technical data sheet
1.14.002.103/0000
MICON 5, SMT low, 3 N, 1 NO
fields of application
special features
Measurement-control-regulation
Mechanical and system engineering
Automotive
Electro-medical
Gold contacts, reliable switching with low
currents
Special tactile feedback
High packing density due to small form
factor (5.1 x 6.4 mm)
Different operating forces
Ring and full illumination of the button
surface due to plunger
Variable overall heights due to plunger
Terminal technology: SMT
Traceability through product identification
in accordance with DIN EN ISO 9001
description
MICON 5 tactile switches offer extreme switching reliability, with a very small space requirement. They can be arranged individually,
in rows or as key blocks. For use beneath overlays, we recommend combining the MICON 5 key switches with plungers. Here are
the properties at a glance:
Suitable for the most important soldering techniques
Soldering bath for THT versions
Reflow soldering for SMT versions
Vapor phase soldering for SMT versions
Manual soldering
Processing of the SMT design with SMT automatic assembly machines
IMDS entry
MICON 5, SMT nieder mit einer Bauhöhe von nur 3,45 mm Verarbeitungshinweis: Sonderpipette (Siemens Siplace Best.-Nr.
348514-02) Bestückung mit Revolverkopf. Vorschlag für Schablonendruck: 150 ?m-Schablone mit 10% Pad-Verkleinerung auf Fläche
technical data
general
Operating temperature, min.
-40 °C
direct links
Storage temperature, min.
-40 °C
RAFI eCatalog
Operating temperature, max.
90 °C
Storage temperature, max.
90 °C
illuminated
No
Soldering
Reflow
The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as
described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and
other information about our products are the mere results of individual technical testing. These descriptions and other product features are
only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to
make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names
may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own
purposes may infringe the rights of the respective entity holding those rights.
date: May 19, 2021 page: 1/3
RAFI GmbH & Co. KG
Ravensburger Str. 128-134
88276 Berg / Ravensburg
Germany
www.rafi-group.com,
info.headquarters@rafi-group.com
1.14.002.103/0000
Solder heat resistance according
to standard
DIN EN 60068-2-58
DIN EN 61760-1
Packaging
Blister
Packaging unit
2,100 pcs.
Operating life
1,000,000 cycles
B10
1,300,000 cycles
Shock resistance according to
standard IEC 60068-2-27
100 g at 6 ms amplitude semi-sinusoidal
oscillation restistance according
to standard IEC 60068-2-6
5 g at 10...500 Hz
MOQ order
2,100 pcs.
RoHS compliant
Yes
REACH compliant
Yes
Component material
Silicon
Installation height
3.45 mm
Grid, min.
6 x 7,8 mm
Outside dimension, length
6.4 mm
Outside dimension, width
5.1 mm
Outside dimension, height
3.45 mm
Actuation function
momentary contact function
Operating force, max.
4N
Operating force, min.
3N
Switching travel
0.6 mm
Contact function
1 NO
Contact system
Snap-action contact
Contact material
Gold
Terminal on the rear
SMT
Solderability
Yes
Rated voltage, min.
0.02 V
Rated voltage, max.
35 V
Dielectric strength
250 V
Rated current, min.
0.00001 A
Rated current, max.
0.1 A
Rated power, max.
1W
mounting diameters
mechanical data
electrical data
date: May 19, 2021 page: 2/3
RAFI GmbH & Co. KG
Germany
www.rafi-group.com,
1.14.002.103/0000
drawings
Dimensioned drawing
System drawing
PCB drawing
PCB drawing
Schematic diagram
Product labeling drawing
Packaging drawing
date: May 19, 2021 page: 3/3
RAFI GmbH & Co. KG
Germany
www.rafi-group.com,
