Conditions
NiMH
C
cell type:
cell size:
1.2 V
1.5 V
nominal voltage:
max. charge voltage:
capacity
nominal:
minimum:
4500 mAh
4500 mAh
4200 mAh
Diagrams
standard charge
at standard charge
(0.1C / 20°C)
discharge at 0.2C
discharge at 0.2C
discharge at 1C
1.0V end discharge voltage
ta: 20°C
fast charge
max. continuous
discharge current:
6750 mA
ta: 0....45°C
charge
standard charge:
quick charge:
fast charge:
current
450 mA
1350 mA
2250 mA
time
14....16hrs
4hrs
2.3hrs
recommended charge
termination control
parameters:
0…5 mV
0.8...1 °C
45...50 °C
- ΔV (-deltaV)
temperature rise per minute
TCO (temperature cut off)
trickle charge current:
45...150 mA
low rate discharge
continuous overcharge:
(less than 1 year)
≤ 450 mA
≤ 20 mΩ
internal resistance:
(impedance)
(recommended)
no conspicuous deformation
no leakage
at 1KHz
battery fully charged
≥ 500 cycles acc. IEC standard
life expectance:
self discharge
charge retention:
≥ 80 %
initial capacity:
≥ 3150 mAh
within 30 days after delivery
discharge at 0.2C
0...45
10...40
20...65
20...50
20...40
20...30
standard charge
fast charge
discharge
storage (≤3months)
storage (≤6months)
storage (≤24months)
ambient temperature
range:
QCT1:
QCT2:
°C
°C
°C
°C
°C
°C
after 12 months
storage at 20°C
high rate discharge
20/4300/20
30/4200/20
mechanical specifications
cell dimensions
diameter d1:
diameter d2:
max.
height h1:
height h2:
min.
weight:
25.6 - 1.0
7.5
50.0 - 2.0
1.5
80 ± 4
mm
mm
mm
mm
g
blister card dimensions:
123 x 85
blister card weight (incl. batteries):
168
mm
g
75
ANSMANN Specifications for model:
data sheet no. / part no.
supplier no.
author / date
C - 4500mAh low self discharge
2pcs blister package
5035352
702069
TG / 12.06.2018
Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
很抱歉,暂时无法提供与“5035352”相匹配的价格&库存,您可以联系我们找货
