CP2102 USB UART BOARD (TYPE A)
    WAVESHARE(微雪电子)
CP2102 USB UART BOARD (TYPE A) 数据手册
CP2102 S I N G L E - C H I P USB T O UART B R I D G E Single-Chip USB to UART Data Transfer Virtual COM Port Device Drivers Integrated USB transceiver; no external resistors required Integrated clock; no external crystal required Integrated 1024-Byte EEPROM for vendor ID, product ID, serial number, power descriptor, release number, and product description strings On-chip power-on reset circuit On-chip voltage regulator: 3.3 V output 100% pin and software compatible with CP2101 Works with existing COM Port PC applications Royalty-free distribution license Windows 98 SE/2000/XP MAC OS-9 MAC OS-X Linux 2.40 USBXpress™ Direct Driver Support Example Applications Upgrade of RS-232 legacy devices to USB Cellular phone USB interface cable PDA USB interface cable USB to RS-232 serial adapter USB Function Controller USB Specification 2.0 compliant; full-speed (12 Mbps) USB suspend states supported via SUSPEND pins Asynchronous Serial Data BUS (UART) Supply Voltage All handshaking and modem interface signals Data formats supported: - Data bits: 5, 6, 7, and 8 - Stop bits: 1, 1.5, and 2 - Parity: odd, even, mark, space, no parity Baud rates: 300 bps to 1 Mbits 576 Byte receive buffer; 640 byte transmit buffer Hardware or X-On/X-Off handshaking supported Event character support Line break transmission 7 REGIN IN Self-powered: 3.0 to 3.6 V USB bus powered: 4.0 to 5.25 V Package Lead free 28-pin QFN (5 x 5 mm) Ordering Part Number CP2102-GM Temperature Range: –40 to +85 °C CP2102 Voltage Regulator VDD RST OUT SUSPEND 6 3 8 USB CONNECTOR VBUS DD+ GND 3.3 V VDD GND RI 48 MHz Oscillator VBUS 3 4 DCD DTR 1 2 SUSPEND 5 4 5 6 D1 D2 D3 DD+ USB Transceiver USB Function Controller UART 640B 576B 1024B TX RX EEPROM Buffer Buffer DSR TXD RXD RTS CTS 9 12 11 (to external circuitry for USB suspend states) 2 1 28 27 External RS-232 transceiver or UART circuitry 26 25 24 23 Figure 1. Example System Diagram Rev. 1.1 9/05 Copyright © 2005 by Silicon Laboratories CP2102 CP2102 2 Rev. 1.1 CP2102 TA B L E O F C O N T E N TS Section Page 1. System Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4 2. Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5 3. Global DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5 4. Pinout and Package Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6 5. USB Function Controller and Transceiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 6. Asynchronous Serial Data Bus (UART) Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 7. Internal EEPROM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 8. Virtual Com Port Device Drivers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 9. USBXpress Direct Driver Support . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 10. Voltage Regulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact Information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .16 Rev. 1.1 3 CP2102 1. System Overview The CP2102 is a highly-integrated USB-to-UART Bridge Controller providing a simple solution for updating RS-232 designs to USB using a minimum of components and PCB space. The CP2102 includes a USB 2.0 full-speed function controller, USB transceiver, oscillator, EEPROM, and asynchronous serial data bus (UART) with full modem control signals in a compact 5 x 5 mm QFN-28 package. No other external USB components are required. The on-chip EEPROM may be used to customize the USB Vendor ID, Product ID, Product Description String, Power Descriptor, Device Release Number, and Device Serial Number as desired for OEM applications. The EEPROM is programmed on-board via the USB allowing the programming step to be easily integrated into the product manufacturing and testing process. Royalty-free Virtual COM Port (VCP) device drivers provided by Silicon Laboratories allow a CP2102-based product to appear as a COM port to PC applications. The CP2102 UART interface implements all RS-232 signals, including control and handshaking signals, so existing system firmware does not need to be modified. In many existing RS-232 designs, all that is required to update the design from RS-232 to USB is to replace the RS-232 level-translator with the CP2102. An evaluation kit for the CP2102 (Part Number: CP2102EK) is available. It includes a CP2102-based USB-toUART/RS-232 evaluation board, a complete set of VCP device drivers, USB and RS-232 cables, and full documentation. Contact a Silicon Labs’ sales representatives or go to www.silabs.com to order the CP2102 Evaluation Kit. 4 Rev. 1.1 CP2102 2. Absolute Maximum Ratings Table 1. Absolute Maximum Ratings Parameter Conditions Min Typ Max Units Ambient temperature under bias –55 — 125 °C Storage Temperature –65 — 150 °C Voltage on any I/O Pin or RST with respect to GND –0.3 — 5.8 V Voltage on VDD with respect to GND –0.3 — 4.2 V Maximum Total current through VDD and GND — — 500 mA Maximum output current sunk by RST or any I/O pin — — 100 mA Note: Stresses above those listed may cause permanent damage to the device. This is a stress rating only, and functional operation of the devices at or exceeding the conditions in the operation listings of this specification is not implied. Exposure to maximum rating conditions for extended periods may affect device reliability. 3. Global DC Electrical Characteristics Table 2. Global DC Electrical Characteristics VDD = 2.7 to 3.6 V, –40 to +85 °C unless otherwise specified. Parameter Conditions Supply Voltage Min Typ Max Units 3.0 3.3 3.6 V Supply Current VDD = 3.3 V — 26 — mA Supply Current in Suspend VDD = 3.3 V — 330 — µA –40 — +85 °C Specified Operating Temperature Range Table 3. UART and Suspend I/O DC Electrical Characteristics VDD = 2.7 to 3.6 V, –40 to +85 °C unless otherwise specified. Parameters Output High Voltage Output Low Voltage Conditions IOH = –3 mA IOH = –10 µA IOH = –10 mA IOL = 8.5 mA IOL = 10 µA IOL = 25 mA Min Typ — VDD – 0.7 — VDD – 0.1 VDD – 0.8 — Max UNITS — — — V — — — — — 1.0 0.6 0.1 — V Input High Voltage 2.0 — — V Input Low Voltage — — 0.8 V Input Leakage Current — 25 50 µA Rev. 1.1 5 CP2102 4. Pinout and Package Definitions Table 4. CP2102 Pin Definitions Name Pin # Type VDD 6 Power In Description 3.0–3.6 V Power Supply Voltage Input. Power Out 3.3 V Voltage Regulator Output. See Section 10. GND 3 Ground RST 9 D I/O Device Reset. Open-drain output of internal POR or VDD monitor. An external source can initiate a system reset by driving this pin low for at least 15 µs. REGIN 7 Power In 5 V Regulator Input. This pin is the input to the on-chip voltage regulator. VBUS 8 D In VBUS Sense Input. This pin should be connected to the VBUS signal of a USB network. A 5 V signal on this pin indicates a USB network connection. D+ 4 D I/O USB D+ D– 5 D I/O USB D– TXD 26 D Out Asynchronous data output (UART Transmit) RXD 25 D In Asynchronous data input (UART Receive) CTS 23* D In Clear To Send control input (active low) RTS 24* D Out Ready to Send control output (active low) DSR 27* D in Data Set Ready control input (active low) DTR 28* D Out DCD 1* D In Data Carrier Detect control input (active low) RI 2* D In Ring Indicator control input (active low) SUSPEND 12* D Out This pin is driven high when the CP2102 enters the USB suspend state. SUSPEND 11* D Out This pin is driven low when the CP2102 enters the USB suspend state. NC 10, 13–22 Data Terminal Ready control output (active low) These pins should be left unconnected or tied to VDD. *Note: Pins can be left unconnected when not used. 6 Rev. 1.1 DTR DSR TXD RXD RTS CTS NC 27 26 25 24 23 22 GND 28 CP2102 DCD 1 21 NC RI 2 20 NC GND 3 19 NC D+ 4 18 NC D- 5 17 NC VDD 6 16 NC REGIN 7 15 NC CP2102 Top View 8 9 10 11 12 13 14 VBUS RST NC SUSPEND SUSPEND NC NC GND Figure 2. QFN-28 Pinout Diagram (Top View) Rev. 1.1 7 CP2102 14 13 12 11 15 6 16 D2 5 D2 2 17 e 4 2 20 21 22 23 24 25 26 27 DETAIL 1 28 1 18 19 E2 2 3 R 6xe E 10 9 Table 5. QFN-28 Package Dimensions L 7 E2 b 8 Bottom View 6xe D A A2 Side View A1 e A3 A A1 A2 A3 b D D2 E E2 e L N ND NE R AA BB CC DD DETAIL 1 CC DD BB AA Figure 3. QFN-28 Package Drawing 8 Rev. 1.1 MIN 0.80 0 0 — 0.18 — 2.90 — 2.90 — 0.45 — — — 0.09 — — — — MM TYP 0.90 0.02 0.65 0.25 0.23 5.00 3.15 5.00 3.15 0.5 0.55 28 7 7 — 0.435 0.435 0.18 0.18 MAX 1.00 0.05 1.00 — 0.30 — 3.35 — 3.35 — 0.65 — — — — — — — — CP2102 0.30 mm 0.50 mm 0.85 mm 0.35 mm 0.50 mm 0.10 mm 0.20 mm 0.20 mm 0.50 mm Top View b 0.20 mm D D2 Optional GND Connection L e E2 0.20 mm 0.30 mm 0.50 mm 0.85 mm 0.35 mm 0.10 mm E Figure 4. Typical QFN-28 Landing Diagram Rev. 1.1 9 CP2102 0.30 mm 0.35 mm 0.50 mm 0.60 mm 0.20 mm 0.10 mm 0.85 mm 0.50 mm 0.20 mm 0.20 mm 0.50 mm Top View 0.60 mm 0.30 mm 0.70 mm b 0.20 mm e L E2 0.20 mm 0.30 mm 0.50 mm 0.85 mm 0.35 mm 0.10 mm E Figure 5. Typical QFN-28 Solder Paste Diagram 10 Rev. 1.1 D D2 0.40 mm CP2102 5. USB Function Controller and Transceiver The Universal Serial Bus function controller in the CP2102 is a USB 2.0 compliant full-speed device with integrated transceiver and on-chip matching and pull-up resistors. The USB function controller manages all data transfers between the USB and the UART as well as command requests generated by the USB host controller and commands for controlling the function of the UART. The USB Suspend and Resume signals are supported for power management of both the CP2102 device as well as external circuitry. The CP2102 will enter Suspend mode when Suspend signaling is detected on the bus. On entering Suspend mode, the CP2102 asserts the SUSPEND and SUSPEND signals. SUSPEND and SUSPEND are also asserted after a CP2102 reset until device configuration during USB Enumeration is complete. The CP2102 exits the Suspend mode when any of the following occur: (1) Resume signaling is detected or generated, (2) a USB Reset signal is detected, or (3) a device reset occurs. On exit of Suspend mode, the SUSPEND and SUSPEND signals are de-asserted. Both SUSPEND and SUSPEND temporarily float high during a CP2102 reset. If this behavior is undesirable, a strong pulldown (10 kΩ) can be used to ensure SUSPEND remains low during reset. See Figure 6 for other recommended options. VDD CP2102 7 R1 4.7 kΩ RST SUSPEND 6 C4 4.7 µF TANT C2 0.1 µF 3 VDD SUSPEND GND RI Option 2 8 USB CONNECTOR VBUS DD+ GND DCD VBUS DTR DSR 1 2 5 3 4 4 5 6 D1 D2 D- TXD D+ RXD RTS D3 Option 3 Option Option Option Option Option 1: 2: 3: 3: 4: Option 1 REGIN C1 1 µF CTS 9 (to external circuitry for USB suspend states) 12 11 R2 10 kΩ 2 1 28 27 Option 4 External RS-232 transceiver or UART circuitry 26 25 24 23 A 4.7 kΩ pull-up resistor can be added to increase noise immunity. A 4.7 µF tantalum capacitor can be added if powering other devices from the on-chip regulator. Avalanche transient voltage suppression diodes should be added for ESD protection . Use Littlefuse p/n SP0503BAHT or equivalent. 10 kΩ resistor to ground to hold SUSPEND low on initial power on or device reset. Figure 6. Typical Connection Diagram Rev. 1.1 11 CP2102 6. Asynchronous Serial Data Bus (UART) Interface The CP2102 UART interface consists of the TX (transmit) and RX (receive) data signals as well as the RTS, CTS, DSR, DTR, DCD, and RI control signals. The UART supports RTS/CTS, DSR/DTR, and X-On/X-Off handshaking. The UART is programmable to support a variety of data formats and baud rates. The data format and baud rate programmed into the UART is set during COM port configuration on the PC. The data formats and baud rates available are listed in Table 6. Table 6. Data Formats and Baud Rates Data Bits 5, 6, 7, and 8 Stop Bits 1, 1.51, and 2 Parity Type Baud Rates None, Even, Odd, Mark, Space 2 300, 600, 1200, 1800, 2400, 4000, 4800, 7200, 9600, 14400, 16000, 19200, 28800, 38400, 51200, 56000, 57600, 64000, 76800, 115200, 128000, 153600, 230400, 250000, 256000, 460800, 500000, 576000, 9216003 Notes: 1. 5-bit only. 2. Additional baud rates are supported. See “AN205”. 3. 7 or 8 data bits only. 7. Internal EEPROM The CP2102 includes an internal EEPROM that may be used to customize the USB Vendor ID, Product ID, Product Description String, Power Descriptor, Device Release Number, and Device Serial Number as desired for OEM applications. Customization of the USB configuration data is optional. If the EEPROM is not programmed with OEM data, the default configuration data shown in Table 7 is used. However, a unique serial number is required for OEM applications in which it is possible for multiple CP2102-based devices to be connected to the same PC. The internal EEPROM is programmed via the USB. This allows the OEM's USB configuration data and serial number to be written to the CP2102 on-board during the manufacturing and testing process. A stand-alone utility for programming the internal EEPROM is available from Silicon Laboratories. A library of routines provided in the form of a Windows® DLL is also available. This library can be used to integrate the EEPROM programming step into custom software used by the OEM to streamline testing and serial number management during manufacturing. The EEPROM has a typical endurance of 100,000 write cycles with a data retention of 100 years. USB descriptors can be locked to prevent future modification. Table 7. Default USB Configuration Data Name Value Vendor ID 10C4h Product ID EA60h Power Descriptor (Attributes) 80h 12 Power Descriptor (Max. Power) 32h Release Number 0100h Serial Number 0001 (63 characters maximum) Product Description String “CP2102 USB to UART Bridge Controller” (126 characters maximum) Rev. 1.1 CP2102 8. Virtual Com Port Device Drivers The CP210x Virtual COM Port (VCP) device drivers allow a CP2102-based device to appear to the PC's application software as an additional COM port (in addition to any existing hardware COM ports). Application software running on the PC accesses the CP2102-based device as it would access a standard hardware COM port. However, actual data transfer between the PC and the CP2102 device is performed over the USB. Therefore, existing COM port applications may be used to transfer data via the USB to the CP2102-based device without modifying the application. Contact Silicon Laboratories for the latest list of supported operating systems. Note: Silicon Laboratories’ VCP device drivers are required for device operation and are only distributed as part of the CP2102 Evaluation Kit (Part Number: CP2102EK). Contact any of Silicon Lab’s sales representatives or go to www.silabs.com to order the CP2102 Evaluation Kit. The CP210x drivers and programming utilities are subject to change without notice. Subscription to the website "Auto Email Alert" system for automatic notification of updates and the use of the "Product Update Registration" service is recommended. 9. USBXpress Direct Driver Support The Silicon Laboratories USBXpress for CP210x Development Kit provides an alternate solution for interfacing with CP210x devices than using the Virtual COM port. No Serial Port protocol expertise is required. Instead, a simple, high-level application program interface (API) is used to provide simpler CP201x connectivity and functionality. The USBXpress for CP210x Development Kit includes Windows device drivers, Windows device driver installer and uninstallers, and a host interface function library (host API) provided in the form of a Windows Dynamic Link Library (DLL). The included device drivers and installation files support MS Windows 98SE/2000/XP. 10. Voltage Regulator The CP2102 includes an on-chip 5 to 3 V voltage regulator. This allows the CP2102 to be configured as either a USB bus-powered device or a USB self-powered device. These configurations are shown in Figure 7 and Figure 8. When enabled, the 3 V voltage regulator output appears on the VDD pin and can be used to power external 3 V devices. See Table 8 for the voltage regulator electrical characteristics. Alternatively, if 3 V power is supplied to the VDD pin, the CP2102 can function as a USB self-powered device with the voltage regulator disabled. For this configuration, it is recommended that the REGIN input be tied to the 3 V net to disable the voltage regulator. This configuration is shown in Figure 9. The USB max power and power attributes descriptor must match the device power usage and configuration. See application note “AN144: CP210x Customization Guide” for information on how to customize USB descriptors for the CP2102. Note: It is recommended that additional decoupling capacitance (e.g., 0.1 µF in parallel with 1.0 µF) be provided on the REGIN input. Table 8. Voltage Regulator Electrical Specifications –40 to +85 °C unless otherwise specified. Parameter Conditions Min Typ Max Units 4.0 — 5.25 V 3.0 3.3 3.6 V VBUS Detection Input Threshold 1.0 1.8 4.0 V Bias Current — 90 — µA Input Voltage Range Output Voltage Output Current = 1 to 100 mA* *Note: The maximum regulator supply current is 100 mA. Rev. 1.1 13 CP2102 CP2102 VBUS VBUS Sense From VBUS REGIN 5 V In Voltage Regulator (REG0) 3 V Out To 3 V Power Net VDD Device Power Net Figure 7. Configuration 1: USB Bus-Powered CP2102 From VBUS VBUS VBUS Sense From 5 V Power Net REGIN 5 V In Voltage Regulator (REG0) 3 V Out To 3V Power Net VDD Device Power Net Figure 8. Configuration 2: USB Self-Powered 14 Rev. 1.1 CP2102 CP2102 From VBUS VBUS VBUS Sense REGIN 5 V In Voltage Regulator (REG0) 3 V Out From 3 V Power Net VDD Device Power Net Figure 9. Configuration 3: USB Self-Powered, Regulator Bypassed Rev. 1.1 15 CP2102 Document Change List Revision 1.0 to Revision 1.1 Updated “Linux 2.40” bullet on page 1. Changed MLP to QFN throughout. 16 Rev. 1.1 CP2102 NOTES: Rev. 1.1 17 CP2102 CONTACT INFORMATION Silicon Laboratories Inc. 4635 Boston Lane Austin, TX 78735 Tel: 1+(512) 416-8500 Fax: 1+(512) 416-9669 Toll Free: 1+(877) 444-3032 Email: MCUinfo@silabs.com Internet: www.silabs.com The information in this document is believed to be accurate in all respects at the time of publication but is subject to change without notice. Silicon Laboratories assumes no responsibility for errors and omissions, and disclaims responsibility for any consequences resulting from the use of information included herein. Additionally, Silicon Laboratories assumes no responsibility for the functioning of undescribed features or parameters. Silicon Laboratories reserves the right to make changes without further notice. Silicon Laboratories makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Silicon Laboratories assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. Silicon Laboratories products are not designed, intended, or authorized for use in applications intended to support or sustain life, or for any other application in which the failure of the Silicon Laboratories product could create a situation where personal injury or death may occur. Should Buyer purchase or use Silicon Laboratories products for any such unintended or unauthorized application, Buyer shall indemnify and hold Silicon Laboratories harmless against all claims and damages. Silicon Laboratories, Silicon Labs, and USBXpress are trademarks of Silicon Laboratories Inc. Other products or brandnames mentioned herein are trademarks or registered trademarks of their respective holders 18 Rev. 1.1
CP2102 USB UART BOARD (TYPE A) 价格&库存
很抱歉,暂时无法提供与“CP2102 USB UART BOARD (TYPE A)”相匹配的价格&库存,您可以联系我们找货
