CR0603AFX-1000ELF
CR0603AFX-1000ELF
    OTHER
    CR0603AFX-1000ELF
CR0603AFX-1000ELF 数据手册
*R AE **H oHS C- AL C Q2 OG OM 00 EN P CO FR LIA M EE NT PL & , IA NT Features n Thick film technology n Power rating up to 1 watt @ 70 °C n RoHS compliant* n Halogen free** n AEC-Q200 compliant CRxxxxA - AEC-Q200 Compliant Chip Resistors Electrical Characteristics Characteristic Model No. CR0201A CR0402A CR0603A CR0805A Power Rating @ 70 °C 0.05 W 0.063 W 0.1 W 0.125 W Operating Temp. Range -55 to +125 °C -55 to +155 °C Derated to Zero Load at +125 °C +155 °C Maximum Working Voltage 25 V 50 V 50 V 150 V Maximum Overload Voltage 50 V 100 V 100 V 300 V 1 Ω ~ 9.76 Ω ±400 ppm/°C 1 Ω ~ 9.76 Ω ±400 ppm/°C 10 Ω ≤ R ≤ 1M Ω ±100 ppm/°C 10 Ω ≤ R ≤ 1M Ω ±100 ppm/°C 1M Ω < R ≤ 10M Ω ±200 ppm/°C 1M Ω < R ≤ 10M Ω ±200 ppm/°C 1 Ω ~ 9.1 Ω 10M < R ≤ 20M Ω ±400 ppm/°C 1 Ω ~ 9.1 Ω 10M < R ≤ 20M Ω ±400 ppm/°C 10 Ω ≤ R ≤ 10M Ω ±200 ppm/°C 10 Ω ≤ R ≤ 10M Ω ±200 ppm/°C 1 A / 2.5 A 2A/5A Resistance Tolerance ±1 %, ±5 % 1 Ω ~ 9.76 Ω -200 ~ +500 ppm/°C Temperature Coefficient @ 1 % (E24 + E96) Temperature Coefficient @ 5 % (E24) Zero Ohm Jumper ≤ 0.05 Ω Rated / Max. Current 1 Ω ~ 9.76 Ω -200 ~ +600 ppm/°C 10 Ω ~ 3M Ω +200 ppm/°C 1 Ω ~ 9.1 Ω -200 ~ +600 ppm/°C 10 Ω ~ 10M Ω +200 ppm/°C 100 Ω ≤ R ≤ 1M Ω ±100 ppm/°C 10 Ω ≤ R < 100 Ω 1M Ω < R ≤ 10M Ω ±200 ppm/°C 1 Ω ~ 9.1 Ω -200 ~ +500 ppm/°C 10 Ω ≤ R ≤ 10M Ω ±200 ppm/°C 10M Ω ≤ R ≤ 20M Ω ±400 ppm/°C 0.5 A / 1 A 1 A / 2.5 A Environmental Characteristics Moisture Sensitivity Level........................................................... 1 ESD Classification (HBM).........................................................1A WARNING Cancer and Reproductive Harm www.P65Warnings.ca.gov * RoHS Directive 2015/863, Mar 31, 2015 and Annex. ** Bourns considers a product to be “halogen free” if (a) the Bromine (Br) content is 900 ppm or less; (b) the Chlorine (Cl) content is 900 ppm or less; and (c) the total Bromine (Br) and Chlorine (Cl) content is 1500 ppm or less. Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Electrical Characteristics (continued) Model No. Characteristic Power Rating @ 70 °C CR1206A CR1210A CR2010A CR2512A 0.25 W 0.33 W 0.5 W 1W Operating Temp. Range -55 to +155 °C Derated to Zero Load at +155 °C Maximum Working Voltage 200 V Maximum Overload Voltage 400 V Resistance Tolerance ±1 %, ±5 % 1 Ω ~ 9.76 Ω ±400 ppm/°C Temperature Coefficient @ 1 % (E24 + E96) 10 Ω ≤ R ≤ 1M Ω ±100 ppm/°C 1M Ω < R ≤ 10M Ω ±200 ppm/°C Temperature Coefficient @ 5 % (E24) 1 Ω ~ 9.1 Ω 10M < R ≤ 20M Ω ±400 ppm/°C 10 Ω ≤ R ≤ 10M Ω ±200 ppm/°C Zero Ohm Jumper ≤ 0.05 Ω Rated / Max. Current 2A/5A Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Product Dimensions L W C D DIMENSIONS: MM (INCHES) T Model L W C D T CR0201A 0.60 ± 0.03 (.024 ± .001) 0.30 ± 0.03 (.012 ± .001) 0.10 ± 0.05 (.004 ± .002) 0.15 ± 0.05 (.006 ± .002) 0.23 ± 0.03 (.009 ± .001) CR0402A 1.00 ± 0.10 (.039 ± .004) 0.50 ± 0.05 (.020 ± .002) 0.20 ± 0.10 (.008 ± .004) 0.25 ± 0.10 (.010 ± .004) 0.32 ± 0.05 (.013 ± .002) CR0603A 1.60 ± 0.10 (.063 ± .004) 0.80 ± 0.10 (.031 ± .004) 0.30 ± 0.20 (.012 ± .008) 0.30 ± 0.20 (.012 ± .008) 0.45 ± 0.10 (.018 ± .004) CR0805A 2.00 ± 0.10 (.079 ± .004) 1.25 ± 0.10 (.049 ± .004) 0.40 ± 0.20 (.016 ± .008) 0.40 ± 0.20 (.016 ± .008) 0.50 ± 0.10 (.020 ± .004) CR1206A 3.10 ± 0.10 (.122 ± .004) 1.55 ± 0.10 (.061 ± .004) 0.50 ± 0.30 (.020 ± .012) 0.40 ± 0.20 (.016 ± .008) 0.55 ± 0.10 (.022 ± .004) CR1210A 3.10 ± 0.10 (.122 ± .004) 2.55 ± 0.10 (.100 ± .004) 0.50 ± 0.30 (.020 ± .012) 0.40 ± 0.20 (.016 ± .008) 0.60 ± 0.10 (.024 ± .004) CR2010A 5.00 ± 0.15 (.197 ± .006) 2.50 ± 0.15 (.098 ± .006) 0.60 ± 0.30 (.024 ± .012) 0.50 ± 0.25 (.020 ± .010) 0.60 ± 0.10 (.024 ± .004) CR2512A 6.30 ± 0.20 (.248 ± .008) 3.20 ± 0.20 (.126 ± .008) 0.60 ± 0.30 (.024 ± .012) 0.50 ± 0.25 (.020 ± .010) 0.60 ± 0.10 (.024 ± .004) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Recommended Pad Layout RESISTOR c a b DIMENSIONS: MM (INCHES) Model a b c CR0201A 0.25 ~ 0.30 (.010 ~ .012) 0.70 ~ 0.90 (.028 ~ .035) 0.30 ~ 0.40 (.012 ~ .016) CR0402A 0.50 ~ 0.60 (.020 ~ .024) 1.40 ~ 1.60 (.055 ~ .063) 0.40 ~ 0.60 (.012 ~ .024) CR0603A 0.70 ~ 0.90 (.028 ~ .035) 2.00 ~ 2.20 (.079 ~ .087) 0.80 ~ 1.00 (.031 ~ .039) CR0805A 1.00 ~ 1.40 (.039 ~ .055) 3.20 ~ 3.80 (.126 ~ .150) 0.90 ~ 1.40 (.035 ~ .055) CR1206A 2.00 ~ 2.40 (.079 ~ .094) 4.40 ~ 5.00 (.173 ~ .197) 1.20 ~ 1.80 (.047 ~ .071) CR1210A 2.00 ~ 2.40 (.079 ~ .094) 4.50 ~ 5.00 (.177 ~ .197) 2.30 ~ 3.50 (.091 ~ .138) CR2010A 3.30 ~ 3.70 (.130 ~ .146) 5.70 ~ 6.50 (.224 ± .256) 2.30 ~ 3.50 (.091 ~ .138) CR2512A 3.60 ~ 4.00 (.142 ~ .157) 7.60 ~ 8.60 (.299 ~ .339) 2.30 ~ 3.50 (.091 ~ .138) Soldering Profile 275 Maximum of 20 seconds between 260 °C peak +255 °C and +260 °C 255 °C Temperature (°C) 225 220 °C 190 °C 60 - 90 seconds 175 Ramp Down 6 °C/second 150 °C 125 60 - 120 seconds 10 seconds minimum 75 Ramp Up 3 °C/second maximum 25 0 50 100 150 200 250 300 Time (Seconds) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Performance Characteristics (AEC-Q200) Test Method Procedure Test Limits ∆R Short Time Overload IEC 60115-1 4.13 2.5 X rated voltage for 5 sec. ± (1 % + 0.05 Ω ) Remarks: 0201: ± (3 % + 0.1 Ω) 0402: ± (2 % + 0.1 Ω) 0 Ω : 50 mΩ or less High Temperature Exposure (Storage) AEC-Q200-REV D-Test 3 MIL-STD-202 Method 108 1000 hrs. @ T=125 °C. Unpowered. Measurement at 24 ±2 hours after test conclusion. 1 %: ± (1.0 % + 0.05 Ω) 5 %: ± (2.0 % + 0.1 Ω) 0201: ± (3 % + 0.1 Ω) 0 Ω: 50 mΩ or less Moisture Resistance AEC-Q200-REV D-Test 6 MIL-STD-202 Method 106 T=24 hours / Cycle,10 Cycles. Notes: Steps 7a & 7b not required. Unpowered. 1 %: ± (1.0 % + 0.05 Ω) 2 %, 5 %: ± (2.0 % + 0.1 Ω) 0201: ± (3 % + 0.1 Ω) 0 Ω: 50 mΩ or less Biased Humidity AEC-Q200-REV D-Test 7 MIL-STD-202 Method 103 1000 hours 85 °C / 85 % RH. Note: Specified conditions: 10 % of operating power (not exceeding max. working voltage). Measurement at 24 ±2 hours after test conclusion. ± (3 % + 0.1 Ω) 0201: ± (5 % + 0.1 Ω) 0 Ω: 100 mΩ or less Operational Life AEC-Q200-REV D-Test 8 MIL-STD-202 Method 108 1000 hours TA=70 °C at rated power. Measurement at 24 ±2 hours after test conclusion. 1 %: ± (1 % + 0.1 Ω) 5 %: ± (3 % + 0.1 Ω) 0201: ± (5 % + 0.1 Ω) 0 Ω: 100 mΩ or less AEC-Q200-REV D-Test 9 MIL-STD-883 Method 2009 AEC-Q200-REV D-Test 10 JESD22 Method JB-100 Electrical test not required. Inspect device construction, marking and workmanship. External Visual Physical Dimension Resistance to Solvents AEC-Q200-REV D-Test 12 MIL-STD-202 Method 215 Verify physical dimensions to the applicable device detail spec. Note: User(s) and Suppliers spec. Electrical test not required. a: Isopropyl Alcohol : Mineral Spirits = 1:3 b: Terpene Defluxer (Bioact EC-7R) c: Deionized water : Propylene Glycol Monomethyl Ether : monoethanolamine = 42:1:1 Marking and protective layer cannot be detached AEC-Q200-REV D-Test 13 MIL-STD-202 Method 213 AEC-Q200-REV D-Test 14 MIL-STD-202 Method 204 5 grams for 20 min., 12 cycles each of 3 orientations. Note: Test from 10-2000 Hz. Resistance to Soldering Heat AEC-Q200-REV D-Test 15 MIL-STD-202 Method 210 Condition B: Immerse the specimens in and eutectic solder at 260 ±5 ℃ for 10 ±1 S. Thermal Shock AEC-Q200-REV D-Test 16 MIL-STD-202 Method 107 -55 °C / +155 °C. Note: Number of cycles required: 300, Maximum transfer time: 20 seconds, Dwell time: 15 minutes. Air to Air. ESD AEC-Q200-REV D-Test 17 Verify the voltage setting at 500 V Solderability AEC-Q200-REV D-Test 18 J-STD-002 Method B, aging 4 hours at 155 °C dry heat Lead-free solder bath at 245 ±3 °C Dipping time: 3 ±0.5 seconds > 95 % area covered with tin Flammability AEC-Q200-REV D-Test 17 UL-94 V-0 or V-1 are acceptable. Electrical test not required. V-0 or V-1 Board Flex (Bending) AEC-Q200-REV D-Test 21 3 mm deflection (0201~1210) 2 mm deflection (2010~2512) 1 %: ± (0.5 % + 0.05 Ω) 5 %: ± (1 % + 0.1 Ω) 0201: ± (1 % + 0.1 Ω) 0 Ω: 50 mΩ or less Terminal Strength (SMD) IEC 60115-1 4.32 Force of 1.02 kg for 10±1 seconds. Remarks: 0402, 0.51 kg Remarks: 0201, N/A ± (0.5 % + 0.05 Ω) 0 Ω: 50 mΩ or less Mechanical Shock Vibration Wave Form: Tolerance for half sine shock pulse. Peak value is 100 grams. Normal duration (D) is 6 ms. ± (1 % + 0.1 Ω) 0 Ω: 50 mΩ or less ± (1 % + 0.1 Ω) 0 Ω: 50 mΩ or less 1 %: ± (0.5 % + 0.05 Ω) 5 %: ± (1 % + 0.1 Ω) 0201: ± (2 % + 0.1 Ω) 0 Ω: 50 mΩ or less ± (1 % + 0.1 Ω) 0201: ± (2 % + 0.1 Ω) 0 Ω: 50 mΩ or less ± (1 % + 0.1 Ω) 0201: ± (2 % + 0.1 Ω) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Derating Curve 100 Power Ratio (%) 80 60 70 40 CR0201A 20 125 0 -55 20 40 60 80 100 120 155 140 160 Ambient Temperature (°C) Packaging Dimensions (Conforms to EIA RS-481A) Model CR0201A CR0402A Tape Type Paper Tape (2 mm pitch) CR0603A CR0805A CR1206A Paper Tape (4 mm pitch) CR1210A CR2010A CR2512A Embossed Tape (4 mm pitch) A B 0.37 ± 0.05 (.010 ± .002) 0.67 ± 0.10 (.026 ± .004) 0.70 ± 0.05 (.028 ± .002) 1.20 ± 0.05 (.047 ± .002) 1.10 ± 0.10 (.043 ± .004) 1.90 ± 0.10 (.075 ± .004) 1.65 ± 0.15 (.065 ± .006) 2.40 ± 0.20 (.094 ± .008) 2.00 ± 0.15 (.079 ± .006) 3.60 ± 0.20 (.142 ± .008) 2.80 ± 0.20 (.110 ± .008) 3.60 ± 0.20 (.142 ± .008) 2.80 ± 0.20 (.110 ± .008) 5.30 ± 0.20 (.209 ± .008) 3.60 ± 0.20 (.142 ± .008) 6.90 ± 0.20 (.272 ± .008) W F E P1 2.00 ± 0.10 (.079 ± .004) 8.00 ± 0.20 (.315 ± .008) P2 T 2.00 ± 0.05 (.079 ± .002) 0.37 ± 0.10 (.015 ± .004) 2.00 ± 0.10 (.079 ± .004) 0.45 ± 0.10 (.018 ± .004) 0.64 ± 0.10 (.025 ± .004) 3.50 ± 0.05 (.138 ± .002) 1.75 ± 0.10 (.069 ± .004) 4.00 ± 0.10 (.157 ± .004) 4.00 ± 0.10 (.157 ± .004) 12.00 ± 0.20 (.472 ± .008) P0 2.00 ± 0.05 (.079 ± .002) 0.84 ± 0.10 (.033 ± .004) 0.84 ± 0.10 (.033 ± .004) 0.84 ± 0.10 (.033 ± .004) 0.85 ± 0.15 (.033 ± .006) 5.50 ± 0.05 (.217 ± .002) 0.85 ± 0.15 (.033 ± .006) DIMENSIONS: MM (INCHES) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Packaging Dimensions (Conforms to EIA RS-481A) PAPER TAPE (2 mm PITCH) BOTTOM TAPE 1.50 ± 0.10 DIA. (.059 ± .004) TOP TAPE E F W RESISTOR B PAPER TAPE T P1 A P2 P0 DIRECTION OF UNREELING PAPER TAPE (4 mm PITCH) BOTTOM TAPE 1.50 ± 0.10 DIA. (.059 ± .004) TOP TAPE E F W RESISTOR B PAPER TAPE T P1 A P2 P0 DIRECTION OF UNREELING EMBOSSED TAPE (4 mm PITCH) EMBOSSED TAPE 1.50 MIN. DIA. (.059) TOP TAPE 1.50 ± 0.10 DIA. (.059 ± .004) E F W RESISTOR B T A P1 P2 P0 DIRECTION OF UNREELING DIMENSIONS: MM (INCHES) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Packaging Dimensions (Conforms to EIA RS-481A) W C DIA. B DIA. T A DIA. Model Packaging Quantity A B C W T 178 ± 2.0 (7.008 ± .079) 60 ± 1.0 (2.362 ± .039) 13.0 ± 1.0 (.512 ± .039) 9.0 ± 1.0 (.354 ± .039) 11.5 ± 1.0 (.453 ± .039) 178 ± 2.0 (7.008 ± .079) 60 ± 0.5 (2.362 ± .020) 13.0 ± 0.5 (.512 ± .020) 13.0 ± 1.0 (.512 ± .039) 15.5 ± 1.0 (.610 ± .039) CR0201A 10K pcs/reel CR0402A CR0603A CR0805A 5K pcs/reel CR1206A CR1210A CR2010A 4K pcs/reel CR2512A DIMENSIONS: MM (INCHES) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors How to Order CR 0603 A F X - 1002 E LF Model (CR = Fixed Resistor) Size 0201 = 0201 size 0402 = 0402 size 0603 = 0603 size 0805 = 0805 size 1206 = 1206 size 1210 = 1210 size 2010 = 2010 size 2510 = 2510 size Feature A = AEC-Q200 Compliant Resistance Tolerance F = ±1 % J = ±5 % TCR (ppm/°C) – See Electrical Characteristics Chart X = ±100 W = ±200 Z = ±400 / = Used for zero Ω (jumper) and values from 1 Ω through 9.76 Ω. Resistance Value For 1 % Tolerance: 100 Ω ....... First three digits are significant, fourth digit represents number of zeros to follow (example: 8252 = 82.5K Ω). For 5 % Tolerance: 10 Ω.......... First two digits are significant, third digit represents number of zeros to follow (example: 474 = 470K Ω). Packaging G = Paper Tape (10,000 pcs.) on 7 ˝ Reel – CR0201A, CR0402A E = Paper Tape (5,000 pcs.) on 7 ˝ Reel – CR0603A, CR0805A, CR1206A, CR1210A E = Embossed Tape (4,000 pcs) on 7 ˝ Reel – CR2010A, CR2512A Termination LF = Tin-plated (RoHS Compliant) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. CRxxxxA - AEC-Q200 Compliant Chip Resistors Symbol for E96 Series Nominal Resistance Value Marking Explanation Symbol E96 Symbol E96 Symbol E96 Symbol E96 01 100 25 178 49 316 73 562 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 102 ±5 % (E24): CR0603A / CR0805A / CR1206A / CR1210A / CR2010A / CR2512A Resistance value is expressed by 3 digits. The first two digits represent the significant figures of nominal resistance value in Ω. And the third digit represents exponent for base of 10. EX: 102 = 10 x 102 = 1000 Ω = 1K Ω ±1 % (E96): CR0805A / CR1206A / CR1210A / CR2010A / CR2512A Resistance value is expressed by 3 digits. The first two digits represent the significant figures of nominal resistance value in Ω. And the third digit represents exponent for base of 10. EX: 102 = 10 x 102 = 1000 Ω = 1K Ω 01A ±1 % (E96): CR0603A When the marking space is too small in such small-sized resistors as CR0603A, the marking cannot be made by 4 digits and may be made by two digits combined with one English capital. EX: 01A = 100 x 100 = 100 Ω Symbol for Multipliers Symbol Multiplier A B 0 10 10 C 1 10 D 2 10 E 3 10 F 4 10 G 5 10 H 6 10 X 7 10 -1 Y 10 -2 Z 10-3 Asia-Pacific: Tel: +886-2 2562-4117 • Email: asiacus@bourns.com EMEA: Tel: +36 88 885 877 • Email: eurocus@bourns.com The Americas: Tel: +1-951 781-5500 • Email: americus@bourns.com www.bourns.com REV. 04/20 Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. Legal Disclaimer Notice This legal disclaimer applies to purchasers and users of Bourns® products manufactured by or on behalf of Bourns, Inc. and P[ZHɉSPH[LZJVSSLJ[P]LS`¸)V\YUZ¹ Unless otherwise expressly indicated in writing, Bourns® products and data sheets relating thereto are subject to change ^P[OV\[UV[PJL
CR0603AFX-1000ELF
物料型号:文档中列出了多种型号的芯片电阻,包括CR0201A、CR0402A、CR0603A、CR0805A、CR1206A、CR1210A、CR2010A和CR2512A。
器件简介:这些芯片电阻采用了厚膜技术,功率等级最高可达1瓦特(在70°C时),符合RoHS标准、无卤素,并符合AEC-Q200标准。
引脚分配:文档中没有提供具体的引脚分配信息,因为这些是无源元件,通常没有引脚。
参数特性:文档详细列出了不同型号的电阻的电气特性,包括功率等级、工作温度范围、最大工作电压、最大过载电压、电阻公差和温度系数等。
功能详解:文档中的功能详解部分主要描述了电阻的电气特性和环境特性,如湿度敏感度等级、ESD分类等。
应用信息:文档中提到了电阻的应用信息,包括推荐的焊盘布局、焊接温度曲线、AEC-Q200性能特性测试方法和限制等。
封装信息:文档提供了不同型号电阻的产品尺寸和推荐垫布局,以及符合EIA RS-481A标准的包装尺寸信息。
CR0603AFX-1000ELF 价格&库存
很抱歉,暂时无法提供与“CR0603AFX-1000ELF”相匹配的价格&库存,您可以联系我们找货
CR0603AFX-1000ELF
  • 1+0.885411+0.11509
  • 10+0.2730910+0.03550
  • 25+0.2048225+0.02663
  • 50+0.1657850+0.02155
  • 100+0.13495100+0.01754
  • 250+0.10587250+0.01376
  • 500+0.08893500+0.01156
  • 1000+0.075871000+0.00986
库存:37396
CR0603AFX-1000ELF
  • 5000+0.055105000+0.00717
  • 10000+0.0491310000+0.00639
  • 15000+0.0462215000+0.00601
  • 25000+0.0430825000+0.00560
  • 35000+0.0412835000+0.00537
  • 50000+0.0395850000+0.00515
库存:37396
