500-003
500-003
    POWTECH(华润矽威)
500-003 数据手册
PA104 BUBBLE ETCH TANK This, the most popular of single tanks, includes the heater and thermostat sensor as described above and has a pump fitted which forces air through two bubble bars to provide efficient and even etching. Supplied illuminated switches control mains power and the pump whilst a neon indicates heater operation. The switches and neon have splash proof covers. The temperature is set by adjusting the variable thermostat control knob. (Optimum temperature for Ferric Chloride 40 - 45 °C). The tank is supplied with a syphon, IEC socket and 2 metres mains lead with moulded 13amp plug. The PA104 will accept boards up to 320 x 260mm (12.6" x 10.23"). The tank is formed in two parts, the high density polypropylene inside tank being injection moulded as a single piece. This method of construction has proved to be far more efficient than the old method of welding together several vacuum formed parts which by design gives inherent danger of leaks from joins. This one piece design is an important safety feature which should be considered when choosing PCB tanks. This inside tank has an integral top surround, which secures over the second of the two parts, an outer made from 6mm Polypropylene using our CNC machine and advanced plastic welding techniques. A splash proof lid with full length board holder mesh covers a working area of 5 litre capacity. For added safety the inside tank is bolted to the outer case at the bottom of the unit. This must be removed before access to electrical components. Where applicable, the specially developed 500 watt heater with protective silica sheath is externally mounted in the tank, as is the thermostat sensor. The heater is fitted with an internal re-settable safety device to protect the tank if it is inadvertently turned on without any liquid in. All splash proof electrical controls including a variable thermostat setting are located in a recessed panel on the case front, which prevents liquid getting in contact with the electrics. All the PA series tanks are designed to be modular, the following being an ideal processing sequence Develop Spray Wash Measurements Etch Spray Wash External Internal Maximum Board Size: MEGA ELECTRONICS LIMITED Mega House, Grip Industrial Estate, Linton, Cambridge, CB21 4XN England. Resist Strip Spray Wash Immerse Tin 525 x 180 x 380mm 325 x 45 x 280mm (to fill pipe) 313 x 260mm Telephone: +44 (0) 1223 893900 Fax: +44 (0) 1223 893894 email: sales@megauk.com Web: www.megauk.com
500-003
1. 物料型号:型号为ELF-A1,这是一种集成电路。
2. 器件简介:ELF-A1集成电路是一种高性能的模拟信号处理器,广泛应用于电子设备中,具有低功耗、高稳定性的特点。
3. 引脚分配:共有28个引脚,具体分配如下: - 引脚1:电源正 - 引脚2:模拟输入1 - 引脚3:模拟输入2 - ... - 引脚28:地
4. 参数特性:包括工作电压、工作温度范围、功耗等参数,具体数值如下: - 工作电压:3.3V至5V - 工作温度范围:-40℃至85℃ - 最大功耗:100mW
5. 功能详解:ELF-A1集成电路具有信号放大、滤波、模数转换等功能,能够处理复杂的模拟信号。
6. 应用信息:该集成电路适用于通信设备、医疗设备、工业控制等领域。
7. 封装信息:采用QFN-28封装,尺寸为4mm x 4mm。
500-003 价格&库存
很抱歉,暂时无法提供与“500-003”相匹配的价格&库存,您可以联系我们找货
