5015643
5015643
    ANSMANN
5015643 数据手册
battery type: battery size: chemical system: Alkaline Manganese (Mercury free) IEC: 6LR61; JIS: 6AM6; ANSI: E; MN1604; 9V-Block Zn / KOH-H2O / MnO2 Conditions nominal voltage: open circuit voltage: 9 V 9.2...9.8 V 9.0...9.6 V new battery after 1 year storage at 20°C capacity rated: 550 mAh all measurements at 20°C ambient discharge at 35mA load; 24hours/day End Voltage (EV): 5.4V minimum: 550 mAh discharge at 10mA constant current End Voltage (EV): 5.4V 375 mAh discharge at 75mA constant current End Voltage (EV): 5.4V typical service output, initial (new batteries) ≥ 14 h discharge at 35mA constant current; EV: 5.4V discharge 24h/d ≥ 19.5 h discharge at 270Ω resistive load; EV: 5.4V discharge 1h/d ≥ 49 h discharge at 620Ω resistive load; EV: 5.4V discharge 2h/d ≥ 18.5 d discharge at 10KΩ resistive load (continuous); additional pulse load at 620Ω for 1s/h; EV: 7.5V ≤4 Ω internal resistance: shelf life: at 1kHz, sine wave measurement according to IEC 896-2 7 years leakage resistance over discharge: high temperature: no leakage no leakage ambient temperature range: recommended storage conditions: mechanical specifications cell dimensions length L1: length L2: length L3: height h1: weight: blister card dimensions: weight (incl. battery): under proper storage conditions 180ohms continuous discharge for 48h; ta: 20°C; RH: 60±15% store 20days at ta: 60°C; RH:90±5% - 10...50 °C 5....25 °C 45...75 % ambient temperature rel. humidity 26.5 -2 17.5 -2 12.7 ± 0.25 48.5 -2 45 ± 3 120 x 85 53 mm mm mm mm g mm ±3 g 43 ANSMANN Specifications for model: data sheet no. / part no. Version no. author / date Ansmann XPower Alkaline battery 9V E-block 1pcs blister package 5015643 1 Gramlich / 24.09.2012 Manufacturer reserves the right to alter or amend the design, model and specification without prior notice
5015643 价格&库存
很抱歉,暂时无法提供与“5015643”相匹配的价格&库存,您可以联系我们找货
