5015332
5015332
    ANSMANN
5015332 数据手册
battery type: battery size: chemical system: Alkaline Manganese Dioxide (mercury free) LR41; LR736; AG3; 392 Zn / KOH-H2O / MnO2 Conditions 1.5 V 1.57…1.63 V 1.55…1.63 V nominal voltage: open circuit voltage: new battery after 1 year storage at 20°C all measurements at 22 ± 2°C ambient capacity rated: 35 mAh discharge at 22kΩ load; 24hours/day End Voltage (EV): 0.9V minimum: 30 mAh discharge at 22kΩ load; 24hours/day End Voltage (EV): 0.9V Service Output nominal: minimum: 395 h at 22kΩ load EV: 1.2V new battery 365 h 330 h dto. dto. tested within 30 days after delivery after 12 months storage at room temperature ≥16 h for IQC measurement at 1kΩ load EV: 1.0V 3 years ≥90 % under proper storage conditions (ta: ≤ 22°C; RH: 60 ± 15%) of the capacity will remain after 12 months storage Discharge diagrams: shelf life: operating temperature range: - 20...60 °C 5…25 °C storage temperature: (recommended) mechanical specifications: cell dimensions: nominal weight: main applications: 7.9 x 3.6 mm A 7.55…7.90 mm B 2.95… 3.20 mm C 3.30… 3.60 mm 0.7 nominal g watch, photo, electronic 43 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date Ansmann LR41 (AG3, LR736) Alkaline Button Cell "Hg free" 701381 TG / 25.07.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5015332 价格&库存
很抱歉,暂时无法提供与“5015332”相匹配的价格&库存,您可以联系我们找货
