131-1-A-5/1D
131-1-A-5/1D
    PICKERING
    PICKERING - 131-1-A-5/1D - Reed Relay, SPST-NO, 5 V, 131 Series, Through Hole, 250 ohm, 700 mA
131-1-A-5/1D 数据手册
Series 131 High Voltage Mini-SIL/SIP Reed Relays — Up to 1500 V stand-off — Choice of 3, 5 or 12 V coils with optional internal diode 1 Package Type — 1 Form A (energize to make) SPST N.O. configuration — Smallest high voltage reed relay currently available — Switching up to 0.7 A, 10 W — Internal mu-metal magnetic screen allows side by side stacking without magnetic interaction — 100% tested for dynamic contact resistance — Highest quality vacuumed, sputtered ruthenium reed switches Text color option — General Purpose & Low Level switch options available —  Additional build options are available — Many benefits compared to industry standard relays (see last page) — Ideal for cable testers, mixed signal/semiconductor testers, backplane testers, high voltage instrumentation, in-circuit test equipment or other applications where high voltage capability is required. Switch Ratings - Dry Switches 1 Form A (energize to make) Stand-off 1 kV, switching up to 1 kV Stand-off 1.5 kV, switching up to 1 kV Series 131 switch ratings - contact ratings for each switch type Max. Switch Switch Power switch No form rating current Max. carry current Max. Life Min. switching expectancy stand-off volts ops typical volts 1 (see Note ) (see Note2) Operate time inc bounce (max) Release time Special features 1 (L) A 10 W 0.7 A 1.25 A 1000 1000 108 0.5 ms 0.2 ms High voltage 1 A 10 W 0.7 A 1.25 A 1000 1500 10 0.5 ms 0.2 ms High voltage 8 Note2: Life Expectancy The life of a reed relay depends upon the switch load and the end of life criteria. For example, for an ‘end of life’ contact resistance specification of 1 Ω, switching low loads or when ‘cold’ switching, typical life is expected to be greater than 1 x 108 ops. At higher voltages and the maximum load (resistive), typical life is 1 x 107 ops. In the event of abusive conditions, e.g. high currents due to capacitive inrushes, this figure reduces considerably. Pickering will be pleased to perform life testing with any particular load conditions. 1 pickeringrelay.com ISSUE 2.3 JAN 2022 Note1: Switching Voltage This high voltage rating is for RESISTIVE loads only. At these high voltages, even stray capacitance can generate very high current pulses, which can damage the contact plating causing welding of the reed switch. If there is capacitance in circuit, provision should be made to limit the surge, to within the current and power ratings of the relay. Specification High Voltage Mini-SIL/SIP Reed Relays – Series 131 Application Note: A characteristic of the switch used in this range is the contact resistance can increase over time if subjected to standoff voltages in the upper range of the specification. This does not affect the life expectancy but can result in contact resistances greater than 1 Ohm. In most high voltage applications this increase has no effect on performance but, in some mixed signal applications low and stable contact resistance is important. For this reason, Pickering offer both a low-level and a general-purpose option for all package types, the low-level parts have a reduced high voltage standoff and are tested for extended contact resistance stability as part of the production testing. The low-level versions have 131L at the start of the part number. For new applications or for further information please contact our Technical department. Operating Voltages Coil voltage - nominal Must operate voltage - maximum at 25°C Must release voltage - minimum at 25°C 3V 2.25 V 0.3 V 5V 3.75 V 0.5 V 12 V 9V 1.2 V Environmental Specification/Mechanical Characteristics In the table below, the upper temperature limit can be extended to +125 °C if the coil drive voltage is increased to accommodate the resistance/temperature coefficient of the copper coil winding. This is approximately 0.4% per °C. This means that at 125 °C the coil drive voltage will need to be increased by approximately 40 x 0.4 =16% to maintain the required magnetic drive level. Please contact sales@pickeringrelay.com for assistance. Operating Temperature Range -20 ºC to +85 ºC Storage Temperature Range -35 ºC to +100 ºC Shock Resistance 50 g Vibration Resistance (10 - 2000 Hz) 20 g Soldering Temperature (max) (10 s max) 270 ºC Washability (Proper drying process is recommended) Fully Sealed 2 pickeringrelay.com Specification High Voltage Mini-SIL/SIP Reed Relays – Series 131 Coil Data and Type Numbers Device Type Coil (V) Type Number 1 Form A Switch No. 1 (1 kV) Package Type 1 1 Form A Switch No. 1 (1.5 kV) Package Type 1 Max. Coil contact resistance resistance (initial) 131L-1-A-3/1DR 3 100 Ω 131L-1-A-5/1DR 5 250 Ω 131L-1-A-12/1DR 12 750 Ω 131-1-A-3/1DR 3 100 Ω 131-1-A-5/1DR 5 250 Ω 131-1-A-12/1DR 12 750 Ω Capacitance (typical) (see Note3) Insulation resistance (minimum at 25 °C) (see Note4) Switch to coil Across switch Closed switch to coil Across open switch 0.17 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF 0.17 Ω 1012 Ω 1012 Ω 2.5 pF 0.1 pF When an internal diode is required, the suffix D is added to the part number as shown in the table. When red printing is required, the suffix R is added to the part number as shown in the table. Note3: Capacitance across open switch This is measured with all other component leads connected to the guard terminal of the measuring bridge. Note4: Insulation resistance Insulation resistance will reduce at higher temperatures. For more information on temperature effects click here, or contact Pickering for more in depth guidance. Pin Configuration, Weights and Dimensional Data (dimensions in inches, millimeters in brackets) PackageType Type Package 0.49 (12.5) 11 PICKERING Weight: Typical 0.58 g Weight: Typical 0.58 g 131-1-A-3/1D 0.145 (3.7) Spot indicates Pin 1 0.02 (0.5) 0.26 (6.6) 1 Form A + 1 0.125 (3.2) Pin 1 0.16 0.08 0.16 (4.0) (2.0) (4.0) 0.02 (0.5) 3 4 6 0.01 (0.25) Important: Where the optional internal diode is fitted, the correct coil polarity must be observed, as shown by the + symbol on the schematics. The technical information shown in this data sheet could contain inaccuracies or typographical errors. This information may be periodically changed or updated and these changes will be included in future versions of this data sheet. For different values, latest specifications and product details, please contact your local Pickering sales office. For FREE evaluation samples go to: pickeringrelay.com/samples 3 pickeringrelay.com Specification High Voltage Mini-SIL/SIP Reed Relays – Series 131 Similar Relays Comparison If the Series 131 is unsuitable for your application, Pickering also manufactures two other series of reed relays with similar characteristics, but in different package sizes. Series Name 131L-1-A 131-1-A 119L-1-A 119-1-A 119L-2-A 119-2-A 119L-1-B 119-1-B Physical Outline Depth Width Height 3.7 (0.145) mm (inches) 3.7 (0.145) 12.5 (0.49) 15.1 (0.595) 6.6 (0.26) 1 Package Volume (mm3) 306 Typical Weights (g) 0.58 Contact Configuration 1-A (SPST) 20.1 (0.79) 369 369 8.9 (0.35) 369 369 491 0.67 662 662 0.74 1-A (SPST) Reed Switch Type Dry Low Level Dry Stand-off Voltage (V) 1000 1500 Dry Dry Low Level Low Level 1000 1500 498 0.89 2-A (DPST) 1-B (SPNC) 498 Dry Dry Dry Dry Low Level Dry Dry Low Level Dry Dry 1500 2000 3000 1000 1500 1000 1500 2000 Switching Voltage (V) 1000 1000 0.7 0.7 Carry Current (A) 1.25 1.25 Switch Power (W) 10 10 104-1-A 498 1.06 Switching Current (A) Series Name 15.1 (0.595) 6.6 (0.26) 104-1-B 104-2-A 100HV-1-A 100HV-1-B 100HV-2-A 10.2 (0.40) Physical Outline Depth 10.2 (0.40) 10.2 (0.40) 24.1 (0.95) 29 (1.14) 24.1 (0.95) 29 (1.14) 29 (1.14) 8.2 (0.32) 12.5 (0.49) 12.7 (0.50) 15.2 (0.60) 15.2 (0.60) Package Volume (mm3) 1245 2284 4496 4496 Typical Weights (g) 2.06 3.75 3.7 6.99 8.75 8.75 Contact Configuration 1-A (SPST) 1-B (SPNC) 2-A (DPST) 1-A (SPST) 1-B (SPNC) 2-A (DPST) Width Height 6.3 (0.245) mm (inches) Reed Switch Type Dry Dry Mercury Dry Wetted Dry Dry Dry 3122 Dry Dry 3000 4000 1500 2000 1500 2000 3122 Mercury Wetted Dry Dry Dry Dry 1500 1500 2000 3000 1500 Dry Dry 2000 1500 Dry Stand-off Voltage (V) 1500 2000 1500 Switching Voltage (V) 1000 500 1000 1000 1000 500 1000 1000 1000 2000 Switching Current (A) 1 2 1 1 1 2 1 1 1 Carry Current (A) 1.5 3 1.5 1.5 1.5 3 1.5 1.5 1.5 Switch Power (W) 25 50 25 25 25 50 25 25 25 Reed Relay Selection Tool Because Pickering offer the largest range of high-quality reed relays, sometimes it can be difficult to find the right reed relay you require. That is why we created the Reed Relay Selector, this tool will help you narrow down our offering to get you the correct reed relay for your application. To try the tool today go to: pickeringrelay.com/reed-relay-selector-tool 4 pickeringrelay.com Ordering Information High Voltage Mini-SIL/SIP Reed Relays – Series 131 Standard Build Options The Series 131 Reed Relay is available with a number of standard build options to tailor it to your specific application. These options are detailed in the table below. If you decide to go ahead and specify one, or more, of these options you will be allocated a unique part number suffix. Mechanical Build Options Electrical Build Options Special pin configurations or pin lengths Different coil resistance Special print with customer’s own part number or logo Very low capacitance possibility Custom packaging possibility Different stand-off or switching voltage Operate or de-operate time Pulse capability Enhanced specifications Non-standard coil voltages and resistance figures Special Life testing under customer’s specific load conditions Specific environmental requirements Controlled thermal EMF possibility Customization If your specific requirements are not met by standard relay, or any of the standard build options, please speak to us to discuss producing a customized reed relay to service your specific application: pickeringrelay.com/contact 3D Models Interactive 3D models of the complete range of Pickering relay products in STEP, IGS and SLDPRT formats can be downloaded from the website: pickeringrelay.com/3d-models Part Number Description: 131 L - 1 - A - 3 / 1 D R - xxx Series Low level version (omit if not required) Number of reeds Switch form Coil voltage Switch number (see table on page 1) Diode if fitted (omit if not required) Red printing (omit if not required Unique suffix (if standard build option selected) Help If you need any technical advice or other help, please do not hesitate to contact our Technical Sales Department. We will always be pleased to discuss Pickering relays with you. email: techsales@pickeringrelay.com Contact Us 5 o n g v it e y y L o n g v it e L UK Headquarters - email: sales@pickeringrelay.com | Tel. +44 1255 428141 USA - email: ussales@pickeringrelay.com | Tel. +1 781 897 1710 Germany - email: desales@pickeringtest.com | Tel. +49 89 125 953 160 Product France - email: frsales@pickeringtest.com | Tel. +33 9 72 58 77 00 25+Years 100% Tested Longevity Nordic - email: ndsales@pickeringtest.com | Tel. +46 340 69 06 69 Czech Republic: czsales@pickeringtest.com | Tel. +420 558-987-613 China - email: chinasales@pickeringtest.com | Tel. +86 4008 799 765 For a full list of agents, distributors and representatives visit: pickeringrelay.com/agents pickeringrelay.com High Voltage Mini-SIL/SIP Reed Relays – Series 131 10 Key Benefits of Pickering Reed Relays Pickering Reed Relays Typical Industry Reed Relays Instrumentation Grade Reed Switches with vacuum sputtered Ruthenium plating to ensure stable, long life up to 5x10E9 operations. Often low grade Reed Switches with electroplated Rhodium plating resulting in higher, less stable contact resistance. 22 Formerless Coil Construction Formerless coil construction increases the coil winding volume, maximizing magnetic efficiency, allowing the use of less sensitive reed switches resulting in optimal switching action and extended lifetime at operational extremes. Use of bobbins decreases the coil winding volume, resulting in having less magnetic drive and a need to use more sensitive reed switches which are inherently less stable with greatly reduced restoring forces. 3 Magnetic Screening Mu-metal magnetic screening (either external or internal), enables ultra-high PCB side-by-side packing densities with minimal magnetic interaction, saving significant cost and space. Pickering Mu-Metal magnetic screen - interaction approx. 5% Lower cost reed relays have minimal or no magnetic screening, resulting in magnetic interaction issues causing changes in operating and release voltages, timing and contact resistance, causing switches to not operate at their nominal voltages. Typical industry screen - interaction approx. 30% 4 SoftCenter™ technology, provides maximum cushioned protection of the reed switch, minimising internal lifetime stresses and extending the working life and contact stability. Transfer moulded reed relays (produced using high temperature/pressure), result in significant stresses to the glass reed switch which can cause the switch blades to deflect or misalign leading to changes in the operating characteristics, contact resistance stability and operating lifetime. 100% testing for all operating parameters including dynamic contact wave-shape analysis with full data scrutiny to maintain consistency. Simple dc testing or just batch testing which may result in non-operational devices being supplied. 1 Instrumentation Grade Reed Switches SoftCenter™ Technology 5 100% Dynamic Testing X-Ray of Pickering mu-metal magnetic screen X-Ray of typical industry magnetic screen Dynamic Contact Resistance Test Operate Contact Resistance Key Benefit Release 6 100% Inspection at Every Stage of Manufacturing 7 Inspection at every stage of manufacturing maintaining high levels of quality. Often limited batch inspection. Stress testing of the manufacturing processes, from -20°C to +85°C to -20°C, repeated 3 times. Rarely included resulting in field failures. +85°C 100% Thermal Cycling -20°C Product Longevity Limited ability to customize. Pickering are committed to product longevity; our reed relays are manufactured and supported for more than 25 years from introduction, typically much longer. Most other manufacturers discontinue parts when they reach a low sales threshold; costing purchasing and R&D a great deal of unnecessary time and money to redesign and maintain supply. o n g v it e o n g v it e y Our reed relays can be customized easily, e.g. special pin configurations, enhanced specifications, non-standard coil or resistance figures, special life testing, low capacitance, and more. L 10 Mass production: Usually large batch sizes and with no quick-turn manufacturing. L 9 Custom Reed Relays Flexible manufacturing processes allow quick-turn manufacturing of small batches. y 8 Flexible Manufacturing Process Product 25+Years Longevity For more information go to: pickeringrelay.com/10-key-benefits 6 pickeringrelay.com © Copyright (2022) Pickering Electronics. All Rights Reserved Pickering Electronics maintains a commitment to continuous product development, consequently we reserve the right to vary from the description given in this data sheet. Coil Voltage
131-1-A-5/1D 价格&库存
很抱歉,暂时无法提供与“131-1-A-5/1D”相匹配的价格&库存,您可以联系我们找货
