1520-0004
1520-0004
    ANSMANN
    ANSMANN - 1520-0004 - Battery, Alkaline, 1.5 V, AAA
1520-0004 数据手册
battery type: battery size: chemical system: Alkaline Manganese (Mercury free) IEC: LR03; JIS: AM-4; ANSI: AAA; MN2400; Micro Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 1.5 V 1.57...1.62 V 1.55...1.62 V capacity rated: 1200 mAh 1070 mAh minimum: 1050 mAh 300 mAh new battery after 1 year storage at 20°C all measurements at 20°C ambient discharge at 10mA load; 24hours/day End Voltage (EV): 0.8V discharge at 75ohms load; 24hours/day End Voltage (EV): 0.8V discharge at 20mA constant current End Voltage (EV): 0.8V discharge at 500mA constant current End Voltage (EV): 0.8V typical service output (new batteries) ≥ 560 cycles load resistor 3.6ohms; EV: 0.9V discharge 15s/m 24h/d internal resistance: shelf life: ≥ 180 min load resistor: 5.1ohms; EV: 0.9V discharge 4min/h 8h/d ≥ 414 min load resistor: 10ohms; EV: 0.9V discharge 1h/d ≥ 16 h load resistor: 20ohms; EV: 0.9V discharge 24h/d ≥ 37 h load resistor: 43ohms; EV: 0.9V discharge 4h/d ≤ 0.3 Ω at 1kHz, sine wave measurement according to IEC 896-2 7 years leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: under proper storage conditions 20Ω continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 10.4 - 0.5 3.6 - 0.4 44.4 - 0.6 1.2 - 0.35 11.5 ± 1.5 ambient temp. rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date Ansmann 35pcs Battery Mix Box RED Alkaline AAA - size 14pcs 1520-0004 701381 TG / 09.07.2014 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice battery type: battery size: chemical system: Alkaline Manganese (Mercury free) IEC: LR6; JIS: AM-3; ANSI: AA; MN1500; Mignon Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 1.5 V 1.57...1.62 V 1.55...1.62 V capacity rated: 2700 mAh 2400 mAh minimum: 2200 mAh 700 mAh new battery after 1 year storage at 20°C all measurements at 20°C ambient discharge at 10mA load; 24hours/day End Voltage (EV): 0.8V discharge at 75ohms load; 24hours/day End Voltage (EV): 0.8V discharge at 35mA constant current End Voltage (EV): 0.8V discharge at 1000mA constant current End Voltage (EV): 0.8V typical service output (new batteries) ≥ 330 cycles discharge at 1000mA; EV: 0.9V discharge 10s/m 1h/d ≥ 79 h load resistor: 43ohms; EV: 0.9V discharge 4h/d ≥ 38 min discharge at 1000mA; EV: 0.9V discharge 24h/d ≥ 17.5 h load resistor: 10ohms; EV: 0.9V discharge 24h/d ≥ 6.2 h discharge at 250mA; EV: 0.9V discharge 1h/d ≤ 0.25 Ω internal resistance: shelf life: 7 years leakage resistance over discharge: high temperature: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: under proper storage conditions 10Ω continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% no leakage no leakage ambient temperature range: at 1kHz, sine wave measurement according to IEC 896-2 - 10...50 °C 5....25 °C 45...75 % 14.4 5.4 50.4 1.7 23 - 0.5 - 0.5 - 0.5 - 0.5 ±2 ambient temp. rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date Ansmann 35pcs Battery Mix Box RED Alkaline AA - size 12pcs 1520-0004 701381 TG / 09.07.2014 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice battery type: battery size: chemical system: Alkaline Manganese (Mercury free) IEC: LR14; JIS: AM-2; ANSI: C; MN1400; Baby Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 1.5 V 1.57...1.62 V 1.55...1.62 V capacity rated: 7200 mAh 6800 mAh minimum: 5800 mAh 2250 mAh typical service output (new batteries) ≥ 18 h internal resistance: shelf life: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: discharge at 75mA constant current End Voltage (EV): 0.8V discharge at 1000mA constant current End Voltage (EV): 0.8V ≥ 18 h load resistor: 3.9ohms; EV: 0.8V discharge 1h/d ≥ 31 h load resistor: 6.8ohms; EV: 0.9V discharge 1h/d ≥ 16 h load resistor: 3.9ohms; EV: 0.9V discharge 24h/d ≥ 100 h load resistor: 20ohms; EV: 0.9V discharge 4h/d ≤ 0.2 Ω at 1kHz, sine wave measurement according to IEC 896-2 no leakage no leakage ambient temperature range: all measurements at 20°C ambient discharge at 25mA load; 24h/day End Voltage (EV): 0.8V discharge at 20ohms load; 24h/day End Voltage (EV): 0.9V load resistor 3.9ohms; EV: 0.9V discharge 4min/h 8h/d 7 years leakage resistance over discharge: high temperature: new battery after 1 year storage at 20°C under proper storage conditions 3.9ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 26.0 7.0 50.0 2.0 72 - 1.0 - 1.0 - 1.0 - 0.4 ±3 ambient temp. rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date Ansmann 35pcs Battery Mix Box RED Alkaline C - size 4pcs 1520-0004 701381 TG / 09.07.2014 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice battery type: battery size: chemical system: Alkaline Manganese (Mercury free) IEC: LR20; JIS: AM-1; ANSI: D; MN1300; Mono Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 1.5 V 1.57...1.62 V 1.55...1.62 V capacity rated: 16000 mAh 13500 mAh minimum: 11500 mAh 4500 mAh typical service output (new batteries) ≥ 18.5 h internal resistance: shelf life: recommended storage conditions: mechanical specifications cell dimensions diameter d1: diameter d2: height h1: height h2: weight: discharge at 100mA constant current End Voltage (EV): 0.8V discharge at 1000mA constant current End Voltage (EV): 0.8V ≥ 35 h load resistor: 3.9ohms; EV: 0.9V discharge 1h/d ≥ 20.5 h load resistor: 2.2ohms; EV: 0.8V discharge 1h/d ≥ 16.5 h load resistor: 2.2ohms; EV: 0.9V discharge 24h/d ≥ 112 h load resistor: 10ohms; EV: 0.9V discharge 4h/d ≤ 0.15 Ω at 1kHz, sine wave measurement according to IEC 896-2 no leakage no leakage ambient temperature range: all measurements at 20°C ambient discharge at 25mA load; 24h/day End Voltage (EV): 0.8V discharge at 10ohms load; 24h/day End Voltage (EV): 0.9V load resistor 2.2ohms; EV: 0.9V discharge 4min/h 8h/d 5 years leakage resistance over discharge: high temperature: new battery after 1 year storage at 20°C under proper storage conditions 2.2ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 34.0 9.0 61.0 3.0 138 - 1.0 - 1.0 - 1.4 - 0.5 ±7 ambient temp. rel. humidity mm mm mm mm g 43 ANSMANN Specifications for model: data sheet no. / part no. Version no. author / date Ansmann 35pcs Battery Mix Box RED Alkaline D - size 4pcs 1520-0004 701381 TG / 09.07.2014 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice battery type: battery size: chemical system: Alkaline Manganese (Mercury free) IEC: 6LR61; JIS: 6AM6; ANSI: E; MN1604; 9V-Block Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 9 V 9.2...9.8 V 9.0...9.8 V new battery after 1 year storage at 20°C capacity rated: 500 mAh all measurements at 20°C ambient discharge at 35mA load; 24hours/day End Voltage (EV): 5.4V minimum: 525 mAh discharge at 10mA constant current End Voltage (EV): 5.4V 350 mAh discharge at 75mA constant current End Voltage (EV): 5.4V typical service output (new batteries) ≥ 13 h discharge at 35mA constant current; EV: 5.4V discharge 24h/d ≥ 18 h discharge at 270Ω resistive load; EV: 5.4V discharge 1h/d ≥ 47 h discharge at 620Ω resistive load; EV: 5.4V discharge 2h/d ≥ 17 d discharge at 10KΩ resistive load (continuous); additional pulse load at 620Ω for 1s/h; EV: 7.5V ≤4 Ω internal resistance: shelf life: 5 years leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: mechanical specifications cell dimensions length L1: length L2: length L3: height h1: weight: plastic battery box: dimensions: weight (assembled): at 1kHz, sine wave measurement according to IEC 896-2 under proper storage conditions 20ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % 26.5 -2 17.5 -2 12.7 ± 0.25 48.5 -2 45 ± 3 ambient temp. rel. humidity mm mm mm mm g 138 x 128 x 65 mm 1480 ± 50 g 43 ANSMANN Specifications for model: data sheet no. / part no. Version no. author / date Ansmann 35pcs Battery Mix Box RED Alkaline 9V E-Block 1pc 1520-0004 701381 TG / 09.07.2014 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
1520-0004 价格&库存
很抱歉,暂时无法提供与“1520-0004”相匹配的价格&库存,您可以联系我们找货
