103GM-1-A-5/2D
103GM-1-A-5/2D
    PICKERING
    PICKERING - 103GM-1-A-5/2D - Reed Relay, SPST-NO, 5 V, 103 Series, Through Hole, 500 ohm, 500 mA
103GM-1-A-5/2D 数据手册
Series 103 Low Capacitance SIL/SIP Reed Relays — Up to 20 W switching — Stacking on 0.2 Inches pitch — Highest quality instrumentation grade switches — Inter-terminal capacitances are a fraction of that for standard SIL relays — 1 Form A or 1 Form A (Coaxial) configurations — Pin compatible with standard 0.2 Inch SIL relays — Optional internal mu-metal magnetic screen — Optional internal coaxial electrostatic screen — Insulation resistance >1012 Ω Package Type 1 2 — Suitable for wide bandwidth A.T.E. switching matrices and attenuator switching —  Additional build options are available — Many benefits compared to industry standard relays (see last page) The Pickering Series 103 is a range of Single-in-Line reed relays intended for such applications as wide bandwidth A.T.E. switching matrices, attenuator switching or any other applications where exceptionally low levels of inter-terminal capacitances are required, for example, when carrying fast rise time pulses. A version with an internal co-axial electrostatic screen is available which is ideal for applications where capacitively coupled noise from switch to coil connections is undesirable. The co-axial device has a characteristic impedance of 50 ohms and is also suitable for RF applications, HF performance is similar to the Series 102M. The range consists of two basic types, the first achieves ultra low capacitance levels of typically 0.1pf from each switch connection to the coil and typically 0.08pf across the open switch contacts, by virtue of an internal coaxial electrostatic screen or guard connection. Where it is not possible to drive a guard, the second type has inherently low capacitance figures of typically 0.4pf from each switch connection to the coil and typically 0.1pf across the open switch contacts. These figures for the unguarded version are around one quarter of those for standard SIL devices. Two types of Form A (energize to make) switches are available, a general purpose switch (switch no.1) and a vacuum sputtered ruthenium switch (switch no.2) which is ideal for very low level or “cold” switching applications. Switch Ratings 1 Form A co-axial (energize to make) Up to 20 W at 1 A Up to 20 W at 1 A (50 Ω) ISSUE 1.2 JAN 2022 1 Form A (energize to make) 1 pickeringrelay.com Specification Low Capacitance SIL/SIP Reed Relays – Series 103 Series 103 switch ratings - contact ratings for each switch type Switch No Switch Power rating form Max. switch current Max. carry current Max. switching volts Life expectancy ops typical (see Note1) Operate time inc bounce (max) Release time Special features 1 A 20 W (*15 W) 1.0 A 1.2 A 200 109 0.5 ms 0.2 ms General purpose 2 A 10 W 0.5 A 1.2 A 200 108 0.5 ms 0.2 ms Low level Switch no.2 is particularly good for switching low currents and/or voltages. It is the ideal switch for A.T.E. systems where cold switching techniques are often used. Where higher power levels are involved, switch no.1 is more suitable. Note1: Life Expectancy The life of a reed relay depends upon the switch load and end of life criteria. For example, for an ‘end of life’ contact resistance specification of 1 Ω, switching low loads (10 V at 10 mA resistive) or when ‘cold’ switching, typical life is approx 10 x 109 ops. At the maximum load (resistive), typical life is 1 x 107 ops. In the event of abusive conditions, e.g. high currents due to capacitive inrushes, this figure reduces considerably. Pickering will be pleased to perform life testing with any particular load condition. Operating Voltages Coil voltage - nominal Must operate voltage - maximum at 25°C Must release voltage - minimum at 25°C 3V 2.25 V 0.3 V 5V 3.75 V 0.5 V 12 V 9V 1.2 V Environmental Specification/Mechanical Characteristics In the table below, the upper temperature limit can be extended to +125 °C if the coil drive voltage is increased to accommodate the resistance/temperature coefficient of the copper coil winding. This is approximately 0.4% per °C. This means that at 125 °C the coil drive voltage will need to be increased by approximately 40 x 0.4 =16% to maintain the required magnetic drive level. Please contact sales@pickeringrelay.com for assistance. Operating Temperature Range -20 ºC to +85 ºC Storage Temperature Range -35 ºC to +100 ºC Shock Resistance 50 g Vibration Resistance (10 - 2000 Hz) 20 g Soldering Temperature (max) (10 s max) 270 ºC Washability (Proper drying process is recommended) Fully Sealed 2 pickeringrelay.com Specification Low Capacitance SIL/SIP Reed Relays – Series 103 Coil data and type numbers Device Type Switch Type Number Form Type No magnetic screen or guard screen (*Note 15 W for 5 V coil) Package Type 1 Magnetic screen only (*Note 15 W for 5 V coil) Package Type 1 Guard screen only (*Note 15 W for 5 V coil) Package Type 2 Guard screen and magnetic screen Package Type 2 Max. Coil Coil contact (V) resistance resistance (initial) Insulation resistance (minimum at 25 °C) (see Note4) Switch Across to coil switch Capacitance (typical) (see Note2) Closed switch to coil (C1 & C2) Across open switch (C3) 0.13 pF A 1 103-1-A-5/1D * 5 150 Ω 0.15 Ω A 2 103-1-A-5/2D 5 150 Ω 0.12 Ω A 1 103M-1-A-5/1D * 5 150 Ω 0.15 Ω A 2 103M-1-A-5/2D 5 150 Ω 0.12 Ω A 2 103G-1-A-3/2D 3 300 Ω 0.12 Ω A 1 103G-1-A-5/1D * 5 500 Ω 0.15 Ω A 2 103G-1-A-5/2D 5 500 Ω 0.12 Ω A 1 103G-1-A-12/1D 12 1000 Ω 0.15 Ω 0.10 pF A 2 103G-1-A-12/2D 12 1000 Ω 0.12 Ω 0.08 pF A 2 103GM-1-A-3/2D 3 300 Ω 0.12 Ω 0.08 pF A 1 103GM-1-A-5/1D 5 500 Ω 0.15 Ω A 2 103GM-1-A-5/2D 5 500 Ω 0.12 Ω A 1 103GM-1-A-12/1D 12 1000 Ω 0.15 Ω 0.10 pF A 2 103GM-1-A-12/2D 12 1000 Ω 0.12 Ω 0.08 pF 1012 Ω 1012 Ω 0.4 pF 1012 Ω 1012 Ω 0.45 pF 0.10 pF 0.13 pF 0.10 pF 0.08 pF 0.10 pF 10 Ω 12 10 Ω 12 0.1 pF 0.08 pF 0.10 pF 10 Ω 12 10 Ω 12 0.2 pF 0.08 pF When an internal diode is required, the suffix D is added to the part number as shown in the table. Note2: Capacitance across open switch The capacitance across the open switch was measured with other connections guarded. Note3: Capacitance values The value will depend upon on the mode of connection/guarding of unused terminals. Please contact technical sales for details. Note4: Insulation resistance Insulation resistance will reduce at higher temperatures. For more information on temperature effects click here, or contact Pickering for more in depth guidance. The technical information shown in this data sheet could contain inaccuracies or typographical errors. This information may be periodically changed or updated and these changes will be included in future versions of this data sheet. For different values, latest specifications and product details, please contact your local Pickering sales office. For FREE evaluation samples go to: pickeringrelay.com/samples 3 pickeringrelay.com Specification Low Capacitance SIL/SIP Reed Relays – Series 103 Pin Configuration, Weights and Dimensional Data (dimensions in inches, millimeters in brackets) Package Type 1 0.19 (4.8) 0.75 (19.1) 103-1-A Weight: Typical 0.92 g 103M-1-A Weight: Typical 1.14 g 0.32 (8.1) 0.125 (3.2) 1 Form A Pin 1 0.2 (5.1) Package Type 2 0.2 (5.1) 0.02 (0.5) 0.2 (5.1) + 1 0.01 (0.25) 3 5 3 5 7 0.19 (4.8) 0.75 (19.1) 103G-1-A Weight: Typical 1.11 g 103GM-1-A Weight: Typical 1.28 g 0.32 (8.1) 0.125 (3.2) 1 Form A Coaxial 0.02 (0.5) Pin 1 0.1 (2.54) 0.1 0.1 0.2 (2.54) (5.1) (2.54) 0.1 (2.54) 0.01 (0.25) + 1 2 6 7 Important: Where the optional internal diode is fitted or for all Form B types, the correct coil polarity must be observed, as shown by the + symbol on the schematics. Simplified Equivalent Circuits It is convenient to consider the internal capacitances as a delta network as in the circuit diagram alongside. C1 is the capacitance between one end of the switch and the coil, C2 is the capacitance between the other end of the switch and the coil. These two figures will be approximately equal. C3 is the capacitance across the open switch. When measuring the values of any one of these capacitances, it is necessary to “guard” the unused relay connections to avoid the parallel effects of the other capacitances, connection details when performing these measurements on a capacitance bridge are shown below. Relays with an internal electrostatic screen have the screen terminals guarded in all cases. Measurement of C1- switch to coil Measurement of C2- switch to coil Measurement of C3 - open switch Bridge Guard Terminal Bridge Measuring Terminals Bridge Guard Terminal Bridge Measuring Terminals Bridge Guard Terminal 4 Bridge Measuring Terminals pickeringrelay.com Specification Low Capacitance SIL/SIP Reed Relays – Series 103 Similar Relays Comparison If the Series 103GM is unsuitable for your application, Pickering also manufactures three other reed relay types with similar characteristics, but in different package sizes. Series Name 111RF-1-A 109RF50-1-A 109RF75-1-A 102M-1-A 102M-1-B 103GM-1-A Physical Outline Depth 3.7 (0.145) 3.7 (0.145) 4.8 (0.19) 4.8 (0.19) 4.8 (0.19) 10.0 (0.39) 15.1 (0.595) 19.1 (0.75) 19.1 (0.75) 19.1 (0.75) 6.6 (0.26) 6.6 (0.26) 7.6 (0.3) 10.2 (0.4) 8.1 (0.32) Package Volume (mm3) 245 369 697 936 743 Typical Weights (g) 0.56 0.88 0.87 1.43 2.19 1.28 Contact Configuration 1-A (SPST) 1-A (SPST) 1-A (SPST) 1-A (SPST) 1-B (SPNC) 1-A (SPST) Reed Switch Type Dry Dry Dry Dry Dry Dry Dry Dry Stand-off Voltage (V) - - - - - - - - - - - Switching Voltage (V) 170 200 200 200 200 200 200 200 200 200 200 Switching Current (A) 0.5 1.0 0.5 1.0 0.5 0.5 1 0.5 1 1 0.5 Carry Current (A) 0.5 1.2 1.2 1.2 1.2 1.2 1.2 1.2 1.2 1.2 1.2 Switch Power (W) 10 15/20 10 15/20 10 10 20 10 20 20 10 Width Height mm (inches) 2 Reed Relay Selection Tool Because Pickering offer the largest range of high-quality reed relays, sometimes it can be difficult to find the right reed relay you require. That is why we created the Reed Relay Selector, this tool will help you narrow down our offering to get you the correct reed relay for your application. To try the tool today go to: pickeringrelay.com/reed-relay-selector-tool 5 pickeringrelay.com Ordering Information Low Capacitance SIL/SIP Reed Relays – Series 103 Standard Build Options The Series 103 Reed Relays are available with a number of standard build options to tailor them to your specific application. These options are detailed in the table below. If you decide to go ahead and specify one, or more, of these options you will be allocated a unique part number suffix. Mechanical Build Options Electrical Build Options Special pin configurations or pin lengths Different coil resistance Special print with customer’s own part number or logo Very low capacitance Custom packaging possibility Operate or de-operate time Pulse capability Enhanced specifications Non-standard coil voltages and resistance figures Special Life testing under customer’s specific load conditions Specific environmental requirements Controlled thermal EMF possibility Customization If your specific requirements are not met by standard relay, or any of the standard build options, please speak to us to discuss producing a customized reed relay to service your specific application: pickeringrelay.com/contact 3D Models Interactive 3D models of the complete range of Pickering relay products in STEP, IGS and SLDPRT formats can be downloaded from the website: pickeringrelay.com/3d-models Part Number Description: 103 G M -  1 - A - 5 / 2 D - xxx Series Guard (omit if not required) Mag. screen (omit if not required) Number of reeds Switch form Coil voltage Switch number (see table on pages 2) Diode if fitted (omit if not required) Unique suffix (if standard build option selected) Help If you need any technical advice or other help, please do not hesitate to contact our Technical Sales Department. We will always be pleased to discuss Pickering relays with you. email: techsales@pickeringrelay.com Contact Us 6 o n g v it e y y L o n g v it e L UK Headquarters - email: sales@pickeringrelay.com | Tel. +44 1255 428141 USA - email: ussales@pickeringrelay.com | Tel. +1 781 897 1710 Germany - email: desales@pickeringtest.com | Tel. +49 89 125 953 160 Product France - email: frsales@pickeringtest.com | Tel. +33 9 72 58 77 00 25+Years 100% Tested Longevity Nordic - email: ndsales@pickeringtest.com | Tel. +46 340 69 06 69 Czech Republic: czsales@pickeringtest.com | Tel. +420 558-987-613 China - email: chinasales@pickeringtest.com | Tel. +86 4008 799 765 For a full list of agents, distributors and representatives visit: pickeringrelay.com/agents pickeringrelay.com Low Capacitance SIL/SIP Reed Relays – Series 103 10 Key Benefits of Pickering Reed Relays Pickering Reed Relays Typical Industry Reed Relays Instrumentation Grade Reed Switches with vacuum sputtered Ruthenium plating to ensure stable, long life up to 5x10E9 operations. Often low grade Reed Switches with electroplated Rhodium plating resulting in higher, less stable contact resistance. 22 Formerless Coil Construction Formerless coil construction increases the coil winding volume, maximizing magnetic efficiency, allowing the use of less sensitive reed switches resulting in optimal switching action and extended lifetime at operational extremes. Use of bobbins decreases the coil winding volume, resulting in having less magnetic drive and a need to use more sensitive reed switches which are inherently less stable with greatly reduced restoring forces. 3 Magnetic Screening Mu-metal magnetic screening (either external or internal), enables ultra-high PCB side-by-side packing densities with minimal magnetic interaction, saving significant cost and space. Pickering Mu-Metal magnetic screen - interaction approx. 5% Lower cost reed relays have minimal or no magnetic screening, resulting in magnetic interaction issues causing changes in operating and release voltages, timing and contact resistance, causing switches to not operate at their nominal voltages. Typical industry screen - interaction approx. 30% 4 SoftCenter™ technology, provides maximum cushioned protection of the reed switch, minimising internal lifetime stresses and extending the working life and contact stability. Transfer moulded reed relays (produced using high temperature/pressure), result in significant stresses to the glass reed switch which can cause the switch blades to deflect or misalign leading to changes in the operating characteristics, contact resistance stability and operating lifetime. 100% testing for all operating parameters including dynamic contact wave-shape analysis with full data scrutiny to maintain consistency. Simple dc testing or just batch testing which may result in non-operational devices being supplied. 1 Instrumentation Grade Reed Switches SoftCenter™ Technology 5 100% Dynamic Testing X-Ray of Pickering mu-metal magnetic screen X-Ray of typical industry magnetic screen Dynamic Contact Resistance Test Operate Contact Resistance Key Benefit Release 6 100% Inspection at Every Stage of Manufacturing 7 Inspection at every stage of manufacturing maintaining high levels of quality. Often limited batch inspection. Stress testing of the manufacturing processes, from -20°C to +85°C to -20°C, repeated 3 times. Rarely included resulting in field failures. +85°C 100% Thermal Cycling -20°C Product Longevity Limited ability to customize. Pickering are committed to product longevity; our reed relays are manufactured and supported for more than 25 years from introduction, typically much longer. Most other manufacturers discontinue parts when they reach a low sales threshold; costing purchasing and R&D a great deal of unnecessary time and money to redesign and maintain supply. o n g v it e o n g v it e y Our reed relays can be customized easily, e.g. special pin configurations, enhanced specifications, non-standard coil or resistance figures, special life testing, low capacitance, and more. L 10 Mass production: Usually large batch sizes and with no quick-turn manufacturing. L 9 Custom Reed Relays Flexible manufacturing processes allow quick-turn manufacturing of small batches. y 8 Flexible Manufacturing Process Product 25+Years Longevity For more information go to: pickeringrelay.com/10-key-benefits 7 pickeringrelay.com © Copyright (2022) Pickering Electronics. All Rights Reserved Pickering Electronics maintains a commitment to continuous product development, consequently we reserve the right to vary from the description given in this data sheet. Coil Voltage
103GM-1-A-5/2D 价格&库存
很抱歉,暂时无法提供与“103GM-1-A-5/2D”相匹配的价格&库存,您可以联系我们找货
