5.72.050.000/0214
5.72.050.000/0214
    RAFI
5.72.050.000/0214 数据手册
LUMOTAST 75 IP40 1 LUMO 75 (40) General data LUMOTAST 75 IP40 pushbutton range Illuminated pushbuttons, signal lamps and keylock switches • Mounting hole diameter 16.2 mm • Degree of protection IP40 • Solder terminals for the following wire cross-sections: - Installed 0.5 mm2 max. - Factory terminated 0.35 mm2 max. • 250 V/4 A max. • 2 NC + 2 NO max. (3 NC + 3 NO on request) • Lamp socket T 4.5 Content LUMOTAST 75 illuminated pushbutton IP40 LUMOTAST 75 illuminated pushbutton IP40, protruding lens, round collar LUMOTAST 75 illuminated pushbutton IP40, flush lens, square collar LUMOTAST 75 illuminated pushbutton IP40, flush lens, rectangular collar LUMOTAST 75 illuminated pushbutton IP40, protruding lens, square collar 1 - 38 1 - 40 1 - 41 1 - 42 1 - 43 LUMOTAST 75 keylock switch IP40 LUMOTAST 75 keylock switch IP40, round collar LUMOTAST 75 keylock switch IP40, rectangular collar 1 - 44 1 - 45 1 - 46 LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5 LUMOTAST 75 IP40 signal lamp with lamp socket T 4.5, round collar, protruding lens LUMOTAST 75 IP40 signal lamp, square collar, flush lens LUMOTAST 75 IP40 signal lamp, rectangular collar, flush lens LUMOTAST 75 IP40 signal lamp, square collar, protruding lens 1 - 48 1 - 49 1 - 50 1 - 50 1 - 51 Pushbuttons 1 - 37 LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40 1 Pict.: with colourless lens Mounting hole Technical data LUMO 75 (40) General information Form of lens Form of collar Colour of collar Rated current AC max. Rated current DC max. Rated current AC/DC min. Contact resistance acc. to life max. Protection class see order block see order block see order block Dimensions Length of collar Width of collar Diameter of collar Overall height Mounting depth Mounting hole see order block see order block see order block 7.5 mm 41.5/49.5/57.5 mm 16.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lamp socket ring nut solder terminals snap-action bridge contact see order block see order block Ag yes T 4.5 Mechanical characteristics Operating force max. Operating travel Switching travel NC Switching travel NO Robustness min. 3 ... 6.5 N 2.7 mm 1.6 mm 0.9 mm 100 N Other specifications Operating life, at 250 V/2 A (operations) Operating life, at 250 V/4 A (operations) Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Approvals Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated voltage AC/DC min. 250 V 220 V 12 V Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 4A 0.2 A 5 mA 200 mΩ II 200000 (momentary) 60000 (momentary), 10000 (latching) IP40 -25 °C +70 °C +55 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 ENEC 25 T 55 (70), UL, CSA V1 yes Accessories LUMOTAST 75 illuminated pushbutton IP40 Description Photo Order no. Page Filament lamp, T 4.5 base, 12 V 1.90.100.022/0000 5 - 6 Filament lamp, T 4.5 base, 24 V 1.90.100.023/0000 5 - 6 1 - 38 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 Accessories LUMOTAST 75 illuminated pushbutton IP40 Description Photo Order no. Page LED T 4.5 superbright, red, 24 V 1.90.690.331/0000 5 - 18 LED T 4.5 superbright, green, 24 V 1.90.690.332/0000 5 - 18 LED T 4.5 superbright, yellow, 24 V 1.90.690.333/0000 5 - 18 LED T 4.5 superbright, blue, 24 V 1.90.690.334/0000 5 - 18 LED T 4.5 superbright, white, 24 V 1.90.690.335/0000 5 - 18 LED T 4.5, red, 2-3 V 1.90.692.001/0000 5 - 18 LED T 4.5, green, 2-3 V 1.90.692.002/0000 5 - 18 LED T 4.5, yellow, 2-3 V 1.90.692.003/0000 5 - 18 Lamp extractor for T 4.5/5.5, lamp diameter 4 mm 1.90.900.002/0000 5 - 22 Lamp extractor for lamp diameter 5-6 mm 1.90.900.004/0000 5 - 22 Protective cap (for 18 x 24 collar) 5.05.800.027/0000 5 - 26 Blanking cap, black, to cover spare holes, dimensions 18 x 18 mm 5.52.006.020/0103 5 - 28 Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 28 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 28 Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 Pushbuttons Stock items are marked by bold printed order numbers. 1 LUMO 75 (40) 1 - 39 LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, protruding lens, round collar 1 Pict.: with colourless lens Mounting hole Contact arrangement Contact function LUMO 75 (40) Colour of collar Order no. without lens 1.15.108.451/0000 Please include the desired lens and diffuser in your order. 1.15.108.551/0000 Please include the desired lens and diffuser in your order. 1.15.108.452/0000 Please include the desired lens and diffuser in your order. 1.15.108.552/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 38 Lenses: Lens, round, transparent colourless, for filament lamp or LED: 5.49.257.011/1002 Lens, round, transparent red, for LED: 5.49.257.011/1301 Lens, round, transparent red, for filament lamp: 5.49.257.011/1303 Lens, round, transparent yellow, for filament lamp or LED: 5.49.257.011/1402 Lens, round, transparent green, for filament lamp: 5.49.257.011/1502 Lens, round, transparent green, for LED: 5.49.257.011/1503 Lens, round, transparent blue, for filament lamp: 5.49.257.011/1601 Accessories: Diffuser, round, for filament lamp, without legend: 5.72.050.000/0202 Diffuser, round, for LED, without legend: 5.72.050.000/0214 1 - 40 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, flush lens, square collar 1 Pict.: with red lens, without ring nut Contact arrangement Contact function Mounting hole Colour of collar Order no. without lens 1.15.108.251/0000 Please include the desired lens and diffuser in your order. 1.15.108.351/0000 Please include the desired lens and diffuser in your order. 1.15.108.252/0000 Please include the desired lens and diffuser in your order. 1.15.108.352/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 38 Lenses: Lens, square, transparent colourless, for filament lamp or LED: 5.49.275.036/1002 Lens, square, transparent red, for LED: 5.49.275.036/1301 Lens, square, transparent red, for filament lamp: 5.49.275.036/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.275.036/1402 Lens, square, transparent green, for filament lamp: 5.49.275.036/1502 Lens, square, transparent green, for LED: 5.49.275.036/1503 Lens, square, transparent blue, for filament lamp: 5.49.275.036/1601 Accessories: Sealing cap IP65 (for 18 x 18 collar): 5.05.200.009/0000 Protective cap (for 18 x 18 collar): 5.05.800.030/0000 Diffuser, square, for filament lamp, without legend: 5.73.013.000/0202 Diffuser, square, for LED, without legend: 5.73.013.000/0214 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 41 LUMO 75 (40) LUMOTAST 75 illuminated pushbutton IP40, flush lens, rectangular collar 1 Pict.: with green lens Contact arrangement Contact function LUMO 75 (40) Colour of collar Order no. without lens 1.15.108.051/0000 Please include the desired lens and diffuser in your order. 1.15.108.151/0000 Please include the desired lens and diffuser in your order. 1.15.108.052/0000 Please include the desired lens and diffuser in your order. 1.15.108.152/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 38 Lenses: Lens, rectangular, transparent colourless, for filament lamp or LED: 5.49.275.032/1002 Lens, rectangular, transparent red, for LED: 5.49.275.032/1301 Lens, rectangular, transparent red, for filament lamp: 5.49.275.032/1303 Lens, rectangular, transparent yellow, for filament lamp or LED: 5.49.275.032/1402 Lens, rectangular, transparent green, for filament lamp: 5.49.275.032/1502 Lens, rectangular, transparent green, for LED: 5.49.275.032/1503 Lens, rectangular, transparent blue, for filament lamp: 5.49.275.032/1601 Accessories: Sealing cap IP65 (for 18 x 24 collar): 5.05.200.008/0000 Protective cap (for 18 x 24 collar): 5.05.800.027/0000 Diffuser, rectangular, for filament lamp, without legend: 5.73.012.000/0202 Diffuser, rectangular, for LED, without legend: 5.73.012.000/0214 1 - 42 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 LUMOTAST 75 illuminated pushbutton IP40, protruding lens, square collar 1 Pict.: with colourless lens Mounting hole Contact arrangement Contact function Colour of collar Order no. without lens 1.15.108.256/0000 Please include the desired lens and diffuser in your order. 1.15.108.356/0000 Please include the desired lens and diffuser in your order. 1.15.108.257/0000 Please include the desired lens and diffuser in your order. 1.15.108.357/0000 Please include the desired lens and diffuser in your order. 1 NC + 1 NO momentary black 1 NC + 1 NO latching black 2 NC + 2 NO momentary black 2 NC + 2 NO latching black Note Technical data see page 1 - 38 Lenses: Lens, square, transparent colourless, for filament lamp or LED: 5.49.275.036/1002 Lens, square, transparent red, for LED: 5.49.275.036/1301 Lens, square, transparent red, for filament lamp: 5.49.275.036/1303 Lens, square, transparent yellow, for filament lamp or LED: 5.49.275.036/1402 Lens, square, transparent green, for filament lamp: 5.49.275.036/1502 Lens, square, transparent green, for LED: 5.49.275.036/1503 Lens, square, transparent blue, for filament lamp: 5.49.275.036/1601 Accessories: Sealing cap IP65 (for 18 x 18 collar): 5.05.200.009/0000 Protective cap (for 18 x 18 collar): 5.05.800.030/0000 Diffuser, square, for filament lamp, without legend: 5.73.013.000/0202 Diffuser, square, for LED, without legend: 5.73.013.000/0214 Pushbuttons Stock items are marked by bold printed order numbers. 1 - 43 LUMO 75 (40) LUMOTAST 75 IP40 LUMOTAST 75 keylock switch IP40 1 Mounting hole Technical data LUMO 75 (40) General information Form of lens Colour of collar Form of collar Dimensions Length of collar Diameter of collar Width of collar Overall height (without key) Mounting depth Mounting hole see order block see order block see order block 7.5 mm see order block 16.2 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illuminability Lock Wafers Lock type Number of locking positions Main key Symmetric key Key removal position 45 no no see order block Mechanical characteristics Rotating angle see order block Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated voltage AC/DC min. Rated current AC max. Rated current DC max. Rated current AC/DC min. Contact resistance acc. to life max. Bouncing time max. ESD-strength min. see order block see order block see order block ring nut solder terminals snap-action bridge contact see order block see order block Ag no cylinder lock 4 pins 1D 21 Other specifications Operating life, at 250 V/2 A (operations) Operating life, at 250 V/4 A (operations) Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Weight max. Approvals Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 12 V 4A 0.02 A 5 mA 200 mΩ 10 ms 14 kV 50000 (momentary) 50000 (momentary) IP40 -25 °C +70 °C -40 °C +80 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 35 g ENEC 25 T 55 (70), UL, CSA V1 yes 250 V 220 V Accessories LUMOTAST 75 keylock switch IP40 Description Photo Order no. Page Blanking cap, black, to cover spare holes, dimensions 18 x 24 mm 5.52.006.021/0100 5 - 28 Blanking cap, black, to cover spare holes, round 18 mm 5.52.006.022/0100 5 - 28 1 - 44 Stock items are marked by bold printed order numbers. Pushbuttons LUMOTAST 75 IP40 Accessories LUMOTAST 75 keylock switch IP40 Description Photo Order no. Page Fixing spanner M 15, M 16 5.58.002.019/0105 5 - 23 Key cap for LUMO 75 5.58.002.030/0000 Spare key for LUMO 75 5.58.004.721/0000 1 LUMOTAST 75 keylock switch IP40, round collar LUMO 75 (40) Mounting hole Contact arrangement Contact function Rotating angle Key removal position Colour of collar Order no. 1 NC + 1 NO latching 90° 0 black 1.15.108.851/0000 1 NC + 1 NO latching 90° 0+1 black 1.15.108.911/0000 1 NC + 1 NO momentary 45° 0 black 1.15.108.941/0000 2 NC + 2 NO latching 90° 0 black 1.15.108.852/0000 2 NC + 2 NO latching 90° 0+1 black 1.15.108.912/0000 Technical data see page 1 - 44 Included: 2 keys. Other lock variants and contacts available on request. Pushbuttons Stock items are marked by bold printed order numbers. 1 - 45 LUMOTAST 75 IP40 LUMOTAST 75 keylock switch IP40, rectangular collar 1 Panel cut-out Contact arrangement LUMO 75 (40) Contact function Rotating angle Key removal position Colour of collar Order no. 1 NC + 1 NO latching 90° 0 black 1.15.108.571/0100 1 NC + 1 NO latching 90° 0+1 black 1.15.108.631/0100 1 NC + 1 NO momentary 45° 0 black 1.15.108.661/0100 2 NC + 2 NO latching 90° 0 black 1.15.108.572/0100 2 NC + 2 NO latching 90° 0+1 black 1.15.108.632/0100 Technical data see page 1 - 44 Included: 2 keys. Other lock variants and contacts available on request. 1 - 46 Stock items are marked by bold printed order numbers. Pushbuttons
5.72.050.000/0214 价格&库存
很抱歉,暂时无法提供与“5.72.050.000/0214”相匹配的价格&库存,您可以联系我们找货
5.72.050.000/0214
  • 2+5.585042+0.72230
库存:2
