/0000 Neon lamp BA 9s (MBC/MCC), 220 V AC: 1.90.560.002/0000 Signal lamps Stock items are marked by bold printed order numbers. 3 - 39 Signal lamps with lamp socket Signal lamps with lamp socket E 10 (MES), 16.2 mm Pict.: red Screw terminals, yellow Panel cut-out Technical data General information Form of lens Colour of lens Diameter of collar 3 Dimensions Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp round see order block 20 mm see order block see order block 16.2 mm Electrical characteristics Voltage limit max. Power limit max. Other specifications Degree of protection from front side Weight Approvals at 2W (T=°C) 250 V 2W IP40 11 g VDE ring nut see order block E 10 filament lamp Accessories Signal lamps with lamp socket E 10 (MES), 16.2 mm Description With Socket Photo Order no. Page Filament lamp, E 10 (MES) base, 24 - 30 V 1.90.010.033/0000 5 - 11 Filament lamp, E 10 (MES) base, 110 - 130 V 1.90.010.037/0000 5 - 11 Protective sleeve for terminals 5.52.011.026/0100 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 3 - 40 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket E 10 (MES), 16.2 mm, round lens Pict.: red Panel cut-out Power Terminals Voltage limit max. limit max. Colour of lens 250 V 2W 250 V 2W 250 V 2W 250 V 2W 250 V 2W transparent colourless transparent red transparent yellow transparent green transparent blue screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated Order no. complete Order no. single parts Housing Lens 1.60.502.102/1002 1.60.502.091/0000 5.49.205.013/1002 1.60.502.102/1301 1.60.502.091/0000 5.49.205.013/1301 1.60.502.102/1402 1.60.502.091/0000 5.49.205.013/1402 1.60.502.102/1502 1.60.502.091/0000 5.49.205.013/1502 1.60.502.102/1601 1.60.502.091/0000 5.49.205.013/1601 Technical data see page 3 - 40 3 Approval: VDE, SEV T70°C. Versions with 2.8 x 0.8 quick-connect terminals available on request. Signal lamps with lamp socket E 10 (MES), 16.2 mm, round lens With Socket Pict.: Screw terminals, yellow Panel cut-out Power Terminals Voltage limit max. limit max. Colour of lens 250 V 2W 250 V 2W 250 V 2W 250 V 2W 250 V 2W transparent colourless transparent red transparent yellow transparent green transparent blue screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated Order no. complete Order no. single parts Housing Lens 1.60.502.001/1002 1.60.502.099/0000 5.49.227.004/1002 1.60.502.001/1301 1.60.502.099/0000 5.49.227.004/1301 1.60.502.001/1402 1.60.502.099/0000 5.49.227.004/1402 1.60.502.001/1502 1.60.502.099/0000 5.49.227.004/1502 1.60.502.001/1601 1.60.502.099/0000 5.49.227.004/1601 Technical data see page 3 - 40 Approval: VDE, SEV T70°C. Signal lamps Stock items are marked by bold printed order numbers. 3 - 41 Signal lamps with lamp socket Signal lamps with lamp socket E 10 (MES), 16.2 mm, round lens Pict.: Screw terminals, yellow 3 Panel cut-out Power Terminals Voltage limit max. limit max. Colour of lens 250 V 2W 250 V 2W 250 V 2W 250 V 2W 250 V 2W transparent colourless transparent red transparent yellow transparent green transparent blue screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated screw terminals nickel-plated Order no. complete Order no. single parts Housing Lens 1.60.502.002/1002 1.60.502.098/0000 5.49.227.005/1002 1.60.502.002/1301 1.60.502.098/0000 5.49.227.005/1301 1.60.502.002/1402 1.60.502.098/0000 5.49.227.005/1402 1.60.502.002/1502 1.60.502.098/0000 5.49.227.005/1502 1.60.502.002/1601 1.60.502.098/0000 5.49.227.005/1601 Technical data see page 3 - 40 Approval: VDE, SEV T70°C. With Socket 3 - 42 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket BA 9s (MBC/MCC), 18.2 mm Pict.: green Mounting hole Technical data General information Form of lens Colour of lens Diameter of collar 3 Dimensions Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp round see order block 22 mm 14 mm 47 mm 18.2 mm Electrical characteristics Voltage limit max. Power limit max. 250 V 2W Other specifications Degree of protection from front side Weight Approvals IP65 22 g VDE T120°C / 2 W ring nut quick connecter 6.3 x 0.8 / 2 x 2.8 x 0.8 tin plated BA 9 s filament lamp Accessories Signal lamps with lamp socket BA 9s (MBC/MCC), 18.2 mm With Socket Description Photo Order no. Page Filament lamp, BA 9s base (MBC/MCC), 12 - 15 V 1.90.060.132/0000 5 - 8 Filament lamp, BA 9s base (MBC/MCC), 24 - 30 V 1.90.060.133/0000 5 - 8 Filament lamp, BA 9s base (MBC/MCC), 110 - 130 V 1.90.060.137/0000 5 - 8 Protective sleeve for terminals made of Buna N (NBR) 5.52.011.027/0100 3 - 44 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket BA 9s (MBC/MCC), 18.2 mm, round lens Pict.: green Mounting hole Power Lamp Voltage limit max. limit max. Colour of lens 250 V 2W filament lamp 250 V 2W filament lamp 250 V 2W filament lamp 250 V 2W filament lamp transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.63.018.001/1002 1.63.018.091/0000 5.49.205.018/1002 1.63.018.001/1301 1.63.018.091/0000 5.49.205.018/1301 1.63.018.001/1402 1.63.018.091/0000 5.49.205.018/1402 1.63.018.001/1502 1.63.018.091/0000 5.49.205.018/1502 Technical data see page 3 - 44 3 With Socket Signal lamps Stock items are marked by bold printed order numbers. 3 - 45 Signal lamps with lamp socket Signal lamps with lamp socket E 14, 22.3 mm Pict.: red Panel cut-out Technical data General information Form of lens Colour of lens Diameter of collar 3 round see order block 28 mm Dimensions Overall height Mounting depth Mounting hole 14 mm 46 mm 22.3 mm Mechanical design Mounting Terminals Lamp socket Lamp ring nut see order block E 14 filament lamp Electrical characteristics Voltage limit max. Power limit max. 250 V 2W Other specifications Degree of protection from front side Weight Approvals 1W (T100°C) Approvals 2W (T85°C) see order block 21 g VDE VDE, DEMKO, NEMKO Accessories Signal lamps with lamp socket E 14, 22.3 mm Description With Socket Photo Order no. Page Filament lamp, E 14 base, 24 - 30 V 1.90.020.033/0000 5 - 12 Sealing ring for IP65 5.30.075.010/0100 5 - 27 Protection against contact to VBG 4 5.50.240.063/0209 5 - 28 Protective sleeve for terminals made of Buna N (NBR) 5.52.011.029/0100 Fixing spanner M 20, M 22, for ring nut 5.58.002.018/0105 5 - 23 3 - 46 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket E 14, IP40, 22.3 mm Pict.: red Panel cut-out Degree of pro- Terminals Voltage limit max. tection from front side Colour of lens 250 V IP40 250 V IP40 250 V IP40 250 V IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing screw terminals brass nickel-plated screw terminals brass nickel-plated screw terminals brass nickel-plated screw terminals brass nickel-plated Lens 1.61.012.011/1002 1.61.012.099/0000 5.00.350.726/1002 1.61.012.011/1301 1.61.012.099/0000 5.00.350.726/1301 1.61.012.011/1402 1.61.012.099/0000 5.00.350.726/1402 1.61.012.011/1502 1.61.012.099/0000 5.00.350.726/1502 Technical data see page 3 - 46 3 Signal lamps with lamp socket E 14, 22.3 mm, screw-on lens, IP40 Pict.: yellow Panel cut-out Degree of pro- Terminals Voltage limit max. tection from front side Colour of lens 250 V IP40 250 V IP40 250 V IP40 250 V IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing screw terminals brass nickel-plated screw terminals brass nickel-plated screw terminals brass nickel-plated screw terminals brass nickel-plated With Socket Lens 1.61.012.061/1002 1.61.012.099/0000 5.49.229.006/1002 1.61.012.061/1301 1.61.012.099/0000 5.49.229.006/1301 1.61.012.061/1402 1.61.012.099/0000 5.49.229.006/1402 1.61.012.061/1502 1.61.012.099/0000 5.49.229.006/1502 Technical data see page 3 - 46 Signal lamps Stock items are marked by bold printed order numbers. 3 - 47 Signal lamps with lamp socket Signal lamps with lamp socket E 14, 30.5 mm Mounting hole Technical data General information Form of lens Colour of lens Diameter of collar 3 Dimensions Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp round see order block 36 mm see order block 58 mm 30.5 mm Electrical characteristics Voltage limit max. Power limit max. 250 V 5W Other specifications Degree of protection from front side Weight see order block 40 g ring nut clamp + quick connector for 2 x 2.8 x 0.8 mm E 14 filament lamp Accessories Signal lamps with lamp socket E 14, 30.5 mm With Socket Description Photo Order no. Page Protection against contact to VBG 5 5.50.240.065/0200 5 - 28 Protective sleeve for terminals 5.52.011.031/0100 Fixing spanner M 25, M 30 5.58.002.020/0105 5 - 23 3 - 48 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket E 14, IP40, 30.5 mm Pict.: green Mounting hole Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.61.021.004/1002 1.61.021.099/0000 5.00.350.013/1002 1.61.021.004/1301 1.61.021.099/0000 5.00.350.013/1301 1.61.021.004/1402 1.61.021.099/0000 5.00.350.013/1402 1.61.021.004/1502 1.61.021.099/0000 5.00.350.013/1502 Technical data see page 3 - 48 Technical data lamps see chapter 5 3 Accessories: Filament lamp, E 14 base, 24 - 30 V: 1.90.020.033/0000 Filament lamp, E 14 base, 24 V: 1.90.020.053/0000 Filament lamp, E 14 base, 220 - 260 V: 1.90.020.061/0000 Single-wire screw terminal with clamp: 2 x 0.75 to 2.5 mm2, stranded core with wire end sleeve: 2 x 0.75 to 1.5 mm2, quick-connect terminal suitable for 2 x 2.8 x 0.8 tin-plated for soldering. Signal lamps with lamp socket E 14, IP40, 30.5 mm With Socket Pict.: red Mounting hole Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.61.021.001/1002 1.61.021.099/0000 5.49.233.005/1002 1.61.021.001/1301 1.61.021.099/0000 5.49.233.005/1301 1.61.021.001/1402 1.61.021.099/0000 5.49.233.005/1402 1.61.021.001/1502 1.61.021.099/0000 5.49.233.005/1502 Technical data see page 3 - 48 Technical data lamps see chapter 5 Accessories: Filament lamp, E 14 base, 24 - 30 V: 1.90.020.033/0000 Filament lamp, E 14 base, 24 V: 1.90.020.053/0000 Filament lamp, E 14 base, 220 - 260 V: 1.90.020.061/0000 Single-wire screw terminal with clamp: 2 x 0.75 to 2.5 mm2, stranded core with wire end sleeve: 2 x 0.75 to 1.5 mm2, quick-connect terminal suitable for 2 x 2.8 x 0.8 tin-plated for soldering. Signal lamps Stock items are marked by bold printed order numbers. 3 - 49 Signal lamps with lamp socket Signal lamps with lamp socket E 14, IP40, 30.5 mm Pict.: yellow Mounting hole Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.61.021.011/1002 1.61.021.099/0000 5.49.233.008/1002 1.61.021.011/1301 1.61.021.099/0000 5.49.233.008/1301 1.61.021.011/1402 1.61.021.099/0000 5.49.233.008/1402 1.61.021.011/1502 1.61.021.099/0000 5.49.233.008/1502 Technical data see page 3 - 48 Technical data lamps see chapter 5 3 Accessories: Filament lamp, E 14 base, 24 - 30 V: 1.90.020.105/0000 Filament lamp, E 14 base, 220 - 260 V: 1.90.020.115/0000 Single-wire screw terminal with clamp: 2 x 0.75 to 2.5 mm2, stranded core with wire end sleeve: 2 x 0.75 to 1.5 mm2, quick-connect terminal suitable for 2 x 2.8 x 0.8 tin-plated for soldering. With Socket 3 - 50 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket BA 15d, 30.5 mm Mounting hole Technical data General information Form of lens Colour of lens Diameter of collar 3 Dimensions Overall height Mounting depth Mounting hole Mechanical design Mounting Terminals Lamp socket Lamp round see order block 36 mm see order block 58 mm 30.5 mm Electrical characteristics Voltage limit max. Power limit max. 250 V 5W Other specifications Degree of protection from front side Weight see order block 40 g ring nut clamp + quick connector for 2 x 2.8 x 0.8 mm BA 15 d filament lamp Accessories Signal lamps with lamp socket BA 15d, 30.5 mm With Socket Description Photo Order no. Page Protection against contact to VBG 5 5.50.240.065/0200 5 - 28 Protective sleeve 5.52.011.031/0100 Fixing spanner M 25, M 30 5.58.002.020/0105 5 - 23 3 - 52 Stock items are marked by bold printed order numbers. Signal lamps Signal lamps with lamp socket Signal lamps with lamp socket BA 15d, IP40, 30.5 mm Pict.: green Mounting hole Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.63.521.004/1002 1.63.521.099/0000 5.00.350.013/1002 1.63.521.004/1301 1.63.521.099/0000 5.00.350.013/1301 1.63.521.004/1402 1.63.521.099/0000 5.00.350.013/1402 1.63.521.004/1502 1.63.521.099/0000 5.00.350.013/1502 Technical data see page 3 - 52 Technical data lamps see chapter 5 3 Accessories: Filament lamp, BA 15d base, 12 - 15 V: 1.90.070.003/0000 Filament lamp, BA 15d base, 24 - 30 V: 1.90.070.004/0000 Filament lamp, BA 15d base, 24 V: 1.90.070.053/0000 Filament lamp, BA 15d base, 220 - 260 V: 1.90.070.061/0000 Single-wire screw terminal with clamp: 2 x 0.75 to 2.5 mm2, stranded core with wire end sleeve: 2 x 0.75 to 1.5 mm2, quick-connect terminal suitable for 6.8 x 0.8 mm / 2 x 2.8 x 0.8 mm, tin-plated for soldering. With Socket Technical data see page 3 - 52 Signal lamps Stock items are marked by bold printed order numbers. 3 - 53 Signal lamps with lamp socket Signal lamps with lamp socket BA 15d, IP40, 30.5 mm Pict.: red Mounting hole Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.63.521.001/1002 1.63.521.099/0000 5.49.233.005/1002 1.63.521.001/1301 1.63.521.099/0000 5.49.233.005/1301 1.63.521.001/1402 1.63.521.099/0000 5.49.233.005/1402 1.63.521.001/1502 1.63.521.099/0000 5.49.233.005/1502 Technical data see page 3 - 52 Technical data lamps see chapter 5 3 Accessories: Filament lamp, BA 15d base, 12 - 15 V: 1.90.070.003/0000 Filament lamp, BA 15d base, 24 - 30 V: 1.90.070.004/0000 Filament lamp, BA 15d base, 24 V: 1.90.070.053/0000 Filament lamp, BA 15d base, 220 - 260 V: 1.90.070.061/0000 Single-wire screw terminal with clamp: 2 x 0.75 to 2.5 mm2, stranded core with wire end sleeve: 2 x 0.75 to 1.5 mm2, quick-connect terminal suitable for 6.8 x 0.8 mm / 2 x 2.8 x 0.8 mm, tin-plated for soldering. Signal lamps with lamp socket BA 15d, IP40, 30.5 mm With Socket Pict.: yellow Mounting hole Power Degree of protection from Voltage limit max. limit max. front side Colour of lens 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 250 V 5W IP40 transparent colourless transparent red transparent yellow transparent green Order no. complete Order no. single parts Housing Lens 1.63.521.011/1002 1.63.521.099/0000 5.49.233.008/1002 1.63.521.011/1301 1.63.521.099/0000 5.49.233.008/1301 1.63.521.011/1402 1.63.521.099/0000 5.49.233.008/1402 1.63.521.011/1502 1.63.521.099/0000 5.49.233.008/1502 Technical data see page 3 - 52 Technical data lamps see chapter 5 Accessories: Filament lamp, BA 15d base, 24 - 30 V: 1.90.070.105/0000 Filament lamp, BA 15d base, 220 - 260 V: 1.90.070.109/0000 Single-wire screw terminal with clamp: 2 x 0.75 to 2.5 mm2, stranded core with wire end sleeve: 2 x 0.75 to 1.5 mm2, quick-connect terminal suitable for 6.8 x 0.8 mm / 2 x 2.8 x 0.8 mm, tin-plated for soldering. 3 - 54 Stock items are marked by bold printed order numbers. Signal lamps
5.49.227.005/1002 价格&库存
很抱歉,暂时无法提供与“5.49.227.005/1002”相匹配的价格&库存,您可以联系我们找货
