5030921
5030921
    ANSMANN
5030921 数据手册
Conditions cell type: cell size: NiMH D nominal voltage: max. charge voltage: capacity nominal: minimum: 1.2 1.5 V V 5000 5000 4500 mAh mAh mAh Diagrams standard charge at standard charge (0.1C / 20°C) discharge at 0.2C discharge at 0.2C discharge at 1C 1.0V end discharge voltage ta: 20°C fast charge max. continuous discharge current: 10000 mA ta: 0....45°C charge standard charge: quick charge: fast charge: current 500 1500 2500 mA mA mA time 14....16hrs 4hrs 2.3hrs recommended charge termination control parameters: 0…5 0.8...1 45...50 mV °C °C - ΔV (-deltaV) temperature rise per minute TCO (temperature cut off) trickle charge current: 25...125 mA (recommended) continuous overcharge: (less than 1 year) ≤ 500 mA no conspicuous deformation no leakage internal resistance: (impedance) ≤ 10 mΩ at 1KHz battery fully charged life expectance: ≥ 500 cycles acc. IEC standard self discharge charge retention: ≥ 70 % after 12 months storage at 20°C initial capacity: ≥ 3500 mAh within 30 days after delivery discharge at 0.2C 0...45 10...40 20...65 20...50 20...40 20...30 °C °C °C °C °C °C standard charge fast charge discharge storage (≤3months) storage (≤6months) storage (≤24months) low rate discharge ambient temperature range: - QCT1: QCT2: high rate discharge 20/4750/12 30/4500/12 mechanical specifications cell dimensions diameter d1: diameter d2: max. height h1: height h2: min. weight: 32.8 - 1.0 9.5 61.5 - 2.0 1.5 110 ± 5 mm mm mm mm g 35 ANSMANN Specifications for model: data sheet no. / part no. supplier no. author / date D - 5000mAh low self discharge bulk package 5030921 701372 TG / 09.12.2015 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5030921 价格&库存
很抱歉,暂时无法提供与“5030921”相匹配的价格&库存,您可以联系我们找货
