3204996
3204996
    POWTECH(华润矽威)
    MEGA - 3204996 - PCB Developer, 1.5 Relative Density, 90°C Boiling Point, Bottle, 1L
3204996 数据手册
Farnell 3204996 = 12-15500 Microtrak PCB Chemicals A range of PCB processing chemistry specifically for MICROTRAK Pre-coated PCB laminates. Microtrak CPD5 Developer High-resolution, positive-working developing solution suitable for use in a tank or processing tray. CPD5 is less aggressive than some other developers which contain Sodium Hydroxide and allows much greater control over the development process. It is also less affected by exposure to air and so has a much longer shelf life. The solution is supplied in concentrate form and is mixed 4 parts water to 1 part developer. It should be used at room temperature (18-24°C). Available in 1 litre (makes 5 litres), 5 litre (makes 25 litres) pack sizes. Only for use with Microtrak. Order Code Description 12-15500 Microtrak CPD5 developer 1 ltr conc makes 5 ltr 12-15501 Microtrak CPD5 developer 5 ltr conc makes 25 ltr 1+ Qty:
3204996 价格&库存
很抱歉,暂时无法提供与“3204996”相匹配的价格&库存,您可以联系我们找货
