5035222
5035222
    ANSMANN
5035222 数据手册
Conditions NiMH AAA cell type: cell size: nominal voltage: max. charge voltage: capacity nominal: minimum: 1.2 1.5 V V 1100 1050 1000 mAh mAh mAh Diagrams standard charge at standard charge (0.1C / 20°C) discharge at 0.2C discharge at 0.2C discharge at 1C 1.0V end discharge voltage ta: 20°C fast charge max. continuous discharge current: 3000 mA ta: 0....45°C charge standard charge: quick charge: fast charge: current 110 330 1100 mA mA mA time 14....16hrs 4hrs 1.1hrs recommended charge termination control parameters: 0...5 0.8...1 45...50 mV °C °C -ΔV (-delta V) temperature rise per minute TCO (temperature cut off) trickle charge current: 10…50 mA (recommended) continuous overcharge: (less than 1 year) ≤ 100 mA no conspicuous deformation no leakage internal resistance: (impedance) ≤ 35 mΩ at 1KHz battery fully charged life expectancy: ≥ 500 cycles acc. IEC standard self discharge charge retention: ≥ 60 % after 28 days storage at 20°C initial capacity: ≥ 380 mAh within 30 days after delivery discharge at 0.2C 0...45 10...40 0...45 20...65 20...50 20...40 20...30 °C °C °C °C °C °C °C standard charge fast charge discharge (≥1C) discharge (
5035222 价格&库存
很抱歉,暂时无法提供与“5035222”相匹配的价格&库存,您可以联系我们找货
    • 2+33.98035
    库存:224
