5030892
5030892
    ANSMANN
    Rechargeable Battery, 1.2 V, Nickel Metal Hydride, 1 Ah, AAA, Raised Positive and Flat Negative
5030892 数据手册
Conditions NiMH AAA cell type: cell size: 1.2 V 1.5 V nominal voltage: max. charge voltage: capacity nominal: minimum: 1000 mAh 950 mAh 840 mAh Diagrams standard charge at standard charge (0.1C / 20°C) discharge at 0.2C discharge at 0.2C discharge at 1C 1.0V end discharge voltage ta: 20°C fast charge max. continuous discharge current: 2000 mA ta: 0....45°C charge standard charge: quick charge: fast charge: current 100 mA 300 mA 500 mA time 14....16hrs 4hrs 2.3hrs recommended charge termination control parameters: 0...5 mV 0.8...1 °C 45...50 °C - delta V temperature rise per minute TCO (temperature cut off) trickle charge current: 5…15 mA low rate discharge (recommended) continuous overcharge: (less than 1 year) ≤ 95 mA no conspicuous deformation no leakage internal resistance: (impedance) ≤ 40 mΩ at 1KHz battery fully charged ≥ 500 cycles acc. IEC standard life expectance: self discharge charge retention: ≥ 75 % ≥ 650 mAh initial capacity: ambient temperature range: - QCT1: QCT2: 0...45 10...40 20...65 20...50 20...40 20...30 °C °C °C °C °C °C after 12 months storage at 20°C high rate discharge within 30 days after delivery discharge at 0.2C standard charge fast charge discharge storage (≤3months) storage (≤6months) storage (≤24months) 20/900/45 30/780/50 mechanical specifications cell dimensions diameter d1: diameter d2: max. height h1: height h2: min. weight: 10.5 - 0.7 3.8 44.5 - 1.5 0.8 13 ± 2 mm mm mm mm g 75 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date AAA - 1000mAh low self discharge 702069 TG / 13.07.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5030892 价格&库存
很抱歉,暂时无法提供与“5030892”相匹配的价格&库存,您可以联系我们找货
    • 2+31.87676
    库存:76
