1.10.001.001/0301
1.10.001.001/0301
    RAFI
    插件
    按动开关 直插 单刀单掷-常开 700mA -25℃~+85℃
1.10.001.001/0301 数据手册
Other pushbuttons Pushbutton, opaque, mounting hole diameter 15.2 mm, 250 V/0.7 A 1 Pict.: Screw terminals, red Technical data Other Pushb. General information Form of lens Colour of lens Form of collar protruding lens see order block round Dimensions Diameter of collar Overall height Mounting depth Mounting hole 19 mm 8.2 mm 21.5 mm 15.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut see order block bridge contact momentary see order block Ag no no Mechanical characteristics Operating force max. Operating travel Switching travel NC Switching travel NO Robustness min. 7.5 N 3 mm 1.2 mm 2.0 mm 100 N Electrical characteristics Rated voltage AC max. Rated current max. Contact resistance when new max. Contact resistance acc. to life max. Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Weight Approvals Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 25000 IP40 (IP65 with sealing cap) -25 °C +85 °C -40 °C +90 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 7g ENEC T 85/55 V0 yes 250 V 0.7 A 50 mΩ 300 mΩ Accessories Pushbutton, opaque, mounting hole diameter 15.2 mm, 250 V/0.7 A Description Photo Order no. Page Sealing cap, transparent (IP65) 5.52.008.115/0000 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 1 - 78 Stock items are marked by bold printed order numbers. Pushbuttons Other pushbuttons Pushbutton, opaque, mounting hole diameter 15.2 mm 1 Pict.: Screw terminals, red Contact arrange- Contact function Illuminability ment Terminals Colour of lens Order no. 1 NO momentary no screw terminals opaque black 1.10.001.001/0104 1 NO momentary no screw terminals opaque white 1.10.001.001/0205 1 NO momentary no screw terminals opaque red 1.10.001.001/0301 1 NO momentary no screw terminals opaque green 1.10.001.001/0507 1 NO momentary no opaque black 1.10.001.011/0104 1 NO momentary no opaque white 1.10.001.011/0205 1 NO momentary no opaque red 1.10.001.011/0301 1 NO momentary no opaque green 1.10.001.011/0507 1 NC momentary no solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm screw terminals opaque black 1.10.001.151/0104 1 NC momentary no screw terminals opaque red 1.10.001.151/0301 1 NC momentary no opaque black 1.10.001.161/0104 1 NC momentary no solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm solder/quick connector 6.3x0.8 / 2x 2.8x0.8mm opaque red 1.10.001.161/0301 Technical data see page 1 - 78 Quick-connector 6.3 x 0.8 mm. The connector is splitted and also usable for two connectors 2.8 x 0.8 mm. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 79 Other Pushb.
1.10.001.001/0301 价格&库存
很抱歉,暂时无法提供与“1.10.001.001/0301”相匹配的价格&库存,您可以联系我们找货
1.10.001.001/0301
  • 1+42.679361+5.52570
  • 10+41.3701810+5.35620
  • 25+40.1482725+5.19800
  • 50+38.7518150+5.01720
  • 100+36.83168100+4.76860
  • 250+34.03875250+4.40700
  • 500+32.11862500+4.15840
库存:47
