1510-0007
1510-0007
    ANSMANN
    ANSMANN - 1510-0007 - Battery, 6 V, A11, Alkaline, 56 mAh, Raised Positive and Flat Negative, 10.3 m...
1510-0007 数据手册
battery type: battery size: chemical system: Alkaline Manganese Dioxide (mercury free) A11 (11A; LR1016; Mn11) Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 6 V 6.2…6.5 V 6.1…6.5 V new battery after 1 year storage at 20°C all measurements at 22 ± 2°C ambient capacity rated: 56 mAh discharge under 10kΩ load; 24hours/day End Voltage (EV): 3.0V minimum: 50 mAh discharge under 10kΩ load; 24hours/day End Voltage (EV): 3.0V Standard discharge time nominal: 90 h at 10kΩ load EV: 3.0V new battery 85 h at 10kΩ load EV: 3.0V after 12 months storage at 20°C 87 h at 10kΩ load EV: 3.0V for IQC measurement (tested within 30 days after delivery) MAD: (minimum avarage duration) Discharge currents standard: 0.06 mA max. recommended current under continuous discharge: 1.0 mA max. recommended current under pulse discharge: 10 mA Discharge diagrams: shelf life: 3 years ≥90 % operating temperature: storage temperature: under proper storage conditions (ta: ≤ 22°C; RH: 60 ± 15%) remaining capacity after 12 months storage - 20…60 °C 5…25 °C (recommended) mechanical specifications: Dimensions(mm): battery label nominal weight: 3.6 g dimensions: 56 x 71.5mm blister card weight: 5.4g (incl. battery) 102 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date A11 (11A, LR1016) Alkaline Battery "Hg free" blister package 1510-0007 703385 TG / 08.02.2018 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
1510-0007 价格&库存
很抱歉,暂时无法提供与“1510-0007”相匹配的价格&库存,您可以联系我们找货
