1502-0006
1502-0006
    ANSMANN
    ANSMANN - 1502-0006 - Battery, 1.5 V, AA, Alkaline, 2.7 Ah, Raised Positive and Flat Negative, 14.4 ...
1502-0006 数据手册
Alkaline Manganese (Mercury free) IEC: LR6; JIS: AM-3; ANSI: 15A; MN1500; Mignon Zn / KOH-H2O / MnO2 battery type: battery size: chemical system: Conditions 1.5 V 1.57...1.65 V 1.55...1.65 V nominal voltage: open circuit voltage: capacity rated: 2800 mAh 2700 mAh minimum: (for IQC measurement) 18.5 h 38 min new battery after 1 year storage at 20°C all measurements at 20°C ambient discharge at 10mA load; 24hours/day End Voltage (EV): 0.8V discharge at 43ohms load; 4hours/day End Voltage (EV): 0.9V at 10ohms constant resistance discharge 24h/d; End Voltage (EV): 0.9V at 1000mA constant current discharge 24h/d; End Voltage (EV): 0.9V typical service output ≤ 0.25 Ω internal resistance: (new battery) 7 years shelf life: leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: at 1kHz, sine wave measurement according to IEC 896-2 under proper storage conditions 10ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 14.4 5.4 50.4 1.7 23 - 0.5 - 0.5 - 0.5 - 0.5 ±2 ambient temperature rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date High Quality Alkaline Battery AA - size 701381 TG / 01.07.2019 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
1502-0006 价格&库存
很抱歉,暂时无法提供与“1502-0006”相匹配的价格&库存,您可以联系我们找货
