100-077
100-077
    POWTECH(华润矽威)
100-077 数据手册
Data Sheet JetStar Inkjet Artwork Film 4138090  4138107  1550279  You must use an inkjet printer that will print on clear transparent media. Both JetStar Standard and JetStar Premium can be used with standard inkjet printers using dye-based or pigment based inks. Both films will produce good quality artworks but for the ultimate quality choose the JetStar Premium with its superior coating over the more economical Standard variant. Results will vary based on printer used, type of ink, software and artwork quality. Generally, printers with higher resolution capability will yield better looking artworks. But remember, image quality depends the most on having quality artwork with adequate resolution and smooth line edges. As with any digital media, experimentation is necessary to determine the proper equipment settings to achieve desired results. 1. Prepare artwork for output. Remember, the quality of your digital artwork will determine the quality of your positive. Artwork should have smooth lines and edges and be of adequate resolution. A minimum of 600 dpi is recommended (1200 dpi is ideal for line art). To prevent ‘undercutting during UV exposure’ we recommend you mirror image (flip) your image in your application software. This will result in the ink being in contact with the resist when the printed image is turned the correct way round ready for exposure to UV 2. Load the film into the printer. Make sure the coated side of the film is the side you print on. To assist in determining the coated side it has a milky, matte appearance and a slightly wet finger-tip touched on the corner of the coating will result in the finger sticking to the film, more so with the Premium Film rather than the Standard. JETSTAR FILM A4 PACK OF 10  JETSTAR FILM A3 PACK OF 10  JETSTAR PREMIUM FILM A3 PACK OF 10  3. Check printer settings. Make sure printer is set for the highest resolution and print quality, with High Speed Setting OFF. Note that the higher the resolution, the slower the print. Next, set the Media Setting to Matte, Heavyweight Matte, Archival Matte or Inkjet Backlight Film. For Epson Ink Jet Printers, set the Brightness control slider to +25 and always print in Black Ink only or Greyscale. Options will vary based on printer and software available. Then, set ink deposit for optimum results. TIP: Experiment with the setting options available with your printer to determine the best set-up for your requirements. If positive seems light or lacks density, try increasing the print quality or amount of ink deposit. 4. Print. JetStar films dry almost instantaneously. With most inks, the positive will be dry and ready for use in less than 2 minutes. Drying times will vary based on printers, inks and conditions. Note: Always make sure positive is completely dry before using. Transfer or marring of image can occur if used before completely dry. Phone: 08701 200200 (8am - 8pm, Monday - Friday) (9am -12pm, Saturday) Web: www.farnell.co.uk email: sales@farnell.co.uk Fax: 08701 200 201 Address: Farnell, Canal Road, Leeds, LS12 2TU JetStar Premium (Farnell)(Data) Version 08/12
100-077 价格&库存
很抱歉,暂时无法提供与“100-077”相匹配的价格&库存,您可以联系我们找货
