200-1-C-5/3D
200-1-C-5/3D
    PICKERING
    PICKERING - 200-1-C-5/3D - Reed Relay, SPDT, 5 V, 200 Series, Surface Mount, 500 ohm, 250 mA
200-1-C-5/3D 数据手册
Series 200 Surface Mount Reed Relays — Including coaxial types for up to 5 GHz — Highest quality instrumentation grade switches — Encapsulated in plastic package with internal Package Type mu-metal magnetic screen for side-by-side 4 mounting without magnetic interaction 5 6 — Insulation >1012 Ω for dry Form A devices — Dry and mercury wetted reed switches available — Wide range of switch configurations - 1 Form A, 2 Form A, 1 Form B and 1 Form C — For R.F. or high speed digital applications, 50 or 75 Ω coaxial devices are available in the same small package — 3, 5 or 12 V coils are standard, with optional internal diode —  Additional build options are available — Many benefits compared to industry standard relays (see last page) 3 2 1 Please contact our technical department for supplementary RF data. The special high temperature plastic package will withstand the temperatures associated with Infra-red or vapor phase reflow soldering processes. A flexible inner encapsulant protects the sensitive glass/metal reed switch seals - this is a very big advantage over the more usual hard moulded package. Series 200 User Guide The Guide gives information on PCB Footprints, Handling Procedures, Packing Options, Soldering, Disposal & Standards. Title Surface Mount Reed Relays Series 200 User Guide Download your copy from pickeringrelay.com/pdfs/series-200-smt-user-guide.pdf Introduction Pickering Series 200 Surface Mount Reed Relays have recommended PCB footprints, a moisture sensitivity level, peak reflow classification, recommended handling procedures and packing options as outlined in this document. Contents 1. PCB Footprints 2. Handling Procedures and Packing Options 3. Soldering 4. Disposal 5. Standards pickeringrelay.com Switch Ratings - Dry Switches 1 Form A Coaxial 50 Ω (energize to make) 1 Form A Coaxial 75 Ω (energize to make) 1 Form B (energize to break) 1 Form C (change-over) 2 Form A (energize to make) 10 W at 200 V 15 W at 200 V 20 W at 200 V 10 W at 500 V 10 W at 200 V 10 W at 200 V 10 W at 200 V 3 W at 200 V 10 W at 200 V ISSUE 1.2 JAN 2022 1 Form A (energize to make) Switch Ratings - Mercury Wetted Switches 1 Form A (energize to make) 1 Form A (position insensitive) 50 W at 500 V 50 W at 500 V 1 pickeringrelay.com Specification Surface Mount Reed Relays – Series 200 Dry Reed: Series 200 switch ratings - contact ratings for each switch type Life Max. expectancy switching ops typical volts (see Note1) Operate time inc bounce (max) Release time Special features 109 0.5 ms 0.2 ms General purpose 200 10 1.2 A 200 1.2 A 500 Switch No Switch form Power rating Max. switch current Max. carry current 1 A 20 W (*15 W) 1.0 A 1.2 A 200 2 A or B 10 W 0.5 A 1.2 A 3 C 3W 0.25 A 4 A 10 W 0.5 A 0.5 ms 0.2 ms Low level 7 10 1.0 ms 0.5 ms Change over 10 8 0.5 ms 0.2 ms High voltage 9 Note1: Life Expectancy The life of a reed relay depends upon the switch load and end of life criteria. For example, for an ‘end of life’ contact resistance specification of 1 Ω, switching low loads (10 V at 10 mA resistive) or when ‘cold’ switching, typical life is approx 1 x 109 ops. At the maximum load (resistive), typical life is 1 x 107 ops. In the event of abusive conditions, e.g. high currents due to capacitive inrushes, this figure reduces considerably. Pickering will be pleased to perform life testing with any particular load condition. Operating Voltages Coil voltage - nominal Must operate voltage - maximum at 25°C Must release voltage - minimum at 25°C 3V 2.25 V 0.3 V 5V 3.75 V 0.5 V 12 V 9V 1.2 V Environmental Specification/Mechanical Characteristics In the table below, the upper temperature limit can be extended to +125 °C if the coil drive voltage is increased to accommodate the resistance/temperature coefficient of the copper coil winding. This is approximately 0.4% per °C. This means that at 125 °C the coil drive voltage will need to be increased by approximately 40 x 0.4 =16% to maintain the required magnetic drive level. Please contact sales@pickeringrelay.com for assistance. Operating Temperature Range -20 ºC to +85 ºC Storage Temperature Range -35 ºC to +100 ºC Shock Resistance 50 g Vibration Resistance (10 - 2000 Hz) 20 g Soldering Temperature (max) (10 s max) 270 ºC Washability (Proper drying process is recommended) Fully Sealed 2 pickeringrelay.com Specification Surface Mount Reed Relays – Series 200 Dry Relay: Series 200 Coil data and type numbers Device Type 1 Form A, Switch No. 1 (*Note 15 W for 5 V coil) Package Type 1 Type Number Coil (V) Max. Coil contact resistance resistance (initial) Capacitance (typical) (see Note2) Insulation resistance (minimum at 25 °C) (see Note4) Switch to coil Across switch Closed switch to coil Across open switch 0.15 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 0.12 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 200-1-A-5/1D * 5 500 Ω 200-1-A-12/1D 12 1000 Ω 200-1-A-3/2D 3 250 Ω 200-1-A-5/2D 5 500 Ω 200-1-A-12/2D 12 1000 Ω 1 Form A, Switch No. 2 (50 Ω Coaxial) Package Type 2 200RF50-1-A-5/2D 5 250 Ω 0.12 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 1 Form A, Switch No. 2 (75 Ω Coaxial) Package Type 2 200RF75-1-A-5/2D 5 250 Ω 0.12 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 200-1-A-5/4D 5 500 Ω 200-1-A-12/4D 12 1000 Ω 0.15 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 200-1-B-5/2D 5 750 Ω 200-1-B-12/2D 12 1000 Ω 0.12 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 200-1-C-5/3D 5 500 Ω 200-1-C-12/3D 12 1000 Ω 0.20 Ω 1012 Ω 1011 Ω See Note3 See Note3 0.12 Ω 1012 Ω 1012 Ω See Note3 See Note3 1 Form A Switch No. 2 Package Type 1 1 Form A, HV Switch No. 4 Package Type 5 1 Form B, Switch No. 2 Package Type 4 1 Form C Switch No. 3 Package Type 6 2 Form A, Switch No. 2 Package Type 3 200-2-A-5/2D 5 400 Ω 200-2-A-12/2D 12 1000 Ω When an internal diode is required, the suffix D is added to the part number as shown in the table. Note2: Capacitance across open switch This is measured with all other component leads connected to the guard terminal of the measuring bridge. Note3: Capacitance values The value will depend upon on the mode of connection/guarding of unused terminals. Please contact technical sales for details. Note4: Insulation resistance Insulation resistance will reduce at higher temperatures. For more information on temperature effects click here, or contact Pickering for more in depth guidance. 3 pickeringrelay.com Specification Surface Mount Reed Relays – Series 200 Mercury Reed Relays With the exception of the position insensitive type, mercury relays should be mounted vertically with pin 1 uppermost. UP Mercury Reed: Series 200 switch ratings - contact ratings for each switch type Switch No Switch form Power rating Max. switch current Max. carry current Max. switching volts Life expectancy ops typical (see Note1) Operate time inc bounce (max) Release time Special features 6 A 50 W 2A 3A 500 108 2.0 ms 1.25 ms Standard mercury 8 A 50 W 2A 3A 500 10 2.0 ms 1.25 ms Position insensitive 8 Note1: Life Expectancy The life of a reed relay depends upon the switch load and end of life criteria. For example, for an ‘end of life’ contact resistance specification of 1 Ω, switching low loads (10 V at 10 mA resistive) or when ‘cold’ switching, typical life is approx 1 x 109 ops. At the maximum load (resistive), typical life is 1 x 107 ops. In the event of abusive conditions, e.g. high currents due to capacitive inrushes, this figure reduces considerably. Pickering will be pleased to perform life testing with any particular load condition. Mercury Relay: Series 200 Coil data and type numbers Device Type Type Number 1 Form A Switch No. 6 Package Type 5 1 Form A, Switch No. 8 (Position insensitive) Package Type 5 Coil (V) Max. Coil contact resistance resistance (initial) 200-1-A-5/6D 5 140 Ω 200-1-A-12/6D 12 500 Ω 200-1-A-5/8D 5 140 Ω 200-1-A-12/8D 12 500 Ω Capacitance (typical) (see Note2) Insulation resistance (minimum at 25 °C) (see Note3) Switch to coil Across switch Closed switch to coil Across open switch 0.075 Ω 1012 Ω 1010 Ω 4 pF 0.1 pF 0.100 Ω 1012 Ω 1010 Ω 4 pF 0.1 pF When an internal diode is required, the suffix D is added to the part number as shown in the table. Note2: Capacitance across open switch This is measured with all other component leads connected to the guard terminal of the measuring bridge. Note3: Insulation resistance Insulation resistance will reduce at higher temperatures. For more information on temperature effects click here, or contact Pickering for more in depth guidance. The technical information shown in this data sheet could contain inaccuracies or typographical errors. This information may be periodically changed or updated and these changes will be included in future versions of this data sheet. For different values, latest specifications and product details, please contact your local Pickering sales office. For FREE evaluation samples go to: pickeringrelay.com/samples 4 pickeringrelay.com Specification Surface Mount Reed Relays – Series 200 Pin Configuration, Weights and Dimensional Data (dimensions in inches, millimeters in brackets) PackageType Type Package Weight: Weight:Typical Typical0.75 0.75g g 0.04 (1.0) 0.6 (15.25) 11 0.08 (2.0) Pin 1 PICKERING 200-1-A-5/1D Spot indicates Pin 1 0.6 (15.25) Weight: Weight:Typical Typical0.74 0.74g g 0.04 (1.0) Pitch PICKERING 200RF-1-A-5/2D Pin 1 Schematic shown from top of relay 0.6 (15.25) 0.08 (2.0) Pitch 0.04 (1.0) PICKERING 200-2-A-5/2D 0.23 (5.85) 6mm Max 0.02 (0.5) Spot indicates Pin 1 Pin 1 Schematic shown from top of relay 0.04 (1.0) 0.01 (0.25) 0.6 (15.25) 44 0.04 (1.0) 0.02 (0.5) PICKERING 200-1-B-5/2D 0.16 (4.0) + 2 Form A 0.04 (1.0) 0.27 (6.8 Max) Weight: Weight:Typical Typical1.10 1.10g g Pin 1 0.04 (1.0) 33 + 1 Form A Coaxial 0.04 (1.0) Pin 1 Package PackageType Type 0.154 (3.90) 4mm Max 0.016 (0.4) Spot indicates Pin 1 0.01 (0.25) Weight: Weight:Typical Typical1.13 1.13g g Schematic shown from top of relay 0.04 (1.0) 0.27 (6.8 Max) Package PackageType Type Pin 1 0.04 (1.0) 0.01 (0.25) 22 + 1 Form A 0.04 (1.0) 0.27 (6.8 Max) Package PackageType Type 0.154 (3.90) 4mm Max 0.02 (0.5) Pin 1 0.23 (5.85) 6mm Max + 1 Form B Spot indicates Pin 1 Pin 1 0.04 (1.0) 0.27 (6.8 Max) Schematic shown from top of relay 0.04 (1.0) 0.01 (0.25) 0.79 (20.0) Important: When an optional internal diode is fitted the orientation0.04 spot end of the relay forms the positive connection. 5 Weight: Typical 1.81 g (1.0) PICKERING 0.16 (4.0) UP Package Type Pin 1 200-1-A-5/6D Spot indicates Pin 1 0.04 (1.0) + Pin 1 Schematic shown from top of relay 0.04 (1.0) 0.01 (0.25) 6 0.23 (5.85) 6mm Max 1 Form A 0.35 (9.0 Max) Package Type 0.02 (0.5) 0.79 (20.0) 5 0.04 (1.0) pickeringrelay.com Pin 1 Specification 0.79 (20.0) 0.04 (1.0) PICKERING 0.02 (0.5) UP 0.16 (4.0) Pin 1 200-1-A-5/6D 0.23 (5.85) 6mm Max 66 0.08 (2.0) Pitch Pin 1 + 1 Form A Pin 1 0.04 (1.0) Schematic shown from top of relay 0.04 (1.0) 0.01 (0.25) Weight: Weight:Typical Typical1.89 1.89g g Schematic shown from top of relay Spot indicates Pin 1 0.35 (9.0 Max) Package PackageType Type Surface Mount Reed Relays – Series 200 0.04 (1.0) 55 Weight:Typical Typical1.81 1.81g g Weight: Pin 1 0.04 (1.0) 0.27 (6.8 Max) 0.01 (0.25) PackageType Type Package + 1 Form B Spot indicates Pin 1 0.79 (20.0) 0.04 (1.0) PICKERING 200-1-C-5/3D 0.02 (0.5) Spot indicates Pin 1 0.23 (5.85) 6mm Max + 1 Form C Pin 1 0.35 (9.0 Max) 0.01 (0.25) 0.04 (1.0) Schematic shown from top of relay 0.04 (1.0) Important: When an optional internal diode is fitted the orientation spot end of the relay forms the positive connection. Similar Relays Comparison The Series 200 is unique in the Pickering range of reed relays. Pickering do not manufacture another series of surface mount relays. Reed Relay Selection Tool Because Pickering offer the largest range of high-quality reed relays, sometimes it can be difficult to find the right reed relay you require. That is why we created the Reed Relay Selector, this tool will help you narrow down our offering to get you the correct reed relay for your application. To try the tool today go to: pickeringrelay.com/reed-relay-selector-tool 6 pickeringrelay.com Ordering Information Surface Mount Reed Relays – Series 200 Standard Build Options The Series 200 Reed Relays are available with a number of standard build options to tailor them to your specific application. These options are detailed in the table below. If you decide to go ahead and specify one, or more, of these options you will be allocated a unique part number suffix. Mechanical Build Options Electrical Build Options Special pin configurations or pin lengths Different coil resistance Special print with customer’s own part number or logo Operate or de-operate time Pulse capability Enhanced specifications Non-standard coil voltages and resistance figures Special Life testing under customer’s specific load conditions Specific environmental requirements Controlled thermal EMF possibility Customization If your specific requirements are not met by standard relay, or any of the standard build options, please speak to us to discuss producing a customized reed relay to service your specific application: pickeringrelay.com/contact 3D Models Interactive 3D models of the complete range of Pickering relay products in STEP, IGS and SLDPRT formats can be downloaded from the website: pickeringrelay.com/3d-models Part Number Description:  200 - 1 - A - 5 / 2 D - xxx Series Number of reeds Switch form Coil voltage Switch number (see tables on pages 2 & 4) Diode if fitted (omit if not required) Unique suffix (if standard build option selected) Help If you need any technical advice or other help, please do not hesitate to contact our Technical Sales Department. We will always be pleased to discuss Pickering relays with you. email: techsales@pickeringrelay.com Contact Us 7 o n g v it e y y L o n g v it e L UK Headquarters - email: sales@pickeringrelay.com | Tel. +44 1255 428141 USA - email: ussales@pickeringrelay.com | Tel. +1 781 897 1710 Germany - email: desales@pickeringtest.com | Tel. +49 89 125 953 160 Product France - email: frsales@pickeringtest.com | Tel. +33 9 72 58 77 00 25+Years 100% Tested Longevity Nordic - email: ndsales@pickeringtest.com | Tel. +46 340 69 06 69 Czech Republic: czsales@pickeringtest.com | Tel. +420 558-987-613 China - email: chinasales@pickeringtest.com | Tel. +86 4008 799 765 For a full list of agents, distributors and representatives visit: pickeringrelay.com/agents pickeringrelay.com Surface Mount Reed Relays – Series 200 10 Key Benefits of Pickering Reed Relays Pickering Reed Relays Typical Industry Reed Relays Instrumentation Grade Reed Switches with vacuum sputtered Ruthenium plating to ensure stable, long life up to 5x10E9 operations. Often low grade Reed Switches with electroplated Rhodium plating resulting in higher, less stable contact resistance. 22 Formerless Coil Construction Formerless coil construction increases the coil winding volume, maximizing magnetic efficiency, allowing the use of less sensitive reed switches resulting in optimal switching action and extended lifetime at operational extremes. Use of bobbins decreases the coil winding volume, resulting in having less magnetic drive and a need to use more sensitive reed switches which are inherently less stable with greatly reduced restoring forces. 3 Magnetic Screening Mu-metal magnetic screening (either external or internal), enables ultra-high PCB side-by-side packing densities with minimal magnetic interaction, saving significant cost and space. Pickering Mu-Metal magnetic screen - interaction approx. 5% Lower cost reed relays have minimal or no magnetic screening, resulting in magnetic interaction issues causing changes in operating and release voltages, timing and contact resistance, causing switches to not operate at their nominal voltages. Typical industry screen - interaction approx. 30% 4 SoftCenter™ technology, provides maximum cushioned protection of the reed switch, minimising internal lifetime stresses and extending the working life and contact stability. Transfer moulded reed relays (produced using high temperature/pressure), result in significant stresses to the glass reed switch which can cause the switch blades to deflect or misalign leading to changes in the operating characteristics, contact resistance stability and operating lifetime. 100% testing for all operating parameters including dynamic contact wave-shape analysis with full data scrutiny to maintain consistency. Simple dc testing or just batch testing which may result in non-operational devices being supplied. 1 Instrumentation Grade Reed Switches SoftCenter™ Technology 5 100% Dynamic Testing X-Ray of Pickering mu-metal magnetic screen X-Ray of typical industry magnetic screen Dynamic Contact Resistance Test Operate Contact Resistance Key Benefit Release 6 100% Inspection at Every Stage of Manufacturing 7 Inspection at every stage of manufacturing maintaining high levels of quality. Often limited batch inspection. Stress testing of the manufacturing processes, from -20°C to +85°C to -20°C, repeated 3 times. Rarely included resulting in field failures. +85°C 100% Thermal Cycling -20°C Product Longevity Limited ability to customize. Pickering are committed to product longevity; our reed relays are manufactured and supported for more than 25 years from introduction, typically much longer. Most other manufacturers discontinue parts when they reach a low sales threshold; costing purchasing and R&D a great deal of unnecessary time and money to redesign and maintain supply. o n g v it e o n g v it e y Our reed relays can be customized easily, e.g. special pin configurations, enhanced specifications, non-standard coil or resistance figures, special life testing, low capacitance, and more. L 10 Mass production: Usually large batch sizes and with no quick-turn manufacturing. L 9 Custom Reed Relays Flexible manufacturing processes allow quick-turn manufacturing of small batches. y 8 Flexible Manufacturing Process Product 25+Years Longevity For more information go to: pickeringrelay.com/10-key-benefits 8 pickeringrelay.com © Copyright (2022) Pickering Electronics. All Rights Reserved Pickering Electronics maintains a commitment to continuous product development, consequently we reserve the right to vary from the description given in this data sheet. Coil Voltage
200-1-C-5/3D 价格&库存
很抱歉,暂时无法提供与“200-1-C-5/3D”相匹配的价格&库存,您可以联系我们找货
