1505-0001
1505-0001
    ANSMANN
    ANSMANN - 1505-0001 - BATTERY, NON RECHARGEABLE, 9V, PP3
1505-0001 数据手册
Alkaline Manganese (Mercury free) IEC: 6LR61; JIS: 6AM6; ANSI: E; MN1604; 9V-Block Zn / KOH-H2O / MnO2 battery type: battery size: chemical system: Conditions 9 V 9.2...9.8 V 9.0...9.8 V nominal voltage: open circuit voltage: new battery after 1 year storage at 20°C all measurements at 20°C ambient discharge at 10mA load; 24hours/day End Voltage (EV): 5.4V capacity rated: 550 mAh minimum: 525 mAh discharge at 10mA constant current End Voltage (EV): 5.4V 475 mAh discharge at 50mA constant current End Voltage (EV): 5.4V typical service output (new batteries) ≥ 14 h discharge at 35mA constant current; EV: 5.4V discharge 24h/d ≥ 18 h discharge at 270Ω resistive load; EV: 5.4V discharge 1h/d ≥ 40 h discharge at 620Ω resistive load; EV: 5.4V discharge 2h/d ≥ 17 d discharge at 10KΩ resistive load (continuous); additional pulse load at 620Ω for 1s/h; EV: 7.5V ≤4 Ω internal resistance: 7 years shelf life: leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: at 1kHz, sine wave measurement full battery under proper storage conditions 20ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % ambient temperature rel. humidity mechanical specifications cell dimensions length L1: length L2: length L3: height h1: weight: 26.5 -2 17.5 -2 12.7 ± 0.25 48.5 -2 45 ± 3 package dimensions: weight (incl. batteries): 87 x 53 x 49 mm 465 ± 25 g mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date Ansmann Industrial Alkaline Battery 9V E-block 10pcs colour box 1505-0001 701381 TG / 15.05.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
1505-0001 价格&库存
很抱歉,暂时无法提供与“1505-0001”相匹配的价格&库存,您可以联系我们找货
